Dexter
An open-source, 3D printed, high precision robotic arm with trainability
Dexter is an open-source robotic arm mostly made with a 3D printer. It uses 5 NEMA-17 stepper motors to control its 5 axes along with harmonic drives on 3 of them. We put quadrature optical encoders on each axis since stepper motors don't have encoders and they sometimes skip if not strong enough. Having these encoders allows the FPGA microcontroller on Dexter to poll the sensors fast enough and correct the motor's position in real time. Thanks to our gateware, we can poll each axis 5 million times per second, creating a 200 nanosecond feedback loop. Dexter is licensed under GPL3 so the design can be reproduced and modified at will. All of our files are on our OnShape, GitHub, and Thingiverse and a link to the building manual is in the build instructions.
Dexter is an open source, 5+ axis robotic arm. Its parts are 3D printed with PLA and held together with carbon fiber strakes for reinforcement. It uses 5 NEMA-17 stepper motors with harmonic drives on 3 of the axes. These don't have encoders and are prone to slipping, so we build our own optical encoders mounted on the axes themselves. We use 2 sensors with one of them 90 degrees out of phase so we get a quadrature encoder out of the system. Our software interpolates these values as sin and cos and allows us to measure each axis.
We use an FPGA to allow us to process the data from the encoders in real time. With our gateware, we're able to take 5 million measurements per second and get a 200 nanosecond control loop with the motors. This allows the motors to react when changes are detected in the optical encoder. One of our control modes known as "follow me" allows someone to physically control Dexter by touch without backdriving the harmonic drives (doing so wears them out and eventually weakens the integrity of the transmission.)
We wanted Dexter to be easy to program to someone new to robotics and a basic understanding of code, so one of our team members created Dexter Development Environment. It uses a modified version of JavaScript due to accessibility and it comes with documentation on how to program Dexter in DDE.
Dexter uses a socket connection for DDE, but that isn't the only thing that has used it. One of the members of the Dexter community has actually developed a Unity library for use with Dexter. Using follow me mode, you can actually connect move Dexter around in virtual reality to interact with objects. Touching one will provide haptic feedback in the physical Dexter. We think this was really cool because that opens the door for Dexter to potentially be used as a game controller.
  • 1 × Stainless Steel Tube Used as a shaft for a differential pulley
  • 2 × 5mm 16 teeth GT2 Pulleys GT2 pulleys made for use with NEMA-17 stepper motors. Used for differential pulleys
  • 1 × Haddington Dynamics PCB https://github.com/kgallspark/Dexter/tree/master/MotorControl
  • 1 × TE Part #2-179694-2 Used as an End Effector In/Out (EEIO) connector
  • 10 × 6P TE Part #215297-6 Used as a connector for optical encoder PCBs to the main PCB
View all 35 components
  • Haddington Dynamics Discord Server
    Haddington Dynamics07/24/2019 at 17:29 0 comments
    We've created a Discord server as a way to quickly interact with the team and the Dexter community. You can talk to other Dexter owners about your current projects and get help troubleshooting any issues you may have. Join here: https://discord.gg/YkfQRJa
  • Dexter HD Build Videos
    Haddington Dynamics01/23/2019 at 19:33 0 comments
    The Dexter HD build manual is now public. Instead of a book like last time, we went with a video series. Parts 1 and 3 aren't necessary for those who buy kits as those have been completed already. They're more for the people who are building their own Dexter HD from scratch.
    The videos can be found in this playlist on YouTube: https://www.youtube.com/playlist?list=PLEJQ7hsad17fC2tqTDGNFI_LPk1kX2aE6
    The BOM for Dexter HD is also available for those who wish to source their own components. Keep in mind that it is still a work in progress from our older system for organization of parts, so some quantities of hardware may be incorrect. It can be found here: https://docs.google.com/spreadsheets/d/1tPxJF4zsaoBsXhz2b6sy5hTPxMfhjwwAfAAC_93CtzM/edit?usp=sharing
    We can't wait to see what you make!
  • Dexter HD
    Haddington Dynamics11/09/2018 at 22:42 1 comment
    We have begun to release the STLs to Dexter HD. A page on Thingiverse has been created where you can download the parts. There are likely at least a few parts missing, but we will be updating everything as we move forward. https://www.thingiverse.com/thing:3206154
    We are also currently creating documentation on how to build Dexter HD. It will be in video form on our YouTube page for all to view. We estimate we will be done with the series within the next two weeks and we are going to release all of them at once.
  • Updated Print Farm
    Haddington Dynamics10/22/2018 at 06:22 0 comments
    If you follow us on Twitter, you may have seen that we have updated our print farm. We have 4 Markforged printers set up, 3 of them are Onyx Series while our first one was a Mark Two. We've been using their Onyx filament along with embedded carbon fiber in the Mark Two. Onyx is a filament created by Markforged that consists of chopped carbon fiber. This allows us to print stronger parts that have a higher melting temperature than PLA. PLA is a good material, but we can't leave a Dexter made of one in a car during the summer here in Las Vegas. We have before and it needed major repairs due to deformation.
