Goliath - A Gas Powered Quadcopter
A BIG Gas Powered Quadcopter
Goliath is an open source prototype vehicle for developing gas-powered quadcopters.
Overview
Goliath is a prototype vehicle for developing large scale quadcopters. The current design is based on a single central gas engine with a belt drive providing power to the four propellers. Control of the vehicle is provided by control vanes placed under the propellers. Each propeller will be enclosed within a duct that protects the rotors and contributes to the lift. Goliath itself will be open source with the creative commons license, and whenever possible open source components are used.
The Mk I vehicle was focused on developing the drive train. The Mk II vehicle was built with lighter weight aluminum frame. Even when completed Goliath is intended as a starting point for future vehicles.
Flight control will be performed using the Pixhawk controller running the PX4 flight stack.
Related Projects
#Inexpensive Composite Propellers/Rotors
#Drone Test Stand
#Measuring Engine RPM with the Pixhawk
Current Status: HOVERING!
The Mk II vehicle has been assembled and hovered for the first time in September 2016.
Details
Structure
The initial Mk I frame was constructed using slotted galvanized angle, also known as Dexion, bolted together. While this is heavier than a steel tube or composite frame, the dexion is quickly assembled and can easily be reconfigured. This allowed for multiple iterations of the drive system to be tested with a minimum of time and cost.
The Mk II frame is built using aluminum tube and assembled using aluminum gussets and and stainless steel rivets. This leads to a lightweight, vibration resistent design that can be assembled easily.
Engine
An electric powered design would have been the most straightforward approach. Electric motors are more efficient than gas motors, but the energy density of gasoline is much greater than today's batteries. So until battery technology improves, for large scale vehicles, gas power seemed the way to go.
Goliath currently uses a single 30 Hp vertical shaft engine and a belt system to transfer power to the four propellers. The setup was chosen because at this scale, four smaller gas engines have a smaller power to weight ratio than a single larger engine. The specific engine, an 810cc Briggs and Stratton Commercial engine was chosen primarily because of its relative low cost per power ratio.
Drive System
The drive system uses High Torque Drive (HTD) belts. These belts are made of neoprene rubber with continuous fiberglass cords. HTD belts are able to transfer more power per weight than roller chain and can also run at higher RPMs that Goliath requires.
To eliminate aerodynamic torque, the drive system rotates two propellers clockwise (CW) and two counter-clockwise (CCW). This is done by using two belts, one sided sided and the second double sided. The direction of rotation is changed by placing the outside of the double sided belt against the driving pulley.
Propellers
The propellers are fixed pitch propellers 36 inches in diameter. They are custom made, starting from a foam blank with birch stiffeners. The blanks are machined using a CNC router and then fiberglass and epoxy are laid up over the machined core. This process produces a propeller that can carry over 60 lbs while only weighing one and a quarter pounds.
Control
An electric quadcopter would traditionally maneuver by varying the speed of each propeller to control thrust. Since Goliath uses fixed pitch propellers and all the propellers turn at the same speed due to the belt drive, maneuvering will be done by control vanes similar to those used to steer hovercraft.
Exhaust
Each of the two exhaust pipes are built from Go-Kart hardware, which are easy to procure and inexpensive. The U-Build It Kits are easily assembled using a minimum of welding and highly customizable.
Electrical System
The electrical system is powered primarily from the alternator with the battery as a backup. The battery is 12V and designed for off-road vehicles, so it'll handle high vibration loads. The micro-controllers and servos are powered using a...
  • 1 × 30 HP vertical shaft gas engine Should equipped with a starter and alternator
  • 1 × Pixhawk Open Source Flight Controller
  • 2 × Clockwise Propellers (36" Diameter) See Detailed Build Instructions for Raw Materials (Forthcoming)
  • 2 × Counter Clockwise Propellers (36" Diameter) See Detailed Build Instructions for Raw Materials (Forthcoming)
  • 4 × Duct (37" Inner Diameter) See Detailed Build Instructions for Raw Materials (Forthcoming)
  • 8 × Control Vane (37" Wide) See Detailed Build Instructions for Raw Materials (Forthcoming)
  • 8 × Control Servo
  • 1 × Throttle Servo
  • 1 × Main Pulley (50 mm wide) HTD Pulley 50 mm wide,34 teeth, with QD Bore (Type SH)
  • 1 × Main Pulley Bushing QD Bushing with 1 1/8" Bore
View all 22 components
  • Evaluating Aerodynamics
    Peter McCloud03/12/2017 at 00:26 0 comments
    Goliath hovered for the first time in September of 2016. The hover performance was less than desirable since it required a higher throttle setting than hoped and the vehicle did not rise evenly. It tended to favor the port side or the aft. Even more puzzling, was that it tended to lift off first on the side that had the most weight. Ballast could fix the issue, but understanding why is also important. Testing has continued to evaluate the aerodynamics of the setup. Below is a video compilation of some of those tests.
    Test 12 was a simple flow visualization of the rotor downwash. Tufts of yarn were added to the frame to show the flow direction along the radius of the rotor and into the frame. The tufts behaved as expected, with the tufts under the rotor mostly steady. Inside the frame, the tufts indicated the flow reversed and flowed upward due to ground effects. While the tufts wiggled, there did not appear to be anything that suggested any unsteady flow phenomena.
