F-CPU
The Freedom CPU project has a log here too now :-)
Today, the Freedom CPU Project's goal is to create and distribute the source code of a microprocessor core under a copyleft license: all the VHDL sources, resources and most tools are Free as in Free Speech. When it was created in 1999, the F-CPU Core #0 (FC0) was the first purely SIMD superpipelined RISC CPU core that could handle 64-bit data and wider.
After the F-CPU project's freeze in 2004 and some explorations of embedded designs, the tools developed for yasep.org are considered for a reboot of this project, with an updated framework, a better roadmap and new direction.
The instruction set architecture and the microarchitecture will be refined and should provide a nice Application Processor (32 and 64 bits versions) and an Offload Processor (wide SIMD, 64 bits and much more, for sound, graphics, physics etc.).
For a good overview from "back then" (in French) : http://frog.isima.fr/copyleft/yann/index.html
Look at all the (still working) links and local copies !
F-CPU has now evolved and the new "cluster of globules" version is described here.
Logs:
1. Overview of the FC1 (F-cpu Core #1)
2. Operating System and Security
3. Instruction packing
4. Pairing and memory read/write
5. Register-Mapped Memory
6. Check-in, Check-out
7. Inter-globule communication
8. Decoupled Globules
9. What can you do with 64 bits wide pointers ?
10. Multicast memory regions
11. Celebration
12. F-CPU as a decent vector processor
13. FC1 : the memo
  • FC1 : the memo
    Yann Guidon / YGDES12/26/2020 at 00:46 0 comments
    Here is a summary of the design so far.
    FC1 or F-CPU core #1 is the successor of FC0 which was designed more than 20 years ago. You can have a look at the original F-CPU manual for an overview of the original concept and history. FC1 is a more mature version that drops the ideas that failed and introduces new ones, the FC1 instruction set is inspired but incompatible with FC0.
    So many features have changed/evolved but the founding spirit remains: make a decent application processor with a fresh RISC architecture, avoid complex out-of-order circuits and instead redesign the instruction set around the problems that OOO tries to solve in HW.
    FC1 is a 4-ways superscalar processor from the ground up. FC0 would require re-engineering to go superscalar and instead counted on its superpipeline (very short pipeline stages, or "the carpaccio approach") to reach high speed and throughput. The cost was more complexity, longer pipeline stages and maybe lower single-thread performance (reminiscent of the "plague of the P4"). The Low FO4 can quickly hit a logic wall and the intended granularity might have been overly optimistic.
    Instead the FC1 is designed as superscalar with very fewer pipeline stages, which is easier to convert to 2-ways or 1-way issue, than the reverse. Code that is correctly compiled and scheduled will run equally well on the 3 possible implementations, though 4-ways is the most natural choice. 2 and 1 way would be interesting for gates-limited versions, such as FPGA.
    Just like FC0, FC1 is an in-order processor that uses a scoreboard to stall the instructions at the decode stage if hazards are detected. To some, this is ugly and unthinkable in 2020 but the "lean philosophy" attempts to avoid feature creep that will add a considerable burden later.
    Instead, the instruction set and architecture are designed to reduce the effects and causes of decode stalls. Precise exceptions, mostly from memory reference faults, are possible by splitting the classic "LOAD" or "STORE" instructions in 2:
    • compute the address, TLB lookup and tag the corresponding address register
    • access the data and use it as operand for another operation
    The access instructions are the one to trap, once the address is known, but only if the address is referenced. This is possible by flagging the corresponding register as "invalid access" for example. This also enables prefetch, to shadow some of the latency from memory.
    By the way, FC1 uses explicitly dedicated Address registers and Data registers. This reduces the complexity and overhead caused by FC0's more flexible and general approach, since now only 16 register addresses have to be flagged "invalid/ready" instead of 63.