  • Reconfigurable Gripper
    Haddington Dynamics10/20/2018 at 21:04 0 comments
    Using our new tool interface design, we have printed a reconfigurable gripper end effector. On the 7th axis, there is a servo for rotary power takeoff for a movable finger which works with a fixed finger. The end effector is removable so different tools can be used. We have already made end effectors for use with pruning scissors, tweezers, and a manual vacuum pump. If you want to build your own, the STLs are available on Thingiverse: https://www.thingiverse.com/thing:3166448
  • Development Branch on GitHub
    Haddington Dynamics10/20/2018 at 02:57 0 comments
    There is a branch on our GitHub repository called TDInt. It is the development branch for testing new things out in Dexter's firmware. One of the recent updates adds functionality for a new file type we call .make_ins. The new type allows for a list of instructions to be run from a single file. Dexter's "boot up dance" is now part of the autoexec.make_ins file instead of in DexRun.c. This allows anyone who wants to change what their Dexter does on boot up to do so without recompiling the DexRun software. This also makes it possible for to Dexter run tasks without the need of an external computer. Check it out here to learn more https://github.com/HaddingtonDynamics/Dexter/tree/TDint
  • Control of Many Servos
    Haddington Dynamics10/18/2018 at 21:29 0 comments
    While we were implementing the 6th and 7th axis onto Dexter, we realized that our FPGA servo control system is so fast, it should be able to operate over 200 servo motors at reasonable update speeds. We're not sure there is any application that could use that many, but we do know that it gives us a great amount of potential in regard to Dexter's end effectors. The Dynamixel servos can be daisy chained together using the included cable. We had already been using this method to connect the 6th and 7th axis, but if your end effector application needs an 8th, 9th, or couple hundred more, that can be done.
  • New Tool Interface
    Haddington Dynamics10/17/2018 at 22:06 0 comments
    We have developed a new tool interface for use with Dexter. It provides more interactivity with a pair of Dynamixel XL-320 servos as a 6th and 7th axis. The 6th axis acts as a wrist and the 7th is available to power a gripper or other end effector/tool. With their built in torque sensing, they can be back-driven like the rest of Dexter's axes. We are also working on adding a set of pogo pins to bring out signals and a tiny screen to display information and take selections from a user. https://github.com/HaddingtonDynamics/Dexter/wiki/End-Effector-Servos
  • Haddington Dynamics Wiki
    Haddington Dynamics10/17/2018 at 16:24 0 comments
    Dexter is a stunningly complex robot. Understanding how it all works just from the source files is nearly impossible. Our inhouse Technical Evangelist, James Newton, has been working hard to develop a centralized place for Dexter documentation. It has information on all things Dexter, from end effectors to gateware to DDE. If you want to understand how Dexter really works, please read the "manual" at: https://github.com/HaddingtonDynamics/Dexter/wiki And if it still doesn't make sense, raise an issue or ask us here. We could use help with the docs.
  • Automatica
    Haddington Dynamics06/01/2018 at 21:16 0 comments
    2018 continues to be good for Haddington Dynamics and we picked up seed investors.
    We will be exhibiting the remote control scaling system in Munich at the automatica show.  This along with the latest version of Dexter we call Dexter HD.
    Very busy times.
View all 13 project logs
  • 1
    Dexter Assembly Manual
    The link to the Dexter Assembly Manual is here
  • 2
    Wiring Harness Tutorials
  • 3
    Complete Schematic and all Design Files
    You can find a link to the complete schematic and STL files in the form of an OnShape model here.
    All other open source files can be found on our website: http://hdrobotic.com/open-source/
View all 4 instructions
Ryanwallace18 wrote 01/05/2019 at 14:19 point
Most force/impedance robotic control systems measure torque to detect an obstacle collision. Does Dexter measure torque perhaps through the motor control circuit, or just use the joint position, or joint position rate of change to detect an obstacle? James, I noticed that you sell magnetic abolute position sensors on your site. The AS5047 gives you 16,384 counts per revolution at about 10-20khz. This is much lower than the one million CPR of your sensor, but was this not high enough resolution or fast enough to do force control?
James Newton wrote 01/06/2019 at 06:15 point
First, my own site and encoders have nothing to do with Dexter or Haddington Dynamics. The AS5047 is 4000 CPR, not 16K. The sensor on the Dexter is very much NOT my design, it was developed by Kent, the principle designer at Haddington Dynamics.
Dexter measures position only, but because it is so sensitive, it can detect forces like a cotton ball being dropped on the arm.
Ryanwallace18 wrote 12/12/2018 at 19:02 point
Has anyone implemented this on anything other than the microzed fpga? It's 5 years old and there are cheaper alternatives now.
James Newton wrote 12/12/2018 at 19:49 point
I think we would love to hear about alternatives which support the same general capabilities: Same FPGA size, 32 bit ARM core, Ubuntu, lots of IO. We've been talking to Avnet about the platform.
Ryanwallace18 wrote 12/12/2018 at 23:13 point
Will the .BIT file work on other xilinx boards or only the MicroZed?
James Newton wrote 12/13/2018 at 21:05 point
I'm honestly not 100% sure. I'll have to ask our lead about that, but my understanding is that the .BIT file is designed for the chip used on the MicroZed, so it would work on any board that had that chip... and... that had the IO pins from the chip connected in the same way that the MicroZed connects them... so, technically "yes" but effectively "no".
Andrew Smart wrote 11/19/2018 at 06:59 point
I came here after receiving an email on the Hackaday prizes, and started researching. This project is fantastic, I am most impressed with the Dexter Development Environment (DDE).
I won't be building this till I've simulated my intended use (using the DDE and maybe FreeCAD [1]) and any cycloidal drive prototype stl's are released. Three harmonic drives at >$100 each [2] in addition to everything else is out of my budget/risk appetite. My personality is such that I'll trade time and labor to minimize expenses and optimize things, you learn more that way anyway, it is what I enjoy!
Slip Ring
8mm slip ring referenced on page 4 of assembly manual. Looking at BaseLite.stl, which slip ring fits over, diameter is 84.3mm.
