close-circle
WiFi Webradio on ESP8266 or ESP32
KaRadio
A fully featured wifi web radio player with only low cost boards.
with or without a vs1053 board
close
Control with any browsers (ie edge, chrome mozilla etc...).
or with an external hardware panel or with the uart interface or with telnet.
Memory for 255 stations
OTA (On the Air) upgrade,
Read direct mp3 or ogg or WMA streams or playlist .pls .m3u, asx and .xspf
Read up to a 320 kb/s stream,
Encoder, IR, lcd ...
Embedded wifi configuration via the web or serial or telnet.
Metadata displayed (ie Title of the current song if given in the stream),
Permanent setting (sound setting, stations, wifi)
Server multi clients with automatic refresh (websocket),
The stations may be downloaded and uploaded within the web site,
Stations sort management by drag drop.
very quick responsive web by caching local information in the browser and websocket.
additional hardware: a led indicates the state of the equipment
Optional: control switches, lcd display, additional ram for buffering
See http://www.instructables.com/id/Wifi-Webradio-With-ESP8266-and-VS1053 for the description of the minimal prototype.
See Github for sources
See github source for the ESP32 version ( vs1053 or i2s or pcm or internal DAC)
See A project derived from KaRadio32 in progress.
See the lcd +IR software's on Github AddOn
See some realizations of users at KaraDio
A nextion touchscreen display for KaraDio from yo2ldk : Here
For more informations or questions, you can enter to the Karadio facebook group
Release 1.6.2
Built on 2017/11/02
New:
  • 1.6.2 Add of the rssi (Received Signal Strength Indication -30:best, -99:worst) at top right of the web page.
  • 1.6.1: Click on header to rewind to the top of a page.
  • Header stays on top of the web page
  • gzipped html tranfert. More stable and improved speed
  • The page content follows the header size.
History:
history
For ESP32 see the github page KaRadio32
ESP8266 Simplest prototype:
- Optional external ram (23LCV1024) support (1:CS/=GPIO16 2:MISO=GPIO12 3:NC 4:GND 5:MOSI=GPIO13 6:SCK=GPIO14 7:GND 8:3.3v)
Attention:
The optional led is now on GPIO2. The blue led on the ESP8266 is blinking at the same rate.
GPIO16 is now the Chip select for the external ram if any.
The external ram is detected at boot time if present.
To upgrade to this release, please flash user1.4096.new.4.bin at 0x1000 ,
user2.4096.new.4.bin at 0X81000 and blank.bin at 0x7e000 & 0x3fe000
After that, all next updates are done with the On The Air (OTA) feature.
New binaries are hosted at http://karadio.karawin.fr .
Loading the esp8266
First use
  • If the access point of your router is not known, the webradio initializes itself as an AP. Connect your wifi to the ssid "WifiWebRadio",
  • Browse to 192.164.4.1 to display the page, got to "setting" "Wifi" and configure your ssid ap, the password if any, the wanted IP or use dhcp if you know how to retrieve the dhcp given ip (terminal or scan of the network).
  • In the gateway field, enter the ip address of your router.
  • Validate. The equipment restart to the new configuration. Connect your wifi to your AP and browse to the ip given in configuration.
  • Congratulation, you can edit your own station list. Don't forget to save your stations list in case of problem or for new equipments.
  • if the AP is already know by the esp8266, the default ip at the first start is 192.168.1.254
  • a sample of stations list is on https://github.com/karawin/Ka-Radio/blob/master/ESP8266-Firmware/WebStations.txt . Can be uploaded via the web page.
Feedback
Please tell me if you succeeded or something more can be done, thanks.
The second step will add some hardware buttons (vol + -, station + -, play ...)