    Just like FC0, FC1 uses 64 registers though as explained above, the register set is not homogeneous, but split into 3 main functions. Just like the #YASEP and the #YGREC8, FC1 uses register-mapped memory:
    • 32 "normal" registers (R0 to R31, and R0 is not hardwired to 0)
    • A0 to A15 hold data addresses
    • D0 to D15 are "windows" to the memory pointed by the respective address register (they can be thought as a port to the L0 memory buffers)
    This is a LOT of ports to memory and the question of the relevance is legitimate (particularly since it creates a LOT of aliasing problems) but we'll see later that it also creates interesting opportunities.
    If Data/Address pairs can be paired, that makes 8 blocks of dual-port L1 cache memory, a particularly high bandwidth is expected and it should be matched with eventual L2 cache and main memory bandwidth, but this is something that is not directly inside the scope of the design. Let's just say that it's less constrained than most existing designs.
    An even more radical aspect of FC1 is that the pipelines are "loosely coupled", and in fact quite decoupled. Each of the 4 pipelines has its own 2R1W register set with 16 addressable registers (8×R, 4×D, 4×A) to keep speed as high as possible. Gone is the humongous register...
  • F-CPU as a decent vector processor
    Yann Guidon / YGDES12/22/2020 at 03:15 5 comments
    Re-inventing-the-wheel-warning ! But in the middle of the decades-old tricks, some new ones could prove fruitful.
    To celebrate the 22nd anniversary of the project, I bring a new life and perspective to vector processing, which fully exploits the superscalar architecture that has evolved these last years.
    To be fair, parts of these considerations are inspired by another similar project : https://libre-soc.org/ is currently trying to tape-out a RISC processor capable of GPU functions, with a CDC-inspired OOO core that executes POWER instructions. Not only that, the project is also trying to add vector computation to the POWER ISA, and this is now completely weird. See https://libre-soc.org/openpower/sv/vector_ops/
    My personal opinion about POWER may bias my judgement but here it is : despite the insane amount of engineering that has been invested in it, it's overly complex and I still can't wrap my head around it, even 25 years after getting a book about it.
    However some of the discussions have tickled me.
    There is one architectural parameter that defines the capacity and performance of vector computers : the number and length of the vector registers. Some years ago, I evaluated a F-CPU coprocessor that contains a large number of scalar registers (probably 256 or 1024) that could then be processed, eventually in parallel if "suitable hardware" is designed, and for now, Libre-SoC considers 128, eventually 256 scalar registers that can be processed in a vector-like way.
    But this number is a hard limit, it defines and cripples the architecture, and as we have seen in the scientific HPC industry, the practical vector sizes have grown and completely exceeded the 8×64 numbers (4Ki bytes) of the original Cray-1. For example the NEC SX-6 (used for the Earth Simulator) uses a collection of single-chip supercomputer with 72 registers of 256 numbers (147456 bytes) and that was 20 years ago. That is way beyond the 1K bytes considered by Libre-SoC which will barely allow to mask main memory's latency. Furthermore, because of the increased number of ports, the vector register set will be less dense and will draw more power than standard cache SRAM for example.
    Clearly, setting a hard limit for the vector size and capacity is a sure way to create problems later. Scalability is critical and some implementation will favour a smaller and cheaper implementation that makes compromises for performance, while other will want to push all the buttons in the quest for performance.
    And you know what is scalable and configured at will by designers ? Cache SRAM. It totally makes sense to use the Data L1 cache (and other levels) to emulate vectors. User code that relies on cache is totally portable (and if adaptive code is not used, the worst that can happen is thrashing the cache) and memory lines are already pretty wide (256 or 512 bits at once) which opens the floodgates for wide SIMD processing as well (you can consider 4 or 8 parallel computational pipelines already). This would consume less power, be denser and more scalable than using dedicated registers. In fact, one of the Patterson & Hennessy books writes:
    In 1986, IBM introduced the System/370 vector architecture and its first
    implementation in the 3090 Vector Facility. The architecture extends the
    System/370 architecture with 171 vector instructions. The 3090/VF is
    integrated into the 3090 CPU. Unlike most other vector machines, the
    3090/VF routes its vectors through the cache.
    That is not exactly what I have in mind but it shows that the idea has been floating around for such a long time that the first patents have long expired.