As the large copper rings appear to be manufactured in bulk by punching/stamping copper sheet [3] (requires machining of stamp), the most cost efficient choice would be to choose some "standard" size that is already mass produced. Using the Conflat Flange (CF) 80 gaskets, used in the high vacuum industry, would be a good fit. 80 refers to the ID in mm, but rounded down, see chart [4]. CF100, with ID of 102mm, appears to be more commonly used/available. No CF80 on Aliexpress, but many Alibaba sellers. CF80 distributor on Ebay sells 2 for $20 [5], but the cheapest single CF100 I could find is $5.50, so...
I can see the assembly manual right now starts but doesn't finish the slip ring connection. Skimming through the videos/webinars I couldn't find directions for the slip ring.
Carbon Fiber Parts
Costs via DragonPlate supplier (for comparison):
1.5mm 4.4mm 705mm CF strake: $4.53 (.057" x .177" x 48") [7]
2.5mm 5.6mm 2652mm CF strake: 2x $8.67 (.092" x .220" x 48") + $4.77 ( .092" x .220" x 24")
3.2mm 12.6mm 2616mm CF strake: 2x $12.74 (.125" x .500" x 48") + $7.01 (.125" x .500" x 24")
5mm 20mm 321mm CF strake: $8.81 (.200" x .250" x 24")
6mm 8mm 137mm CF rod/tube: $5.05 (.315"OD x .239"ID x 24") [8]
1" CF Square Tube: $60.75 [9] (base arm)
.75" CF Square Tube: $49.75 [10] (forearm)
Cart total is $183.49. And shipping at checkout is "Shipping charges are calculated when order ships"... Would save some $ by using 1" tube for the forearm, but would have to change model.
DIY Carbon Fiber Parts
Making the CF strakes/rods from carbon fiber sheet and epoxy is an option worth considering. It looks to be lower cost and higher labor, but I see an opportunities like customizability and making a skin [6] using scrap materials. There are plenty of forum guides on making CF parts by hand, and in the future, by robot arm? :)
Carbon fiber fabric:
.23mm 1yd@$13.5/yd 36" [11]
.38mm 1yd@$17/yd 50" [12]
Layer 4 .38mm CF fabrics for 1.5mm thickness strakes, and etcetera:
.38mm*4 = 1.52mm
.38mm*6 + .23mm = 2.51mm
.38mm*6 + .23mm*4 = 3.2mm
.38mm*12+ .23mm = 5.02mm
Cured sheets would then be cut with table saw [13], or possibly by Dexter as he is so precise!
Only 4.05ft^2 of 12.5ft^2 .38mm fabric used; much to spare!
1" square aluminum stock (~$23 for 72" at US stores) can be the form for the square CF tubes [14]. And a 6mm aluminum rod (~$1-2) as the form for the CF tubes.
DIY Cost: $115.45 = $13.5 (.23mm CF) + $17 (.38mm CF) + $45 (Quart 820 Epoxy) + $15 (US shipping estimate) + $23 (1" aluminum stock, cheaper with a trip to the scrapyard)
Savings over DragonPlate and only using ~1/3 of the Carbon Fiber ordered. Downsides are less quality parts and no fancy cure process (e.g. curing oven to raise temperature resistance and mechanical properties [15]).
FPGA
MicroZed: $178+sh [16]
Might find a cheaper reseller or alternative, e.g. Xilinx Z-turn lite $117 [17] or $103 [18]. Would be nice to know what VIVA is compatible with, esp. considering this MicroZed can handle a lot more than Dexter's stock requirements.
P.S. I like your twitter quote of Stephen Hawking, we should be scared of capitalism, not robots. "If machines produce everything we need, the outcome will depend on how things are distributed."
[1] http://hdrobotic.com/dexter-community/#!/general:freecad
[2] https://hackaday.com/2018/08/24/a-peek-at-the-mesmerizing-action-of-a-cycloidal-drive/#comment-4976153
[3] https://www.ebay.com/itm/253978363132
[4] https://i.ebayimg.com/images/g/LE4AAOSw9~Rb6nKP/s-l1600.jpg
[5] https://picclick.com/2pcs-CF80-Copper-Gasket-New-Vacuum-Pump-Flange-173608218978.html
[6] https://github.com/HaddingtonDynamics/Dexter/issues/4
[7] https://dragonplate.com/Carbon-Fiber-Strip
[8] https://dragonplate.com/DragonPlate-Carbon-Tube-315OD-x-239ID-x-24
[9] https://dragonplate.com/Carbon-Fiber-Roll-Wrapped-Twill-Square-Tube-1-ID-x-1-ID-x-24
[10] https://dragonplate.com/carbon-fiber-roll-wrapped-twill-square-tube-075-id-x-075-id-x-24-3
[11] https://www.sollercomposites.com/Carbon-3K-Fabrics.html
[12] https://www.sollercomposites.com/Carbon-6K-Fabrics.html
[13] https://www.practicalmachinist.com/vb/general/cutting-carbon-fiber-plate-216679/
[14] https://www.bentrideronline.com/messageboard/showthread.php?t=3120
[15] http://www.shadowaero.com/COMPONENTS.htm
[16] https://www.avnet.com/shop/us/products/avnet-engineering-services/aes-z7mb-7z010-som-g-rev-f-3074457345635221615/
[17] https://www.aliexpress.com/item/XILINX-Z-turn-lite-ZYNQ-7010-ARM-Cortex-A9-with-FPGA-dual-core-Development-Board-Control/32836668246.html
[18] https://www.xilinx.com/products/boards-and-kits/1-pcz4jb.html
James Newton wrote 11/20/2018 at 01:42 point
Hey Andrew,
Nice work tracking all that down. We do have a partial BOM (linked from the repo) but it is a bit out of date and could certainly use to be updated. Let me know if you want to help update it. We did raise a help wanted issue about it.
https://github.com/HaddingtonDynamics/Dexter/issues/34
I've made that google sheet "Anyone can comment" so if you want to leave notes on it, go for it, and if you want to edit, just ask me.
