3D Printed Robot Actuator
A high speed and high torque robotic actuator using low-cost brushless motors, custom controller, 3D printed parts and bearings.
Public Chat
I wanted to make a quadruped or biped with enough power to jump off the ground. Typical servo solutions were not good enough.
Design sections
Mechanical - Cycloidal gearbox with rolling elements, bearings and dual input and output shafts
Motor - Low-cost high torque Brushless outrunner using Multistar Elite Motors
Sensors - Dual absolute magnetic encoders for motor position and joint position
Electronics - Custom PCB including Mosfets with Mosfet driver DRV with Cypress PSOC4 SOC, sensor inputs and communications. Plus Magnetic Encoder PCBs
Software - Field Oriented Control (FOC) for position control. Mosfet Driver, Encoder and CAN communications.
The purpose of the Actuator is to create a design than I can easily make with a 3D printer using cheap and powerful Brushless motors from China. I have three prototype sizes of Cycloidal gearboxes 44mm, 60mm and 78mm diameter. The size of the motor, number of poles and their shafts are also adjustable.
hackaday.stp
Step File of the Whole Actuator
stp - 4.09 MB - 06/03/2018 at 06:13
Download
CAD-Hackaday.zip
Pack and Go files for Autodesk Inventor
x-zip-compressed - 21.85 MB - 06/03/2018 at 06:11
Download
WS3.cywrk.Archive01.zip
PSOC4 Project files Hardware and software (code) files
x-zip-compressed - 1.74 MB - 06/03/2018 at 04:17
Download
ENC_MAG (3-06-2018 12-14-05 PM).zip
Altium project Schematic and PCB
x-zip-compressed - 485.14 kB - 06/03/2018 at 04:15
Download
Adobe Portable Document Format - 100.01 kB - 06/03/2018 at 04:14
Preview
Download
View all 11 files
  • Arduino Brushless FOC Controller
    Paul Gould4 days ago 2 comments
    In an effort to make the controller accessible to more makers I've strated designing an Arduino based system. It uses the SAM D21 G 32-bit micro-controller as used on the MKRZERO board. This chip has an advanced Timer Counter Controller which can generate three centre aligned PWM signals. After sorting out the correct pin mapping it is up and running.
    The code is based on information provided in the Arduino forum by MartinL.
    https://forum.arduino.cc/index.php?topic=346731.0
    I will create a github shortly
    Next up dual SPI. One for the absolute magnetic encoder sensors and the other for the FET gate Driver IC.
    PID and FOC should be easily ported across.
    Voltage and current measurement may be difficult because the Arduino doesn't support free running sequential ADCs very well.
    The SAM D21 does not have CAN commucations so it will need RS485 and USB.
  • Biped Design
    Paul Gould06/09/2018 at 15:22 1 comment
    6x Actuators
    Do all the joints need the same size actuators?
    Are different reduction ratios required? Higher torque less speed.
  • Mini Quadruped Design (CAD)
    Paul Gould06/08/2018 at 16:16 0 comments
    12x Mini Actuators
    Needs a head, tail, electronics and batteries.
    Two leg has been 3D printed. Some assembly required. See end of YouTube video. It's the little one on the left.
    I have made some 2 axis legs for testing. They have enough torque but the speed is huge, even under load. Jumping is not impossible.
  • Actuator Testing
    Paul Gould06/01/2018 at 15:31 0 comments
    Testing using the Brushless motor, Cycloidal gearbox, Position sensors, Controller and LiPo Battery
    • 3kg of weights placed at 330mm distance from the center axis = 100kg/cm or 10Nm
    • The laptop sends a command to move between 90 (vertically down) and 180 degrees (horizontal)
    • 11.1V 3Cell LiPo (1500mAh 30C)
    • Peak Current while moving is about 6A @ 12V = 60W
    • Controller is set to 50% max PWM (I don't want to break anything yet)
    • 90degrees transit time is about 1 second @ 10Nm load
    My prototype actuator has a tested no load speed of 60deg in 0.2sec @ 12V, 4A @ 50 Max PWM
    I have not tested the max stall torque but 10Nm is currently suitable for my needs.