    Cache SRAM have enough burst bandwidth to emulate a huge vector register but this is far from being enough to make a half-decent vector processor. The type of CPU/GPU hybrid I consider is rather used for accelerating graphics primitives, not for large matrix maths (which is the golden standard for HPC, and I don't care about LINPACK ratings)...
  • Celebration
    Yann Guidon / YGDES12/22/2018 at 20:23 0 comments
    https://news.slashdot.org/story/98/09/08/1646240/the-f-cpu-project-the-freedom-cpu-project
    20 years ago, I shyly joined a crazy pipedream vaporware project, which I found on Slashdot. Since then, it's been a constant adventure.
    I have learned a LOT. I have met a LOT of people. I have gotten a LOT of knowledge and understanding and this project has shaped a lot of my day-to-day life, you couldn't imagine. And it's not going to end. My presence on HAD is fueled  by the need to innovate, create, build, design, and break ALL the ground that was needed for FC0. We didn't have the right people, the right tools, the right structure. I do all my best to at least create the environment that will make F-CPU a reality, even if I have to scale things down to the extreme (see #YGREC8 ) before going back to the full-scale SIMD.
    There is no way I could build everything alone and no way I could tapeout FC1 either alone or with the original structure. I have grown a bit wiser and I try to surround myself with the BEST people. I have found many here on HAD (if you read this, you might be one of them).
    The motto will always remain :
    « There can be no Free Software without Free HardWare Designs »
    and such a chip is long overdue.
    There is so much to do and there is certainly something you can do.
  • Multicast memory regions
    Yann Guidon / YGDES12/01/2018 at 12:27 0 comments
    As already stated, F-CPU enforces a strong separation between the data and instruction memory spaces. This is a central requirement because this processor will run user-provided (or worse: 3rd party) code and security must not be an afterthought.
    Another security measure is to ensure that each data block can be accessed by only one thread. Zero-copy information sharing happens when one thread "yields" a block to another thread, as a payload of a message for example. At that point, the original owner loses ownership and rights to that block, that must be previously allocated from a dynamic pool. This ensures (ideally) that no information is leaked (as long as the allocator clears the blocks after use).
    There are also "hard" semaphores in the Special Registers space, with a scratch area where appropriate read and write rights allow deadlock-free operation.
    But there are still cases where this is not enough and zero-copy operation is impossible or too cumbersome. In a few cases, the overhead of yielding a block is too high and we would like one thread to be able to write to a buffer while other threads can read it. Without this feature, the system is forced to clump data into a message packet, which adds latency. This is multiplied by the number of interested recipients but the added cost would not be justified if this specific update is not required at the moment. It would be faster and lighter to read some word here and there from time to time.
    This desired "multicast" feature is reminiscent of a system that must be somehow implemented : ONE thread is allowed to write to the instruction space, to load programs, and this space may be shared by several threads. However, all the other threads can't access the program space, and shared constants (read-only values) must exist in the data addressing space, a multicast system is required anyway.
  • What can you do with 64 bits wide pointers ?
    Yann Guidon / YGDES12/01/2018 at 10:47 0 comments
    When looking at (almost?) all the 64 bits CPUs out there, you see that the MSB of addresses are not really used. 48 bits give you 256 terabytes, which is about the RAM installed into a HPC rack these days. But so much space can't be really used conveniently because access times prevent efficient access across a rack or a datacenter. Message passing often takes over when communication is required across compute nodes or blades.
    So we're left with these dangling bits... The addresses are usually "virtual" and require translation to physical space. But you know I hate wasted resources, right ? So I want to use the MSB as an "address space ID" and store some meta-information such as process number. It's easy to check if this address is valid so it adds some sort of protection while allowing the whole addressable space to be linearised.
    Of course there is the question of "how many bits should be allocated" because there is always a case that will bump into fixed limitations. The solution is to make a flexible system with not just an ID to compare, but also a bitmask (this is used nowadays for comparing addresses in chipsets, for example). The OS will allocate as many bits as required by the workload, either 56 address bits for 256 tasks, or 40 bits for 16M tasks, or any desired mix (think : unbalanced binary tree)...
