close-circle
WiFi Webradio with ESP8266 and VS1053
A wifi web radio player with only low costs boards.
KaRadio, listen the world.
Control with any browsers (ie edge, chrome mozilla etc...).
or with an external hardware panel or with the uart interface.
Memory for 255 stations
OTA upgrade
Read direct mp3 or ogg streams or playlist .pls .m3u and .xspf
Read up to a 320 kb/s stream,
Embedded wifi configuration via the web or uart interface
Metadata displayed (ie Title of the current song if given in the stream),
All settings saved (sound setting, stations, wifi)
Server multi clients with automatic refresh for all (websocket),
The stations can be downloaded and uploaded within the web site,
Stations sort management by drag drop.
very quick responsive web by caching local information in the browser and websocket.
additional hardware: a led indicates the state of the equipment (gpo2->resistor->led->3.3volt). Speed blink: init, 90%in 10%out: connection in progress, 10% in 90%out: Equipment ready.
Optional: control switches, lcd display., additional ram for buffering.
See http://www.instructables.com/id/Wifi-Webradio-With-ESP8266-and-VS1053 for the description of the minimal prototype.
See Github for sources
See the lcd +IR software's on Github AddOn
See some realizations of users at KaraDio
A nice telnet+IR extension from Gábriel Kovács gabeszakem@gmail.com: ESP8266-WiFi-UART-Bridge-master.zip
A nextion touchscreen display for KaraDio from yo2ldk : Here
For more informations or questions, you can enter to the Karadio facebook group
Release 1.4
New:
  • A telnet server multi clients on port 23. It is the same interface as the uart one. So the low level management can be done via the network and it offers a complete interface for remote addons.
  • A deep modification of the memory management. More free room.
  • new commands: help and sys.adc.
  • The web volume command is now on a POST if the websocket is not ready.
Bugs resolved:
  • a problem on the web interface close resolved.
Built on 2017/07/19
Older releases:
  • Blink task replaced with an os timer. More memories.
  • Edit station now in modal window
  • Added a mouse event on full url
  • New control buttons on the web interface
  • A potential huge bug removed
Bugs resolved:
  • A problem when a control panel and an addon are present is removed
  • A problem with the AP2 password not working is removed (regression).
  • Volume correction for the control panel.
  • The volume is now saved every second if needed (less stress for the flash).
  • Stability
- New uart command: sys.date Send a ntp request and Display the current locale time
- New uart command: sys.tzo Display or change the timezone offset
See Interface.txt-
New No needs to parse the url of stations on the web interface. Now it can be done automatically.
- New uart command: cli.info Display nameSet, all icy and volume. Used to synchronize the lcd extension.
- cli.list command modified.
- Now Both AP SSID and AP Password are encoded to permit special characters like & : etc
- "Restore stations" corrected for some heavy lists
- Station information now give the number of the current station
- retry client connection modified to avoid blocking situation.
- Modification of the list of uart command. See uart and html interfaces
- New sys.patch command. Inhibit or permit (default) the load of a vs1053 patch for AAC stations.
- New sys.led command. Default is blinking mode, or Play mode: the led is on when a station is playing.
- Modification of the wifi.con command. Now the AP can be set in the AP
mode (192.168.4.1) without the need of the web interface.
- New print button on the Stations panel: Print the list of stations, number and name.
- New logo ;-)
- Many bugs removed thanks to users feedback's.
- New IR and LCD software
- Autoplay corrected
- Now 2 AP's can be set. The second one will be tested if the first is not detected.
- The Mac address of the radio is displayed
- An offset volume can be set for each station in Station editor.
- Added: a reset button for the equalizer
- Pb on Autostart not correctly checked: corrected
- New html command: instant="http://your url"
- The path of a station can now include some & parameters.
-- Uart command list now can take a parameter: the number of the station to display.
.If no parameter, the complete list is sent.
- New wake and sleep features. Two modes: Time mode: "hh:mm" to wake or sleep at a given hour, or the delay mode "mm".
- Many minors html adjustments.
- The user agent for http request can be set for some special streams.Example: http://pcradio.ru/player/listradio/pcradio_ru.xml
which need a user agent= pcradio.
