Stickvise - low profile soldering vise
Stickvise is a low profile vise designed for PCB soldering. This product was born on Hackaday.io.
Thanks to Hackaday for helping me make this a product! They sold the first 1k Stickvises through their store, although it is no longer being sold there. <br><br>Find it now at:<br>- Amazon (<a target="_blank" rel="noopener noreferrer" href="http://amzn.to/2dgmQCE">http://amzn.to/2dgmQCE</a>)<br>- Adafruit (<a target="_blank" rel="noopener noreferrer" href="https://www.adafruit.com/products/3197">https://www.adafruit.com/products/3197</a>)<br><br>Stickvise is a low profile soldering vise that addresses several problems with PCB holders and vises currently on the market. <br><br>1) Most soldering aids are too tall, requiring your hands to hover in the air while soldering.<br><br>2) Most soldering aids are not capable of holding a flat object parallel to the table top, making it difficult to work under magnification without losing focus as you slide the subject around.<br><br>3) Higher end fixtures are too complex and expensive<br>
How it works:
- With the wing nut loose, the movable jaw can slide to any position along the shaft.
- To grab a circuit board, gently squeeze the jaws against board edges.
- Tighten wing nut to fix the movable jaw.
- Easily take circuit board in and out of spring loaded jaws
More Details
Stickvise comes with the basic components shown in the picture below. Scroll down to see some ideas for ways to enhance, customize and hack your vise.
If you have a 3d printer, you can download and 3d print some of the jaw designs that I have come up with.
If you need to hold something larger, buy a longer shaft or raise your jaws up using M3 standoffs. More details: http://stickvise.com/hacks/ots-upgrades
Finally if you have a custom idea, use my OpenSCAD script to design yourself a set of custom jaws, you can then 3d print or send out to have them made. I have designed the code to generate models such as the ones below by changing a few parameters at the top, no learning curve or coding knowledge necessary.
Stickvise_CupHolder_Jaw.stl
Make your Stickvise into a big spring loaded cupholder. This is one jaw, so two will need to be printed.
Standard Tesselated Geometry - 409.46 kB - 08/11/2017 at 18:34
Download
Stickvise_InterlockingV.STL
Interlocking Jaws - My favorite jaws, these hold a PCB as well as any size cylindrical part horizontally (from a small wire to a cable to a 1" diameter motor)
Standard Tesselated Geometry - 114.93 kB - 02/28/2016 at 12:24
Download
Stickvise_VJaw.STL
Jaws with vertical v-grooves for holding cylindrical parts upright
Standard Tesselated Geometry - 264.14 kB - 02/28/2016 at 12:24
Download
Stickvise_Grooved_Jaw.STL
wire grooves everywhere, this jaws is almost obsolete compared to the interlocking jaws, but it uses less printer material
Standard Tesselated Geometry - 177.82 kB - 03/04/2016 at 01:13
Download
Stickvise_TallJaw.STL
Raise the PCB up to acommodate tall components
Standard Tesselated Geometry - 30.94 kB - 02/28/2016 at 12:24
Download
View all 7 files
  • Stickvise Cupholder Jaws
    Alex Rich • 08/11/2017 at 18:39 • 0 comments
    I spilled coffee on myself two days ago, so I decided to design some cupholder jaws for Stickvise to help me avoid this situation in the future.  Now you too can make your Stickvise into a neat cupholder with this new set of jaws.
    https://cdn.hackaday.io/files/3287140631008/Stickvise_CupHolder_Jaw.stl
  • New Canadian Distributor! Buyapi.ca
    Alex Rich • 03/14/2017 at 15:06 • 0 comments
    Stickvise has a new distributor in Canada - Buyapi.ca. They are the largest distributor of Raspberry Pi merchandise in Canada and now they stock Stickvise!