  • Decoupled Globules
    Yann Guidon / YGDES11/30/2018 at 14:37 0 comments
    One design goal of the F-CPU is to increase efficiency with smart architecture features, and with the FC1 I would like to get closer to OOO performance with in-order cores.
    You can only go so far with all the techniques already deployed and explored before : superscalar, superpipeline, register-mapped memory, ultra-short branch latency... Modern OOO processors go beyond that and can execute tens or hundreds of instructions while still completing old ones.
    FC1 can't get that far but can at least go a bit in this direction. Typically, the big reordering window is required for 1) compensate for false branches 2) wait for external memory.
    1) is already "taken care of" with by the design rule of having the shortest pipeline possible. A few cycles here and there won't kill the CPU and the repeated branches have almost no cost because branch targets are flagged.
    2) is a different beast : external memory can be SLOW. Like, very slow. Prefetch (like branch target buffering) helps a bit, but only so much...
    So here is the fun part : why wait for the slow memory and block all the core ?
    Prefetch is good and it is possible to know when data are ready, but let's go further: don't be afraid anymore to stall a pipeline... because we have 3 others that work in parallel :-)
    I was wondering earlier about "microthreads", how one could execute several threads of code simultaneously, without SMT, to emulate OOO. I had seen related experimental works in the last decade(s) but they seemed too exotic. And I want to avoid the complexity of OOO.
    The method I explore now is to "decouple" the globules. Imagine that each globule has a FIFO of instructions, so they could proceed while one globule is stalled. Synchronisation is kept simple with
    • access to SR
    • jumps (?)
    • writes to other globules
    The last item is the interesting one : the last log moved the inter-globule communication from the read to the write part of the pipeline. The decoder can know in advance when data must cross a globule boundary and block the recipient(s). This works more or less as implied semaphores, with a simple scoreboard (or just four 4-bits fields to be compared, one blocking register per globule).
    I should sketch all that...
    Note:
    I vaguely remember that in the late 80s, one of the many RISC experimental contenders was a superscalar 2-issues pipeline where one pipeline would process integer operations and the other would just do memory read/writes. They could work independently under some constraints. I found it odd and I have never seen it mentioned since, so the name now escapes me...
    Addendum :
    Decoupling the globules creates a new problem and goes against one of the golden rules of F-CPU scheduling : don't "emit" an instruction that could trap in the middle of the pipeline. It creates so many problems and requires even more bookkeeping...
    Invalid memory accesses could simply silently fail and raise a flag (or something). A memory barrier instruction does the trick as well (à la Alpha).
    Anyway, decoupling is a whole can of worm and would appear in FC1.5 (maybe).
  • Inter-globule communication
    Yann Guidon / YGDES11/22/2018 at 01:42 0 comments
    So far, the 2R1W opcodes have 1 full destination field (6 bits) that determines the globule number, one partial source register address within the same globule, and one full register address that can read from any other globule. It's quite efficient on paper but the corresponding circuit is not as straight-forward as I'd like.
    Decoding the full source field creates significant delays because all the source globules must be checked for conflict, the 4 addresses must be routed/crossbarred, oh and the globules need 3-read register sets.
    Inter-globule communication will be pretty intense and will determine the overall performance/efficiency of the architecture... it is critical to get it right. And then, I remember one of the lessons learned with the #YASEP Yet Another Small Embedded Processor  : You can play with the destination address because you have time to process it while the value is being decoded, fetched and computed.
    OTOH the source registers must be directly read. Any time spent tweaking it will delay the appearance of the result and increase the cost of branches, among others. So I evaluate a new organisation :
    • one full (6 bits) source register address, that determines the globule
    • one partial (4 bits) source register address, in the same globule as above
    • one full destination address register that might be in a different globule.
    This way, during the fetch and execute cycles, there is ample time to gather the 4 destination globule numbers and prepare a crossbar, eventually detect write after write conflicts, route the results to the appropriate globules...
