Grinder Minder
Bench Grinders are everywhere. So are fingers. May the two never meet. That's where grinder minder comes in.
This project has been rolled into a company and more information is available at: <a target="_blank" rel="noopener noreferrer" href="http://www.makesafetools.com">www.makesafetools.com</a><br><br>We all have stories to tell about shop injuries and &quot;almosts&quot; but it&apos;s not fair to put young makers or industrial operators at risk. Most schools don&apos;t have faculty with the breadth of experience to keep everything above board and industry is full of &apos;those guys&apos;. This is the perfect opportunity for technology to take up the slack!<br><br>We started by surveying what tools are high risk and pitting that against how common a tool is in a shop. We arrived at the humble bench grinder. This ubiquitous and seemingly gentle tool that can be had at Harbor Freight for just $35. Little did we know it claims thousands of fingers every year and even causes death when the wheels shatter. Not OK!<br><br>We have set out to create a small device that provides DC Injection motor
SUMMARY DESCRIPTION:
Tools like stationary grinders can continue to spin for two and a half minutes after being powered off, presenting an enduring hazard to the operator and nearby individuals. Worse, operators tend towards the mindset of "it's off therefore it is safe" which the coasting problem proves alarmingly false. Grinder Minder's primary purpose is to act as a drop-in control replacement with automatic braking minimize the chance of an off tool being dangerous and does so in three different ways (detailed below).
THE CHALLENGE WE'RE ADDRESSING:
Every day, millions of people work around and with motorized machinery and tools. Many of these tools sport flywheels, heavy tooling, work-pieces, or other large mass components. And since inertia is a property of matter, when these tools get spinning, they don't like to stop just because someone turns off the motor. A grinder, for instance, can spin for up to 2.5 minutes after power has been removed. Despite these machines being nearly as dangerous in that time as they were when powered, people will often act as though "Off" means "Safe". As you might expect, the collision of this misconception with the reality of fingers, clothing, or hair getting caught in moving machinery leads to serious injuries.
HOW WE'RE ADDRESSING THE CHALLENGE:
Our solution turns "Off==Safe" into reality, instead of misconception. By replacing the user interface and supplementing control circuitry, all in a "plug-and-play" package, our device brings the motor to a rapid stop, creating a safe environment without requiring each user to change their workflow or habits. And because this solution requires control circuitry, we were able to implement three highly sought after safety features:
  • Automated tool braking to close the gap between "Off" and "Safe"
  • Accidental-restart prevention to keep your device from starting unexpectedly in power failure situations like a tripped and restored breaker
  • Access Controls to give you the ability to regulate who can use the tool (a key switch)
HOW THE SOLUTION IS USED:  (Installation, Operation, Calibration)
SOURCES AND SCHEMATICS:
Project sources and schematics will be shared as attachments in this project page.
LICENSING:
Each file's license will be added in the file's description.
PROJECT SCOPE:
Device Class:
While the circuit itself could be expanded to handle any device with an induction motor, creating and testing a circuit across so many devices would have been difficult for the 2019 HackADay Prize competition. To narrow the scope, we focused in on a commonly found and high-inertia device: the grinder.
Customer:
Our original customer focus was around consumers and hobbyists working out of their small shops or garages. We expected that these customers would typically have single-phase consumer grade bench-top grinders, like those sold at Home Depot. This focus shifted mid-project to the opposite end of the spectrum when some customer research and interactions with individuals in the safety industry expressed a strong interest in much larger commercial 3-phase grinders.
PRODUCT FEATURES:
We identified some core features which we felt would be necessary to satisfy our customer group:
  • DC Injection Braking - to stop the tool quickly after each use thus preventing injuries associated with coasting. This requires the supply of up to 5kW of DC power delivered for up to 4 seconds.
  • Accidental Restart Protection - to prevent the startup of the tool in the event of power loss or accidentally leaving the power switch in the 'on' position.
  • Emergency Stop - an ANSI-compliant emergency stop button to activate braking in the event of an emergency.
  • Drop-In Installation - designed so installation requires nothing more than plugging it in in-line with the...