    Tests were also conducted outside to see if the shop walls and ceiling were effecting the aerodynamics. Occasionally in the past, loose debris had been ingested into the rotors and the debris recirculated inside the wake as the flow got turned around by the walls and got re-ingested. Testing outside reduced the re-circulation.
    Test 16 nearly ended up with the vehicle getting damaged. There were four hold-downs, intended to allow the vehicle to move slightly upward, yet remain captive. They weren't made long enough and the hold-downs failed on the aft end of the vehicle. Fortunately, the throttle was reduced in time and the vehicle settled back on the stand (albeit precariously).
    The hold-downs were fixed and the testing continued. During Test 17, the vehicle again lifted up, favoring the port side, but at a reduced throttle setting. However, the test stand didn't allow enough movement for a full hover to be achieved. The test showed that the asymmetries were present, regardless.
    In theory, the rotors themselves should have been out of ground effect as they were at least one diameter above the ground. However, for quadcopters, it may be that the ground effect is dependent on the length scale of the four rotors together and not the length scale of a single rotor. If that is true, then perhaps the port rotors are experiencing higher thrust since they are slightly closer to the ground. It's difficult to tell exactly. This may be why the Mallory Hoverbike has the offset rotors catty-corner from each other.
  • Mitigating the vibrations
    Peter McCloud12/12/2016 at 05:04 0 comments
    I'd hoped to be well into working on the controls on Goliath by now, but the shorter days and colder weather mean less time in the shop. I'm still nailing down some lingering issues with the drive train. The new pulleys are weeping grease because the bearings are getting too hot. I suspect it's because I'm using all thread axles and nuts to keep the bearings in place. I'm working on building the proper axles and axles mounts to go with the new pulleys.
    Meanwhile I wanted to document the progress made on mitigating the vibrations that the avionics experience. This was accomplished by better isolating the engine from the frame and the avionics tray from the frame. The new engine mounts are made primarily of rubber, but are built such that if the rubber fails, the bolts are still captive. Stainless steel bolts are used to attach the mounts.
    The avionics tray was switched from aluminum to steel. This was to add mass to help reduce the displacement of the avionics tray. Below is the new tray with some of the avionics populated.
    The tray is mounted to the frame using four Expansion Nuts. I forgot to take a picture of them before I installed them, so here is a link. Below is a shot showing the flange on the expansion nut between the tray and the frame.
    So how much did all the changes help? Data from the Pixhawk shows a huge reduction in the pitch rates down by a factor of 5 to 10. This means that the Pixhawk should be able to control Goliath once the rest of the hardware is complete.
    Hopefully the next log update in the not too distant future will be about fixing the bearing issues.
  • Quick Status Update
    Peter McCloud11/21/2016 at 05:25 0 comments
    It's been a little over two months since Goliath hovered for the first time. Here are some of things that have gone on since then.
    First was a trip to the Portland Maker Faire, September 11 and 12th at OMSI. It was a lot of fun showing off the vehicle, especially now that it hovers. Thanks to everyone who came out and checked out the project. I had a lot of great conversations that weekend.
    After getting back to the shop and making sure everything was in working order, it was time to get back to work. The first order of business was to finalize some of the hardware. While Goliath hovered, the center of gravity didn't seem to be in the most ideal location. In order to remedy this, all of the hardware needs to be finalized with the flight weight components, particularly the remaining steel pulleys.
    This was the same process as before, but since these are idlers and tensioners, no holes are needed for bolts. The last of of these components are complete, with each saving around a pound of weight. There is now only one one steel pulley left on the vehicle, the main engine pulley.
    There was also a hiccup with the battery and solenoid. The battery died, likely because it was undersized and was being deeply discharged. A new bigger battery was added with 18Ah, 80% more capacity than the previous battery, but with only 4 more lbs. Some thought was given to switching from the lead AGM type to a Lithium based battery, which would save about 10 lbs. However, the AGM has been demonstrated to work with the high vibration environments.
    The solenoid failed again, the second on that's failed on Goliath. It's obvious that the stock lawnmower ones aren't built for the vibrations that Goliath creates. It was replaced with another stock solenoid as a temporary fix, but a heavy duty one needs to be sourced for the future.
    Lastly, the temporary Avionics Tray was replaced with a permanent one. This time it was made from 16 gauge steel. It weighs a little more than a pound. The idea is that the added mass will help to dampen the vibrations. The tray is isolated from the frame. using rubber expansion nuts.
    I'll have more details in a future log post, but the great news is that between the new engine mounts and the avionics tray have reduced the vibrations that the Pixhawk experiences low enough for it to work now.
    Stay tuned for more details.
  • Goliath Mk. II Hovers!
    Peter McCloud09/08/2016 at 05:21 8 comments
    Over Labor Day weekend the assembly of the Mk. II vehicle was completed. The new vehicle was weighed and the current weight is 170 lbs, 50 lbs lighter than the previous vehicle. The first couple of tests were conducted and Goliath has hovered for the first time!
    There is obviously a lot more to be done, but hovering is a big step in the right direction.