This pcradio user agent is already implemented automatically in the code when a pcradio station is encountered.
- Drag an drop on the stations list: rearrange the list by dragging a line to another one. Save the change when asked.
- Themes toggle between light blue and dark marron theme with a click on the logo.
- Sleep mode to stop the play after a delay.
- Functions on the web...
octet-stream - 409.29 kB - 07/19/2017 at 14:26
download-circle
Download
download-circle
Download
boot_v1.6.bin
A new one. Don't know what is new.
octet-stream - 3.77 kB - 01/10/2017 at 11:04
download-circle
Download
octet-stream - 4.00 kB - 07/21/2016 at 15:19
download-circle
Download
esp_init_data_default.bin
Must be written only one time.
octet-stream - 128.00 bytes - 07/21/2016 at 15:18
download-circle
Download
View all 6 files
View all 6 components
View all 11 project logs
  • 1
    Step 1
    Wiring:
    From ESP8266_ESP12( 3.3 v) or nodeMCU(5v) to VS1053 (5 v)
    REST:
    ADC : gound if control panel not used
    CH_PD to 3.3v
    GPIO16 led output
    D5:GPIO14 to VS1053 SCK
    D6:GPIO12 to VS1053 MISO (or so)
    D7:GPIO13 to VS1053 MOSI (or si)
    TXD to CH340G UART rx
    RXD from CH340G UART tx
    D1:GPIO05 to VS1053 XDCS
    D2:GPIO04 to VS1053 DREQ
    D3:GPIO00 to VS1053 XRST
    GPIO02
    D8:GPIO15 to VS1053 XCS
  • 2
    Step 2
View all instructions
jan wrote 02/12/2017 at 15:40 point
Hi JP the ESP 8266 is not starting when I connect it to the USB port I have to press the reset button on the ESP 8266 to start it up  then its going oke
is it possible to get it started directly ? or by a command from Arduino
Is it possible to get time information sent to tx
jp cocatrix wrote 02/12/2017 at 21:29 point
Not sure to be able to do something for that. May be a weak usb?.
It works ok here.
The time is only on the browser for the moment. Do you need the time for displaying on the lcd?
jan wrote 02/12/2017 at 21:36 point
Yes i like the time on the Nextion diplay
jan wrote 04/15/2017 at 19:18 point
Thanks JP for the time for the display I not yet have it fix for my self butt will at it soon to the screen.
Sergio wrote 02/06/2017 at 05:02 point
Hi JP, since update 1.14 or 1.1.5and 1.1.6, i have something extrange with my player, after 30 min of playing the player stops alone. i have to push again the play button to continue listening a radio station. i testing for some hours and this problem happend every 30 min. can you check the sleep/wake code? Thanks.
jp cocatrix wrote 02/06/2017 at 06:50 point
When the stream disappear, a connection is retried once.
In Log you see:
##CLI.STOPPED# from try restart
##CLI.PLAYING#
##CLI.PLAYING#
##CLI.STOPPED# from data not played
The timeout is 10 seconds for a registered station and 2 seconds for an instant play.
The wake/Sleep code has nothing to do here.
Sergio wrote 02/06/2017 at 14:47 point
Thanks JP for your help, now i see this in log
##CLI.STOPPED# from clientConnect
##CLI.PLAYING#
But no sound on the speakers
i have to reset de player
jp cocatrix wrote 02/07/2017 at 13:16 point
You are right, a problem found when the stream disappears for a while.
I will debug. Thanks
yo2ldk wrote 02/03/2017 at 19:15 point
I publish my project with all need it to adapt the Nextion touchscreen on KaRAdio:
  https://hackaday.io/project/19707-nextion-touchscreen-display-for-web-player-karadio
jp cocatrix wrote 02/03/2017 at 20:15 point
Great.