Wiring:
From ESP8266_ESP12( 3.3 v) or nodeMCU(5v) to VS1053 (5 v)
REST
ADC
CH_PD to 3.3v
GPIO16 (a 1Hz output)
D5:GPIO14 to VS1053 SCK
D6:GPIO12 to VS1053 MISO
D7:GPIO13 to VS1053 MOSI
TXD to CH340G UART rx
RXD from CH340G UART tx
D1:GPIO05 to VS1053 XDCS
D2:GPIO04 to VS1053 DREQ
D3:GPIO00 to VS1053 XRST
GPIO02
D8:GPIO15 to VS1053 XCS
application/octet-stream - 368.60 kB - 09/17/2017 at 10:26
download-circle
Download
download-circle
Download
octet-stream - 3.98 kB - 09/17/2017 at 10:26
download-circle
Download
octet-stream - 4.00 kB - 07/21/2016 at 15:19
download-circle
Download
esp_init_data_default.bin
Must be written only one time.
octet-stream - 128.00 bytes - 07/21/2016 at 15:18
download-circle
Download
View all 6 components
View all 11 project logs
  • 1
    Step 1
    Wiring:
    REST:
    ADC : gound if control panel not used
    CH_PD to 3.3v
    GPIO16 led output
    D6:GPIO12 to VS1053 MISO (or so)
    D7:GPIO13 to VS1053 MOSI (or si)
    GPIO02
  • 2
    Step 2
View all instructions
vanilinman wrote 04/01/2017 at 23:01 point
I solved the problem of crackles.I shorten the loop of wires between the modules (I connected without a breadboard).Thanks for the tips.
vanilinman wrote 04/01/2017 at 21:48 point
Thank you. You are super. It began to play. Please tell me how to get rid of crackles in the headphones. I tried various sources of power, it does not help.
jp cocatrix wrote 04/01/2017 at 21:52 point
I don't have this problem.
Check the ground wires (try another gnd entry may be) and try to short it (and all other....
Enjoy.
JP
vanilinman wrote 04/01/2017 at 20:54 point
Hello friends. Help is needed. I picked up the radio for Wemos D1 Mini following the instructions, but it does not want to play. The port writes:
##CLI.STOPPED# from playStationInt
##CLI.NAMESET#: 1 Record
##CLI.URLSET#: air.radiorecord.ru:8101/rr_320
##CLI.PATHSET#: /Icecast 2.3.3-kh10
##CLI.PORTSET#: 80
##CLI.OVOLSET#: 104
##CLI.STOPPED# from clientConnect
##CLI.VOL#: 254
jp cocatrix wrote 04/01/2017 at 21:02 point
url: air.radiorecord.ru
Port: 8101
Path: /rr_320
And it will work.
##CLI.STOPPED# from Post instant_play
##CLI.PATHSET#: /rr_320
##CLI.PORTSET#: 8101
##CLI.OVOLSET#: 0
##CLI.VOL#: 72
##CLI.ICY0#: Radio Record
##CLI.ICY4#: Dance
##CLI.ICY5#: 320
##CLI.ICY7#:  ice-samplerate=44100;ice-bitrate=320;ice-channels=2
##CLI.PLAYING#
##CLI.META#: Bounce Inc - Faith
Thomas wrote 02/18/2017 at 09:50 point
Hi JP, how is the correct Syntax to Change UART Baud over Browser?
jp cocatrix wrote 02/18/2017 at 09:54 point
Thomas wrote 02/18/2017 at 10:05 point
Hi JP, i already found but dont understand. Is it 192.168.2.136/sys.uart("19200") for example? This Dont Work so i guess my Syntax ist wrong
jp cocatrix wrote 02/18/2017 at 10:11 point
Two different interfaces:
On browser:
192.168.2.136/?uart   revert the uart to 115200 until a reset. Useful in case you don't remind the current speed.
But on the uart interface (serial on tx rx)
sys.uart("115200")
Or other speed to change the uart baud rate on the next reset and forever until another sys.uart command.
115200 is the default. Before connecting a display controller, you must change to 28800.