Prototype_Enclosure_Body.stl
The 'walls' of the prototype enclosure. Standard STL mm format. CC BY 4.0
Standard Tesselated Geometry - 65.02 kB - 08/15/2019 at 21:22
Download
Prototype_Enclosure_Assembly.rsdoc
The assembly of the prototype enclosure. Created in Design Spark Mechanical. CC BY 4.0
rsdoc - 893.43 kB - 08/15/2019 at 21:21
Download
Prototype_Enclosure_Mount Plate.stl
The mounting plate for the circuit board. Standard STL mm format. CC BY 4.0
Standard Tesselated Geometry - 280.55 kB - 08/15/2019 at 21:21
Download
Prototype_Enclosure_Graphic.svg
The top surface of the prototype enclosure. Designed to be cut/engraved on a laser cutter. Best edited in InkScape. CC BY 4.0
svg+xml - 14.37 kB - 08/15/2019 at 21:20
Preview
Enclosure Matrix.xlsx
CC BY 4.0
sheet - 17.80 kB - 08/14/2019 at 16:37
Download
View all 8 files
  • Inertial Load Testing
    Scott Swaaley08/14/2019 at 19:12 0 comments
    Captains log, supplemental. You may have seen our first dry test in a previous log and you were probably thinking "C'mon, there wasn't even a mechanical load on that thing!?" Well this clip is for you. We built an inertial test rig, which is basically a 10lb 10" flywheel enclosed in a protective screen to prevent it from decapitating us. Considering that angular momentum is proportional to the square of radius, and that this wheel is almost double the combined mass of a bench grinder drive train, it's a big test. Check it out.
  • Schematic Evolution
    Scott Swaaley08/14/2019 at 17:40 0 comments
    I thought it would be interesting to show the evolution of our schematics over time, focusing on our primary power center - our 5kW DC Braking power supply - the switching of power sources - and control. We detailed the unusual specs for our power supply in a previous project log and describe the overall function of our device in the project details but figured we'd show the quick evolution here. You'll probably notice that there are no microcontrollers in these - that's because an adviser told me that getting firmware NRTL Listed in a safety product was a huge pain in the butt and best avoided for a first product. Also, keep in mind that the goal here was to make a plug-and-play device that works irrespective of what is happening downstream. Lastly, this is all single-phase because our switch to poly-phase is a recent change.
    The beginning.
    It didn't take long for me to start looking at thyristors for rectification so here is one of the first schematics with only relay logic and simple R/C/D thyristor control.
    What we learned:
    - MOVs do not effectively reduce arcing. This causes severe arcing when the DC relay opens.
    - Half-wave rectified DC does not brake the motor.
    Key Control.
    Multiple people were asking about the ability to restrict access to equipment so we started experimenting with simple ways to integrate a key switch into the device.
    What we learned:
    - Electrically, this is easy.
    - It's really hard to find a key switch that can switch even a small AC coil without getting fried from arcing.
    Full Wave.
    It was now obvious that we needed full wave rectification but with relays as the most expensive element by far, we were trying to do it all while minimizing the contacts required. We experimented with full-wave-rectifiers in front of and behind an SCR, full converters, and semi-converter rectification topologies.
    What we learned:
    - Trying to control two thyristors with independent reference voltages is crazy complicated and would bump up control complexity significantly.
    - It's VERY easy when designing these topologies and switching between AC run mode and DC braking to create an accidental short across mains through one of the diodes or thyristors in the rectifier.
    - The reality of relay make and break times can also create make-before-brake situations that also short mains.
    - Shorting mains makes big booms.
    - Isolation of the o-scope is critical.
    Triac
    Turns out that the most cost efficient way for us to provide the switching and connectivity we wanted was with a triac before a standard full-wave rectifier and to control it with a simple R/C/Diac circuit. You can adjust the pot to adjust firing angle and thus output voltage.
    What we learned:
    - Output voltage control (via R/C/D pot) is really funky and has to be turned up before being reduced to the setting you want. Like an old lantern. A lucky find in an online forum pointed out an elegant solution to this (see FWR and resistors to left of power schematic).
