I have been intrigued with Nixie clocks for some time, but was daunted by the high voltages required to run them. I decided to try experimenting with Numitrons first, since they are very similar to 7-segment LED displays, but with filaments in a glass tube instead of LEDs. After trying out some simple circuits with an Arduino, some shift registers, and some Numitron tubes, I decided to purchase some Nixie tubes on Ebay and give it a go. The way I have designed this clock, the Nixies display the hours, minutes, and seconds, while the Numitrons will display the temperature, the date, or any other information that I want to display.
Charles Ahrens
This is the assembled clock with tubes in. Right before I took this, I dropped (and shattered) one of the Numitron tubes, so I will have to order another from ebay.
Yann Guidon / YGDES
Bud Bennett
Nicholas Amrich
This clock is just what I have been looking for. I have a bunch of IN-14 and IN-12 tubes. Now I just need to pick up the Numitrons. Thanks for posting this.