JP Means Jean-Pierre ;-)
jan wrote 01/31/2017 at 20:29 point
Hi I have a question is it possible to connect a Nextion touch screen to it to control the radio
I love the web radio and the possibility to  update it thru the web interface I like to use this project to at it in a shower project I`m doing at this moment the Nextion wil be built in to controle the shower like temp end the 6 massage jets I like to ad the web radio into this project
jp cocatrix wrote 01/31/2017 at 20:40 point
https://hackaday.io/yo2ldk done  it. Contact him.
ldv82 wrote 01/31/2017 at 18:54 point
Send commands sys.patch ( "0"). How do I know if it is adopted? Thank you. Everything worked. But I did not understand why. Many times you enter a command sys.patch ( "0"), but it did not help. More will not upgrade the firmware unnecessarily in this.
jp cocatrix wrote 01/31/2017 at 20:03 point
##CLI.URLSET#: stream.pcradio.biz
##CLI.PATHSET#: /Ruki_Vverh-low
##CLI.PORTSET#: 8000
##CLI.OVOLSET#: 0
##CLI.VOL#: 79
Header: Moved
##CLI.STOPPED# from C_HEADER
##CLI.URLSET#: 85.25.43.52
##CLI.ICY0#:  Ruki_Vverh
##CLI.ICY3#:  http:\/\/www.pcradio.ru\/
##CLI.ICY4#:  Misc
##CLI.ICY5#:  24
##CLI.ICY6#:  Liquidsoap Radio!
##CLI.ICY7#:  channels=2;samplerate=44100;bitrate=24
##CLI.PLAYING#
##CLI.META#:
##CLI.VOL#: 132
##CLI.META#: Руки Вверх! - Убегай
It play well! but only with the patch.
Without it, the vs1053 crash.
If the patch is loaded you see:
VS Version (VS1053 is 4) = 4
SCI_ClockF = 0xB800
I2S Speed: 0
plugin size 18ce 2 c67
plugin start: 7 1 8050 6
scandone
Do a sys.patch ( "1") to enable it again, and reboot.
Are you sure to have the last release? Do an OTA upgrade please.
This is an alpha command not yet documented.
ldv82 wrote 01/31/2017 at 20:26 point
Yes. Already there were rows in the log
Tried sys.patch command ( "1") of the sample. Maybe it helped.
What is the difference sys.patch command ( "0") and sys.patch ( "1")?
jp cocatrix wrote 01/31/2017 at 20:42 point
sys.patch ( "0")  inhibe the patch loading at reboot
sys.patch ( "1")  load the patch at reboot.
Some vs1053 doesn't support the patch, so i added this advanced command.
ldv82 wrote 01/30/2017 at 12:21 point
JP cocatrix
Upgrading to version 1.1.5+ via OTA already have? I updated via OTA and just hang on AAC channels began again. And I do not have the firmware 1,1,5, which worked.
It would be nice to be able download the last stable version of firmware.
jp cocatrix wrote 01/30/2017 at 12:38 point
Sorry, i don't understand your request.
AAC Channel?
Send a log please.
I don't want to store old release. Just make the new one working for everybody.
jp cocatrix wrote 01/30/2017 at 12:55 point
This release adds the official patch for aac. If it is a problem, send
sys.patch("0")
And reboot again.
It seems that some vs1053b are not really up to date to accept this patch.
No mean to see it from the software. (vs version is 4 for all vs1053)
vis22 wrote 01/28/2017 at 11:28 point
Currently OTA passes starts WEB interface to 192.168.4.1.
After entering the existing AP SSID: AP PASSWORD and Validate their begin to pour in on UART
Fatal exception (0):
epc1 = 0x401000bb, epc2 = 0x00000000, epc3 = 0x4028251f, excvaddr = 0x00000000, depc = 0x0 0000000
I returned to version 1.1.5 from 24.01.2017.
jp cocatrix wrote 01/28/2017 at 12:27 point
Tested with 2 old prototypes, and a brand new one succesfully.
May be another problem?
vis22 wrote 01/28/2017 at 08:44 point
Dear jp cocatrix, seems to firmware 1.1.5 is not workable, as is the case of OTA and the github.kom, had through UART revert to version 1.1.4.
jp cocatrix wrote 01/28/2017 at 09:12 point
Yes, true. A wrong update. Do an OTA again.
Thanks a lot.
Tell me if it works now.
vis22 wrote 02/04/2017 at 23:29 point
Sorry, but there is really only Problem with ESP8266-7 (tested on 3 copies). With ESP8266-12 no problem.
jp cocatrix wrote 02/05/2017 at 09:12 point
vis22 wrote 10 hours ago
Sure, it is linked for esp8266 with 4MBytes only for OTA. (esp12 is ok)
I never tell that it support other flash size.
