NodeUSB- ‘Eat your own dog food’ WiFi IoT DevKit
NodeUSB is a tiny, low cost $9, WiFi ready, ESP8266 USB dev kit for Internet of things, it comes with NodeMCU pre-installed
NodeUSB is a ‘eat your own dog food’ DevKit for IoT.
NodeUSB is low cost, WiFi ready, based on ESP8266 SoC and NodeMCU.
Quick dev boards on the market is good, but you can not make product your friends can use everyday. All the thousands of cool things you can do on Arduino are just experiment.
Features:
- You can plug NodeUSB into any USB power adapter, you can ready to go!
- Open source Software. NodeMCU.
- Add sensors by just plug in USB boards.
- Low cost
Super easy to connect many sensors, just plug to USB female of NodeUSB, then ready to go.
Tested sensors:
- bmp180, bmp085
- DHT11, DHT22,
- ds18b20,
- si7021 (Humidity),
- 433m
- UltraSound
- 5V relay
Just received first shipments of prototypes today. Looks good.
We are in kickStarter now:
https://www.kickstarter.com/projects/786298545/nodeusb-tinylow-costeat-your-own-dog-food-devkit-f
  • Solar powered WiFi weather station
    Michael Wen05/14/2015 at 03:21 0 comments
    Found a great spot for Solar powered WiFi weather station:
    My deck, it will block the rain, block the sun, and easy to mount solar panel
    Pictures:
    The battery with charging PCB is still naked, I am waiting for the PCB shipment so I can make the Battery Node. Stay tuned.
    This is another one in front of my house, it is facing south, so lots of sun shine, 2 sensors will give me both the temperature under the sun or not.
  • WiFi weather station
    Michael Wen05/10/2015 at 23:49 0 comments
      Steps to make a WiFi weather station:
      1. soldering 90 degree 2.54mm headers onto NodeUSB
      2. Soldering si7021 module on 2.54mm header
      3. If you want to add barometer, Use quick connect wire to add bp180 module
      4. put into case closures
      5. put in USB power adapter
      Here are the pictures:
  • Touch Node Video
    Michael Wen04/22/2015 at 22:37 0 comments
    Touch node video!
  • Universal PCB for modules. (Arduino, etc )
    Michael Wen04/21/2015 at 01:15 0 comments
    PCB have 8 headers (4 pins, 2.54mm). (With 6 different combinations )
    So you connect different I2C modules (with different pin-outs) in just one Node. For example, you can use it to add both si7021 and bmp180 in your project. Sounds cool?
    Also USB male and female pass-through, you can create Nodes Chain with several nodes!
  • Use with Solar Panel and Battery
    Michael Wen04/20/2015 at 05:26 0 comments
  • Connect Different sensors using USB
    Michael Wen04/09/2015 at 17:59 0 comments
    Different connectors
    Connect hall sensor:
    Connect Relay:
    Connect Soil humidity sensor:
    Touch Sensor:
    ds3231 RTC:
    HMC5883L
    Light Sensor
    OLED display module:
    CO sensor
    LED module
    PIR Sensor
    LED light
    Ultrasound range sensor
    si7021 temperature and humidity sensor
    BMP018, BMP085 barometer and temperature sensor
    ds18b20
    DHT22 sensor
    433mHz receiver and transmitter
    Use solar battery to power NodeUSB and bmp018 sensor
  • Few NodeUSB sensors
    Michael Wen04/02/2015 at 15:11 0 comments
    NodeUSB plug in USB power adapter:
    Use NodeUSB to control 433mHz power switch:
    UltraSound range sensor:
View all 7 project logs