    Also, if you're in the Portland area this weekend, come see Goliath at the Maker Faire!
  • Assembly Nearly Complete, 1 Week to the Portland Maker Faire
    Peter McCloud09/03/2016 at 20:44 0 comments
    Work has continued on the Mk II vehicle and it's nearly complete. The latest work has been attaching the idler pulleys, tensioners and the battery.
    The ilder pulleys were mounted to same 1/8" plate used for the engine mounting plate. Aluminum angle was riveted around the edges and the plates were bolted to the frame.
    Below, the two idler pulleys for the single sided belt are attached.
    The center idler for the double sided belt required a different approach. The upper attachment was already part of the engine mounting plate. The lower attachment was made from a smaller piece of plate and riveted to two cross members that were added to the frame. Below is a shot looking at the underside of the frame where the cross members were added.
    The other idler for the double sided belt was attached using two different methods. On the lower side, the aluminum plate with angle was used and bolted to the frame. For the upper side just a plate was used was bolted to the engine mounting plate, using the same bolts for the engine mount.
    With the idler pulleys all attached and the tensioner attachment method decided upon, some additional gussets were added to reinforce the aft end of the vehicle.
    With the aft gussets attached, the exhaust pipes could mounted.
    Not shown are the flexible mounts scavenged from the original frame.
    Next a tray for the battery was created from angle pieces.
    A rubber liner was added to the bottom of the tray.
    To keep the battery in place an additional piece of angle was bolted in place on top of the battery.
    Now all that remains to complete the Mk. II vehicle is to add to the electronics and the fuel tank. With some luck, the vehicle could be complete and running by Labor Day.
    Stay tuned...
  • Come see Goliath Mk. II at the Portland Mini Maker Faire (Sept 10th and 11th)
    Peter McCloud08/25/2016 at 23:23 0 comments
    Goliath Mk. II will be at the Portland Mini Maker Faire on Saturday and Sunday, September 10th and 11th at OMSI. This will be the first time the Mk. II vehicle will be shown in public. I'm working on completing the vehicle and having its first test before the Maker Faire. The vehicle will not be run at the Faire. Look for it at the McCloud Aero Corp booth.
    More details can be found at:
    https://www.facebook.com/makerfairepdx/
  • Lower Frame Completed, Upper and Lower Halves Joined
    Peter McCloud08/15/2016 at 04:26 0 comments
    This last weekend was productive and the major portions of the frame are now complete.
    After attaching the engine mounting plate to the frame, the next step was assembling the lower frame. The lower frame is similar to the lower ring of the upper frame, so it was possible to reuse the jig for the upper frame with some minor modifications. This was simply making new wood rotor shaft mounts for the lower frame and swapping them out in place of the old ones. Then all of the lower frame elements were cut and placed in the jig.
    With all of the elements in place, the same process for riveting the gussets was followed.
    Next the lower rotor shaft mounts were machined out of metal. There was a couple of hiccups due to the double sided tape not holding and bit breaking.
    Once the mounts were completed, the shaft mounts were attached with bolts to the lower frame in the same manner of the upper frame.
    In the future the gussets would be attached to the top side of the lower frame. However, at this stage the method of attaching the idler pulleys and tensioners hadn't been finalized. Therefore the upper gussets were left off at this point.
    With the two halves completed, it was time to start attaching them together. Both halves of the frame were attached to the rotor axles to hold the two halves relative to each other. It was easiest to work with the frame flipped over since most of the riveting was on the bottom.
    Four lengths of tubing were initially cut and attached on the sides of the frame along with the gussets for the lower frame. Clecos were used to hold the parts together prior to riveting.
    Next the lower cross members were added to the lower frame
    With all of the new elements attached, it was time to riveting the parts and finalized the attachment between the frames. At that point the frame was flipped back over to see the progress.
    At this point about 80% of the frame is complete. the frame members at the front of back need to be added and some smaller cross members need to be added to stiffen the frame. However, before completing the frame elements, the attachment hardware needs to be completed to make sure there aren't any issues with the remaining structure. Once the attachment hardware has been finalized, then the frame can be finalized.
  • Attaching the Engine Mounting Plate to the Upper Frame
    Peter McCloud08/02/2016 at 19:32 0 comments
    Progress on the Mk. II vehicle is moving along and the engine mounting plate is now attached to the upper frame.
    The first step was to start measuring and cutting the tubing that attach the engine mounting plate to the upper frame. This was starting by making a simple jig to hold the pieces at the right elevation to each other.
    This worked for doing some preliminary alignment, but to make sure everything fit well, it was decided to redo the jig so that the engine could be placed on the vehicle while it was in the jig. This was done by further elevate all the pieces, with 2x4 blocks holding up the engine mounting plate.
    When all of the tubing was cut, the holes were drilled on the ends attached to the mounting plate and the parts were held together with Clecos.
    The plate with the tubes attached was put back in the jig and aligned with the upper frame. Then the gussets for the remaining joints were made and attached with more Clecos.
    The gussets are wrapped around the tubing and will also serve as the attachment points between the upper and lower halves of the frame. This required bending the gussets with a larger 3/4" radius. To get a good radius bend, the press brake was used with a 3/4" diameter steel bar placed along side the sheet metal to provide the right shape for bending.
