Cell Phone Signal Repeater / Booster / Femtocell
An outside pole mounted aerial picks up RF signals which are then filtered, amplified and re-transmitted through a second inside aerial.
In more remote areas it is often not financially viable for the cell network operator to build extra base stations for a small number of people and their phones/modems etc. Fortunately, this is not the end of the road as we can, in theory, build our own base stations and even create our own cells.
There are currently available two groups of devices that already claim to do this, one of which is reassuringly expensive and the other is just plain illegal! This project aims to democratise the situation enabling cost effective, hackable devices to be built that not only work properly but also conform to the telecoms regulations.
Searching the Interweb, I found very little useful information on how to do this project and so have had to delve into the dark world of RF (Radio Frequency) and try and understand how exactly our cell phones work. Apart from the theory, there are also many practical obstacles such as the extremely small size of components.
Here is a basic diagram of how the device 'should' work:The band pass filters (BPF) only allow the desired frequency ranges to go into the amps and so makes them much more efficient, otherwise they would be trying to amplify all the local radio stations etc. The amps may or may not need to be cascaded and there may or may not need to be other building blocks in the set up.
Fortunately, at the moment at least, there is no complicated coding as the main variable gain amp can be controlled by using 6 digital pins on an Arduino in conjunction with a simple truth table. This will be explained a bit later on when I have actually got it to work (hopefully).
There are 2 'received signal strength indicator' blocks (RSSIs) which send analogue signals to the Arduino telling it how good or bad the signals on the two aerials are. If the external signal is good for some reason, for example if it's just started to rain, then the amp is turned down so as not to send very strong signals to the cell base station or to the phone. Simply turning up the gain to full can have serious side effects such as locking up the phone or, yes, locking up the cell base station, in which case you're in serious trouble!
There is a certain amount of risk in the project in that for one, it may just not work at all or two, that it may be too simplistic. Personally, I prefer option two and I'm fully prepared to go down a completely different route if necessary. If the project fails then as long as I know why it failed then I have learnt something!
In parallel with this 'build my own hardware' option, I am working on using a pre-built system, namely the LimeSDR transceiver. The main problem with this option is that, coming from a place of almost no previous experience of RF, this gadget currently seems incredibly complicated and it could well take several months just to learn how to use it. Undaunted by the challenge, I am inspired by the guys at Lime Microsystems in Guildford, UK ( http://www.limemicro.com/ ) who have been incredibly helpful. The key to success here seems to be to create software models in a system called 'Pothos' which is an excellent learning tool as it explains a lot of stuff really well and outputs a really useful log of what parameters are being changed in real time in the device. Limemicro has also helped me link an Arduino to their LimeSDR via SPI which enables, in theory, an Arduino Due to control the transceiver or at the very least, upload a predetermined set of register values.
Current chances of project success = 75%
Band_20_Repeater_02.ini
Finally I have produced a LimeSuite .ini for the LimeSDR that actually 'seems' to work! Probably needs some fine tuning.
ini - 16.57 kB - 04/18/2017 at 13:08
Download
Simple_806MHz_Bandwidth_30_Repeat_03.ini
Here I attempted to re-transmit received frequencies at centre frequency 806MHz with a bandwidth of 30MHz. (Band 20 base Tx LTE). Although I got a nice Rx spectrum in the LimeSuite FFT, my second SDR rig failed to notice successful transmission :(
ini - 16.57 kB - 04/18/2017 at 09:32
Download
Simple 806MHz repeat 01.pothos
A simple repeater sketch was set up in Pothos and 'Scooped' up in Limesuite and a second SDR was used to prove that it worked.
pothos - 101.45 kB - 04/16/2017 at 18:07
Download
Simple_806MHz_Repeat 01.ini
ini - 16.57 kB - 04/16/2017 at 18:04
Download
pothos - 182.29 kB - 04/16/2017 at 16:29
Download
FM retransmit 04.ini
https://youtu.be/Xh1dsejrtdY
ini - 16.57 kB - 04/16/2017 at 16:24
Download
Another duplexer test, this time with a stronger signal. This scenario showed a better signal to noise ratio with nice clean lines.