    The motor can handle 600W (22V @  27A) and the brushless controller can handle 4000W (40V @ 100A) (both dependent on cooling)
    In comparison, the Dynamixel MX-106R is the servo I wanted as it had 100kg/cm (10Nm) stall torque but it's no load speed is 55RPM and it cost ~US$500
  • PSOC4 Controller software
    Paul Gould05/16/2018 at 15:03 0 comments
    The software runs on the PSOC4 by Cypress and is a Programmable System on Chip which includes
    • 32-Bit ARM Cortex M0 (48MHz)
    • Programmable Digital Blocks - UDB  (Like FPGAs)
    • Programmable Analogue Blocks (Opamps, Comparitors, ADC, DAC)
    In the PSOC4 you can choose between fixed blocks (as in normal micro-controllers) or Universal Digital Blocks (as in FPGAs). So features  like SPI, I2C, UART, Timers and Counters (PWM), can be either fixed or custom.
    I was hoping to say that is it fully configurable but it is really not. There are many limitations and work-arounds in both hardware and software. That being said, it is a brilliant chip, you can do many things without the CPU being involved at all. The sequencing SAR ADC is a good example of this. The IDE is good but hides too much low level functions. Things like being able to change the CAN ID on the fly meant searching through lines of undocumented c code.
    The software/configuration went through many iterations depending on the Controller version.
    Software Structure for Brushless Controller 2.0
    • Restore Configuration data from User Flash
    • Create Sin array from number of motor pole pairs
    • Configure Motor Driver
    • Enable Everything (Comms, PWM, ADC and IRQ)
    • The Sequencing ADC End of Conversion IRQ is the sub-routine for the controller loop
      • Read Motor and Joint position information
      • Read ADC information (Current, Voltage, Temp)
      • PID
      • Field orientated Control (FOC)
      • Sin to PWM output
    • CAN IRQ
    • Motor Fault IRQ
    • UART Debug Control and User Flash Configuration
    The sub-routine for the controller loop runs at 10kHz and uses about 20% of the CPU time. Not bad for a 48MHz CPU and doing FOC. The main reason it runs efficient is the that FOC array is pre-calculated to suit the number of poles of the motor being used. The other two phases are just offsets in the main array. The output from the PID is just a multiplied by the FOC array and shifted to get the three PWM signals. There are no sin and division calculations in the controller loop.
    The FOC array is based on modified sinusoidal waveform, often called saddle profile. It has the benefits of higher voltages between phases (than pure sin waves) and 1/3 less switching losses. The FOC array has 4096 (2^12) points and the Motor's Magnetic encoder has 16384 2^14 steps. Which is fine, because the encoder has some noise.
    The hardware and software has been updated to the "file page".
  • Actuator Controller - Hardware
    Paul Gould05/13/2018 at 15:03 0 comments
    From everything that was learnt from the hardware development a real / custom actuator had to be developed. After some research the best/easiest solution for me was the 3-Phase driver DRV8305 paired with 6x N-MOSFETs and the PSOC4 Processor.
    Hardware for the Second Controller
    • Custom 4 Layer PCB 47mmx45mm
    • PSOC4 CY8C4247AZI-L485 ARM Cortex-M0 32-bit Processor with Programmable Analog Block and Programmable Digital Blocks
    • DRV8305 MOSFET Driver with integrated Current Sense Amplifers, SPI and PWM Control
    • 6x N-MOSFETs R-on-typical @ 0.7mOhms 40V
    • 3x 1mOhms Current Sense Resistors
    • CAN Transceiver
    • 25MHz Oscillator
    • LMR14206 Step Down Regulator
    • Optional (un-populated) - RS485, FET Temp Sensor, USB, Hall effect input, Sensorless operation
    There is not much to say about this controller. All components were "wired" up as per their datasheets. As the two main IC's have a lot of  integrated components inside there is not much interconnects required.