James Newton wrote 11/20/2018 at 01:59 point
Andrew, true confessions here: We've all disabled the slip rings on our robots... they just are NOT reliable and they cause so many problems with reliability that we gave up on them. If someone out there that can make a reliable slip ring, please let us know. Anyway, the robots typically don't need to spin around for the bulk of the work they do is all in the same quadrant.
James Newton wrote 11/20/2018 at 02:48 point
As I understand it, Viva is a high level design tool so it's compatible with any FPGA that we can get an accurate descriptor... file... format... thingy... for. I'm not the expert on that so I'ma shut up now.
What I AM an expert on is firmware, so I'm starting work on a code only (no FPGA) version with a lasercut encoder which should be as accurate (or better with a good laser) but much much slower. It's designed for human input, so you can make a non-powered "arm" with this, connect to a Dexter arm somewhere else in the world, and control it by moving this low cost local "arm" encoder around. Please consider being involved:
https://github.com/JamesNewton/HybridDiskEncoder
I'm hoping we can use the Cypress PSoC chips because they have a good 32 bit ARM core, enough memory to do ATAN2 (which is the necessary math), they have an onboard programmable analog front end, AND... they have a little FPGA which we may be able to use in the future to increase speed.
Andrew Smart wrote 12/13/2018 at 17:49 point
Now that I look more, I think the MicroZed looks quite interesting. I'm sold after seeing the MicroZed chronicles, seeing OpenCV works with it, and utility for other projects.
I think it best for now I offer suggestions/ideas where I think I may have something to contribute. I hope I can get through other projects and start building Dexter, though there is much preliminary reading I must do. 3kg payload, very impressive!
James Newton wrote 12/13/2018 at 20:11 point
Andrew, don't hesitate to ask if there is anything we can do to help you get started building a Dexter.
andrew.craton wrote 11/14/2018 at 20:29 point
What is the approx BOM cost?  How much can we expect to pay for all the materials?  Will you create a kickstarter or "kit" that we can purchase and install ourselves? Thank you and congratulations!
jdarthurs wrote 11/14/2018 at 22:21 point
I was just about to ask what the BOM cost is. my 3D printer is currently down, I'm redesigning it. So also, I was wondering about PLA components.
megazoid wrote 11/16/2018 at 18:21 point
They have a kit apparently : http://hdrobotic.com/store
The kit is $2,999. If you tried to make this yourself without the kit, I would give it a ball park figure of about half that, but I would research it completely before diving in.
Haddington Dynamics wrote 11/16/2018 at 23:53 point
We will be moving to an HD kit which will be available soon on our website.
Haddington Dynamics wrote 11/16/2018 at 23:52 point
Thank you for the congrats!!
We have the BOM on our GitHub space.  It is being updated.  The HD BOM is in progress.
nraynaud wrote 11/05/2018 at 06:32 point
Congrats on your prize.
I really like your idea for artificially increasing the sensor resolution.
I had another idea about arm position sensing: running a cable from next join to the one that is sensed, wind it around the encoder with a spring, to be able to also sense the backlash and the deflection of the instrumented segment.
James Newton wrote 12/13/2018 at 21:13 point
Hey, sorry I didn't see this comment earlier... not sure how I missed it. Yes, I've done exactly that with a 4000 CPR magnetic encoder and got 4 clicks per 1/1000 of movement on a CNC conversion. You have to watch out for a few things:
1. The string will stretch, vibrate, and eventually fail. The stretch isn't a big deal as long as the force on the string is very consistent. It will drift for a while, then settle. However... that drift will re-appear with some types of string based on heat, humidity, and the phase of the moon. So it's really best for relative movement and must be re-homed on start-up (not a big deal)
2. If the shaft of the encoder requires any torque to move, it will either slip or will "drift" into place after the move. e.g. you will see the reading change after motion has stopped as the string stretches to balance the force on either side of the shaft. The non-contact magnetic encoder eliminated this issue, and most good optical encoders should be fine, but I've seen a lot of them that require significant torque to turn, and I would be leary of that issue.
3. You have to be really careful about the string not touching anything or rubbing or vibrating. Not sure how much of a problem that actually is, but I'd watch out for it.
You might be interested in this project where we are applying the method used on Dexters encoder to a very low cost laser cut / 3d printed encoder system that can be used separately from the Dexter control electronics:
nraynaud wrote 12/13/2018 at 21:50 point
thank you for your insightful answer.
Have you looked into contactless sensors, like time of flight or interferometry? I am still thinking of having sloppier joints to reduce the cost, and try to sense and correct the error.
I like your sub-project on the quadrature sensor, in particular it validates my obsession with telling people that PSoC are the gateway to FPGAs :)
1) I have not found your exact calibration procedure
2) are you running at a "dual rate" where at high speed your just read the thresholded LED like a normal encoder, and at slow speed you try to finely discern the intensity of the LED?
James Newton wrote 12/14/2018 at 04:46 point
Yes, using an encoder on the joint to compensate for a lower cost drive train is smart. That's exactly why I was doing that for the CNC. No ball screws, just very sloppy lead screws on the Z axis.
As I said, I used a non-contact magnetic encoder. This one specifically:
http://massmind.ecomorder.com/techref/ecomprice.asp?p=416083
I don't know much about TOF or interferometry to be honest. I'd love to learn more about them.
If you have experience with the PSoC chips, I'd love any advice or help you can offer. I'm new to them, and loving it, but stumbling through it.