Graphics Interchange Format - 7.49 MB - 04/14/2017 at 18:04
Preview Download
USD020A Datasheet.pdf
Band 20 LTE duplexer
Adobe Portable Document Format - 458.22 kB - 04/14/2017 at 15:18
Preview Download
Test MIMO 02.pothos
Testing the MIMO capabilities of the LimeSDR - Channels 1 and 2 simultaneous receive. Revised sample rates and clock speed. Adjusting frequencies on channel B continues to only affect channel A .... FAIL!
pothos - 174.97 kB - 04/10/2017 at 08:51
Download
Test MIMO 01.pothos
pothos - 137.46 kB - 04/09/2017 at 15:27
Download
View all 14 files
  • At last a promising .ini file for the LimeSDR!
    TegwynTwmffat04/18/2017 at 12:41 0 comments
    Thanks to Zack (again!) at Lime Microsystems, I seem to have managed to produce a functioning repeater in full duplex mode. It does not actually help with 4g on my own phone yet as it probably needs some fine tuning.
    Here's the file:
    https://cdn.hackaday.io/files/20500877072000/Band_20_Repeater_01.ini
  • LimeSDR test: Limesuite was used to 'scoop up' settings generated by Pothos
    TegwynTwmffat04/16/2017 at 16:27 0 comments
    I used Pothos to create a block diagram for the LimeSDR that receives a local FM station and re-transmits it 1Mhz higher at very low power.
    Limesuite was then used to 'scoop up' the settings generated by Pothos with the idea of closing Pothos and recreating the whole test using Limesuite alone.
    The whole test worked nicely!
    I then tried a similar thing in the LTE band 20 at 809 MHz, just repeating the whole base station Tx spectrum, using my trusted USD020 duplexers ..... And that worked too! I've been trying to do this for about 5 days, so why does it suddenly work now? I think the answer is that the Limesuite needs to be a 'blank canvas' before trying to scoop from Pothos, otherwise settings 'left over' from previous trials mess things up.
    Files used:
    https://cdn.hackaday.io/files/20500877072000/Simple_806MHz_Repeat 01.ini
    https://cdn.hackaday.io/files/20500877072000/Simple 806MHz repeat 01.pothos
    https://cdn.hackaday.io/files/20500877072000/FM retransmit 04.ini
    https://cdn.hackaday.io/files/20500877072000/FM Re-Transmit 04.pothos
  • Noise and Insertion Loss using Band 20 Duplexer
    TegwynTwmffat04/14/2017 at 15:11 0 comments
    The animation below shows really clearly the noise created and the loss of signal incurred when the CTS USD020 duplexer is used. For comparison, when the duplexer, which is basically a pair of band filters, is used I ramped up the LNA (low noise amplifier) by 4 dB. This is not necessarily bad as the advantages of having a reasonably good band pass filter are enormous.
  • Testing MIMO capabilies of LimeSDR
    TegwynTwmffat04/09/2017 at 15:31 0 comments
    Not sure what's going on here. Adjusting one channel seems to affect the other channel and I wouldn't expect that to happen! If anybody can check this out, the file is in the files section: Testing MIMO 01.pothos.
  • Successful Transmit on FM using LimeSDR and Pothos Software
    TegwynTwmffat04/05/2017 at 17:03 0 comments
    At last I seem to be getting somewhere with the LimeSDR transceiver. Yesterday I started using Pothos to create an FM radio and today I was able to re-transmit one of my local radio stations to another frequency just before my local telecoms regulator discovered what I was doing.
    This is an important step towards producing a proper 4G signal repeater - there's no point in diving in right at the deep end so a simple transmit is a good step forwards.
    The Pothos file for this project is here on this Hackaday page under the 'Files' section.
    Please could someone tell me why I was getting double transmission either side of the selected frequency? This can be seen on the video below:
  • Learning the LimeSDR Tranciever.
    TegwynTwmffat04/04/2017 at 09:32 0 comments
    Whilst waiting for new antenna cables to arrive, I'll be programming this LimeSDR transceiver to pick up an FM radio station as a learning exercise. I did try using this device as a Femtocell but failed due to the incredible complexity of this gadget and my incredible lack of expertise! There are plans afoot to connect the SDR to an Arduino and carry on learning how to use it properly.
