Minimal Raspberry Pi CM 4 Carrier
A very minimal design to break out some common peripherals of the CM4. More a quick demonstration than anything else.
The goal was to show how little you have to do to do a fairly feature rich carrier board for the Compute Module 4. Also to demonstrate that you don't have to be scared by high-speed signals like HDMI and that they can still work fine in very bad conditions like a single layer PCB like this one without a reference plane underneath.
Please only use this as a starting point if at all and take a look at the open reference design by the Pi foundation for a more in-depth carrier design. This design skips several saftey features like load switches on the USB and HDMI, most of the time that's fine but you should make sure that you really don't care about that.
Also do please attempt to do some impedance matching. An online calculator to get the correct trace width is already an ok approximation for most use cases.
4 Layer PCBs are to be had for 5$ and less now a days.
Kris Jones wrote 3 days ago point
I love this project! What make/model PCB mill did you use?
hypervirtualx2 wrote 3 days ago point
It is just amazing how far we've come in terms of diy homemade engineering, thanks for sharing. I have a question about the usb connection: I see that you left the otg_id floating, does the raspberry pi acts as a host or a device in this case? I'm thinking of connecting the otg_id to a microusb id pin, but I saw in the documentation that the otg functionality is not fully implemented. My idea is to use a single microusb connection as a device and also as a host with an usb A adapter.
runescapehall wrote 11/16/2020 at 15:39 point
Thanks a lot. I might use this in the near future.
Prof. Fartsparkle wrote 11/16/2020 at 13:39 point
Sure, this already linked in the resource section?
Elliot Williams wrote 11/13/2020 at 19:25 point
Damn, son!  :)
I take back everything bad I've ever said about milled PCBs.  This one is sweeeeet.
Prof. Fartsparkle wrote 11/13/2020 at 22:22 point
haha, thanks Elliot :)