    The partial address field is a significant win when compared to FC0, there are 16 address bits compared to 18 in the 2000-era design. This means more space for opcodes or options in the instruction word. And moving the complexity to the write stage also reduces the size of the register sets, that now have only 2 read ports !
    But communication will not be as flexible as before...
    I have considered a few compromises. For example, having shared registers that are visible across globules. It would create more problems than it solves : it effectively reduces the number of real registers and makes allocation harder, among other things that could go wrong. Forget it.
    Or maybe we can use more bits in the destination register. The basic idea is to use 1 bit per destination globule and we get a bitfield. The destination address has 4 bits to select the destination globule, and 4 bits for the destination register in the globule. The result could be written to 4 globules at once !
    Decoding and detecting the hazards would be very easy, by working with 4 decoded bits directly. The control logic is almost straight-forward.
    However this wastes all the savings in precious opcode bits and many codes would not be used or make sense.
    A globule field with 3 bits would be a good compromise, and the most usual codes would be expanded before going to the hazard detection logic :
    000  G0
    001  G1
    010  G2
    011  G3
    100  Gx, Gx+1
    101  Gx, Gx+2
    110  Gx, Gx+3
    111  G0, G1, G2, G3 (broadcast)
     The MSB selects between unicast and multicast. One instruction can write to one, two or four globules at once. The last option would be very efficient for 4-issue wide pipelines, and take more cycles for smaller versions.
    x is the local globule, determined by the source's full address. Some wire swappings and we get the proper codes for every decode slot simultaneously...
    Moving data to a different globule would still have one cycle of penalty (because transmission is slow across the chip) but this is overall much better than delaying the whole code when one source must be fetched in another globule. Furthermore, broadcast uses fewer instructions.
    It is less convenient than reading from a different globule, because moves must be anticipated. This is just a different way to read/scan/analyse/partition the dataflow graph of the program... More effort for the compiler but less complexity for the whole processor....
  • Check-in, Check-out
    Yann Guidon / YGDES03/07/2018 at 08:22 0 comments
    I think I'm closer to the solution of the old old problem of copy-less data transmission between threads or processes.
    Already, switching from one process to another is almost as easy as a Call/Return within a given process. The procedure uses 3 dedicated opcodes : IPC, IPE and IPR (InterProcess Call/Enter/Return). The real problem is how to transfer more data than what the register set can hold.
    My new solution is to "mark" certain address registers to yield the ownership of the pointer to the called process.
    • The caller saves all the required registers on its stack and "yields" one or more pointers with a sort of "check-out" instruction that sets the Read and Write bits, as well as changes the PID (ownership of the block) OR puts the block in a sort of "Limbo" state (still owned but some transfer of ownership is happening, in case the block is not used by the recipient and needs to be reused).
    • The called process "accepts" the pointer(s) with a "check-in" instruction so the blocks can be accessed within the new context and mapped to the new process' addressing range.
    This creates quite a lot of new sub-problems but I believe it is promising.
    • How do you define a block ? It's basically 1)  a base pointer 2) a length 3) access rights 4) owner's PID. All of these must have some sort of HW support, merged with the paging system.
      The sizes would probably be powers-of-two, so a small number easily describes it, and binary masks checks the pointer's validity.
    • Transferable blocks must come from a global "pool" located in an addressing region that is identical for everybody because we don't want to bother with translating the addresses.
    • IF there is a global pool then one process must be responsible for handling the allocation and freeing of those blocks.
    This affects the paging system in many ways so this will be the next thing to study...
  • Register-Mapped Memory
    Yann Guidon / YGDES02/22/2018 at 04:41 0 comments
    I just had this little "hah!" moment...
    I keep thinking about how to make FC1 much more badass. While writing one of the latest logs of #PDP - Processor Design Principles  I realised I could/should have more than one data register per address register.
    For example, 4 address registers are linked to one data register, and 4 other address registers are linked to 4 data registers each. Advantages include :
    • much faster and lighter call/return (it would emulate register windows sans their drawbacks)
    • faster register save and backup
    • better memory bandwidth
    • solves loop unrolling
    • fewer aliasing problems ?
