Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Events Hackerspaces Profiles Hackaday.com Tindie Marketplace Remoticon
Sign up Log in
AutoFold the Box Folding Robot
We are creating a system to automate the process of folding boxes
FourthLevelMfgFourthLevelMfg
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.8k views
7 comments
161 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 26
    • View all
  • Instructions 0
  • Discussion 7
View Gallery
4.8k
7
161
49
Team (3)
  • FourthLevelMfgFourthLevelMfg
  • Boian MitovBoian Mitov
  • DavidDavid
Join this project's team
Software
ongoing project
hardware
ROBOT automation Mechatronics FUSIon 360 servos arduino LabView Stepper motor prototype lasercut 3D printed
Related lists
The Supplyframe DesignLab
Supplyframe DesignLab projects and creative resident teams building hardware projects in Art, Design, Technology, and Science.
This project was created on 01/18/2017 and last updated 6 months ago.
Description
Our project is small automatic box folding robot. This system is designed for micro factories like a successful kickstarter, or US based small manufacturing company. People who want to stay local, but the only way to compete with cheap overseas labor is to be automated. Technology like 3D printing and CNC are making automation attainable but in packaging there is still a missing component. We plan to uses a LabView based virtual interface for easy operation via touch screen. Its key mechanical feature is a universal linear actuator. We have a clever cheap arduino controlled design for them we are developing. These linear actuators can be combined in a huge number of configurations and are proving to be one of the most fun and exciting discoveries in the project. It will folds Indestructo Mailers, a new style of cardboard box. They requires no glue or tape to assemble. They are also stronger, have a lid, and stack in higher densities when un folded.
Components
  • 1 × arduino mega
  • 12 × NEMA 17 Stepper motors yes we need 11 stepper motors for box folder
  • 12 × big Easy motor drivers
  • 50 × Lots of Vslot
Project Logs
Collapse logs
  • It's Finally Working!!!
    FourthLevelMfg • 07/14/2017 at 01:29 • 1 comment
  • Wiring Nightmare
    FourthLevelMfg • 06/20/2017 at 19:46 • 2 comments
  • I think I left it in the wrong part of town
    FourthLevelMfg • 06/13/2017 at 16:48 • 0 comments
    No Motors :(
  • Almost all motor installed
    FourthLevelMfg • 06/12/2017 at 18:47 • 1 comment
  • New Motor Controller boards
    FourthLevelMfg • 05/26/2017 at 19:05 • 0 comments
    I reduce the motor controller boards down from 5 Big Easy drivers to 4. I also made the 24 volt lines much thicker. Also a special thanks Metal for all his help and the better Quick connectors
  • Set backs & fried components :(
    FourthLevelMfg • 05/17/2017 at 17:55 • 0 comments
    I blew up chips on our Motor controllers
    if you look at the pins below the heat sink you will see one is missing, that is because it got fried.
    I have fried 3 like this so far :(
    One was because of bad stepper motors. The steppers also destroyed the internals of 4 other drivers. They have been sent back and replaced. Thank you Dan for getting replacements.
    One was my fault, I wired a motor to the drive wrong.
    The latest time I don't know why it blew. This is of course the one bothers me the most because the unknowns are preventing us from getting more than 5 motors working in sequence.
  • Tower of Power!!!
    FourthLevelMfg • 05/02/2017 at 22:43 • 3 comments
    We made the boards for all the motor drivers 15 in one big stack!
  • It's Alive!!!
    FourthLevelMfg • 04/18/2017 at 23:40 • 1 comment
    we finally have 4 motors all working together in the correct order
  • 1st Month Photoshoot
    FourthLevelMfg • 04/04/2017 at 16:56 • 0 comments
  • PCB TIME!! (like hammer time only defferent)
    FourthLevelMfg • 04/01/2017 at 01:23 • 0 comments
    we made some circuit bored or the first time on the other mill. It was very satisfying. Starting we made a beak out bores to connect our 8 limit switches to a IDC 16 pin ribbon cable. We made a 4 stepper to IDC also. we got the tool and made the cable our selves and it was relay fast with no soldering.
    we used KiCad to make the circuit.
    total mess at first.
View all 26 project logs
Log In/Sign up to comment
Sign up with Github
OR
GrayPillow wrote 05/31/2017 at 03:40 • point
Do you  have some problems about motion control ?Maybe AnanasStepper https://hackaday.io/project/20980-ananasstepper-20 is to meet your need!
Tegwyn☠Twmffat wrote 05/27/2017 at 13:25 • point
What chips are you using for the stepper controllers? I'm currently testing out L6482 's which are SPI controlled so only one wire from the mcu is required.
GrayPillow wrote 05/14/2017 at 03:34 • point
Nice project!  It a really a nice application for my project (AnanasStepper), which is designed to control multi stepper motor at the same time. I think we can cooperate!
Florian Festi wrote 05/02/2017 at 09:27 • point
Well, servos are made for RC toys. Even the big ones are not really made to drive stuff. The way to go would be a geared DC motor in combination with two end stops. Get something that can put out a two digit wattage. DC motors can go into overdrive for a short time if they get time to cool down afterwards. Something you can easily do in this application.
It kinda bugs me that you are heading for all this high precision CNC gear while you actually need something strong and rugged with comparably low precision.
You could probably get away with some cheap steal rods with wooden carriers directly riding on them with laser cut holes.
David Levi wrote 04/09/2017 at 03:48 • point
Hey I'm in Pasadena and will need to fold a ton of cardboard mailers for my own project in a month or two. When will you all be looking for testers?
Yvan256 wrote 01/30/2017 at 20:30 • point
Given that you don't need to be extremely precise to fold box panels, I'd go with servos which are geared internally instead of stepper motors. The servos are cheaper, more powerful and easier to drive too.
FourthLevelMfg wrote 01/31/2017 at 20:17 • point
We are testing both at this time, currently the stepper are winning for most parts.
Hackaday Prize 2020
Mostly 3D printed HAWT windturbine incl. 3D printed disk-generator and brake system.
Project Owner Contributor
WinDIY - HAWT Wind turbine
FabFab
Goal: Create a syringe pump to feed material to the Moineau Extruder or the Oogoo Mixer.
Syringe Pump
doctekdoctek
A vertical spinner approach (October 2015-)
RC Battlebot #2: Big Tooth
GertlexGertlex
Official Hackaday Prize Entry
A completely-open, scratch-built PUMA arm with 24" reach and 1lb payload
Open-Source 6-Axis Robotic Arm
Colin KingsburyColin Kingsbury
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "AutoFold the Box Folding Robot", please tell us the reason.
Send message
Remove Member