  • Some small success
    TegwynTwmffat04/04/2017 at 09:15 0 comments
    At last, I managed to get the 800 MHz frequencies boosted using some cascaded basic power amps and one side of one of the duplex filter:
    Tried to replicate it today but one of the antenna cables failed :(
  • Building and testing microwave duplex band pass filters
    TegwynTwmffat03/25/2017 at 14:45 0 comments
    I decided to try and be a bit more logical in my approach to this project and start building the gadget from the beginning - the band pass filters. Why do we need them? They're to filter out all those FM radio stations etc and provide (hopefully) a nice clean break between the incoming signals and the outgoing ones, which operate on well defined frequency bands eg band 20 base stations transmit on frequencies between 791 and 821 MHz.Our cell phones, if they're actually using band 20, transmit on 832 to 862 MHz and we don't really want each of our amps trying to process both sets of frequencies at the same time .... And certainly not FM radio stations!
    Ok, less of the theory and more of the mechanics. Looking at the actual filter units, the USD020 s from CTS, it looks like they've been attacked by some kind of cyber-kinetic squirrel:
    And looking more closely we can see that they've actually been deliberately gouged out with a precision machine:I contacted CTS, worried that somebody had sabotaged my filters, but they reassured me that this was in fact fine tuning at the manufacturing plant - FANTASTIC!
    So, check, re-check, quadruple check the soldering guide for these beasts and place them on their mini PCBs and into the toaster oven for breakfast:
    The filters are heavy blocks of metals so my thermometer probe is going to lag behind the actual readings by about 30 seconds or so by my estimates. In any case, the maximum temperature was not exceeded and it all working out fine - thank God, as these components are not cheap!
    Now for testing on the LimeSDR:
    I paused the FTT waterfall halfway through and changed the filter connections from Rx to Tx and we can see nice clean separation between the two sets of frequencies - wonderful - those cyber-kinetic squirrels did a really good job! Now to solder up the rest of them and test them as well.
  • Building blocks at the initial stages of the project
    TegwynTwmffat03/21/2017 at 14:03 0 comments
    Here are some boards for putting together a basic 4G femtocell.
    It would be very tempting to try and design and build a PCB with all the desired features from the very beginning and, in an apparent contradiction, there is actually a final design in progress as well. So what I have done is to split the project up into building blocks, mostly on separate PCBs or using PCBs with different blocks on different sides of the board. Confusing? - Yes, I am very possibly confused about what I am doing as it seems that I am trying to do the initial and the final stages simultaneously! There is however some logic to this, as l will try and explain.
    Here below are the building blocks for stage 1 (There are already some more consolidated building block PCBs for stage 2, but I'm trying to ignore them at the moment ):
    The top board has a couple of RF amp circuits and a power supply. The left hand RF circuit has a basic amp with no gain control which can be used in series with the other amp or on it's own. The big difference is that it's easy to solder. The middle circuit is another amp but it has digital variable gain control. I had the chip soldered in by a specialist company so that at the very least I had one possible error eradicated. I will try and solder subsequent boards myself and will use this board as a testing reference to compare and check my own soldering with a multimeter or oscilloscope. The two amp circuits were taken directly from the datasheets for the main component so all the passives (capacitors, inductors and resisters) were given by those sheets.
    The middle board has an enormous band pass filter (BPF) pad on it which is factory tuned for high accuracy. It also has a couple of tiny 'cell phone' BPFs professionally soldered on, just to test the difference between the two options, one being big and expensive and the second being ridiculously small and 1/4 of the price.
    The bottom board, which is actually the reverse of the middle board, has pads for home made filter circuits with one tunable inductor. This circuit is here just to prove to myself that we can't design and build our own BPFs because of the poor tolerances of the available components (mostly +-5%). It might even work!
    The next log will look at another board that is already sitting on my table ready to be soldered up and that has some of the above features combined. Maybe stage 2 will work straight off, but if it doesn't, then I've got stage one as a good fallback. I give stage 1 about 70% chance of success and stage 2 about 50% chance.
    One of the problems with working with PCBs like this is that the turn around time for manufacture is 10 days, including postage from China. For this reason it's good to try and be 10 days ahead of myself. Another problem is that some of the components are very hard to get hold of. The large BPFs are made in China for a USA company who only sell through one UK company so the supply chain takes about 3 weeks to navigate.