    Once all the gussets were in place, the engine was mounted to double check that there was adequate clearance, before permanently attaching the plate to the frame.
    All of the clearances checked out and with no glaring design issues present, the rest of the rivets were pulled on the frame side of the tubes. Since there wasn't enough clearance to pull the rivets under the engine mounting plate, the frame was flipped over and the last of the rivets in the plate were installed.
    A quick note on the rivets for the engine plate. Rivets are designed to join a specific thickness of material. The 1/8" thick plate is thicker than the gussets, so slightly longer rivets had to be used. So care has to be taken to make sure the right rivets are used in the different locations.
    At this point, the frame is about 50% complete. The frame was weighed in it's current configuration (without the engine) and weighs 14 lbs, 2 oz. This means that the final structure weight is sill on track to weigh around 30 lbs.
    Next up for the Mk. II vehicle is to build the lower half of the frame and machine the lower rotor shaft mounts. Once that work is complete, the two halves of the frames can be joined together.
  • Engine Mounting Plate Complete
    Peter McCloud07/26/2016 at 14:34 0 comments
    The engine mounting plate has been completed and the middle portion of the Mk. II frame is now complete.
    Designing the engine mounting plate required working though a few iterations before the coming to current design. The plate is made from 1/8" thick 6061-T6 Al plate from Aircraft Spruce. It wasn't cheap, so making sure the design was good before cutting the material was important.
    The first step was setting up the initial layout, using cardboard to layout the engine mounts and make sure that the plate wouldn't be in the way of the exhaust. The engine mounts are made of rubber and steel and should help with dampening some of the vibration from the engine.
    After doing the cardboard layout, and comparing it to the Mk. I design, it became apparent that it would make sense to go ahead and incorporate the mount one of the idler pulleys as part of the design.
    Next, the part was designed using CAD and another prototype was machined using foam board. One other feature incorporated. at this point was multiple tabs on the sides of the plate for attaching to both the lower and upper frames. The tabs would be bent +/- 15 degrees depending on which half of the frame it would be attached to.
    However, after holding the part inside the new frame a very big design flaw become apparent. The middle tabs were meant to be bent downwards, but that would place them in the way of the idler pulley, which will be placed below the engine plate. Second, I could go to both the lower and upper frame from the engine plate directly, otherwise the structure would have to pass through the belts. If that was done I'd have to assemble and re-assemble the frame every time the belts were added or removed.
    It was decided to just attached the engine plate to the upper frame, similar to how the Mk I frame is laid out. The plate was redesigned. one last time, this time adding engine mounts to the front and back and also adding a mounting area for the motor servos at the aft end of the plate.
    After a test fit, the design was complete and the part was ready to be machined using the aluminum plate. Since the CNC router needs to go slow to cut the aluminum plate, it took about an hour to cut the part. In the images, the edges of the plate look somewhat rough. This is actually the protective film that is on both sides of the plate. The actual edges come out very clean.
    After cutting, the tabs were bent to the correct angles using the press brake. The protective film has been left on to prevent marring the material.
    After getting all of the bends to the right angle, the mounts were placed on the plate and the engine was test fit to make sure all of the clearances looked good.
    With the engine plate complete, it was time to start attaching it to the upper frame. I'll have those details in the next log.
  • New Rotor Shaft Mounts
    Peter McCloud07/04/2016 at 03:10 6 comments
    The upper set of new engine mounts are now complete. This log documents both the design and the process of building the new mounts.
    The new hardware is considerably different from the previous design. The prior mounts were originally a 6" piece of angle iron bolted to the slotted angle frame and had a slot cut out for the shaft. The shaft was held captive between two shaft collars that also served to transfer the thrust between the shaft and the shaft mounts. One of the previous shaft mounts can be seen below, just above the closest rotor.
    The mounts for the Mk. II vehicle had to go from the shaft and mount to the three aluminum tubes that comprise the rotor arms. This required a custom part that could be bolted to the tubes and also act directly as the shaft mount, instead of using multiple shaft collars. The design process started by making a CAD object using Cubify Design.
    After that, the next step was making some prototypes out of wood on the CNC router.
    These were also used in the Jig to align the tubes for the rotor arms.
    Next, it was time to make the actual hardware. The parts were machined out of 6061-T6 bar stock. The parts were cut on the CNC router. A CNC mill would be better suited than the CNC router, but I don't have one. That being the case, it took a couple tests to find the right settings on the CNC router. The first test run had some issues with galling. The galling causes the poor surface finish and the feathering on the edges.
    The fix was simply to slow down the feed rates and lower the spindle speed. After that the roughing passes came out a lot cleaner.
    Once the roughing pass was done, a waterline pass was made.
    Next, a parallel pass was made in the Y-axis to clean up the upper surface.
    The last pass was with a 3/4" diameter ball end to clean up the grooves.
    With the machining on the CNC Router done, the next step was to drill and countersink the holes for the bolts to mount to the frame. The last step was to drill the holes for the mounting.
    When everything is together the shafts will be mounted using half of a shaft collar.
    With the parts complete, it was time to attach them to the upper frame.
