Add a headphone jack for the FC3000.
After uploading the instructions, I changed some images and corrected some typos.
View project log
The available room is about 8-9mm in height, so the one I picked was 8.5mm and I bent the pins to fit it without problems.
This was the item:
https://www.ebay.com/itm/382841364175
You should look for SMD parts, otherwise size will be too big.
Your mileage may vary depending on what you buy.
See my other project for this:
FC3000 disassemble instructions
Desolder the speaker from the PCB:
If you have a multi-meter, check the resistance, should be 8 ohms if your speaker is like mine.
The wires and the connection point are very fragile, don't abuse them or they will probably break.
View all 12 instructions
roelh
Swastik B S
Shashi Suman
Yes, delete it Cancel
You are about to report the project "FC3000 Headphone jack mod", please tell us the reason.