Thomas wrote 02/18/2017 at 10:23 point
Ok, its a pitty. I  thought it could be adjusted on browser also. Is it possible to read the curren setting of baud on the browser? I unfortunatly have no communication between display controller and Esp . And want to check this first before Disassemble my Radio to connect it to a computer.
Thomas wrote 02/20/2017 at 11:07 point
Hi JP i know that your Standard setting is 28800. But i changed it both to 19200 because 28800 is not selectable with Arduino Serial Monitor. This works fine for me, also with IR Receiver on a pro Mni with 8 Mhz and 3,3 Volts.
In the past i had sometimes trouble with self changing settings on the Baudrate.
But in this case i checked now with computer, it hasnt changed.  I detached the esp Module and mount it again, and now Display works again.
It seems that my build on a protoboard is not much better than on a breadboard.
Regards
Thomas
Sergio wrote 02/13/2017 at 17:01 point
Hi JP, its posible to replace the VS1053 by a Bluetooth, to play the streams on some audio equipments or BT earphones?
jp cocatrix wrote 02/13/2017 at 17:17 point
To replace the vs1053? No, absolutely no, it is the stream decoder (mp3 aac etc).
But you can add a bluetooth transmitter after to send audio.
http://www.ebay.com/itm/EEEKit-Bluetooth-Transmitter-Receiver-Wireless-A2DP-Stereo-Audio-Music-Adapter-/192080524398
https://www.aliexpress.com/item/Bluetooth-launch-module-CSR57E6-bluetooth-audio-transmitter-module-DC5-24V/32780319150.html?spm=2114.01010208.3.25.IYofEc&ws_ab_test=searchweb0_0,searchweb201602_4_10065_10068_10000074_10000032_119_10060_10062_10056_10055_10000062_10054_10059_10099_10000013_10103_10102_10000016_10096_10000056_10000059_10052_10053_10107_10050_10106_10051_10000097_10000094_10000053_10000007_10000050_10084_10000100_10083_10000047_10080_10082_10081_10110_10111_10112_10113_10114_10115_10037_10033_10000041_10000044_10078_10079_10077_10000038_10073_10000035_10122_10121,searchweb201603_10,afswitch_2,ppcSwitch_5,single_sort_1_default&btsid=009badba-8b67-45c2-af4c-2ccb512e3c12
https://www.aliexpress.com/item/High-Quality-Mini-3-5mm-Bluetooth-Audio-Transmitter-A2DP-Stereo-Dongle-Adapter-for-TV-Mp3-Mp4/32783336194.html?spm=2114.01010208.3.83.nyyA3a&ws_ab_test=searchweb0_0,searchweb201602_4_10065_10068_10000074_10000032_119_10060_10062_10056_10055_10000062_10054_10059_10099_10000013_10103_10102_10000016_10096_10000056_10000059_10052_10053_10107_10050_10106_10051_10000097_10000094_10000053_10000007_10000050_10084_10000100_10083_10000047_10080_10082_10081_10110_10111_10112_10113_10114_10115_10037_10000041_10000044_10078_10079_10077_10000038_10073_10000035_10122_10121,searchweb201603_10,afswitch_2,ppcSwitch_5,single_sort_1_default&btsid=7bf82844-0d36-4b60-b01b-2619dfaded88
jan wrote 02/12/2017 at 15:40 point
Hi JP the ESP 8266 is not starting when I connect it to the USB port I have to press the reset button on the ESP 8266 to start it up  then its going oke
is it possible to get it started directly ? or by a command from Arduino
Is it possible to get time information sent to tx
jp cocatrix wrote 02/12/2017 at 21:29 point
Not sure to be able to do something for that. May be a weak usb?.
It works ok here.
The time is only on the browser for the moment. Do you need the time for displaying on the lcd?
jan wrote 02/12/2017 at 21:36 point
Yes i like the time on the Nextion diplay
jan wrote 04/15/2017 at 19:18 point
Thanks JP for the time for the display I not yet have it fix for my self butt will at it soon to the screen.