    - Arcing can be slightly helped (but not totally eliminated) with an RC snubber.
    - RC snubbers create consistent leakage current and also inrush during switching, which can cause problems.
    Switching Detection and Control
    The circuit has to detect the status of the switch on the tool that's plugged in (the restart prevention and post-braking mode), switch between AC and DC modes when activated, and not short out or cause fires. After LOTS of relay puzzles, we arrived at this:
    What we learned:
    - We could feed a sensing current through the power tool (load) to sense the position of the tool switch. This worked with a broad range of motor impedances.
    - We could use spare contacts in relays (negligible cost adder) to get latching functionality.
    - This setup works!
    Moving to Digital(ish) Control
    After showing this product off a bit to friends and a few potential clients, they didn't like needing to hold down the brake button and thought it would be too easy to do it wrong and still get hurt. So we made a BIG jump to digital...
  • Production Enclosure Design Decisions
    Scott Swaaley08/14/2019 at 16:00 0 comments
    You probably saw in our last project log that the other Scott mocked up an awesome 3D printed enclosure for our newest prototype and there are some photos of the assembly below. As bad ass as it looks - 3D printing isn't practical for the volumes we hope to one day produce so we began to look at our options for enclosures. We aren't industrial designers yet we are keenly aware that our product needs to (a) hold up to abuse in a shop environment (getting stepped on, kicked around the floor, etc.), and (b) look professional, and (c) have some kind of distinct brand shape, color, or markings.
    A few months back I met a representative for an enclosure design firm (https://bcmechanicaldesign.com/) at a hackers meetup in Silicon Valley so I gave them a call and got an introductory consult. The basic summary of the call is that a custom enclosure is totally doable with injection molding but the enclosure as designed is a no-go because of the complexity of a mold. Not only have we not considered the draft angle of walls (so the part can release from a mold), but our inset wall profiles would require a mold that has actuated parts that move in and out to mold then release the part ($$). We didn't expect this to be our final enclosure design, but the breadth of design considerations for an injection moldable design was significant. We talked order-of-magnitude cost and there is a fixed tooling cost in the $10,000-$20,000 range, not to mention NREs and design costs. After that the parts themselves are almost negligible in cost but that means the economics don't make sense until we're in the thousands of units. We aspire to that volume - but it's also important for us to be able to bootstrap up and to minimize investment until the product is validated and successful in the market. Also, coming back to the NRTL Listing we'll eventually need to do, custom enclosures require an additional regulatory evaluation of materials and process ($$). The MacroFab Engineering Podcast discussed injection molding a while back and their narrative supported the same things. In other words, injection molding scared us off for now. We'll get there eventually, but it's not a priority at this stage.
    So .... I guess that leaves us fishing for an off-the-shelf enclosure? The enclosures will be much cheaper in low volume but we'll need to mark and machine them ourselves. Again, NRTL listing comes into the mix and we'll need "permanent markings" (a.k.a. super expensive stickers). It's still cheaper for starting off though. There are almost as many enclosures out there as there are connectors but I was able to filter by the NEMA and UL requirements we'll likely need. Namely, that the enclosure, if plastic, has a 94V-2 fire rating or better and can take some physical abuse. If you're curious, this basically means the thing doesn't like lighting on fire and extinguishes itself quickly (test description here). On the physical side, it needs to take a multi-pound steel ball to the face after sitting in an oven for a while, and not deform. With these search criteria we went on the hunt and found a great company (https://www.polycase.com/) that had a wide selection and, most importantly, really good dimensional search functionality on their site. They also offer digital printing and machining services that we could grow into over time. Ok - we like them - moving on.
    Using our existing PCB prototype dimensions as a general guide for what size we need, and trying to stay relatively low profile, we started the search. Despite their great search functionality, we ended up parsing one of their pages and put 33 of the ones we likes into our own matrix (screenshot below, excel sheet in project files).
    Turns out that our relays are too damn tall for most of them. Ugh. If we get an internal height that is tall enough, then the box is obtrusively large and mostly empty. Hrm. We were able to find a "PC PIN STYLE" (in blue) variation...