    The next part of the project is building the engine supports. To make sure everything is right before it's riveted all together, which means that the parts need to be scavenged from the first vehicle. More on that next time.
View all 71 project logs
  • 1
    THINK BEFORE YOU START
    Before you start this project, take some time to REALLY think about what you're about to build. Seriously, this is a flying machine that weighs more than most people and runs on gasoline, a chemical that the states of Oregon and New Jersey have deemed too dangerous for the average citizen to pump into their own car.
    While Goliath is a big and powerful, it's only as dangerous as the user. As you build, test and fly your giant quad copter be mindful of your safety and the safety of others.
  • 2
    BUILDING THE COMPOSITES
    Building the composite pieces requires the longest amount of lead time. It's recommended to start these pieces first, and the rest of the components likely be built while waiting for the composite pieces. Components made from composites are:
    • Propellers
    • Ducts
    • Control Surfaces
  • 3
    BUILDING THE UPPER FRAME
    Tools - Miter Saw, Jig Saw or Tin Snips, File, Drill with #30 drill bit,Rivet Puller
    A) Build the Jig for the Upper Frame
    To properly build the frame, jigs are required to hold all of the frame elements in place. The jig is constructed from particle board. Below the completed jig is shown with the upper frame elements in place.
    B) Cut the Upper Frame Elements
    Using a miter saw, cut all of the frame elements and place them in the jig to ensure a proper fit.
    C) Cut the Common Gussets
    Cut the common gussets (4 A & 4 B), layout and drill the holes with the #30 drill bit.
    D) Assemble the Upper Deck Elements
    1) Remove the frame elements for the upper ring, leaving just the pieces for the upper deck
    2) Clamp the common gussets in place and drill half of the holes into the frame. Use Clecos to fill in the holes as you go.
    3) With half of the holes filled with Clecos, drill the remaining holes and fill them with rivets.
    4) Remove the Clecos and fill in the remaining holes with rivets.
    5) Remove the upper deck from the jig, flip it over and place it back in the Jig
    E) Cut the Corner Gussets
    F) Assemble the Upper Ring
    1) Place the remaining frame elements back in the Jig
    2) Attach the corner gussets
    G) Join the Upper Ring to the Upper Deck
    1) Cut the Angle Gussets
    2) Attach each of the angle gussets
    The Upper Frame is now complete and can be removed from the Jig
View all 11 instructions
Robert McClintock wrote 03/06/2017 at 18:13 point
This is a cool project. When you were building this did you use a Design program when drawing this thing out? Or was this all built from experience? The reason I am asking is because its for college course I am taking. I'm wanting to build this for my CAD project and know if had any previous info like dimensions for the frame? Well, thanks for reading and I will be being staying tune in for project updates.
Peter McCloud wrote 4 days ago point
Robert, thanks for the interest in this! I'm sorry I didn't respond earlier, I never got notified about this comment.
I hope its not too late to do this for your project. I've got coordinates for the frame buried in the github repo. I'll PM you and we can get in touch.
charles wrote 12/26/2016 at 10:56 point
Have you considered using a variable speed pulley system and an actual quadcopter stabilizing software and hardware setup to control the amount of speed each pulley produces? Servos and actuators incorporated along with tensioners to increase and decrease the amount of speed that each pulley system produces. There are many manufactures of these belts and pulley sets. I personally think that would be the best solution to be able to maneuver this craft safely.  If this helps your quest to make a gasoline powered quad please inform me about it. You would need 4 sets of these to manage the quadcopters prop speeds. https://trade.indiamart.com/search.mp?search=variable+speed+pulleys Or you could even use a small electric motor design that manages the amount of tension either with screw type management or offset tensioner pulley on the electric motor that changes each belt according to its thrust using the quadcopters hardware. But the reaction time would suffer greatly by using a screw type actuator just saying that for reference.
Ricky wrote 10/03/2016 at 19:43 point
Brilliant. I was thinking why is there nothing modern like this lol. im new to flying but not rc. Its been a while though. I wanted to know were you are? Woud love to get involved.
jd_jaidev94 wrote 09/21/2016 at 13:00 point
If money was no issue, what engine would you use and in combination with what motors and props? Can heavy payload and long range flight be possible with gas powered engines and electrical motors?
Peter McCloud wrote 09/22/2016 at 10:29 point
If money was no issue, I'd probably try to make my own engine along the lines of #Open Source Two-Stroke Diesel Engine. There are engines out there with higher power to weight ratios, but the peak power RPM isn't optimal, so additional gearing is needed.
For props carbon fiber would give you the lightest weight and if money is not an issue, you could just get 4 variable pitch tail rotors from a helicopter.
Carl Mueller wrote 07/02/2016 at 22:34 point
As far as a control system, you could just treat this as a singlecopter.  The fact that it has 4 rotors instead of one is not really material, since all give the same thrust.  The implication is that (a) you only need 4 vane controls, and (b) it's already available in Ardupilot.
Peter McCloud wrote 07/04/2016 at 02:40 point
I hadn't thought of it in terms like that, but you're right. It looks like there is one difference between Goliath and the Ardupilot singlecopter setup. Goliath is setup as an X configuration vs the Ardupilot singlecopter + configuration. Regardless, it should be something that can be adapted. Thanks for the excellent insight!