View all 9 project logs
  • 1
    License:
    Creative Commons Attribution-ShareAlike 4.0 International Public License
    By exercising the Licensed Rights (defined below), You accept and agree to be bound by the terms and conditions of this Creative Commons Attribution-ShareAlike 4.0 International Public License ("Public License"). To the extent this Public License may be interpreted as a contract, You are granted the Licensed Rights in consideration of Your acceptance of these terms and conditions, and the Licensor grants You such rights in consideration of benefits the Licensor receives from making the Licensed Material available under these terms and conditions.
    Section 1 – Definitions.
    1. Adapted Material means material subject to Copyright and Similar Rights that is derived from or based upon the Licensed Material and in which the Licensed Material is translated, altered, arranged, transformed, or otherwise modified in a manner requiring permission under the Copyright and Similar Rights held by the Licensor. For purposes of this Public License, where the Licensed Material is a musical work, performance, or sound recording, Adapted Material is always produced where the Licensed Material is synched in timed relation with a moving image.
    2. Adapter's License means the license You apply to Your Copyright and Similar Rights in Your contributions to Adapted Material in accordance with the terms and conditions of this Public License.
    3. BY-SA Compatible License means a license listed at creativecommons.org/compatiblelicenses, approved by Creative Commons as essentially the equivalent of this Public License.
    4. Copyright and Similar Rights means copyright and/or similar rights closely related to copyright including, without limitation, performance, broadcast, sound recording, and Sui Generis Database Rights, without regard to how the rights are labeled or categorized. For purposes of this Public License, the rights specified in Section 2(b)(1)-(2) are not Copyright and Similar Rights.
    5. Effective Technological Measures means those measures that, in the absence of proper authority, may not be circumvented under laws fulfilling obligations under Article 11 of the WIPO Copyright Treaty adopted on December 20, 1996, and/or similar international agreements.
    6. Exceptions and Limitations means fair use, fair dealing, and/or any other exception or limitation to Copyright and Similar Rights that applies to Your use of the Licensed Material.
    7. License Elements means the license attributes listed in the name of a Creative Commons Public License. The License Elements of this Public License are Attribution and ShareAlike.
    8. Licensed Material means the artistic or literary work, database, or other material to which the Licensor applied this Public License.
    9. Licensed Rights means the rights granted to You subject to the terms and conditions of this Public License, which are limited to all Copyright and Similar Rights that apply to Your use of the Licensed Material and that the Licensor has authority to license.
    10. Licensor means the individual(s) or entity(ies) granting rights under this Public License.
    11. Share means to provide material to the public by any means or process that requires permission under the Licensed Rights, such as reproduction, public display, public performance, distribution, dissemination, communication, or importation, and to make material available to the public including in ways that members of the public may access the material from a place and at a time individually chosen by them.
    12. Sui Generis Database Rights means rights other than copyright resulting from Directive 96/9/EC of the European Parliament and of the Council of 11 March 1996 on the legal protection of databases, as amended and/or succeeded, as well as other essentially equivalent rights anywhere in the world.
    13. You means the individual or entity exercising the Licensed Rights under this Public License. Your has a corresponding meaning.
    Section 2 – Scope.
    1. License grant.
      1. Subject to the terms and conditions of this Public License, the Licensor hereby grants You a worldwide, royalty-free, non-sublicensable, non-exclusive, irrevocable license to exercise the Licensed Rights in the Licensed Material to:
        1. reproduce and Share the Licensed Material, in whole or in part; and
        2. produce, reproduce, and Share Adapted Material.
      2. Exceptions and Limitations. For the avoidance of doubt, where Exceptions and Limitations apply to Your use, this Public License does not apply, and You do not need to comply with its terms and conditions.
      3. Term. The term of this Public License is specified in Section 6(a).
      4. Media and formats; technical modifications allowed. The Licensor authorizes You to exercise the Licensed Rights in all media and formats whether now known or hereafter created, and to make technical modifications necessary to do so. The Licensor waives and/or agrees not to assert any right or authority to forbid You from making technical modifications necessary to exercise the Licensed Rights, including technical modifications necessary to circumvent Effective Technological Measures. For purposes of this Public License, simply making modifications authorized by this Section 2(a)(4) never produces Adapted Material.