Pierre-Francois Bonnefoi wrote 01/26/2017 at 10:18 point
Wonderful project : tried it, love it ! Two suggestions : implement mDNS for easy discovery and allow two manual IP configurations, one for each provided AP.
jp cocatrix wrote 01/26/2017 at 17:49 point
The free ram memory is critical. So i am not sure to implement mDNS.
Less critical is the ip conf for each AP.  For the moment I recommend to use a static DHCP lease to avoid the need of two fixed IP. With a well configured router, it is transparent. That's why I added the MAC address. I have to develop a new bank in eeprom to store more permanent configurations. The first one is full, that's why I postponed the second IP.
Thanks for your suggestions and appreciations.
Dominique GEORGES wrote 01/25/2017 at 23:21 point
Very good project : step 1 OK for me : module ESP8266 OK. Now I wait module VS1053 and go !
Thank you for your help. DOM from France !
vis22 wrote 01/25/2017 at 16:30 point
Many thanks.
vis22 wrote 01/24/2017 at 21:00 point
Many thanks!!!
I will try to connect the IR remote from the boom box.
P.S. Dear jp kokatriks, in the current version karadioU8glib.ino on github.com no strings the #define IR and the #ifdef IRLib2 ?
jp cocatrix wrote 01/24/2017 at 21:56 point
vis22 wrote 01/24/2017 at 18:05 point
Спасибо за совет.
Выход модуля питания 5V установлен конденсатор 220 мкФ.
Технический паспорт для vc1053 рекомендует конденсаторы 22 мкФ в силовых цепях.
Установленная на плате модуля С17 и С18 были сомнительными номинальным.
Под руки были только 100 мкФ.
В результате, цель достигнута, отказы прекратились.
Могу ли я узнать ИК-датчик схема проводки и способ настройки командных кодов ИК?
jp cocatrix wrote 01/24/2017 at 18:12 point
In u8glibConf.h of the software:
**** Instruction for the IR module *****************************************************************************************
The model used here is from:
https://www.aliexpress.com/item/Hot-Selling-1pcs-New-Infrared-IR-Wireless-Remote-Control-Module-Kits-For-Arduino-Wholesale/32334118062.html?spm=2114.13010608.0.0.XzmgYk
or equivalent. Cost less than 1$
- Based on NEC protocol; Built-in 1 x AG10 battery;
- Remote control range: above 8m;
- Wavelength: 940Nm;
- Frequency: crystal oscillator: 455KHz; IR carrier frequency: 38KHz
// IR library
Install the library from https://github.com/cyborg5/IRLib2
Uncomment the #define IR  and the #ifdef IRLib2 at the beginning of the karadioU8glib.ino file.
The IR receiver pins:
From left to right (pin at bottom, sensor in front of you)
Gnd VCC Signal
The signal must be connected to
For mini #define PIN_IRRECV  2  or 3
For micro #define PIN_IRRECV  2  or 3 or 7
In karadioU8glig.ino:
//  Uncomment the following line to see the code of your remote control and report to the case the value
//        Serial.print("Protocol:");Serial.print(results.decode_type);Serial.print("  value:");Serial.println(results.value,HEX);
If you want to use another remote, you can see the code of the keys and modify the switch case for the needed function.
See IRremote.h  to add the protocol you need for the remote.
The tx of the pro mini must be connected to the rx of the esp12 but
Warning; the esp rx pin is not 5V tolerant, so if your pro mini is a 5v version we need to adapt the level.
See
http://www.instructables.com/id/Pi-Cubed-How-to-connect-a-33V-Raspberry-Pi-to-a-5V/
The value of the resistors is not critical. Only the ration 1/3 2/3 must be respected 1k and 2k for example)
Enjoy.
Sergio wrote 01/23/2017 at 23:40 point
Hi JP,
Autoplay dosn't work correctly, every time I turn the player on, I have to press the play button, to start the radio playing
jp cocatrix wrote 01/24/2017 at 02:22 point
update please.