1. The project isn't to that point yet. I'm hoping the only calibration needed will be setting the drive levels on the LEDs. Time will tell.
2. That's the plan, but not at first. We are targeting this at human input, so speed isn't an issue.
Anool Mahidharia wrote 11/04/2018 at 03:24 point
Amazing project. Congratulations on your 1st Prize at the 2018 Hackaday Prize. Way to go. Looking forward to the next rev of this project.
drenehtsral wrote 08/04/2018 at 00:39 point
Where do you buy the gearboxes? A couple years back I was looking for essentially exactly those gearboxes and could not for the life of me find a distributor or reseller. (Some manufacturers will sell their products directly to individuals but many will not (either because volume would be too low or because they are only set up for business-to-business sales)).
Haddington Dynamics wrote 08/09/2018 at 17:47 point
Hello, we normally buy them from HanZhen. http://www.hanzh.com/product-2.html
Kenneth Lerman wrote 09/19/2018 at 23:02 point
How much do the harmonic drives cost?
AVR wrote 09/20/2018 at 15:07 point
holy hell knowing I can buy these just opened many doors in my mind
James Newton wrote 09/21/2018 at 00:30 point
Kenneth, the prices vary widely depending on specs, source, qty, etc... but they are generally not real cheap. $50 to $100 range.
AVR, yep! They are cool ask heck, but if you want your mind really blown, look into cycloidal drives. e.g:
The price isn't much lower, because they use so many little bearings, but they are very configurable, and can avoid a type of backlash caused by bending / deformation.
jdarthurs wrote 11/14/2018 at 22:25 point
STOP IT! Too many cool things! I'm having yet another "something shiny!" moment. And it's the third I've had in as many minutes.
James Newton wrote 07/13/2018 at 17:37 point
LOL. Ok, ok... The responses before ARE written by the guy at HD who does marketing. It's funny to me that he is providing the very best answers he can provide, given data from the techs and engineers in the company, and it still doesn't make anyone happy because of the language. Give the poor guy a break?
So I'm an engineer at HD (firmware, testing, working on Arduino compatible smarts in the new end effector). And I'm a long time OSH / FOSS supporter. And I completely freaking fail at marketing (check my side business. LOL).
Maybe a conversation with me is better? I'll post some responses below this.
James Newton wrote 07/13/2018 at 17:38 point
1. ITAR, CCL, whatever stupid government regulation it actually is we don't care about. We aren't allowed to put an encoder on the 'bot that exceeds a certain angular resolution and then sell the bot outside the USA. It's freaking stupid and very annoying, but we want to stay out of jail so we do as we are told.
From a technical perspective, the encoder is AMAZING! I have a Dexter, I know what it can do. There ARE problems with it, but they are mostly related to the processing of the data and not related to the encoder itself. e.g. We currently are not exposing the actual joint angle from the FPGA to the onboard Firmware, but that's on the "backlog" list for the next iteration. As a result, we currently can't read back the actual joint angle in the firmware, we only send a desired joint angle and the system "makes it so". We can get back the error, and other status info, but actual join angle is important and we will add it. This presentation may do a better job of explaining how the encoder works and why it's able to do more:
https://docs.google.com/presentation/d/1YGBnNvxhoP9J7alk5sASB5aUM_wg30fUuiZzM94uL2w/edit?usp=sharing
Let me know if you have more questions about the encoder. It's a technology I think more people should understand, so I'm happy to spend more time explaining it.
instead of using the slots in the encoder disk as "on", "off" / "black", "white" / binary values, we use the optical sensors in /analog/ mode. With a high resolution ADC, we get thousands of positions per slot. And yes, those are not perfectly linear, and yes, there is noise and all that poop. But the end result is MUCH higher resolution than a standard encoder. Fantastic repeatability (NOT accuracy). And it's a pretty cool idea, huh?
But even in home applications, why NOT print a low res encoder disk, use photodiodes and A2D encoders, and get higher resolution positioning? It's a freaking cool idea! And we open sourced it.
James Newton wrote 07/13/2018 at 17:39 point
 2. Massively parallel, super whatever... who cares? It's an FPGA doing stuff faster than the FIrmware can do it. That the point. That's cool. Really, really cool, actually. It gives us a stunningly fast feedback time so we can do things like adjust the "springiness" of the response. Or switch into a compliant "follow" mode instead of position "keep" mode. In follow, you can grab the robot, move it around, and record waypoints or the entire path. Then play back, insert into a program, whatever. It makes it really easy to use.
One issue we have right now is that you have to return to "home" to switch from follow to keep modes, but we are working on that as well. It's a tricky problem that we didn't see coming, and honestly, it's over my head why it doesn't work.
James Newton wrote 07/13/2018 at 17:42 point
3. Open source: Dexter is as open source as we can legally make it. There is ONE area of Dexter that isn't /really/ fully open source and that is, as modzer0 points out, the HDL for the FPGA. The reason for that is that our primary engineer, who developed the HDL himself. It's called "Viva". He sold it to another company and that company is sitting on it. It's a decision he may well regret, but feeding the family is sometimes a good idea, no? He has a resale license, and can "sell" a copy here and there for $1, but there are limits on his ability to do that.
The files that come out of the HDL are available online (in the github) and they are /technically/ editable, and the source file is also there, but yeah... we get it. It's not really fully open source on that point because the editor isn't available to the general public.
So why not use a "standard" HDL? I'm so glad you asked. Because, and this is really important, so please read to the end and think about it, all the existing HDL's for FPGA design force you to THINK in sequence as you write the code. Our HDL, "Viva" is graphical. It shows you things on the screen in a format that more closely represents what is actually happening in the FPGA. If you write in a standard HDL, you have to think about a process that is parallel, then transcribe it into an inherently serial form (the HDL) then it gets processed back into parallel operation. With Viva, you think, and draw in parallel. It's just better, and it's what the big mfgrs /should/ be providing and are not.