TTN wrote 05/26/2016 at 01:46 point
I guess its easier to just test with new pulleys at this stage, but I was just wondering if you have considered using a 2 or 4 stroke motorcross bike engine? Light weight, high power, somewhat pricey, but not impossible to purchase. The engine units are generally well separated so the transmission part of the engine can be milled off the engine. Either way its a lot of work to do an engine swap. I can see a lot of work has gone into this project!
Peter McCloud wrote 05/26/2016 at 03:58 point
Eventually a different engine would be ideal. I had not looked at motocross engines, I'll have to add that to the list. One reason I've stayed with the current engine is that it's inexpensive and if the vehicle crashes I'd rather lose this engine.
Poppy Ann wrote 01/20/2016 at 08:44 point
did you consider using a set up similar to :- http://www.hobbyking.com/hobbyking/store/__66943__Assault_Reaper_500_Collective_Pitch_3D_Quadcopter_Mode_2_Ready_to_Fly_Lite_.html
which uses only one motor and then uses constant speed propeller blades that use the same system that helicopters use to alter the pitch  to adjust the lift of each corner?
I have been thinking of building a similar design of one power system but using one of the Honda silent generators for power then either still using separate motors at each blade or a single motor and belt drive like the Hobbyking Assault Reaper quad.
Regards Poppy Ann.
Peter McCloud wrote 01/21/2016 at 00:10 point
That's been talked about a couple times in the comments. Essentially, it's a whole other project in itself to build adjustable pitch propellers. Once Goliath is flying I may investigate it then.
Thanks for pointing out the typo. I fixed the error in the instructions.
Poppy Ann wrote 01/20/2016 at 08:36 point
Hi who did the editing of this page? I am dyslexic and noticed one obvious mistake as soon as I read it ie:- "Oregon and New Jersey have deemed too dangerous for the average citizen to handle putting their own car."
where is the average citizen trying to put their car that is so dangerous ? or did you mean :- "Oregon and New Jersey have deemed too dangerous for the average citizen to handle putting in their own car."
Regards Poppy Ann.
ken wrote 12/01/2015 at 16:21 point
Increase the diameter of the pulley on the motor and add a centrifugal
clutch to allow the engine to start and addle be for engage the propellers this
will allow higher rpm to the propellers. Do this till the motor can’t increase
to the max rpm than back off a little this will tell you if the motor is too
small. I don’t think it is you just need to get the rpm’s up on the propellers.
And put a cage around it when you test it. I don’t think
your propellers will withstand the rpms needed for lift off. If one breaks very
bad news for ever who is around.
Peter McCloud wrote 12/15/2015 at 14:40 point
Any recommendations on specific clutches? I looked around for one that would work my Goliath about a year ago and I didn't find any.
Thanks for the concern about safety. When Goliath is being tested, there is a safety net that is put up, and everyone is behind a big steel tool cabinet. There are some pictures of the safety net in the project logs.
goldenshuttle wrote 11/04/2015 at 07:05 point
Great project. Have you taken a run on each part to reduce total weight ?
thesunman84 wrote 09/05/2015 at 15:16 point
From my experience in the structural world, might I suggest adding a washer under the bolt head to distribute force evenly?  Right now, it looks like most of your bolt heads are only gripping a very small amount of the galvanized steel.  You are best off using a flanged nut with a washer under the bolt head.  I know you're trying to cut weight and washers won't help that but neither will a bolt head pulling through steel :)
http://www.boltscience.com/pages/faq.htm#11
Peter McCloud wrote 09/11/2015 at 14:40 point
Thanks for the link and the suggestions.  I'll have to keep that in mind as I continue to develop the vehicle
Aaron Cooper wrote 08/26/2015 at 21:04 point
Have you looked into lightening the engine itself? some features like the fuel shutoff solenoid are potentially un-needed as those were added to prevent a bad needle valve from flooding the engine during storage.  The various covers are potentially replaceable with lighter weight parts.  I was briefly interested in using a weed eater engine to power a RC plane, there is a community dedicated to modifying small engines for RC use. I believe some of them modified or replaced the flywheel to make it lighter.
Peter McCloud wrote 08/27/2015 at 14:24 point
All good thoughts. I haven't concentrated on that area yet. I would like to leave the solenoid in to be able to shut off the fuel source in case there is an engine fire. It's a common practice for aircraft, though it's probably pretty unlikely that I'll have an engine fire and still be able to command the fuel to shut off.  The fuel solenoid is pretty small, so it'd not too big of a weight penalty.
The plastic covers would be fairly easier to replace. I could make molds off the existing ones and replace them with fiberglass.
I'd love to get a lightweight flywheel for the engine, that's probably be the most beneficial and it's relatively easy to swap out. I haven't found any out there for my particular engine model.
If you could share any links to the specific RC groups you mentioned that'd be great.
Thanks for the inputs!
Aaron Cooper wrote 08/27/2015 at 19:14 point
Below is one site that has a bunch of info, they focus on the smaller engines but a lot of it should apply. Also a site that has parts that may be compatible or at least copy-able design wise for your engine.
http://www.rcfaq.com/ANSWERS/ENGINES/WEEDIES.HTM
http://www.mcssl.com/store/midwestsupercub/v-twin-parts
michael.rodenbarger wrote 07/21/2015 at 14:21 point
Very interesting! Great job thus far :).