Sergio wrote 02/06/2017 at 05:02 point
Hi JP, since update 1.14 or 1.1.5and 1.1.6, i have something extrange with my player, after 30 min of playing the player stops alone. i have to push again the play button to continue listening a radio station. i testing for some hours and this problem happend every 30 min. can you check the sleep/wake code? Thanks.
jp cocatrix wrote 02/06/2017 at 06:50 point
When the stream disappear, a connection is retried once.
In Log you see:
##CLI.STOPPED# from try restart
##CLI.PLAYING#
##CLI.PLAYING#
##CLI.STOPPED# from data not played
The timeout is 10 seconds for a registered station and 2 seconds for an instant play.
The wake/Sleep code has nothing to do here.
Sergio wrote 02/06/2017 at 14:47 point
Thanks JP for your help, now i see this in log
##CLI.PLAYING#
But no sound on the speakers
i have to reset de player
jp cocatrix wrote 02/07/2017 at 13:16 point
You are right, a problem found when the stream disappears for a while.
I will debug. Thanks
yo2ldk wrote 02/03/2017 at 19:15 point
I publish my project with all need it to adapt the Nextion touchscreen on KaRAdio:
  https://hackaday.io/project/19707-nextion-touchscreen-display-for-web-player-karadio
jp cocatrix wrote 02/03/2017 at 20:15 point
Great.
JP Means Jean-Pierre ;-)
jan wrote 01/31/2017 at 20:29 point
Hi I have a question is it possible to connect a Nextion touch screen to it to control the radio
I love the web radio and the possibility to  update it thru the web interface I like to use this project to at it in a shower project I`m doing at this moment the Nextion wil be built in to controle the shower like temp end the 6 massage jets I like to ad the web radio into this project
jp cocatrix wrote 01/31/2017 at 20:40 point
https://hackaday.io/yo2ldk done  it. Contact him.
ldv82 wrote 01/31/2017 at 18:54 point
Send commands sys.patch ( "0"). How do I know if it is adopted? Thank you. Everything worked. But I did not understand why. Many times you enter a command sys.patch ( "0"), but it did not help. More will not upgrade the firmware unnecessarily in this.
jp cocatrix wrote 01/31/2017 at 20:03 point
##CLI.URLSET#: stream.pcradio.biz
##CLI.PATHSET#: /Ruki_Vverh-low
##CLI.PORTSET#: 8000
##CLI.OVOLSET#: 0
##CLI.VOL#: 79
Header: Moved
##CLI.STOPPED# from C_HEADER
##CLI.URLSET#: 85.25.43.52
##CLI.ICY0#:  Ruki_Vverh
##CLI.ICY3#:  http:\/\/www.pcradio.ru\/
##CLI.ICY4#:  Misc
##CLI.ICY5#:  24
##CLI.ICY6#:  Liquidsoap Radio!
##CLI.ICY7#:  channels=2;samplerate=44100;bitrate=24
##CLI.PLAYING#
##CLI.META#:
##CLI.VOL#: 132
##CLI.META#: Руки Вверх! - Убегай
It play well! but only with the patch.
Without it, the vs1053 crash.
If the patch is loaded you see:
VS Version (VS1053 is 4) = 4
SCI_ClockF = 0xB800
I2S Speed: 0
plugin size 18ce 2 c67
plugin start: 7 1 8050 6
scandone
Do a sys.patch ( "1") to enable it again, and reboot.
Are you sure to have the last release? Do an OTA upgrade please.
This is an alpha command not yet documented.
ldv82 wrote 01/31/2017 at 20:26 point
Yes. Already there were rows in the log
Tried sys.patch command ( "1") of the sample. Maybe it helped.