    The angle of the motor and the joint is read by the AS5147s via SPI. PSOC4 uses PID to determine the required joint position and uses Field Orientation Control from motor angle to calculate 3 Sinusoidal values. These Sinusoidal values are converted to PWM signals to drive the 3-phase Driver. This intern drives the 6x N-MOSFETS to power the Brushless Motor. Control of the Actuator is done by CAN.
    As the board was soldered by hand, the SPI link between PSOC4 and the DRV8305 helped to to pick up dry-joints and short-circuits on the MOSFETs, Current Sense Resistors and some DRV8305 pins. It had many fault and error registers which points directly to the bad connection.
    The Schematic and PCB has been uploaded to the "file page".
  • Actuator Controller - Hardware Development
    Paul Gould05/11/2018 at 17:30 0 comments
    The goal of the Actuator Controller is to
    • Drive the Brushless motor at high speed and low speed including zero speed (holding joint position)
    • Joint Position Control PID
    • Actuator Communications
    Hardware for the First Controller
    • PSOC4 Development board CY8CKIT-043
    • 3x Half Bridge Drivers BTN8982TA (10mOhms 55Amps 40V)
    • CAN Transceiver
    • Hall effect sensors for Motor commutation
    • Potentiometer for Joint Position
    Brushless Controller 1.0 (of many)
    The control of the Sensored Brushless Motor with Hall effect sensors was done by a "look-up table" in the digital Marcocells of the PSOC4, no CPU overhead is needed for Brushless comutation. Only Direction and PWM duty cycle are passed to the Marcocells. The hall effect sensors only had a resolution of 6 phases per electrical revolution. This worked ok at high speeds but the motors operation would not be smooth a low  speeds or when trying to hold a set position.
    Brushless Controller 1.1
    The Hall effect sensors used had a differential analogue output. In the previous control method they went into the PSOC's internal compactors. In this control method they can be read by the PSOC's differential ADC and a reasonably accurate electrical position can be calculated. Having full motor position information meant that Field Vector Control could be implemented. (More on this later)
    The problem with using hall effects in this manner is that the distance between the hall effect sensor and the flux ring has a large effect on the voltage output. Also the type of sensor and thickness of the flux ring varies so much that it is not practical to use this technique for a general purpose robot actuator. For example, when used on the Multistar Elite 5008 the hall effect sensors gave a good sinusoidal output over one electrical rotation, every time took apart system and put back the Hall-effect board the amplitude of the sinusoidal output would change. Moving the hall effect sensors over to the Multistar Elite 3508, the effective diameter had to change but the sinusoidal output was very small.
    I came to the conclusion that the thickness of the flux ring on the Multistar Elite 5008 was too thin or the magnets are too strong, either way it is not the most efficient design. It let too much of the magnetic strength travel on the outside of the motor. By contrast the the Multistar Elite 3508 had very little magnetic flux on the outside of the motor. This is not good for using external hall effect sensors but at least the full magnetic strength can be potentially used
    Using external hall effect sensor with differential analogue to use Field Vector Control is not relieable for general use. Maybe internal hall effect sensors could work better but they would not be installed easily for different types of motors.
    Brushless Controller 1.2
    No more Motor based hall effect sensors. Some other brushless controllers use quadrature optical encoders but these need to be referenced on power up. I prefer absolute position sensors, so a diametric magnetic is placed on the motor output shaft and the magnetic rotary encoder chip placed opposite to it. The first chip i used was a AS5043 10-bit SSI, PWM and analogue outputs with a Max 30kRPM (10KHz update rate). This is the "Magnetic Induction" that is used in the Hobbyking HK47360TM Servos, I had several of these in one of my original quadruped robots. The AS5043 and diametric magnetic replaces the normal potentiometer in the servo. It was setup using it's analog output set to 180 degree at full scale and low noise/slow mode.
    For use as a absolute angle sensor with Brushless motors a few changes were made. Slow mode was changed to Fast Mode. The SPI from the PSOC was connected the AS5043 SSI which gave a 1024 counts per revolution. With the 5008 having 7 magnetic...