      5. Downstream recipients.
        1. Offer from the Licensor – Licensed Material. Every recipient of the Licensed Material automatically receives an offer from the Licensor to exercise the Licensed Rights under the terms and conditions of this Public License.
        2. Additional offer from the Licensor – Adapted Material. Every recipient of Adapted Material from You automatically receives an offer from the Licensor to exercise the Licensed Rights in the Adapted Material under the conditions of the Adapter’s License You apply.
        3. No downstream restrictions. You may not offer or impose any additional or different terms or conditions on, or apply any Effective Technological Measures to, the Licensed Material if doing so restricts exercise of the Licensed Rights by any recipient of the Licensed Material.
      6. No endorsement. Nothing in this Public License constitutes or may be construed as permission to assert or imply that You are, or that Your use of the Licensed Material is, connected with, or sponsored, endorsed, or granted official status by, the Licensor or others designated to receive attribution as provided in Section 3(a)(1)(A)(i).
    2. Other rights.
      1. Moral rights, such as the right of integrity, are not licensed under this Public License, nor are publicity, privacy, and/or other similar personality rights; however, to the extent possible, the Licensor waives and/or agrees not to assert any such rights held by the Licensor to the limited extent necessary to allow You to exercise the Licensed Rights, but not otherwise.
      2. Patent and trademark rights are not licensed under this Public License.
      3. To the extent possible, the Licensor waives any right to collect royalties from You for the exercise of the Licensed Rights, whether directly or through a collecting society under any voluntary or waivable statutory or compulsory licensing scheme. In all other cases the Licensor expressly reserves any right to collect such royalties.
    Section 3 – License Conditions.
    Your exercise of the Licensed Rights is expressly made subject to the following conditions.
    1. Attribution.
      1. If You Share the Licensed Material (including in modified form), You must:
        1. retain the following if it is supplied by the Licensor with the Licensed Material:
          1. identification of the creator(s) of the Licensed Material and any others designated to receive attribution, in any reasonable manner requested by the Licensor (including by pseudonym if designated);
          2. a copyright notice;
          3. a notice that refers to this Public License;
          4. a notice that refers to the disclaimer of warranties;
          5. a URI or hyperlink to the Licensed Material to the extent reasonably practicable;
        2. indicate if You modified the Licensed Material and retain an indication of any previous modifications; and
        3. indicate the Licensed Material is licensed under this Public License, and include the text of, or the URI or hyperlink to, this Public License.
      2. You may satisfy the conditions in Section 3(a)(1) in any reasonable manner based on the medium, means, and context in which You Share the Licensed Material. For example, it may be reasonable to satisfy the conditions by providing a URI or hyperlink to a resource that includes the required information.
      3. If requested by the Licensor, You must remove any of the information required by Section 3(a)(1)(A) to the extent reasonably practicable.
    2. ShareAlike. In addition to the conditions in Section 3(a), if You Share Adapted Material You produce, the following conditions also apply.
      1. The Adapter’s License You apply must be a Creative Commons license with the same License Elements, this version or later, or a BY-SA Compatible License.
      2. You must include the text of, or the URI or hyperlink to, the Adapter's License You apply. You may satisfy this condition in any reasonable manner based on the medium, means, and context in which You Share Adapted Material.
      3. You may not offer or impose any additional or different terms or conditions on, or apply any Effective Technological Measures to, Adapted Material that restrict exercise of the rights granted under the Adapter's License You apply.
    Section 4 – Sui Generis Database Rights.
    Where the Licensed Rights include Sui Generis Database Rights that apply to Your use of the Licensed Material:
    1. for the avoidance of doubt, Section 2(a)(1) grants You the right to extract, reuse, reproduce, and Share all or a substantial portion of the contents of the database;
    2. if You include all or a substantial portion of the database contents in a database in which You have Sui Generis Database Rights, then the database in which You have Sui Generis Database Rights (but not its individual contents) is Adapted Material, including for purposes of Section 3(b); and
    3. You must comply with the conditions in Section 3(a) if You Share all or a substantial portion of the contents of the database.