What is the difference sys.patch command ( "0") and sys.patch ( "1")?
jp cocatrix wrote 01/31/2017 at 20:42 point
sys.patch ( "0")  inhibe the patch loading at reboot
sys.patch ( "1")  load the patch at reboot.
Some vs1053 doesn't support the patch, so i added this advanced command.
ldv82 wrote 01/30/2017 at 12:21 point
JP cocatrix
Upgrading to version 1.1.5+ via OTA already have? I updated via OTA and just hang on AAC channels began again. And I do not have the firmware 1,1,5, which worked.
It would be nice to be able download the last stable version of firmware.
jp cocatrix wrote 01/30/2017 at 12:38 point
Sorry, i don't understand your request.
AAC Channel?
Send a log please.
I don't want to store old release. Just make the new one working for everybody.
jp cocatrix wrote 01/30/2017 at 12:55 point
This release adds the official patch for aac. If it is a problem, send
sys.patch("0")
And reboot again.
It seems that some vs1053b are not really up to date to accept this patch.
No mean to see it from the software. (vs version is 4 for all vs1053)
vis22 wrote 01/28/2017 at 11:28 point
Currently OTA passes starts WEB interface to 192.168.4.1.
After entering the existing AP SSID: AP PASSWORD and Validate their begin to pour in on UART
Fatal exception (0):
epc1 = 0x401000bb, epc2 = 0x00000000, epc3 = 0x4028251f, excvaddr = 0x00000000, depc = 0x0 0000000
I returned to version 1.1.5 from 24.01.2017.
jp cocatrix wrote 01/28/2017 at 12:27 point
Tested with 2 old prototypes, and a brand new one succesfully.
May be another problem?
vis22 wrote 01/28/2017 at 08:44 point
Dear jp cocatrix, seems to firmware 1.1.5 is not workable, as is the case of OTA and the github.kom, had through UART revert to version 1.1.4.
jp cocatrix wrote 01/28/2017 at 09:12 point
Yes, true. A wrong update. Do an OTA again.
Thanks a lot.
Tell me if it works now.
vis22 wrote 02/04/2017 at 23:29 point
Sorry, but there is really only Problem with ESP8266-7 (tested on 3 copies). With ESP8266-12 no problem.
jp cocatrix wrote 02/05/2017 at 09:12 point
vis22 wrote 10 hours ago
Sure, it is linked for esp8266 with 4MBytes only for OTA. (esp12 is ok)
I never tell that it support other flash size.
Pierre-Francois Bonnefoi wrote 01/26/2017 at 10:18 point
Wonderful project : tried it, love it ! Two suggestions : implement mDNS for easy discovery and allow two manual IP configurations, one for each provided AP.
jp cocatrix wrote 01/26/2017 at 17:49 point
The free ram memory is critical. So i am not sure to implement mDNS.
Less critical is the ip conf for each AP.  For the moment I recommend to use a static DHCP lease to avoid the need of two fixed IP. With a well configured router, it is transparent. That's why I added the MAC address. I have to develop a new bank in eeprom to store more permanent configurations. The first one is full, that's why I postponed the second IP.
Thanks for your suggestions and appreciations.
Dominique GEORGES wrote 01/25/2017 at 23:21 point
Very good project : step 1 OK for me : module ESP8266 OK. Now I wait module VS1053 and go !
Thank you for your help. DOM from France !
vis22 wrote 01/25/2017 at 16:30 point
Many thanks.
vis22 wrote 01/24/2017 at 21:00 point
Many thanks!!!
I will try to connect the IR remote from the boom box.
P.S. Dear jp kokatriks, in the current version karadioU8glib.ino on github.com no strings the #define IR and the #ifdef IRLib2 ?
jp cocatrix wrote 01/24/2017 at 21:56 point
vis22 wrote 01/24/2017 at 18:05 point
Спасибо за совет.
Выход модуля питания 5V установлен конденсатор 220 мкФ.
Технический паспорт для vc1053 рекомендует конденсаторы 22 мкФ в силовых цепях.