  • Sensors - Absolute Magnetic Encoders
    Paul Gould05/10/2018 at 16:05 0 comments
    The position sensor board uses the AS5147 is a 14-bit Magnetic Encoders
    One for is used for the motor electrical position/angle. One is used for the joint position/angle. The are connected via daisy chain on SPI communication with 2x 16bit clocking. There is a piece of Silicon Steel between the two sensors boards to prevent cross flux of diametric magnets.
    The technical information for the system:-
    • 14500RPM (240 REV/sec)
    • Multistar Elite 5008 motor maximum speed 7000 RPM
    • 7 Pole pairs
    • 10kHz sample rate (85 samples per revolution at full RPM)
    • 12 samples for electrical rotation at full RPM
    • DAEC™ dynamic angle error compensation
    This basically means that they are quite suitable for this application.
  • Motor Modification
    Paul Gould05/10/2018 at 15:26 0 comments
    The Hobbyking range of Multistar Elite Brushless motors are powerful and lightweight.  I have paid between AU$25 and AU$75 for the Multistar Elite 5008. They do need to be modified to be integrated into the robot actuator. The shaft has been replaced with a longer one (with a hole) and the base has been reduced in size and weight.
  • Mechanical Design - Cycloidal Transmission
    Paul Gould05/06/2018 at 14:58 0 comments
      Typical Cycloidal Transmissions consist of four main sections.
      1. Input shaft and eccentric bearing
      2. Cycloidal Gear(s)
      3. ring pins and housing
      4. Output rollers and shaft
      The way that the sections are arranged are with the input shaft on one side and the output shaft on the other and the housing in the middle.
      https://en.wikipedia.org/wiki/Cycloidal_drive
      This means that the output rollers are based on the "Fixed-Free Beam Moment" and are not suited to high torque operation when 3D printed.
      This design's output support pins are based on the "Fixed-Fixed Beam Moment". This means the housing and the output rollers are dual sided. The motor input shaft is only single sided. This all works well on 3D printed parts as the forces on the steel output support pins are spread over a large area in the ABS material. A huge credit goes to Mike Buckingham for his idea on making the input shaft go through both the housing and output shaft. Sure it increased the complexity but it made the design usable.
      The CAD files are uploaded to the "files page".
      There are two sizes of Cycloidal Transmissions but they are identical in their design.
      LargeSmall
      Thin wall Bearing 6809 58x47x7
      Hobbyking Elite 5008-330KV (6s 600W)
      Shaft size 6mm
      Eccentric offset 1mm
      Reduction Ratio 1:25
      Cycloidal Gear "Teeth" 25
      Ring Pins 26
      Output Support Pins 8
      Thin wall Bearing 6807 47x35x7
      Hobbyking Elite 3508-268KV HV (8s 300W)
      Shaft size 4mm
      Reduction Ratio 1:20
      Cycloidal Gear "Teeth" 20
      Ring Pins 21
View all 11 project logs
  • 1
    Actuator Assembly
    1x Brushless motor with extended shaft (6mm Silver Steel)
    1x Custom Brushless Controller Board
    2x AS5147 Absolute Position Boards
    2x 6mm x 2.5mm Diametric Neodymium Magnet
    12x 3D printed parts
    16x 5x8x2.5 bearings
    2x 6809 Bearings
    5x 12x18x4
    1x 6x10x3
    8x 3mm dia x 30mm Silver Steel shaft
    26 (or 13) 3/32" x 28mm Silver Steel shaft
    26 (or 13) 1/8" x 16mm Brass tube (thin wall)
    24x M3 bolts
    10x M2 Bolts
    3x PZT screws
    1x M6 thin wall washer
    1x 2mm dia x 11mm Silver Steel shaft
  • 2
    Sources of information
    Suppliers
    • CCDIY 3D filiment
    • Plaig Bearings
    • MiniTech
    • Digikey/Mouser
    • Apollo Bearings
    Favorite Makers
    • Makers Muse
    • AVE
    • Clickspring
    • Tom Stanton
    • Ivan Miranda
    • James Bruton
    • Gear Down For What?