Have you thought of using 2 stroke motors at all? You can generally get more power out of a lighter 2 stroker vs a 4 of the same size. How about using crankshafts instead of a belt driven system? Weight can be reduced with creative use of materials (carbon fiber or fiberglass shafts).
Peter McCloud wrote 07/21/2015 at 21:19 point
Hirth makes an experimental aircraft engine that weighs the same as engine currently being used, but has more than 3x the HP. The issue is that it costs 10x the current engine.
The real issue with drive shafts isn't the shafts themselves, but the gears required to make them work.  I haven't found gearboxes that can support the Hp and are light enough.
Thanks for the interest in the project!
surubarescu wrote 05/25/2015 at 08:49 point
I have some suggestions: for the belt pulleys you can use some with slightly barrel shape that will self center the belt (like on band saw), yet giving the power transmitted, the pulleys should have shoulders to keep the belt flying. Or you can use a transmission box like two mikey mouses heads connected at the neck: two big gears, one connected to the engine, the other used to reverse the rotation, and for each one 2 smaller gears to send the power to the propellers using shafts (either  via 2 sets of conic gears if the engine and propellers are level, or if the engine is very low shafts with universal joints).
Almost forgot: this thing will have a gatling gun turret under it?
Peter McCloud wrote 05/26/2015 at 19:49 point
Maybe I can add a paintball Gatling underneath and put it up against this guy:
http://makezine.com/2015/05/17/car-no-match-15-foot-fighting-megabot/
As far the the barrel shaped pulleys belts go, I'm using those for the flat sided idlers.  All the toothed pulleys are flat faced, but they all do have shoulders.  You can't have the barrel shape and still maintain the right tooth profile.
I did look into gearboxes as well, but they are too heavy for what I need.
surubarescu wrote 05/27/2015 at 07:55 point
Nice mech, but the driver is protected by chicken wire. You won't get a clear head shot, but you'll spray it well with paint.
Let me draw you a little picture of how i see this "gearbox" (better said a collection of gears) [you'll need to view it using fixed font - paste it in notepad]
ENGINE
propeller                       |               propeller
----+-----            _____   __|__             ----+-----
   _|_               |__|__| |__|__|               _|_
 _____
|  |  | this is a combination of cylindrical and conical gear
|__|__| the cylindrical part engages the other identical gear
\  |  / the conical engages the shaft conical gear
 -----  for each of these gears there are two shafts for two propellers
The only issue is that you'll have adjacent propellers rotating in the same direction (but you already choosed this configuration). You can also use sliding shafts to counter the bends in the propellers trusses.
Rollyn01 wrote 05/25/2015 at 01:41 point
You ever thought of expanding this to build an actual factual flying car?
Peter McCloud wrote 05/25/2015 at 03:21 point
Yes. I originally wanted to build a quadcopter large enough to carry a single person. However getting a more powerful engine and the hardware to go with it would have been expensive. I chose to make a smaller (relatively) prototype to test out the technology needed  before  going bigger.
Adam Fabio wrote 01/15/2015 at 05:57 point
Awesome work Peter! The wider belts do seem to be working out pretty well. I've made the same mistake leaving the screw out of a servo. I bet you needed a change of shorts after the unexpected jump to full throttle!
Peter McCloud wrote 01/17/2015 at 03:00 point
When it happened, it seemed to be at full throttle for a while before I killed it, but after watching the video, it seemed much shorter. That's what adrenaline does I guess.
dwardio wrote 12/03/2014 at 16:42 point
Very interesting project! Like many others, I'm curious as to how controlling thrust direction will replace variable prop pitch or speed.
Also, what is the estimated full-up weight at take-off? Current AMA guidelines are that any model weighing in at more than 50 pounds should be registered as an experimental aircraft. Needless to say, this bad boy is going to be potentially lethal, making sure you're within the rules is a good investment.
Peter McCloud wrote 12/04/2014 at 22:31 point
Thanks for the interest! I'm hoping to have a gross takeoff weight of 240 lbs, with 40 lbs of payload capacity. Your right, Goliath can be hazardous and this is not something you simply take to the park and fly around.
Your right, knowing what the rules are is a good investment. I'm curious if you happen to have a link to the guidelines you're referring to. I did some looking and found AMA document 520A (http://www.modelaircraft.org/files/520-a.pdf). It simply states that AMA Large Model Aircraft 1 (LMA1) can be from 50 to 77.2 lbs and LMA2 can be from 77.3 to 150 lbs.
I did find a reference to the IMAA guidelines that states:
"IMAA qualification also requires the RC model be a maximum weight of 55 pounds, with fuel – ready to fly. Models over this weight up to 100 pounds, with fuel – ready to fly (known as Experimental Radio Controlled Aircraft) may also qualify as IMAA giant scale provided they have a Permit To Fly signed by an AMA certified “Experimental Inspector”"
My understanding is that drones are currently certificated by the FAA, and the guidelines that they are working on will be valid for 55 lbs and below. So this leaves Goliath in a questionable area. I'm not sure where I'll be able to fly it once it is flying. For now I'll just have to worry about it once I get Goliath flying.