    This should be a more cost effective option than ordering from a US distributor for all interested Candians!
    https://www.buyapi.ca/product/stickvise-the-low-profile-pcb-vise/
  • Time-lapse video milling PTFE jaws on the Shapeoko
    Alex Rich • 03/05/2017 at 20:37 • 4 comments
    I am using a very inexpensive Shapeoko 3 to produce precision milled PTFE jaws for Stickvise from my basement!
    Why don't I have the part molded or machined somewhere else? I project sales of about 200 pairs per year. Molding PTFE is a specialized process because of the very high temperatures, so it would only be warranted at higher volumes or if I could justify a much higher price point. Machining is more typical in this volume range, but outsourcing machining was still too expensive.
    To hit the price point I wanted and not commit to large manufacturing runs, I chose to get a machine to make the parts myself. This also meant I could justify having my own CNC at home, which I had wanted for a while.
    I'm happy to say the machine is working well and has already paid for itself. Most importantly, I have a new toy that I never would have bought otherwise.
  • Raspberry Pi Zero Jaws by bfesser
    Alex Rich • 12/23/2016 at 01:06 • 2 comments
    Check these out!
    This is exactly the kind of thing I had in mind for Stickvise - mod and hack to make custom fixtures for holding PCBs. These are a cool set of jaws by @bfesser that not only hold two RasPi zeros, but you can flip them around and hold any size PCB. There is actually a dual and a single jaw set available. Enjoy pics below, if interested in 3d printing these, head over to thingiverse to download.
    https://www.thingiverse.com/thing:1985615
  • New Stickvise distributor: Adafruit
    Alex Rich • 09/11/2016 at 21:17 • 14 comments
    After over a year of selling through the Hackaday Store I have expanded to add a new distributor - Adafruit!
    Super excited to expand the Stickvise audience, Adafruit is a really cool company. They did an amazing job on photographing Stickvise, check out some of the shots they took! Better than any I have taken for sure. Also on the Adafruit product page you can see a great video of Limor and Phil talking about it a little bit.
  • Ben Heck Show Stickvise sighting!
    Alex Rich • 07/11/2016 at 02:15 • 0 comments
    I sent Ben Heck a Stickvise a couple months ago, I thought it was a long shot to even get a response but I wanted to at least give it a try. You have to put yourself in his shoes, he probably gets tons of unsolicited crap shipped to him every week that people hope will make it into one of his videos. It turns out he was really nice, even sent me a thank you email when it arrived and told me that he was using it a few minutes after it arrived. Very cool of him to do that.
    I noticed in the show's latest video (covering the completion of his Hackmanji game) that Stickvise was on his bench in the background the whole time. Not sure what he's holding in the vise but it's an honor to see it being used!
    I sent his Stickvise out with a customized "Ben Heck Show" PCB, I thought it looked pretty cool:
    Here is the episode
  • Replacement Jaws
    Alex Rich • 04/24/2016 at 01:25 • 1 comment
    On Monday I'm shipping out Stickvise replacement jaws to the Hackaday Store! They should be available in the next week or so. For those who have damaged their jaws and want some spares, check them out. For starters there will be two options: standard nylon and high temperature PTFE
  • Milling a PCB outline on Stickvise
    Alex Rich • 03/22/2016 at 15:46 • 2 comments
    Still brainstorming the idea of using Stickvise for PCB milling. After a brief chat on Twitter with Danielle Applestone (owner of Other Machine Co. makers of the Othermill) I was inspired to delve further into this possible application. The main issue is full slotting, particularly parallel to the edges of the jaws where the PCB is most likely to slip. This morning I did some testing to see how Stickvise would handle this.
    Below are the results, not a bad start - didn't have movement in any of the five test boards I cut out.
    Sorry for the absolute bush league mistake of putting my finger over the lens, that's embarrassing. You can see more about the jaw design I'm using in this older project log.