More than that, it's the format our principle developer thinks in and works in, so we aren't going to change it. Sorry. End of story. Not going to burn more cycles defending that.
If you want to reject our FPGA claims, that's your choice and there isn't much we can do about it. I'll try to post screenshots if that helps? I think I can do that...
If you want to reject "massively parallel" and "FPGA super computer" then... LOL. Yeah, I kind of agree with you. Those are marketing words. But the FPGA IS doing cool things for us, it DOES solve a lot of problems, and you CAN see that in our demos and in person if you are near someone who has a robot.
If anyone in the SoCal area wants a demo, and can make it to Escondido, I'll happily setup and time and show you what the robot can, and can not, do. We go to Maker Faires all the time, stop by and see for yourself. All the other parts of Dexter are FULLY open source. The firmware, the hardware (schematics, PCB's, etc...) the physical objects, etc... I've printed new end effectors from the files on OnShape. I'm using CircuitMaker.com for the power supplies (and soon the new interface board) for the new end effector.
If there is something (other than the FPGA HDL) that we've missed sharing, please point it out.
James Newton wrote 07/13/2018 at 17:46 point
3. The "end all scarcity" / robots in Africa thing. That's the goal. SpaceX wants to make humans interplanetary. All sorts of AI companies have crazy end goals. We set our sights high. At this point, other people have used Dexter to cut things with a laser, make art, tend a 3D printer (remove the finished part and dump it in a box), run a camera (a youTuber), stuff like that. We are short on practical applications, and we need YOU involved to find and solve problems with our "solution" (with Dexter).
Our best application at this point is teaching people how to make a robot and NYIT is using it for exactly that at this time.
If you wanna learn how to make a really cool robot, dig into the github. Post issues if you find a problem / don't understand something / can't find something. We REALLY want people to get involved in the project:
(p.s. please check out the wiki... I've worked really hard on that and I'm proud of it, but I want feedback on how to improve it.)
Daniel wrote 07/13/2018 at 22:36 point
Understand that Hackaday is a haven and focal point for a large number of hackers, hardware hackers, reverse engineers, hobbyists, makers, and professionals in related fields. A large percentage of them love seeing tech scams dismantled and destroyed. Some systematically discredit marketing claims for recreation. The number one response from those scammers is marketing speak, and the tactic of attacking the credibility of those posting hard technical questions or even basic science why their product will not work as advertised. The people behind those scams have large teams of marketers and few if any engineers.
There are people who will fall for those tactics, and there are those who see right through them and smell bullshit. Hackaday has a large percentage of the latter.
A bit of advise for this site is to take any interaction with it away from the marketing guy. Remove all the claims in the description and stick to technical details. You don't have to be a good communicator. In fact if you're too good it will just create skepticism. Post about the process. The problems and how you worked through them. It should be about how things work and how you made them work. That's the purpose of the site. A place to show off projects and build logs.
One thing never to do is trying to undermine someone's credibility rather than addressing the technical questions. That's a fatal mistake as evidenced by Modzer0's surprisingly polite checkmate followed by the forceful creation of a new orifice for your marketing guy. Don't try the marketing impulse to delete the jab.  If he just apologizes everyone will forget it. Trying to cover it up will just make screenshots surface and you'll look even worse. Integrity is increasingly rare these days, displaying some will help fix that damage. Don't act like the tech scammers who are all marketing.
If you discuss the problems you have with designs you'll find people will help you with solutions.
James Newton wrote 07/14/2018 at 19:28 point
Yeah, Daniel, I hear you and you are right. But the engineers at the company are heads down working, and we tend to forget about reaching out. Our bad, I know. I mean, we have a marketing guy to do the "reach out" stuff, so he is just trying to do his job. Honestly, it's my fault because I'm pretty sure he said something about posting on Hackaday and I should have twigged that it wasn't the right fit. I'm the only (I think) engineer at the place who has been on hackaday before going to work there, so I do understand and I should have caught it quicker.
I do hope my responses and the details I've provided have answered your and others concerns? If you have any other questions, please don't hesitate to ask and I'll do my best to answer them. It would be a crying shame if I fail to convey how truly frick'n cool this robot and this company really are. Seriously, I have this job today because I spent a good long time contributing via open source just because I could see how amazing it is. I only got hired because I was whining about my regular day job being cut back and they wanted me to spend more time with them! LOL.
Modzer0 wrote 07/12/2018 at 00:15 point
Classy, labeling me as 'angry'. Such things are typically a defensive statement when one feels their ability to respond is in a weakened position.
I also never asked for your 'ITAR' data because you have none. ITAR deals with items and companies dealing with such defined in the USML. What you linked is the CCL, the commerce control list. Any microcontroller with a processor speed over 40Mhz is technically under that as well. I've actually had to sign export control documents to buy ESP32 modules that were imported from China to begin with.
As for the USML the use of a high resolution encoder in a robot arm isn't defined as a munition as it is:
 (1) not 'specially designed' to be a weapon system
(2) not used in angular control of devices designed for infrared optical tracking for intelligence gathering purposes.
