The general approach using DDAs will be to simulate a system of
first-order differential equations, which can be nonlinear. Analog
computers use operational amplifiers to do mathematical integration. We
will use digital summers and registers. For any set of differential
equations with state variables v1 to vm: <br>
<br>
dv1/dt = f1(t,v1,v2,v3,...vm) <br>
dv2/dt = f2(t,v1,v2,v3,...vm)<br>
dv3/dt = f3(t,v1,v2,v3,...vm)
dvm/dt = fm(...)
We will build the following circuitry to perform an Euler integration approximation to these equations in the form
v1(n+1) = v1(n) + dt*(f1(t,v1(n),v2(n),v3(n),...vm(n))<br>
v2(n+1) = v2(n) + dt*(f2(t,v1(n),v2(n),v3(n),...vm(n))<br>
v3(n+1) = v3(n) + dt*(f3(t,v1(n),v2(n),v3(n),...vm(n))<br>
...<br>
vm(n+1) = vm(n) + dt*(fm(...))
Where the variable values at time step n are updated to form the values at time step n+1. Each equation will require one integrator. The multiply may be replaced by a shift-right if dt is chosen to be a power of two. Most of the design complexity will be in calculatingF(t,V(n)).
We also need a number representation. I chose 18-bit 2's complement with
the binary point between bits 15 and 16 (with bit zero being the least
significant). Bit 17 is the sign bit. The number range is thus -2.0 to +1.999985.
This range fits well with the Altera DE2 Audio codec which requires 16-bit 2's
complement for output to the DAC. Conversion from the 18-bit to 16-bit
just requires truncating the least significant two bits ([1:0]).
Second order system (damped spring-mass oscillator):
As an example, consider the linear, second-order differential equation resulting from a damped spring-mass system:
d<sup>2</sup>x/dt<sup>2</sup> = -k/m*x-d/m*(dx/dt)
where k is the spring constant, d the damping coefficient, m the mass,
and x the displacement. We will simulate this by converting the
second-order system into a coupled first-order system. If we let v1=x and v2=dx/dt then the second order equation is equivalent to
<br>
<br>
<code>dv1/dt = v2<br>
dv2/dt = -k/m*v1-d/m*v2<br>
These equations can be solved by wiring together two integrators, two multipliers and an adder as shown below. In the past this would have been done by using operational amplifiers to compute each mathematical operation. Each integrator must be supplied with an initial condition.
<code> <code><br>
<img src="http://people.ece.cornell.edu/land/courses/ece5760/DDA/AnalogSim2order/SecondOrder.png" height="133" width="434"><br>
<br>
Converting this diagram to Verilog, the top-level module verilog code defines the 18-bit, signed, state variables and a clock divider variable (count).
The clocked section resets and updates the state variables. The
combinatorial statements compute the Euler approximation to the F(t,V(n)). The separate multiply module ensures that the multiplies will be instantiated as hardware multipliers. The Audio_DAC_ADC module
was modifed to allow either ADC-to-DAC passthru or to connect the
computation output to the DAC, depending on the position of SW17. SW17
up connects the computation.
All details at
http://people.ece.cornell.edu/land/courses/ece5760/DDA/index.htm
<code><code>
Bruce Land
JNLabs
Jac Goudsmit
Can you explain the advantage of using the DDA to model a non-linear system?
Stepping back for a moment from FPGA implementations, I thought that any
non-linear system, could be modeled to fit an LTI system.
Let us imagine for a moment the steady state system begins to oscillate, can a DDA ever become deterministic? The sources for the DDA models are very academic.