    For the avoidance of doubt, this Section 4 supplements and does not replace Your obligations under this Public License where the Licensed Rights include other Copyright and Similar Rights.
    Section 5 – Disclaimer of Warranties and Limitation of Liability.
    1. Unless otherwise separately undertaken by the Licensor, to the extent possible, the Licensor offers the Licensed Material as-is and as-available, and makes no representations or warranties of any kind concerning the Licensed Material, whether express, implied, statutory, or other. This includes, without limitation, warranties of title, merchantability, fitness for a particular purpose, non-infringement, absence of latent or other defects, accuracy, or the presence or absence of errors, whether or not known or discoverable. Where disclaimers of warranties are not allowed in full or in part, this disclaimer may not apply to You.
    2. To the extent possible, in no event will the Licensor be liable to You on any legal theory (including, without limitation, negligence) or otherwise for any direct, special, indirect, incidental, consequential, punitive, exemplary, or other losses, costs, expenses, or damages arising out of this Public License or use of the Licensed Material, even if the Licensor has been advised of the possibility of such losses, costs, expenses, or damages. Where a limitation of liability is not allowed in full or in part, this limitation may not apply to You.
    1. The disclaimer of warranties and limitation of liability provided above shall be interpreted in a manner that, to the extent possible, most closely approximates an absolute disclaimer and waiver of all liability.
    Section 6 – Term and Termination.
    1. This Public License applies for the term of the Copyright and Similar Rights licensed here. However, if You fail to comply with this Public License, then Your rights under this Public License terminate automatically.
    2. Where Your right to use the Licensed Material has terminated under Section 6(a), it reinstates:
      1. automatically as of the date the violation is cured, provided it is cured within 30 days of Your discovery of the violation; or
      2. upon express reinstatement by the Licensor.
      For the avoidance of doubt, this Section 6(b) does not affect any right the Licensor may have to seek remedies for Your violations of this Public License.
    3. For the avoidance of doubt, the Licensor may also offer the Licensed Material under separate terms or conditions or stop distributing the Licensed Material at any time; however, doing so will not terminate this Public License.
    4. Sections 1, 5, 6, 7, and 8 survive termination of this Public License.
    Section 7 – Other Terms and Conditions.
    1. The Licensor shall not be bound by any additional or different terms or conditions communicated by You unless expressly agreed.
    2. Any arrangements, understandings, or agreements regarding the Licensed Material not stated herein are separate from and independent of the terms and conditions of this Public License.
    Section 8 – Interpretation.
    1. For the avoidance of doubt, this Public License does not, and shall not be interpreted to, reduce, limit, restrict, or impose conditions on any use of the Licensed Material that could lawfully be made without permission under this Public License.
    2. To the extent possible, if any provision of this Public License is deemed unenforceable, it shall be automatically reformed to the minimum extent necessary to make it enforceable. If the provision cannot be reformed, it shall be severed from this Public License without affecting the enforceability of the remaining terms and conditions.
    3. No term or condition of this Public License will be waived and no failure to comply consented to unless expressly agreed to by the Licensor.
    4. Nothing in this Public License constitutes or may be interpreted as a limitation upon, or waiver of, any privileges and immunities that apply to the Licensor or You, including from the legal processes of any jurisdiction or authority.
View all instructions
TegwynTwmffat wrote 04/14/2017 at 15:30 point
If you take the phone outside it will try to receive from the base station and will also try and receive from the antenna inside the building. If the system is working properly it should be able to do this simultaneously, I think.
Receiving from base station and from the inside antenna is all done on the same frequency.
Transmitting from the phone and from the inside antenna is done on another close-by frequency and a good quality duplexer will provide a very sharp separation between the two frequencies mentioned above (Rx and Tx).
This answer above is slightly simplified because the 2 frequencies mentioned are actually located in a vast bundle of frequencies that constitute the LTE band itself.
hTo137 wrote 04/12/2017 at 02:45 point
I had to research what a duplexer really is.... The essence is that it allows Rx/Tx with one antenna. Probably obvious to most but it's something I didn't know.
Since the inside-the-dwelling band is different than the outside-the-dwelling band what happens if you take the phone outside? Will it talk to the cell tower or try to talk to the outside antenna? Or try to talk to the inside antenna?