    • MRB Engineering
    • Thomas Sanladerer
    • ODrive Robotics
    • Benjamin's Robotics
    • Laura Kampf
    • Tested
View all instructions
Alan Timm wrote a day ago point
Hey Paul, this is an outstanding project, and congratulations on your win!
For the parts that require you to center them, it would be a snap to design and print a centering spacer to use during assembly.
I've been eyeballing the failure modes, and I think the first part to fail at load will be the eccentric bearing lobes. That's based on the stresses between the top and bottom lobe and a single eccentric bearing pin, which I assume is going through the center of the top lobe. Maybe sticking a second pin through the center of the lower lobe would help mitigate that?
And, did I see that you can backdrive the actuator? I wouldn't have expected that.
I have to admit that I've watched this video about 12 times already to understand how you've accomplished this. I'm looking forward to building a couple of these to see how they work.
Aliexpress would be a great source for most of the parts like the bearings, bulk 2mm x 28mm steel dowel pins, and 3mm (2.6mm internal) brass tubing.  the 2mm pins are a bit smaller (15%) than the 3/32".  Do you think those will work?  Otherwise there are other sources for true 3/32" x 1 1/8" steel dowel pins.
Can you share a bit about the modified axle/shaft?  Did you fabricate it?  Or is that something that can be found and ordered online?
neilmbajaj wrote 2 days ago point
Can the actuators be backdriven? I suppose if you want it to stand passively, you would not want that, bu it seems like putting the bearing in, on at least the interior pins, could greatly reduce internal friction.
Since your external pins touch two of the cycloid rings at once, would bearings not help there? Your cad odel appears to have bushings over the exterior pins, but i feel like they might have the same issue.
Backdriveable actuators are especially nice when you want to do force control, or try to map motor current to torque, which might be useful when trying to make this robot walk or jump.
Paul Gould wrote 2 days ago point
The Actuator is backdriveable. It is only a 26:1 ratio. I think that having it backdriveable with regenerative capabilities is a must for overall efficiency. I had a prototype with bearings on the outside pins but the reduction ratio was lower because of the bearing spacing around the circumference. Also that is a lot of additional bearings, which increases cost and weight. Series Elastic actuator is also much better for efficiency (the big quad design has this). I am also trying to work out how to store potential energy from the elastic actuator (spring). Store the energy on a foot fall and release when going to jump/step.
Dan Royer wrote 2 days ago point
I saw a project recently that used an atmospheric pressure sensor (very small) wrapped in a rubber material.  When the rubber touched a flat surface the pressure on the sensor was registered.  Made for a really quick contact sensor for feet.  Might be useful for your quad walker.
That is a nice idea but it will only tell you after you have hit the ground. It would be nice to know just before then so that you can turn off the motors so the joints are a bit "softer".
how about... if the motor senses resistance and the foot is not touching then we know it's not ground interference.  not sure what the logic branch from there would look like, tho it's an interesting edge case...
K.C. Lee wrote 2 days ago point
The sensor deforms make contact before the leg reaches all the way down and transfers its full weight.  It is like the pads and hairs on the bottom of a cat's feet can provide feedback for the cat to walk quietly.  Or your keyboard keys making contact before it reaches full stroke.
Pressure can travel, so the sensor doesn't need to be where actual impact happens;
albertson.chris wrote 2 days ago point
Maybe just to re-state one point.  I had the idea that a motor controller should live INSIDE a length of the 25x25 tube.
I had a robot fire a year of so ago.  I has dumb and THOUGH the cable has protected from overcorrect but the design was faulty and I vaporized a #8 cable (3mm diameter copper conductor)  I
I saw that 25x25 tube and though "use it as conduit", "use it as housing for electronics", "use it as a heat sink",  "EMI shielding if you ground it." "I wonder of batteries will fit inside?"
I thing the most valuable space in the robot might is the inside of the 25mm square tubes
Robots like these and to fall and take bubbles down stairs or worse the limbs get into self-collisions and rip wires from each other.  At least until the motional planner is fully debugged.
