In this project we are trying to build a very simple but functional 3-trit balanced ternary computer. The only building block allowed is a ternary multiplexer based on DG403 analog switches.
![](https://raw.githubusercontent.com/ssloy/tutorials/master/ternary/triador/schematics/triador.png)
══════════════════════════════════════════════════════════ Description of the ternary computer TRIADOR ══════════════════════════════════════════════════════════ General purpose registers trits 2 1 0 (a trit can take -1,0,+1 values) ┌─┬─┬─┐ R1│ │ │ │ \ ├─┼─┼─┤ | Program memory R2│ │ │ │ | trits 4 3 2 1 0 ├─┼─┼─┤ |-- main set ┌─┬─┬─┬─┬─┐ R3│ │ │ │ | of registers a -364│ │ │ │ │ │ ├─┼─┼─┤ | d ├─┼─┼─┼─┼─┤ R4│ │ │ │ / d -363│ │ │ │ │ │ ├─┼─┼─┤ r ├─┼─┼─┼─┼─┤ R5│ │ │ │ \ e -362│ │ │ │ │ │ ├─┼─┼─┤ | s ├─┼─┼─┼─┼─┤ R6│ │ │ │ | s : : : : : : ├─┼─┼─┤ | ├─┼─┼─┼─┼─┤ R7│ │ │ │ | -1 │ │ │ │ │ │ ├─┼─┼─┤ | ├─┼─┼─┼─┼─┤ R8│ │ │ │ | 0 │ │ │ │ │ │ ├─┼─┼─┤ |-- extra registers ├─┼─┼─┼─┼─┤ R9│ │ │ │ | +1 │ │ │ │ │ │ ├─┼─┼─┤ | ├─┼─┼─┼─┼─┤ R10│ │ │ │ | : : : : : : ├─┼─┼─┤ | ├─┼─┼─┼─┼─┤ R11│ │ │ │ | +363│ │ │ │ │ │ ├─┼─┼─┤ | ├─┼─┼─┼─┼─┤ R12│ │ │ │ / +364│ │ │ │ │ │ ├─┼─┼─┤ └─┴─┴─┴─┴─┘ R13│ │ │ │ Special register, └─┴─┴─┘ specifies memory segment for JP ttt ┌─┬─┬─┬─┬─┬─┐ PC │ │ │ │ │ │ │ program counter register (-364..+364) └─┴─┴─┴─┴─┴─┘ ┌─┐ C │ │ borrow/carry flag (+1 borrow, -1 carry) └─┘ Every 3-trit register can take values from -13 to +13: t2*9 + t1*3 + t0 where t0,t1,t2 - trits (-1,0,+1) ═══════════════════════════════════════════════════════════ TRIADOR instruction set ═══════════════════════════════════════════════════════════ (for lisibility we use N,O,P instead of -1,0,+1) ┌───────┬────────┬───────────────────────────────────────┐ │op code│mnemonic│ description │ ├───────┼────────┼───────────────────────────────────────┤ │ NNttt │ EX ttt │ extension commands (work in progress) │ ├───────┼────────┼───────────────────────────────────────┤ │ NOttt │ JP ttt │ unconditional jump to R13*27+ttt │ ├───────┼────────┼───────────────────────────────────────┤ │ NPttt │ SK ttt │ conditional skips of the next command │ ├───────┼────────┼───────────────────────────────────────┤ │ ONttt │ OP ttt │ tritwise unary operation over R1 │ ├───────┼────────┼───────────────────────────────────────┤ │ OOttt │ RR ttt │ copying between registers │ ├───────┼────────┼───────────────────────────────────────┤ │ OPttt │ R1 ttt │ write ttt to the register R1 │ ├───────┼────────┼───────────────────────────────────────┤ │ PNttt │ R2 ttt │ write ttt to the register R2 │ ├───────┼────────┼───────────────────────────────────────┤ │ POttt │ R3 ttt │ write ttt to the register R3 │ ├───────┼────────┼───────────────────────────────────────┤ │ PPttt │ R4 ttt │ write ttt to the register R4 │ └───────┴────────┴───────────────────────────────────────┘ Additional comments: - ttt means a 3-trit number with values from NNN (-13) to PPP (+13) - RR ttt instruction copies a register to/from R1 or performs an increment/decrement over R1 OONNN — copy R1 to R13 OONNO — copy R1 to R12 OONNP — copy R1 to R11 OONON — copy R1 to R10 OONOO — copy R1 to R9 OONOP...Read more »
Hello. Your project seems interesting but dg403 is so expensive and is not easy to find.
I don't know much about Electronics but perhaps they can be replaced with 4016? 300 of them have enough analogue switches and the price will be reduced a LOT.