    • easier unaligned access in one cycle (by combining 2 pipelines for a 2R2W instruction)
    • reduces the number of address registers and pointer update instructions
    It looks like a weird mix between Itanium, SPARC and TMS9900... I have to ponder more about it but the overwhelming benefits are enticing.
    I also have to find a proper behaviour for pointer aliases, should they trap ?
  • Pairing and memory read/write
    Yann Guidon / YGDES04/09/2017 at 08:38 0 comments
    The register-mapped memory system, pioneered by Seymour Cray in the CDC6600, has many benefits and I developed it in my own way in the #YASEP
    I used a different approach however, where the data register both reads and writes. The CDC had data 5 registers for reading and 2 for writing, with different code sequences.
    For the YASEP, my approach makes perfect sense because the core uses onchip memory with single-cycle latency. You set the address register and by the next cycle, the data is read, whether you need it or not. Same for the #YGREC where the access time is "relatively immediate".
    The F-CPU is a different beast though. We expect multi-level memory and going off-chip is a definitive performance killer. There must be a way to determine if a memory access is for reading or writing.
    The CDC6600 version, with registers that are dedicated to functions, is not possible : there are already 16 registers, 1/4 of the total, and there is no room left, either in the register set or the opcodes (each bit is precious !)
    The semantics of the address/data registers is to access the memory contents directly, through a buffer like a cache line, for example. Loading the cache line is the costly part.
    How do I tell the CPU to load the cache line ? Simply by using/reading the data register. But doing this will stall the core if the cache line is not ready... This totally defeats the purpose of the system, where the memory's latency is hidden by explicit scheduling of the instructions: you calculate the address, schedule some instructions while waiting for the data to arrive, then read the register.
    The costly part is the reading and it's too unpredictible : the data could be in the cache, in the local DRAM, on another CPU, or swapped out... So let's think in reverse and consider the write operation : the sequence goes like
    1. write the destination address to the address register
    2. write the data to the data register
    The point of this log is to make a sort of atomic pair that the decoder can easily detect : the destination register must be the same (modulo one inverted bit) in two consecutive instructions (or closely enough, if the core can afford the comparators) to indicate that it's a write and the memory system shouldn't fetch the line right now.
    There are a couple of things to notice :
    1. the address register of one port must be located in the "mirror" globule of the data register so the two instructions (set address, write data) can be "emitted" at the same time (and only one comparator is required, no comparison across pairs and simpler decoder)
    2. the SIMD globules need their own data ports but the address must remain in the scalar globules. I should change the register map... but now each of the 4 globules has their own dedicated memory block, with a matching data size !
    And now, due to the pairing rules, it seems obvious that all the address registers must reside in the first globule, or else the pairing rules must be more complex, but this creates an imbalance in the register allocation...
    Honestly I dislike the new asymmetrical design because it makes the architecture less orthogonal and potentially less efficient to code for. Architecturally, you only had to design one globule (or two if you want SIMD) and there you go, copy-paste-mirror-connect and you're done.
    But let's look at the new partition :
    1. First globule is specialised for addresses, has A0-A7, and its dedicated memory block accessed with D0 & D1. Since you write all the addresses there, the TLB is directly connected to its ALU's output. Aliasing is directly managed there. The 6 remaining registers can be used to store some pointers, frame base, indices and increments, as well as supplement the standard computations.
    2. Second globule has only 2 data registers, to access the dedicated cache. 14 working registers can do some meaningful work. No TLB here, it can be "replaced" by a barrel shifter/multiplier array/division unit
    3. The 3rd globule has 2 data registers, accessing the wider (but shallower) cache...
View all 13 project logs
Yann Guidon / YGDES wrote 12/24/2018 at 23:59 point
Note for later...