I know first hand that LiPo battery fires can't be put out, you just have to wait.
albertson.chris wrote 3 days ago point
I think a good way to design a motor driver is to look at what controls the driver.   I think anyone building a walking robot is going to be using ROS/MoveIt or ROS/TOWR so you'd want to run ROS Serial and a joint controller node on the driver.  It would save a ton of work to build the controller on a CPU platform that can run ROS Serial.    Not looking upward at the higher level controller might mean you later have to introduce a layer between.  A chain of controller adapter PCBs is ugly.
STM makes the STSPIN32F0 with builtin MOSFET drivers the chip is designed for robotics and BLDC motors.
The higher level controller likely a "Joint Trajectory Action Controller" attempt to place joints in space at a given time and velocity within the limits of the hardware.  This is the controller this driver will need to interface with.  best to make it seamless.
All that said.  I'm pretty sure I'll be using a stepper motor at fist.  Steppers are easy to control.
ðeshipu wrote 3 days ago point
If you look at the walking robot projects (https://hackaday.io/list/29475-walkers), you will notice that very few of them use ROS in any way.
But they also lack any interesting behavior other than walking.     What's the point of that?   I would think the reason you use legs rather then wheels is because wheels can't work for you application.    But so many of these robot have no application.
As a minimum, I'd want antonymous navigation and route planning that gets from point A to point B without attempting to walk through solid objects, replannrng aroubd obstacles.
We see this a lot with hobby robots, nice mechanics with no software
ðeshipu wrote 2 days ago point
Some of them have pretty interesting behaviors. Also, lack of application is not an exclusive feature of ROS-less robots.
For "antonymous" navigation you need sensors that cost two orders of magnitude more than the whole budgets of those projects. But they usually do obstacle avoidance, so they don't walk into things.
No software is often better than crappy and bloated software. At least you get to learn how it actually is done.
Paul Gould wrote 3 days ago point
Albertson.chris - can you tell me about the joint controller have you have made?
The PSOC4 controller can be configured to support the following communication protocols PWM,  I2C, SPI, UART, RS485, USB, CAN, Step/Dir and LIN. I like CAN the best, as the packet handling is supported in hardware and it has a higher immunity to noisy environments. The CPU is running at 90% idle, so i'm sure adding some sort of Trajectory planning should be possible.
The current big quad I'm designing requires interaction between the joints as the two actuators are joined as one parallel linked series elastic actuators. Two controllers, two gearboxes and one series elastic actuator. This will most likely require a centralized controller.
The CPU in the STSPIN32F0 is not a "high end" controller. 4KB of RAM is not much for a Robot controller.
I think a robot controller for a robot that has as many degrees of freedom is a quadruped is going to be hierarchical.    Every group of 6 MOSFETS controls one motor has one CPU.   The cPU only has to run a position and velocity feedback loop and monitor temperature.  I would bolt the mosfets to the 25x25 mm tube as a heat sink.  These controllers could live inside the structurel tubes and all connect to a bus and DC power.     4K is easy enough to run a couple loops and control one motor if not get a bigger uP.
The next layer of control like does coordinated movement.   It receives as input a series of vectors.  The vector has a target position and velocity for every joint and also a time tag for when those positions are to be realized.   It then sends commends to all the motor controllers to update their set points such that every point gets to it's target at the same time.
The next level above os motion planning.  It's output is the vector of joint targets
Above that is the SLAM and navigation.  The robot needs to know where it is and how to get to where it needs to be and hw to rout arub fixed and moving obstacles.  This means a LIDAR, Vision, IMU, Kalman filters and so on.   This is where ROS is best used.  One person could never write a modern SLAM and sensor integration suite in one lifetime.
The level above is what decides the where it needs to be part which is likely based on a high-level command give by the owner of the robot who just said "go downstairs and fetch me a beer"
Using the "fetch me a beer" scenario is a great place holder.  It the design can do that is is general enough.  I don't need a beer fetcher but I do want a personal assistant for a blind person.  A machine that cn read signs and not bump into walls and communicate by voice.