    The info on the cut is as follows -
    Machine: Tormach 770
    Spindle Speed: 10,000 RPM
    Feed Rate: 10 in/min
    Tool: 1/8" diameter, 2 flute carbide endmill, uncoated, general purpose (I think I got it from McMaster)
  • Jaw production begins!
    Alex Rich • 03/21/2016 at 21:51 • 4 comments
    Ok everything went well today, I cut all of my blank material (made like 135 pieces, or 67.5 pairs) using a table saw, that worked great. Then I used my fixture to make 12 pairs of PTFE jaws. It's not a blazing fast process, I am going to have to be careful how I price these things as I could easily see myself wind up working for $2 per hour if I go too low.
  • Jaw Production Fixture Done
    Alex Rich • 03/20/2016 at 16:51 • 3 comments
    Check it out, fixture is done. I milled the aluminum on a Tormach 770, really an excellent machine.
    One fun thing about CNC is you can do things that wouldn't be feasible on a manual mill. I decided to go in and chamfer all of my edges using a Maritool 90 degree chamfer mill. You can see in the pics below there are perfect little beveled edges on everything, even the circles. It would have been overly tedious to do this on a manual machine, so you invariably would have hand filed. Nothing wrong with that technique, just doesn't look as cool!
    On top of that, I had some fun adding a bead blasted finish just to top it all off. I use an inexpensive Grizzly sandblast cabinet, and some fine glass bead media that I bought from McMaster years ago. This final step really makes tool marks disappear and leaves a nice matte finish, didn't need to sand or polish anything.
    Couple notes
    - tapping not done yet, will do that next
    - Thanks to @Jan for advice on my initial design. I added extra holes for clamping each part in two places instead of just one. I'm sure I won't regret that decision. We'll see how this works soon, stay tuned...
    below is the Maritool chamfer mill I used
View all 36 project logs
Marc Miller wrote 05/11/2021 at 03:01 • point
Hello @Alex Rich   Your cool Stickvise product inspired me to try making my own.  It was a great learning experience and I'm pretty pleased with how it came out.  Here are some photos.  https://imgur.com/gallery/R3sikB5
Roobotics wrote 06/10/2017 at 07:39 • point
(2 years later). The stickvise's at my workplace are still going strong with daily wear and tear, you've made an excellent product.
Just learning SCAD I was struggling to find a good end-use until I made a parametric copy of stickvise. But don't get me wrong, the weight and feel of the metal version will always be superior to a plastic imitation. :)
Alex Rich wrote 06/10/2017 at 13:51 • point
Cool, thanks for the note! Glad it is still working for you!
Jonathan Beri wrote 11/16/2015 at 17:00 • point
Any idea when they'll be back in stock on store.hackaday.com?
Alex Rich wrote 11/16/2015 at 17:13 • point
Yes!  They are in production now, scheduled to ship out on Nov 30 so they should be back in stock in December.  Sorry, thanks for inquiring - they didn't order more from me until the store went totally out of stock.  Better planning next time.  BTW - I need to check out your talk, looks interesting.  Wish I had been able to go to supercon.
Jonathan Beri wrote 11/16/2015 at 18:17 • point
Awesome! They gave out discount codes for the store so I plan on getting all the things on my list :)
Please do! And let me know if there's anything you're interested in learning more about. I expect the video to go up soon.
Alex Rich wrote 12/15/2015 at 00:36 • point
@Jonathan Beri - Stickvise is back in stock, sorry for the delay! http://store.hackaday.com/products/stickvise
Jonathan Beri wrote 12/17/2015 at 05:59 • point
Looking forward to adding it to my bench!
Martijn wrote 07/25/2015 at 13:20 • point
Did my first PCB with my own diy Stickvise yesterday. It's awesome, soldering will never be the same again.
What's your stance on other people sharing their own builds? (not only the jaws)
Alex Rich wrote 07/25/2015 at 13:25 • point
I'm all for it, please share your build!  Anyone who wants to make their own should do it, those who don't have the tools will find it easier to just buy one.
