LoRaNicator
A wireless telecommunications device, based on LoRa technology, that receives and displays alphanumeric messages.
Public Chat
LoRaNicator is a pager device based on LoRa technology. - 128x64px monochrome LCD with build in ST7565R-G Controller - ATSAMD21G18A-AU Cortex-M0+ 32bit low power ARM MCU (Arduino compatible) - Extremely Accurate I2C RTC - On-Board Single-Cell Li-Polymer Charge Management Controller - Smart push-button on/off controller - Micro SD-Card Slot - RFM95W LoRa Transceiver (868MHz or 915MHz) - 3-way Navigation Switch - High-Efficient Buck-Boost Voltage Converter - On-Board Coin Pager Motor - On-Board Piezoelectric Sounder - GPIO Header for External Periphery - 2-Layer PCB - Dimensions LxWxH (mm): 100x78x14 (without battery incl. SMA 8mm connector) - Open Source Hardware
Project Write-Up
Tiny note: maybe my English sucks a bit, but I hope you can understand the most of the text below :-)
A couple of months ago, I wanted to experiment with LoRa modules. I started with a breadboard, two AI-Thinker Ra-02 LoRa modules, Nokia displays and ATmega328 boards. After a couple of experiments, I designed a tiny board, my first LoRa pager.
I played around with the new board for a while, made some range tests and got some ideas for improvements.
In the second version of the board, I wanted to keep the board Arduino compatible, but needed a better microcontroller, so I used a SAMD21 Cortex M0 (same on Arduino Zero MKR) microcontroller instead of ATmega328p. I was a bit unhappy with the Nokia display and replaced it with a bigger one. The availability of the AI-Thinker Ra-02 module isn't as good as the RFM95 and I also wanted to get rid of the U.FL connector. So the three main components were replaced and I needed some more features like LiPo Charger, real time clock, sd-card, a proper on/off circuit, navigation switch instead of common push buttons and a buck/boost-voltage converter. I also added some nice-to have things, eg. vibration motor and buzzer.
While designing the schematic, I decided to pick components, which I can get from the common big distributers for electronic components. I decided to choose all the components from Digi-Key, so I can save some shipping costs.
(I don't want to write the detailed hardware description here. For hardware details see the "LoRaNicator Hardware Description" below.)
After 10 sheets of schematics drawing, I started to design the two layer board and configured the design rules first. I used following (significant) design specs which are compatible with the most pcb manufacturers (OSHPark, JLCPCB etc.)
Min. Trace Width / Clearance                    6.3mil (0.16mm)
Min. Via Drill / Outer Diameter                 10mil (0.254mm) / 20mil (0.508mm)
For the power rail I've chosen a thicker traces: ~23mil (0.6mm). There are two interfaces, where the impedance controlled design has been required. The antenna trace and the USB differential pair.
For those kind of trace design I like to use the PCB Toolkit. Since the board is a two layer design, with 1.6mm thickness, I neglected the USB differential pair to avoid crazy thick traces. The USB traces are pretty short, so it shouldn't make any trouble.
I only focused on the width of the antenna trace. The transmission-line I decided to go with, is coplanar waveguide with ground plane (GCPW). I entered the substrate thickness of the pcb (1.5mm / 59mil) and the overall clearance 0.16mm (6.3mil) and calculated 1mm (~40mil) for the trace width to get a 50Ohm impedance.
I also modified the signal pad of the SMA connector (same width as the trace) to match the 50R impedance. I added a rounded corners to the pad and added a copper cut-out at the edge, next to the signal pin. Furthermore I added a via fence around the GCPW.
A good ground connection is also a factor to improve the HF design. So I created a special design rules in CurcuitStudio, to make a solid connection to GND pins of SMA connector and the RFM95 module. The ground connection for all the other components has the relief connection format
Also placed a lot of vias, for direct connection to the ground plane on the other side of pcb. Maybe it will improve the HF performance or maybe not, but I placed a shield can over the RFM95 module.
After designing the schematics and pcb, I ordered the board and a stencil for reflow soldering. The boards came with a gold finish and black solder mask and looked pretty nice :)
There are about 180 components on the board and many resistors and capacitors in 0402 package. So I didn't want to solder...