  • Enclosure in Photos
    scott.mcgimpsey08/07/2019 at 00:02 0 comments
    I went from design of a case to prototype in hand over the last few days, and snagged some photos of the process. Here's the shots, with short descriptions.
    I quickly modeled the case with 3d printing in mind -- Notice the box walls are all 45 degree chamfers, and that the top of the box is a separate element entirely to prevent the sloppiness of overhangs. The bottom, where the board will mount, has very thick chamfered standoffs to compensate for the weakness typically seen with narrow bodies printed using FFF printing.
    Assembled in 3d.
    The body STL, pre-slicing in Cura.
    The 3d print of the body, about 4 hours in. Notice how there was no overhang issue at the edges. :D
    The completed body section. After I pull this off, I'll just have the mounting plate and the top to make.
    The same body, flipped 180 to face right-ways up.
    A (blurry) shot of the mounting plate with the built in standoffs. If we need to remake this, I'm going to buy some shorter screws to drop the total height of those standoffs, and pass the hole through the bottom so it can attach to rubber feet. Time to start on the top plate.
    Instead of 3d printing the top plate, I decided to laser cut some acrylic sheet. I replicated the measurements for the panel in Inkscape, vectorized the HaD logo, and made a quick case name. The gray section was just my notation of the safe space to work in for graphics -- I deleted the gray block and flipped the graphics prior to saving to ensure that the engraved sections were facing inside the box.
    I tossed the acrylic panel on my cheap K40 laser cutter, and used K40Whisperer to send the instructions out to the device.
    Damn beautiful.
    Installation with a few M3 screws. I used a standard fit on the holes on the acrylic, and a bit of a snug fit on the screw holes so they'd effectively tap themselves into the body.
    Interestingly enough, I -forgot- to properly size the holes on the mounting plate which hook the plate to the body, and had to tap right through the mounting plate. Damn. But something else to fix in the next version, I suppose. Good enough for what we need for the prototype! Now to decide on whether manufactured will be injection molded or pre-fabbed!
  • Design For Manufacture Meeting
    Scott Swaaley08/04/2019 at 20:09 0 comments
    Now that we have a functional proof of concept circuit, we're working to plan out a longer term design for manufacturing. We had heard good things about a local PCBA manufacturer so we setup a meeting and discussed product manufacturability. The place is Hughes Circuits, Inc. and they have an incredible facility where they Manufacture PCBs and assemble products for military applications. Overkill for our device, perhaps, but they're experts and had good input. We met the other day with their BD guy and their FAB lead, shared our prototype and intent for next steps, and absorbed their wisdom. Interestingly, a lot of the discussion came down to reliable part sourcing, testing methodology, and which parts would lend themselves well to certain soldering and cleaning strategies. The relays we're using, for instance, aren't water-tight, which means that submersion cleaning of the boards after assembly would be unwise unless the cleaning step took place prior to the addition of the relays.
    The folks at Hughes were helpful in some unexpected ways as well. One of the manufacturing engineers brought up the topic of the thermal connection between the heat-sink and the SCRs. According to him, while the Silver thermal paste was a really good thermal conductor, the manual application of the goop to every heat-sink was going to be more work than something like a thermal pad and more prone to inconsistent application. This kind of manual task obviously makes the work more expensive, growing the cost per unit.
    The good new was that they didn't see any serious concerns with the state of the circuit board from a manufacturing point of view. While things like through hole components would add to the cost, the crew at Hughes was generally positive about the overall circuit board design. Now our concerns are shifting to the manufacturability of the enclosure and assembly as a whole. More soon!
  • Closing in on Enclosures
    Scott Swaaley08/04/2019 at 04:11 0 comments
    While the circuit design settles down, we're starting to think about a longer game when it comes to the finalized product. Specifically around the form of the thing. What should it look like? Where should it go? Should it attach directly to the Grinder or next to it? I've started playing around with a few different ideas, but with the manufacturing aspect to consider first, we're starting with the assumption that we'll likely end up either designing it ourselves, or sourcing something that does the job already. Since we're thinking plastic is going to be a good material for the forms we're considering, we'd likely need to use injection molding. Alternatively, if we can find some pre-fabbed enclosures at a modest price, we may just jump on that to simplify our lives.