I've been looking for motors.  Hoby King has the one in the you tube video.  But then checked industrial brushless motors and found a line of them a StepperOnline.com   One of them has a Kv of 111.  That means 3X more torque per  amp.  Same price but physically larger in the axial direction by a lot, but on the other hand I doubt it needs cooling.  Likely more weight.
Maybe suitable for an indutrial robot arm that with base fixed to platform
albertson.chris wrote 4 days ago point
I just read the comment about casting.  It is not hard. You can print a mold, pour in the resin then, here is the key:  the mold comes apart in two or three sections.  The mold parts have flanges that bolt together.  and have registration indents for precision alignment.  Coat the inside with some kind of mold release and car past wax.
I will have access to CNC mill just as soon as I finish my CNC conversion project.  Milling from mild steel is not as hard as it seems
Comercial cscloidic drive this size use grease only the larger ones need a oil bath.  I'd stay with white lithium grease
Now to find suitable motor
I have been looking for an actuator for the exact same reasons you were.  My goal was an affordable quadruped that could jump off the ground.  Yours is great and (I say this in a positive way) there is room for modification which means it could be even better.
I think the electronics can be very much simplified. and I don't know how your position/velocity feedback works yet or anything about the magnetic encoders.
About cooling, yes, the motors likely can run hotter than you are letting them get and remember that heat flows in proportion th the difference in temperature.   So hot is not bad.  My first try would be putting a fan in the shaft then making the mount out of aluminum and a thermistor some place to measure temperature.   I'm going to have to build one of these and study it.    Thanks for all the hard work
I need to buy a brushless motor -- Sorry I've not read everything yet, do you a source  for the motors? Or a model number i can google.
Paul Gould wrote 4 days ago point
Any ideas and improvements are always welcome. For the electronics you can get a uC with inbuilt FET driver but then I loose the ability of the PSOC FPGA section (which is very useful). The advantage of the magnetic encoder is you can get full torque at 0RPM at angle angle using FOC. The motors are from Hobbyking Multistar Elite 5008/5010 or from Arris Hobby 5008/5010/5020 or from Foxtech 5010 or T-motor 5008/5012
JoshuaBRussell wrote 4 days ago point
Really cool project! I'm interested in motor control myself. What resources did you use when helping design the motor control electronics? Specifically related to the PWM, DRV chip, etc.
ODrive and VESC are a good starting point. For the FET Drivers, I like the smarter chips of TI's DRV8xxx family. They offer various control and fault detection options. Gate control can be tricky and these chips handle them easily. The main reason for my custom controller was to have full motor torque at 0RPM.
Deinactivation wrote 4 days ago point
This is extremely interesting, but how does it compare to the commercial actuators on price? You said those ones are ~$500, but what I can find looks like this one has to be pushing at least $200. A full BOM with sources and costs would be awesome.
I was comparing the actuator to the DYNAMIXEL PRO line of robot servos. They start about $500. I will update the BOM over the next few weeks.
Dan Royer wrote 5 days ago point
Nice work! I’m very interested in your project. I’ve tried to make cycloids in the past. My sixi robot arm needs a min holding torque of 20Nm at the base. What kind of play are you getting? (How’s the repeatable accuracy?)
The backlash is quite small but that is all relative. It is good for a quad, not sure about a robot arm. It depends on the tolerances of the 3D printed Cycloidal gear. The joint position sensor is 14bits but getting the magnetic sensor and diametric magnet concentric will effect the accuracy. I have seen people have a calibration table for the magnetic sensor, so maybe the usable accuracy is only 12bits.
Josh Starnes wrote 06/13/2018 at 13:58 point
It reminds me of transformers and other robots that have rotating discs in the joints, and you made it real, waaaah !!
Josh Starnes wrote 06/13/2018 at 13:57 point
Khudos, I really hope you were one of the individuals in the top 20 who got the $1000 prize, this concept is really cool and I love it!! It could be used in any joint in robotics.