Rebelj12a wrote 11/10/2014 at 21:31 point
Odd thought, are you still having stability issues...
I wanted to make a gas powered one for more sustained flight anyways. Current electric quadrocopters dont have alot of flight time especially for heavier things.
I dont know if this will work, however it might...
One, place a direct porpeller on the motor itself. Primary lift comes from the center of the craft.
Recess the center motor further down, i.e. angle the quad rotors upwards by maybe... 20 Degrees 30 degrees?
Add brushless propeller motors on the ends of the quadrocopter.
Heres the "if" and I dont now if it will work... See if you can find an alternator and a flight controller. There are lots of electric ones, although it may need to be retooled but this will allow you to balance the quad with the brushless motors. The motors would be powered by the gas engine turning the alternator, well besides the initial first charge.
At the most maybe, it would need to be tuned to stay afloat, however instead of the rotors providing primary lift the engine would therefore making it more powerful and using the rotors for stabilization and guidance using the flight controller. That may need to be tuned im sure the physics are different. Although with the *hanging* design of having the motor propeller and camera/gimbal lower it should make stabilization a bit easier.
A thought I had bouncing around. In any case thought i'd throw it your way, never know.
Peter McCloud wrote 11/11/2014 at 18:19 point
Thanks for the inputs. This is what I feel Hackaday.io is all about, so please keep the inputs coming. The issues I've been having are oscillations with the belts themselves, I hope I have it fixed, but I haven't tested out the latest config.
A hybrid design would be nice, it certainly would solve the issues of having belts. I haven't done the math as to how much power I would need to maneuver using electrical power. The engine is already equipped with an alternator, so it'd just be extra weight of the control motors. Something to think about if the current fixes don't work out. Thanks!
Rebelj12a wrote 11/12/2014 at 10:32 point
Possibly add an adjustable belt tensioner? Similar to this.
http://www.alibaba.com/trade/search?fsb=y&IndexArea=product_en&CatId=&SearchText=belt+tensioner
Also for fairly decent cheap parts this place is the place to look. Couldnt believe the prices so i'd question the build quality long term however for a working concept and for ideas on what to look for. This place has got the parts.
Also the idea to lower the engine and main rotor a bit came from here.
http://www.dji.com/product/spreading-wings-s1000-plus/feature
Look at the very bottom, theres the degrees of inclination. The lower center of gravity at the center as well makes it more stabile. Also.....
If you were to go with a single gas propellery and smaller control engines on the outside. I would use a propeller with a center connect and outside connection ring. Fix the propeller inside a round shell. That way it would have the stability if you wanted, to even attach the 4 control engines above the main main blade itself. It might offer a bit more stability as well, keeping the propeller blade from oscillating, attached to the motor.
Also for safety reasons too XD
Peter McCloud wrote 11/13/2014 at 01:31 point
I have added spring loaded adjustable tensioners, that I built from scratch. They can be seen in the video link here.
https://www.youtube.com/watch?v=OfnLvJodg84
Hopefully the remaining issue was having the pulley flanges setup right. Hopefully I'll find out it's all right with the next test.
Rebelj12a wrote 11/13/2014 at 03:08 point
Oooh oh I dont know about springs. Makes it bouncy thats not good. I would have use screw adjustible ones you can lock into place. Especially because depending on temperature and wear the belts will loosen and tighten (dont know about you but its getting cold here XD)
If all else fails. I highly suggest looking at a chain based solution. Grab a couple old bikes for the gears and chains from thrift or garage sales.
Rebelj12a wrote 11/12/2014 at 21:16 point
Also, of note on the page I linked is the motors they use and the kg of force they exert for flight.
PointyOintment wrote 11/11/2014 at 22:47 point
66
99
Like this?
http://www.geek.com/science/weve-been-designing-quadcopters-incorrectly-since-day-one-1577256/
gnoejuan wrote 10/17/2014 at 22:18 point
What i see here is a flying lawnmower. And that's exactly how I'd use it.
Dave Hermeyer wrote 09/30/2014 at 11:11 point
I'm glad that you put a disclaimer "Think before you start" at the beginning of your instructions, but you go on to say "it's only as dangerous as the user". That's exactly the problem! There's plenty of fools out there, and I'd hate to imagine one of these machines in their hands. And what happens when you have engine problems in mid-flight, or a belt breaks?
Peter McCloud wrote 09/30/2014 at 20:09 point
Yes there are people out there who could do bad things with Goliath, but there are many other things that they can get there hands on as well that'd be dangerous.
Once I start flying more than a few feet off the ground I intend to install a ballistic recovery chute. In an emergency the parachute is shot out using compressed gas or a rocket. There are some sized for ultralight aircraft. So that would be ideal. It'd be nice to have redundant belts, but I don't think there's enough weight margin for that.
michaeldlewandowski wrote 10/17/2014 at 17:41 point
I am interested in designing/ building a recovery system for this monster! I have emailed you.
Peter McCloud wrote 10/19/2014 at 02:07 point
I look forward to hearing about your ideas. I'll contact you soon!