Sergio wrote 01/24/2017 at 11:00 point
With the last update, i don't have sound with any stations
jp cocatrix wrote 01/24/2017 at 12:22 point
Do another ota update, and enter the command on uart:
sys.patch("0")
And reboot again.
I wonder why your prototype doesn't like the vs1053 patch.
Are you alone in the world? May be some other problem on wire can explain it?
Sergio wrote 01/24/2017 at 14:28 point
Till i'm update the player  to the last update works ok, the only problem was that the autoplay doesn´t work ok. No wire problems, i´ll try with the uart command that you said.
Sergio wrote 01/25/2017 at 00:10 point
now works, on 2 players i have to entered the command on the uart
Thanks, may be a problem with the VS1053 patch
jp cocatrix wrote 01/25/2017 at 09:16 point
The vs1053 patch is the official one. No problem with it. May be a spi error on transfert? The wires are longs between the esp and vs?
vis22 wrote 01/23/2017 at 17:45 point
May be. The power supply used DC-DC step-down module LM2596 powered by the voltage regulator +12 V boom-box.
ESP8266-12 randomly stopped communication with VS1053, assuming a fault ESP8266-12 replaced it ESP8266-7 effect it is not received, the modules behave as well. Only extra capacitors ensure their reliable operation.
jp cocatrix wrote 01/23/2017 at 18:13 point
May be a high frequency filter with a few pf, and a 22µf on the 5 volts only?
vis22 wrote 01/22/2017 at 19:04 point
The recommended VS1053 module has to install additional capacitors 22 microfarads in parallel of C17 and C18 to the supply chains. Without them, the module sometimes freezes.
jp cocatrix wrote 01/22/2017 at 19:25 point
Never seen on more than 10 prototypes.
May be a power supply problem on your prototype before these regulators?
Paul wrote 03/14/2017 at 04:10 point
Hi, what caps do you recommend, just ceramic SMC's?
jp cocatrix wrote 03/14/2017 at 18:07 point
I never experimented a freeeze of the vs1053.
archetix wrote 01/20/2017 at 06:07 point
HI T4SPAM,
exactly
amp would be activated only during playback
(It prevents clatter at start-up)
the rest suppresses  filter
Please excuse my bad English
(CZech > EN Google translate)  :-)
Thomas wrote 01/20/2017 at 08:00 point
Great. Pin D4(GPIO2) is already in use for LED on Button Interface.
But we can use Pin Playing 12 on LCD MCU as well.
Regards
Thomas
archetix wrote 01/20/2017 at 09:16 point
Pin D4 (GPIO2) is already in use for LED on Button Interface ...
I would therefore suggest a new feature firmware for ESP8266
configuration GPIO2
LED out
or
amp control
thus enabling control amplifier without display
jp cocatrix wrote 01/20/2017 at 10:27 point
Yes, I can also add a sys command to choose between the blinking default and the playing status on gpio2
archetix wrote 01/20/2017 at 12:47 point
HI jp cocatrix,
It would be great
Thank you in advance
Archetix
jp cocatrix wrote 01/20/2017 at 16:38 point
No problem. in the next release
sys.led("x")  with x=0 default blink, x=1 led On when playing (state saved in eprom)
Ok?
archetix wrote 01/20/2017 at 17:58 point
OK
Thank you very much
archetix wrote 01/19/2017 at 13:52 point
Hello I want to commend this great project.
I have a suggestion for a configuration option GPIO2
such as switch power amplifier
could be a useful function (standby mode)
Thank you...
Thomas wrote 01/20/2017 at 04:59 point
Hi Archetix,
i also tried to use  a Pam based amplifier beacause it is very cheap.
But i has very frustrating klicking when loudness is low. i guess your cirquit can eleminate that, right?
Regards
Thomas
jp cocatrix wrote 01/20/2017 at 16:33 point
Well done for the ground to avoid loop!
vis22 wrote 01/15/2017 at 20:10 point
Thank you for your project, it is allowed to breathe life into my boom-box.
jp cocatrix wrote 01/15/2017 at 20:53 point
You are welcome.
Sergio wrote 01/15/2017 at 14:59 point
The new updates, load into WEb browser more quickly than old versions.
jp cocatrix wrote 01/15/2017 at 15:42 point
Yes, a bug in the websocket corrected.