The "LSB" flag (parity) should be complemented by a8, a16, a32 and a64 to check pointer alignment... it's just a NOR of the 1/2/3/4 LSB (respectively)
Julian wrote 08/25/2018 at 22:34 point
Wow.  I remember this project from back in the day. I always thought you guys were crazy with your 6 gates per pipeline stage rule. I presume you've relaxed that a little for this version? :)
Yann Guidon / YGDES wrote 08/25/2018 at 22:50 point
hi Julian :-)
crazy, but not that much, when you consider today's hyperpipelines, some CPUs have 20 stages easily...
Anyway it's a strong design guide, because P&R will always find ways to break the rules.
I have also evolved and enhanced many aspects of my design rules. I'm more experienced and have come up with more and better rules.
Still, FC0 was not /that/ crazy. We were just a bit too young and poor :-P
Right now I polish all my skills on the #YGREC8 which inspires many things for FC1.
Yann Guidon / YGDES wrote 06/02/2018 at 10:21 point
Bienvenue @hlide !
hlide wrote 06/01/2018 at 08:14 point
Ca tombe bien, j'ai un MiSTer (basé sur Terrassic DE10-nano). Je me disais où je pouvais trouver les sources de F-CPU64 pour faire joujou avec (plus dans une version 16 et 32). Un coup de pouce ?
f4hdk wrote 06/01/2018 at 17:29 point
Oh, the F-CPU is not dead!!!
Does someone know where is the source code of the F-CPU?
Has someone made a full implementation of it on a FPGA board?
@hlide : have you begun your CPU project?
hlide wrote 06/02/2018 at 09:05 point
Hi f4hdk!
My CPU project? which one? I'm mainly collecting some "ordinosaures" (SHARP MZ series) coupled with Arduinos and acquired a MiSTer (Terassic DE10-nano) to start some FPGA coding. I may try to integrate a F-CPU core on MiSTer if I could have the most recent and working source of it.
f4hdk wrote 06/02/2018 at 11:15 point
@hlide  : You had a CPU project in january 2017, when we exchanged by e-mail together. A strange CPU with 2 instruction set, and FIFOs instead of registers. You had bought 2 FPGA cards especially for your project.
@Yann Guidon / YGDES : I'm sure you still have the source code (Verilog or VHDL) of the F-CPU. Could you please share it with us? I'm interested too.
hlide wrote 06/02/2018 at 11:57 point
Oh I see. Well, I have now 4 FPGA: the first 3 FPGA are based on Xillinx and are so badly documented with no interesting examples so they are mostly parked. The last one is MiSTer (Terrassic DE10-nano) with full examples (Arcarde and Retrocomputer cores) that are more helpful. So I guess I could retry that old project but it is not the one I would prioritized now.
Yann Guidon / YGDES wrote 06/02/2018 at 11:59 point
@f4hdk see my comment below -_-
f4hdk wrote 06/02/2018 at 14:45 point
@Yann Guidon / YGDES : This was not my question. I know that no version of F-CPU has been finished. But my question remains : could you please provide the sources of F-CPU, as is, even if it is not finished?
The F-CPU project was supposed to be open source.
Yann Guidon / YGDES wrote 06/02/2018 at 16:36 point
@f4hdk I'll see if I can find old files... Though I have to remind you that the latest developments were 15 years ago. I forget if I have put anything relevant on f-cpu.org during the reboot.
hlide wrote 06/02/2018 at 10:07 point
Et par F-CPU64, je pensais bien sûr au core #0, pas le core #1 qui doit être qu'en état d'étude. Le truc, c'est que j'ai perdu les sources depuis des années et que maintenant, c'est chaud pour retrouver ça - vu qu'il n'y avait pas GitHub à l'époque.
FC0 n'a jamais pu être avancé suffisamment, on avait des morceaux de code et rien qui tienne ensemble, puisque ça partait dans tous les sens...
J'espère que ça ira mieux un jour, c'est pour ça que je reprends tout depuis la base de la base :-P
llo wrote 12/13/2015 at 21:15 point
a very exciting news :)
Yann Guidon / YGDES wrote 12/13/2015 at 21:17 point
it was only a matter of time