Martijn wrote 07/25/2015 at 17:59 • point
Great!, I just added mine. I think you'll like it. I will write a bit more detailed 'user experience' log later.
Roobotics wrote 07/08/2015 at 07:43 • point
Thanks for making this awesome project/product. I ordered 2 and took one to work, ended up ordering 3 more. I think you should consider a production run of the latest interlocking jaws if the shape isn't overly complex for manufacture.
Alex Rich wrote 07/08/2015 at 13:20 • point
Thanks for ordering a bunch and for the feedback Reed!  It is great to hear people getting good use out of Stickvise.  I do like the interlocking jaws, I might consider getting some made at some point, I wish there was an easy way to do it.  I would have to order in fairly high bulk to make the price reasonable.  Requires some cash investment.  Maybe I will try a small kickstarter at some point for various accessories.
haydn jones wrote 06/21/2015 at 15:18 • point
Mine has just aarrived and I'm using it already. Trying to make solenoids :)
Alex Rich wrote 06/21/2015 at 15:36 • point
haha cool, hadn't thought of using it like that.  Thanks for the pic!
zakqwy wrote 06/16/2015 at 21:18 • point
Just bought one--looks like a great product, stoked to ditch my Helping Hands!
Alex Rich wrote 06/16/2015 at 21:57 • point
thanks for the support!
Alex Rich wrote 06/16/2015 at 20:07 • point
wow, I'm glad you like it!  thanks for the stellar review, I will see if I can get hackaday to tweet it out for me.
Chris Wagner wrote 06/07/2015 at 13:36 • point
Thank you Alex for this very nice tool. I like it, because it can be modify.
I won it with my project for ESP8266-Modules.
https://hackaday.io/project/3965-esp8266-dev-board
Thank you hackaday, too.
Have a nice day.
Alex Rich wrote 06/07/2015 at 16:29 • point
thanks! Send pictures of how your using it. Cool project btw
Open Green Energy wrote 06/05/2015 at 00:46 • point
Thank you Alex for design this awesome PCB holder. I think its useful for all maker.
I won this  from HAD for my project on MPPT controller.
https://hackaday.io/project/4613-arduino-mppt-solar-charge-controller.
Alex Rich wrote 06/05/2015 at 00:52 • point
Thanks, your project is awesome very well explained so that someone who is not an electrical engineer can understand it (like me).  I hope you get good use out of your Stickvise!
Open Green Energy wrote 06/05/2015 at 01:07 • point
Thanks.
Yeah it will be very helpfulI for me.I am eagerly waiting for its arrival.
frankstripod wrote 06/04/2015 at 19:14 • point
Stickvise Rocks! Just won one and I can't wait to get it! :)
Alex Rich wrote 06/04/2015 at 19:22 • point
thanks!  looking forward to feedback
haydn jones wrote 06/04/2015 at 18:52 • point
Soon to be a proud owner courtesy of HAD, looking forward to using it :)
Alex Rich wrote 06/04/2015 at 19:00 • point
Awesome! thanks for the skull and follow - please let me know about your experience once you have used it a bit.
miawtthias wrote 06/04/2015 at 15:53 • point
I just received mine and it's awesome !
Alex Rich wrote 06/04/2015 at 16:20 • point
Sweet! Thanks for the skull/follow/feedback! Test it out in as many ways as you can and let me know what you like and don't like.
Ben Delarre wrote 05/29/2015 at 17:10 • point
Just wanted to say congrats on getting to market Alex. Hope it does really well for you.
I've been using mine and I absolutely love it. Don't know how I went so long without a PCB vice now!
Alex Rich wrote 05/29/2015 at 17:35 • point
Thanks Ben!  It has been such a fun experience, couldn't have done it without you and others believing in it!