    While we review and research the comparative costs, I ginned up a quick prototype design and am currently printing it. It's a bit bulky, but it carries that angled and chamfered look that really says "I'm designed to be stepped on and kicked around". Given our target market, it makes sense. Here's some photos, and a quick exploded design.
  • It's Alive!
    Scott Swaaley07/29/2019 at 18:27 0 comments
    We had every expectation that our first electrical test would be a spectacular fireworks show (especially considering the fireworks from our previous mosfet testing) but then something strange happened...
    It just worked! Like - when does that ever happen!? The other Scott (McGimpsey) claims that it's the result of our planning and experience. This Scott (Swaaley) calls it good luck. We'll be doing some testing with larger inertial loads and varied settings over the next week. Stay tuned!
  • Test Gear
    Scott Swaaley07/29/2019 at 17:48 0 comments
    Now that we were moving towards a 3-phase product .... we needed the ability to test 3-phase. First problem was a 3-phase source of power. The Lab and The Shop are just a spare bedroom and the garage of my house and we have a 100A 240V service so we started hunting around.
    After learning more than I ever wanted to know about phase converters, I found one that was reasonably affordable and bought it. A few notes in case you ever need to buy one:
    • Don't fall victim to the 180 degree vs. 120 degree phase debate. The internet is awash with this dogma. The 240V that feeds a phase converter is single-phase (no common reference with a 2-wire feed) so the idler motor can make a true 120 leg. The voltage isn't always perfect on that artificial leg - and it's current response can lag a bit - but it's passable 3-phase power.
    • Don't fall victim to the "solid state" or "idler free" phase converter. It's just a capacitor bank that functions as a starting capacitor that shifts the current of a motor's 3rd phase during starting then turns off .... leaving your motor to run on just two-phases. It works for motors (though reduces HP by 1/3) but it's a starting current nightmare and not something you'd want to test with.
    We also needed a motor to use. We haggled and picked up a small 3-phase motor from a local surplus.
    Here are our new babies:
  • Macr - Oh $#it
    Scott Swaaley07/29/2019 at 17:38 0 comments
    Since our sharp left turn last month, we've been heads down working out a prototype. We took advantage of the awesome folks at MacroFab and had a PCB made. Then ... of course ... we realized the mistakes we made on layout and had to hack it a bit (well, a lot). This is how it looked going into our first test.
    Big picture - this PCB contains a few parts.
    1. High-voltage high-power AC: big fat relays, big fat traces (2oz / 3mm), and lots of nothing (large spacing) to prevent arcing or shock.
    2. High-voltage high-power DC: we're testing some ideas for a high-power-density DC source (see previous post). You definitely don't want to touch this part
    3. Low voltage controls: galvanic isolation is a big deal so we've isolated all low-voltage stuffs and kept it simple. Digital controls but it's all logic - so software or firmware.
    Next it's time to turn it on!
  • Pics!
    Scott Swaaley07/11/2019 at 19:56 0 comments
    new phase converter just arrived for testing!!!
View all 20 project logs
ckngg350 wrote 01/02/2023 at 07:51 point
Meat is an inherent part of the non-vegetarian’s diet. And we love making new recipes and eating them. Especially beef, ham, and chicken are the common types of meat to use in everyday life  Best Meat Grinders for Deer. But one of the drawbacks of consuming these meats on a regular basis is that they are rich in fat.
Scott Swaaley wrote 05/10/2019 at 19:35 point
Hi Mike! We're still finalizing the feature set (trying to keep costs low so consumers can afford it) but yes - access control is high on the list. We'll already need a relay in there so might as well add a key-switch in series with the relay coil. In my previous life running shops, fancy fob/rfid/card systems never worked well as the back-end was never maintained.
P.S. I need to mess with my notifications settings - I never saw this comment until just now. Sorry!
Mike Szczys wrote 04/22/2019 at 16:22 point
This sounds great! Are you focusing on a lockout-type system that ensures only users trained on this tool are able to turn it on, or is there a more preventative technology like sawstop?
