See http://www.instructables.com/id/Wifi-Webradio-With-ESP8266-and-VS1053 for the description of the minimal prototype.
See github source for the ESP32 version ( vs1053 or i2s or pcm or internal DAC)
See A project derived from KaRadio32 in progress.
See the lcd +IR software's on Github AddOn
See some realizations of users at KaraDio
A nextion touchscreen display for KaraDio from yo2ldk : Here
For more informations or questions, you can enter to the Karadio facebook group
KaRadio32 Release 1.9
KaRadio32: Release 1.9 Rev 0 - Built on 2019/02/16
- Improved encoder for new chinese device (shorter pulses) (reverse A/B in case of reverse way)
- Better vs1053 detection.
- RSSI display needed a click of a button to start.
- AP mode on init: the web page starts on the "Setting" panel and the stations list is skipped.
- Wifi option: If wifi is disconnected choose to reset or wait for the connection on the same SSID:
- Command wifi.auto("x") with x = 0: reboot, x=1: wait for the SSID
- For internal reasons, the touch screen needs to be calibrated again.
- No more fall back to i2s when the vs1053 is not detected. - Many small improvements in the code.
KaRadio: Release 1.8
Release 1.8 R2 - Built on 2019/02/10
New:
- 1.8:
- Ram optimization
- New edit panel with play/stop control
- New volume control on web with Ctrl arrow keys
- New upgrade indication on telnet, serial and web
- Web page look changed (a bit),
- Added the TZO on the setting page
- Added the mDNS hostname on the setting page
History:
For ESP32 see the github page KaRadio32. Release 1.6 R4
ESP8266 Simplest prototype:
- Optional external ram (23LCV1024) support (1:CS/=GPIO16 2:MISO=GPIO12 3:NC 4:GND 5:MOSI=GPIO13 6:SCK=GPIO14 7:GND 8:3.3v)
Attention:
The optional led is now on GPIO2. The blue led on the ESP8266 is blinking at the same rate.
GPIO16 is now the Chip select for the external ram if any.
The external ram is detected at boot time if present.
To upgrade to this release, please flash user1.4096.new.4.bin at 0x1000 ,
user2.4096.new.4.bin at 0X81000 and blank.bin at 0x7e000 & 0x3fe000
After that, all next updates are done with the On The Air (OTA) feature.
New binaries are hosted at http://karadio.karawin.fr .
Loading the esp8266
- https://github.com/karawin/Ka-Radio/blob/master/ESP8266-Firmware/bin/boot_v1.5.bin at 0x0000
- https://github.com/karawin/Ka-Radio/blob/master/ESP8266-Firmware/bin/upgrade/user1.4096.new.6.bin at 0x1000
First use
- If the access point of your router is not known, the webradio initializes itself as an AP. Connect your wifi to the ssid "WifiWebRadio",
- Browse to 192.164.4.1...
Hello!
I want a firmware that runs the SH1106 LED display, unfortunately I couldn't solve it ... Thank you! Sorry for my weak English knowledge! If I were to get a link it would be the simplest ... The display is 128x64 size 1.3 ".