(3) not a device used to track angular rate or position of missile technology(MT) that doesn't apply to rotary encoders and wasn't funded by the DoD
(4) is not space qualified and is not being used in an instrumentation radar
Lots of people misunderstand the things ITAR applies to
FPGAs can do tasks in parallel. It all depends on the contents of the bitstream given to it. If it's given a single cpu IP say something like a small pure stack based CPU then it is not in fact 'completely parallel'. It depends on how you use it. The way you describe it is how a marketing person would word it to impress potential customers. FPGAs are just configurable hardware, though very useful configurable hardware that can be used as application accelerators processing data clock for clock more efficiently than a general purpose CPU. That's why there's quite a number of motion control IP available.
I love FPGAs, I don't love the development environments or having to keep multiple versions of very large dev tools installed just because I'm working on an older FPGA. The licensing is something that gives finance bad dreams. Also a 'typical' 30 person FPGA team? That's a very large team.
As for the 'Duopoly' you almost make that sound like a conspiracy. You sure it wasn't them just supporting languages that were IEEE standardized and didn't come with very high license fees?
James Newton wrote 07/13/2018 at 18:00 point
Can I be honest? We really aren't government employees and we really don't understand all that regulatory crap. Or at least I don't. We were told to limit the resolution and we didn't want to get into any trouble with the government so we did it.
Can we get back to the technology? Because that's what's really cool! Have you seen how the encoder actually works? This presentation might help explain it:
instead of using the slots in the encoder disk as "on", "off" / "black", "white" / binary values, we use the optical sensors in /analog/ mode. With effective 13 bit resolution, (12 bit but dithered) we get 8096 positions per slot. And yes, those are not perfectly linear, and yes, there is noise and all that poop. But the end result is MUCH higher resolution than a standard encoder. Fantastic repeatability (NOT accuracy). And it's a pretty cool idea, huh? Watch the video above... I've seen that demo in person. Swing by my office in Escondido, CA and I'll happily show you.
It's really wild when you use 2 robots slaved together because the human operator takes out any accuracy issues. The 2nd can send back position errors to the first, which can then use that to increase the position resistance which provides the operator with "feeling" from remote touches. It's amazing if you experience it yourself. Sadly, I only have one Dexter at my office, so I've only seen that at the main office in Las Vegas and at the Maker Faires. I think we will be at New York Maker Faire, September 22,23 and then San Diego Maker Faire October 6,7.  Come down and see it!
But even in home applications, why NOT print a low res encoder disk, use photodiodes and A2D encoders, and get higher resolution positioning? And then if you know FPGAs you should be able to code up a feedback loop (PID or whatever) and use that to regulate the joint.
Modzer0 wrote 07/02/2018 at 04:32 point
I remember this from the kickstarter and the ridiculous claims of supercomputer FPGAs and how it would somehow solve a bunch of problems. All the claims of open source yet the provided HDL wasn't even complete. Nothing about it was that exceptional considering the amount of off the shelf IP available for motion control. The kickstarter video with all of it's helping the impoverished and buzzword marketing tactics says a lot about the people behind it.
Then there's this 'project' that's purely marketing itself.
Haddington Dynamics wrote 07/06/2018 at 21:54 point
Thank you for your input. We are sorry that you are dissatisfied with our project. We use an FPGA board with in-house code written by Kent Gilson, the pioneer of hypercomputing, with FPGAs using his own language.  With a pinch of research, you would have been able to see that we do not use Verilog or HDL.  We can get a 33 million gate program onto an off-the shelf Zed board.  Here is an early article from 2003 in Forbes regarding the founder’s work. https://www.forbes.com/2003/03/25/cz_dl_0325star2.html#2794832ef226 Here is an article to explain how we are doing what we are doing and how different it is from current control systems. https://www.roboticstomorrow.com/article/2018/06/using-fpga-supercomputers-to-build-a-high-precision-robot/12145- There was a big launch at automatica-Munich for an 8kHz control system.  We are currently running at 100kHz on each joint.  We restricted our encoders to 19.5bit so we don’t hit ITAR restrictions and therefore can not open source what we have done.  Lastly, not sure how to take your final comment regarding the marketing buzzwords.  If you are saying we are not sincere in our convictions to use technology to help others with a goal of ending scarcity, then I would direct you to the website https://www.whycantwe.org/ which was written by Fry (co-founder) and his fellow MIT colleague Henry Liberman.  One final link to help you and others understand our influences – I direct you to Jeremy Rifkin and The Third Industrial Revolution.  https://www.youtube.com/watch?v=QX3M8Ka9vUA Hopefully these links help you and others understand what we are doing.
Anoir Ben Tanfous wrote 07/07/2018 at 14:48 point
I appreciate your answer
Modzer0 wrote 07/07/2018 at 19:16 point
An answer filled with more marketing. You keep repeating your founder's name like he invented the wheel or something. The hypercomputing you referred to is best described as 'hype' computing as it was all mostly hype with little substance other than taking people's money.  It's much like someone proudly stating that they invented Steorn's Orbo. Then you're using some magic FPGA language that's so great that no one has really heard of it in professional circles. So color me very skeptical of any claims without visible, testable, and verifiable results. You restricted the encoders? Great, remove those restrictions on the encoders and show us the results associated part numbers, and code that people can actually synthesize/compile and use for independant verification. It's also fairly easy to fine tune motors for a single repeated movement.
How about repeating the movement accuracy test say 10 times, then picking up a 100 gram weight and repeating it to increment up to the practical weight limit of the arm. Continuous video with no cuts.
As for ITAR, please provide specifics on the exact item you're in danger of exceeding. I have quite a bit of familiarity with it as much of my work is for the DoD and US Government.
As for my reference to marketing terms I refer to the continuous use of terms like 'supercomputer' to describe the FPGA based motor control system. That is a textbook example of a marketing buzzword.
I'm a scientist at heart so my default skepticism isn't fixed. The burden of proof is on you. I'll sing your praise if proof is independently verifiable.