Установленная на плате модуля С17 и С18 были сомнительными номинальным.
Под руки были только 100 мкФ.
В результате, цель достигнута, отказы прекратились.
Могу ли я узнать ИК-датчик схема проводки и способ настройки командных кодов ИК?
jp cocatrix wrote 01/24/2017 at 18:12 point
In u8glibConf.h of the software:
**** Instruction for the IR module *****************************************************************************************
The model used here is from:
https://www.aliexpress.com/item/Hot-Selling-1pcs-New-Infrared-IR-Wireless-Remote-Control-Module-Kits-For-Arduino-Wholesale/32334118062.html?spm=2114.13010608.0.0.XzmgYk
or equivalent. Cost less than 1$
- Based on NEC protocol; Built-in 1 x AG10 battery;
- Remote control range: above 8m;
- Wavelength: 940Nm;
- Frequency: crystal oscillator: 455KHz; IR carrier frequency: 38KHz
// IR library
Install the library from https://github.com/cyborg5/IRLib2
Uncomment the #define IR  and the #ifdef IRLib2 at the beginning of the karadioU8glib.ino file.
The IR receiver pins:
From left to right (pin at bottom, sensor in front of you)
Gnd VCC Signal
The signal must be connected to
For mini #define PIN_IRRECV  2  or 3
For micro #define PIN_IRRECV  2  or 3 or 7
In karadioU8glig.ino:
//  Uncomment the following line to see the code of your remote control and report to the case the value
//        Serial.print("Protocol:");Serial.print(results.decode_type);Serial.print("  value:");Serial.println(results.value,HEX);
If you want to use another remote, you can see the code of the keys and modify the switch case for the needed function.
See IRremote.h  to add the protocol you need for the remote.
The tx of the pro mini must be connected to the rx of the esp12 but
Warning; the esp rx pin is not 5V tolerant, so if your pro mini is a 5v version we need to adapt the level.
See
http://www.instructables.com/id/Pi-Cubed-How-to-connect-a-33V-Raspberry-Pi-to-a-5V/
The value of the resistors is not critical. Only the ration 1/3 2/3 must be respected 1k and 2k for example)
Enjoy.
Sergio wrote 01/23/2017 at 23:40 point
Hi JP,
Autoplay dosn't work correctly, every time I turn the player on, I have to press the play button, to start the radio playing
jp cocatrix wrote 01/24/2017 at 02:22 point
update please.
Sergio wrote 01/24/2017 at 11:00 point
With the last update, i don't have sound with any stations
jp cocatrix wrote 01/24/2017 at 12:22 point
Do another ota update, and enter the command on uart:
sys.patch("0")
And reboot again.
I wonder why your prototype doesn't like the vs1053 patch.
Are you alone in the world? May be some other problem on wire can explain it?
Sergio wrote 01/24/2017 at 14:28 point
Till i'm update the player  to the last update works ok, the only problem was that the autoplay doesn´t work ok. No wire problems, i´ll try with the uart command that you said.
Sergio wrote 01/25/2017 at 00:10 point
now works, on 2 players i have to entered the command on the uart
Thanks, may be a problem with the VS1053 patch
jp cocatrix wrote 01/25/2017 at 09:16 point
The vs1053 patch is the official one. No problem with it. May be a spi error on transfert? The wires are longs between the esp and vs?
vis22 wrote 01/23/2017 at 17:45 point
May be. The power supply used DC-DC step-down module LM2596 powered by the voltage regulator +12 V boom-box.
ESP8266-12 randomly stopped communication with VS1053, assuming a fault ESP8266-12 replaced it ESP8266-7 effect it is not received, the modules behave as well. Only extra capacitors ensure their reliable operation.
jp cocatrix wrote 01/23/2017 at 18:13 point
May be a high frequency filter with a few pf, and a 22µf on the 5 volts only?
