Log Entries
- Four phase clock generator
- More speeeeed!
- Testing speed of D Flip Flops
- One ALU Slice tested with real hardware
- ALU Slice design done
- Feeling the pressure
- CPU Emulator
- A 4-to-16 Decoder board
- Assembler for this CPU
- Instruction set
- UART RX Timing board done
- Bus Viewer with LEDs
- Testing of comparator-chain
- Added glitch detector for RX
- Soldering of the octal D-latch
- Received some parts
- Ordering NAND PCBs
- UART-RX
matseng
Brandon Reinhart
Eric Ljungquist
Yann Guidon / YGDES
Andrew Starr
ok, it can run Fuzix OS ?