Prove you're not like Waterseer of which your feel good help the people marketing video for a robotic arm of all things sounds very similar. Engineers and scientists told them their design wouldn't work and they kept claiming it did. Now they've switched to what's basically an overpriced dehumidifier proving everyone who told them their ground and wind based passive system would never really work much less come near their claimed values correct. Then there's solar roadways with all of it's hype and after taking in millions they still haven't paved a road or made a test installation that's net positive on power generation.
Then there's the simple reality of the modern tech economy. If it was really that good the company would have already been bought. Instead you're marketing hobby robotic arms on a site primarily for personal projects.
Haddington Dynamics wrote 07/11/2018 at 21:51 point
Skeptics are always welcomed – however you come across more angry than skeptic.  Not sure we can resolve that other than provide more information which you will promptly call marketing.  Either we stepped on your toes or this is just you.
We use the term hyper or super to provide context to massively parallel computational horsepower.
A typical FPGA team is around 30 folks in 6 divisions (integration, testing, timing etc..)  We do not have these constraints.  Regarding why this language is not adopted or widespread - you need not look further than the duopoly that is Xilinx or Alterra.  What hardware company is going to support software that is agnostic to its manufacturer.  They make their money on the software- a challenge to that will not be supported.  Also, if FPGAs were not a serious contender for where hardware is going – would Intel spend north of $13B to buy Alterra?
Regarding ITAR restrictions - an encoder that is 20bits can steer lasers accurately.  Beam steering is not open source material.  You are an anonymous individual, so we have no idea of your credentials but based on your statement above you ‘work for the DoD and US Government’ then it should not have taken a request to us regarding ITAR restrictions on optical encoders.  But again, we don’t know who you are. https://www.bis.doc.gov/index.php/documents/regulations-docs/federal-register-notices/federal-register-2014/990-ccl3-2/file page 14.
You want a part number?  The layout to our Opto board is here https://github.com/HaddingtonDynamics/Dexter.  ‘It’s just a simple optical encoder system where we turn a 3D printed code disk into an analog sine cosine wave to get a circle and do interpolation from it. We record a table and then compare against that table to normalize, 2 million samples per second. Which spread over 10 converters--2 at a time--equals 200,000 samples per second per LED/phototransistor which gives us 100,000 (100kHz) frequency bandwidth per axis. From that we get loads of data. We can then use signal processing to get process gain. And all of this is done in real time.  FPGAs are completely parallel. It’s completely different from a processor where you have one thread running or multiple threads running. Everything is happening all the time simultaneously; you have to be explicit about things that are synchronized because it’s all happening at once.’
This can’t be done with serial processors that are “so abundant” on the internet today.  If you don’t want precision and haptics at a low cost – there are plenty of alternatives.
Regarding outside testing – you are absolutely correct.  Let others challenge our statements.  We applaud testing.  Which is kind of funny that you are arguing for us to prove ourselves and yet at the same time our proving ourselves means nothing if it not outside tested.  So far we have received positive feedback from Google X, Toyota Research Institute, New York Institute of Technology, NASA, Axiom Electronics and others that we can’t talk about because of NDAs.
When you have disruptive technology, you want to make sure it is available to the bright minds.  Many of those bright minds are in the maker community and can expand the capabilities of our robot beyond what we could do as a small company.  And getting to the people has worked.  Here is a link to one of our clients working with Dexter on a path we would not have taken as a company.  Robots/AI/painting https://www.facebook.com/ZSparkyThoughts/videos/214948589158880/
Presenting on this site was not a marketing ploy.  We were asked at the Bay Area Maker Faire to please submit our information – they liked what we were doing.  They liked that we were also working with a university that is moving to a maker focus.  In fact, 6 courses this fall at NYIT will have our technology as part of their curriculum.  Giving makers new tools is both economically viable and creatively exuberant.
We knew when we open sourced that we took a large chunk of potential buyers and investors off the table.  This was a calculated decision, the only way to get disruptive tech into the market was to make sure everyone had access to it.  We had plenty of investors on the upfront with silly valuations – they all wanted to spend that money on IP attorneys.  In our opinion that is not how you get a new platform to the market.  These decisions could end up biting us.  But at least the IP is not tied up and others can use it.
Daniel wrote 07/12/2018 at 15:26 point
He got a point. The engineers who get it done have a spidey sense earned with experience. If things look like it's written by marketing what shows up rarely meets expectations.
You've got to be a marketing or PR person. If not, you should be. The responses read like prepared press releases. The kinda things that irritate engineers. I bet if you just posted the technical details he wouldn't have any objections. Hell, there's way too many marketing keywords and phrases for my tastes.
I understand the objection to the Kickstarter video as well. Ever been to the poorer regions of Africa? They don't have any use for robot arms. They'd be happier with security, safe water, reliable food supplies, communications, power, lights, education, and a few other things before robot arms appear on the list. Even then I can say those robot arms will break fairly quickly in those conditions. There are people susceptible to marketing everywhere. There are also people who are irritated by it and will avoid the product just out of spite.
It might also annoy the open source crowd when you use a proprietary, dead language for a key part of how it works.
James Newton wrote 07/13/2018 at 18:04 point
Daniel, Modzer0, see my post above. Yeah, the guy who wrote this is a marketing person. He is doing the best he can with data from our engineers (I'm one of them). We've been to busy working to post here. And yeah, the FPGA source isn't /really/ open source because the program to open the file isn't available commercially. Answers / reasons in my post and replies to it above. It IS still a really cool project, it's as open source as we can make it, and people who contribute and have FPGA ability are welcome and maybe we can work something out to get you access to the HDL software we use. Read my post and the replies for details.