CircuitStudio_Project_Package_HaD.zip
Altium CircuitStudio Project (Schematics, PCB)
x-zip-compressed - 2.91 MB - 03/17/2019 at 11:05
Download
LoRaNicator_PT2B_Gerber.zip
x-zip-compressed - 166.57 kB - 03/17/2019 at 10:41
Download
LoRaNicator_PCB_3D_model.step
step - 8.43 MB - 03/17/2019 at 10:24
Download
  • 1 × RFM95W Low Power Long Ra nge Transceiver Module
  • 1 × ATSAMD21G18A-AU‎ Microchip MCU 32BIT 256KB FLASH 48TQFP
  • 1 × Navigation Switch COM-08184 COM-08184
  • 1 × Vibration Motor 316040001
  • 1 × LCD COG GRAPH 128X64 Graphic LCD Display Module Transflective Black (White - Inverted) FSTN - Film Super-Twisted Nematic Parallel/Serial 128 x 64 NHD-C12864LZ-FSW-FBW-3V3‎
View all 11 components
  • Working on a case for LoRaNicator
    5Volt-Junkie • 04/03/2019 at 20:35 • 0 comments
  • Example Code
    5Volt-Junkie • 03/25/2019 at 18:32 • 0 comments
    Some people asked if I already published the LoRaNicator source code. At the moment I don't have a LoRaNicator specific code. There are just two example codes merged together and modified . The RFM95 example code from Adafruit und the display example code from u8g2 lib.
    See Adafruit Tutorial for a transmitter setup.
    If you still want to see my actual code, you can find a snippet here
    That's it!
    For tests with RTC, SD-Card, navigation switch etc, I just used Arduino example codes.
    I'm not a programmer and my source code for AVR microcontrollers was always bad. Now, the SAMD21 is completely new for me and I've to figure out a couple of things and have to RTFM ;-)
  • LCD and a new On/Off Controller
    5Volt-Junkie • 03/08/2019 at 10:28 • 0 comments
    Successfully tested the display. Also ordered a different type of On/Off-controller, which expects a feedback from microcontroller within >10 seconds instead of 2 seconds.
  • First board tests
    5Volt-Junkie • 03/04/2019 at 16:13 • 0 comments
    Started testing the hardware. Need another On/Off-controller since the current model allows only 2 seconds time frame for the feedback from microcontroller and the SAMD21 with Arduino bootloader needs ~2.5 seconds for booting and setting the GPIO to High.
     Following initial tests passed (tested with example codes)
     - RFM95 module
     - I2C RTC (fixed a mistake in routing of I2C. SDA and SCL were swaped :(  )
     - uSD-card
     - LiPo charger
     - programming over USB
    Next steps:
    - order some missing parts (capacitors for the display)
    - test display :-)
  • PCBs arrived :)
    5Volt-Junkie • 02/28/2019 at 16:37 • 0 comments
  • Green light for pcb layout
    5Volt-Junkie • 02/08/2019 at 18:49 • 0 comments
    The schematic is almost done. Just need to add some information to part properties. Now I can start with the PCB design. The dimensions of the board will be about 100x70mm big (3.9x2.76inch).
    I already ordered a couple of components, because I had to create some libraries and it's also a good feeling to having some real components while working on the project :-)
  • Starting with power
    5Volt-Junkie • 01/27/2019 at 21:35 • 0 comments
    Started with the power management today. A couple of month ago, I found a very interesting ic from ST, the SRC0. It's a small on/off controller, which can be connected to a SMPS, so the power supply can be enabled / disabled by a simple press of the push-button. Furthermore it has an input for external signal, to disable the power (e.g. from microcontroller).
    For the SMPS I would like to use the TI TPS63001 buck-boost converter. It provides a fixed +3,3V voltage output @ >1000mA current output (Vin = 2.6 - 4.2 VDC).
    In this voltage range and at ca. 100mA load, the efficiency stays >90%, which is not so bad :)
    For the charging circuit I'll use MCP73831. The circuit will be powered by 1 LiPo cell.
  • Start
    5Volt-Junkie • 01/26/2019 at 23:33 • 0 comments
    After playing around with the first Prototype of LoPSy (LoRa Paging System ;-) ) and the first range test went well, I wanted to start with a new hardware revision.
    The first hardware prototype contained a Nokia display, AI-Thinker Ra-02 433 MHz LoRa module and an ATmega328 µC.
    For the new hardware revision I would like to replace the mentioned components and add few more functions.
    Some requirements:
    • SMPS instead of linear regulator
    • 1-cell LiPo charger IC
    • ATSAMD21 microcontroller (compatibility with Arduino Zero MKR (and Adafruit Feather?))
    • Get rid of the Nokia Display
    • uSD-card
    • tiny pager motor
    • buzzer
    • to be defined...
View all 8 project logs
Davinder Chandhok wrote 12/23/2020 at 12:00 • point
Can I make one just from the included files? I live in Germany, how much do all the components cost?
5Volt-Junkie wrote 04/06/2019 at 15:35 • point
LoRaNicator communicates over LoRa only. There is no WiFi or BLE on board.