Paul Gould wrote 06/13/2018 at 16:48 point
Thanks Josh. I was one of the 20 finalists. I think that the electronic part of the actuator is not the easiest for makers to implement into their designs right now so I might improve it a bit. The PSOC4 is not an easy chip to learn. Maybe something Arduino compatible.
Josh Starnes wrote 06/13/2018 at 16:52 point
I hope the prize encourages you to keep developing it, I normally use high torque servos on my robots but I would like something better and purpose built like this, if there is any way I can help .... even testing some setups I’m happy to be involved
Dan DWRobotics wrote 06/08/2018 at 18:02 point
Can only second my previous comments. The level of work and detail on this project is incredible. I am very excited to see the outcome!
Alberto wrote 06/06/2018 at 12:07 point
Incredible project! Super neat mechanical design.
Paul Gould wrote 06/05/2018 at 11:54 point
@Dan DWRobotics  I do have a little bit of backlash, but it is hardly noticeable. The teeth of ABS cycloidal gear acts like a mini spring, so the back increases a bit with increase load. As you said the software can compensate for this. Backlash was the main reason I started to look into my own actuator design. I made a little biped with RC servos and my own servo amplifiers. The servo backlash was terrible.
Oskar Weigl wrote 06/04/2018 at 06:14 point
This looks super awesome! There's a group of roboticists that would love to hang out with you on the ODrive Discord: https://discord.gg/J9bG3dH
Swing by if you have some time to chat!
Paul Gould wrote 06/04/2018 at 09:37 point
Thanks Oskar. I just joined your ODrive Discord, but remember I'm on Australia time.
Dan DWRobotics wrote 06/03/2018 at 20:30 point
This looks amazing. I always considered cycloidal gears to be just too tricky to make into actuators for joints, but seems like you have done a great job. Also seems like they are very strong and quick joints. Look forward to seeing future progressions. The quadroped construction you have looks really interesting.
Paul Gould wrote 06/04/2018 at 05:11 point
Thanks Dan. I was surprised it worked so well. The first 10 prototypes were tricky but now they are made quite quickly. Cutting the silver steel rods and the brass tube still takes time. ABS is not the right material to make the cycloidal gears with. I sure other filaments would have better mechanical properties. I am using ABS because I can't get other materials to print well on my cheap 3D printer.
I've been watching your project for a while, as cost is a huge factor in how I design robots. Things start to add up when you have 20ish joints. Do you have a problem with backlash? All of the tooth gearboxes I 3D printed were very bad.
Dan DWRobotics wrote 06/04/2018 at 22:25 point
I have a couple of methods for dealing with backlash, but unfortunately there is still a bit. The cost savings across an entire platform justify me programming strategically to mitigate those effects. But I can't pretend that backlash is not an issue. I can imagine you have zero back lash on those gears?
Josh Starnes wrote 06/13/2018 at 17:22 point
have you considered casting the parts out of urethane or nylon? both have lubricating qualities and are much stronger than the pla or abs. I wonder if a outer casing and lube grease might make the mechanism more quite
drew wrote 06/13/2018 at 19:45 point
You might want to think about using Dowel Pins for the drive pins instead of silver steel. They're available in lots of diameters and lengths.
Paul Gould wrote 7 days ago point
Josh, I would like to try casting but it doesn't seem to easy. I was thinking to 3D printed Nylon. I haven't added any grease to the gears yet. The final actuator will be fully sealed (outer housing to be added later).
Drew, I didn't know about Dowel pin, thanks for the tip.
ðeshipu wrote 06/03/2018 at 10:30 point
This is really great. I wonder, do you have any problems with heating/cooling of the motors? The quadcopter motors are made to work in a pretty fast stream of air, I wonder how they work without that for cooling.
Paul Gould wrote 06/04/2018 at 04:43 point
I have not run the motors for more than a minute at a time and I am limiting the power to 60W. They are a bit warm, but I can still touch the stator, (about 50degC). Cooling will be required as the project progresses. I had though of water cooling around the stator with some red die in clear tubing so it looks like blood running through the quadruped's body.