Anool Mahidharia wrote 05/28/2015 at 12:04 • point
Awesome! I'll prolly pick one up when I next visit NoVa Labs in Sept this year. Also, check this out : http://hackaday.com/2015/05/09/printed-tentacles-for-pcb-probing/
Alex Rich wrote 05/28/2015 at 12:11 • point
Cool, I was just at NoVa Labs yesterday dropping off a couple of demo vises.
Yes I love the system in your article, I actually saw it on twitter before you guys wrote it up on HaD.  I printed one up and liked it so much I made a compatible jaw design for Stickvise that lets you attach two of those arms.  They work great, but I decided the ball and sockets came apart too easily so I designed an enhanced version (where I credited the original):
https://hackaday.io/project/5739-locking-ball-and-socket-gooseneck-system
Anool Mahidharia wrote 05/29/2015 at 09:29 • point
I read about the Stickvise on the NoVa labs chatter mailing list - Bob Coggeshall posted about it. :)
Alex Rich wrote 05/29/2015 at 11:55 • point
Cool, I got a ton of hits on my website from that email blast. @Bob Coggeshall is a great guy - I picked his brain about my project for a couple of hours the other day.  I'm hoping to get more involved at NoVa labs, wish I lived a little closer though.
davedarko wrote 05/19/2015 at 10:47 • point
I've seen Ben Heck NOT using this. You should sell this to him - he was soldering a board seesaw style :)  I'll definitely order one next time I'm in America!
Alex Rich wrote 05/19/2015 at 13:08 • point
Thanks Dave, I am putting together sample packs to send out to hopefully get reviewed by a few people here and there.  I will see if I can send him something.
Martijn wrote 05/09/2015 at 01:02 • point
Very nice product, It has 'why didn't I think of this' written all over it.
Alex Rich wrote 05/09/2015 at 01:07 • point
Thanks!  I hope it takes off, I am having so much fun with this.
Alex Rich wrote 05/08/2015 at 23:29 • point
@tmuel1123 @Fidel salinas Stickvise is available if still interested, if you do get one let me know how it works for you.  http://store.hackaday.com/products/stickvise
tmuel1123 wrote 05/09/2015 at 09:50 • point
Its on it's way. :-)
Alex Rich wrote 05/09/2015 at 11:56 • point
thanks for your support!
Alex Rich wrote 05/18/2015 at 21:10 • point
Did the Stickvise make it to you?  Interested to hear how it is working for you.
tmuel1123 wrote 05/18/2015 at 21:28 • point
No, not until now. It's still on its way. The tracking of the parcel says that it has left Frankfurt Airport on Friday (which is just a hour away from me). I assume that it will arrive during this week after it has (hopefully) passed the customs office unattended. Otherwise I will have to pick it up at the customs office and pay the tax to pick it up.
I will definitely give you a response after I have played with it.
tmuel1123 wrote 05/28/2015 at 20:25 • point
Hi Alex,
Today I have picked up my Stickvise from the customs office. I have played a little with it and I can say you that I already added it to the list of my favorite tools. It is very practical and easy to use. I also love the simplicity, there is not a single piece to much its just exactly what is needed.
Thank you very much for that great idea!
I've added some M3 plastic screws to the M3 threads on the bottom if the vise to avoid scratching the table.
tmuel1123 wrote 05/28/2015 at 20:29 • point
P.S.: Just forgot to use one word: AWESOME
Alex Rich wrote 05/28/2015 at 20:53 • point
Awesome, thanks for the kind words, so glad it made it to you and you like it!
Fidel salinas wrote 01/18/2015 at 16:00 • point
i'd love to add this to my work bench as well. Hope you do crowd fund.
Alex Rich wrote 01/18/2015 at 19:50 • point
Thanks @Fidel salinas. I am not crowd funding but the product is in production now, should be available in March if manufacturing goes smoothly. Follow the page, I will update as soon as it becomes available.
tmuel1123 wrote 01/02/2015 at 22:52 • point
Hi Alex, do you have any idea when and where I can by one of these?
