Relay-based projects
A list of projects where the relays are doing some kind of processing or computing - i.e. something more than just switching a load.
If you're into relay logic then you probably already know about many of these projects - but hopefully some are new to you and can give you additional insights and ideas for your own projects.
Hackaday relay projects
YGREC16 - YG's 16bits Relay Electronic Computer
https://hackaday.io/project/18757
(superseded by #YGREC-РЭС15-bis)
SPDT16: 16-bits arithmetic unit with relays
hackaday.io/project/10889
(superseded by the above project)
SPDT16
Kalin-Burkhart Logical Truth Calculator
hackaday.io/project/7871 (project vanished ?)
4 bit relay adder
hackaday.io/project/3802
RISC Relay CPU
hackaday.io/project/11012
Simple Relay ALU
https://hackaday.io/project/162246-simple-relay-alu
Relay Puzzle Box
hackaday.io/project/2075
Swifty's Relay Clock Project
https://hackaday.io/project/55956
Relay Logic Clock
hackaday.io/project/8683
Relay Computer
hackaday.io/project/10303
RelayRepRap
https://hackaday.io/project/11914-relayreprap
Brainfuck relay computer
https://hackaday.io/project/18599-brainfuck-relay-computer
4 bit relay adder
https://hackaday.io/project/3802-4-bit-relay-adder
4-bit Relay ALU (РЦВМ-1)
https://hackaday.io/project/159308-4-bit-relay-alu-1
RELAY COMPUTING
https://hackaday.io/project/163254-relay-computing
R200 Relay Computer
https://hackaday.io/project/160710-r200-relay-computer
Super Micro Relay Computer
https://hackaday.io/project/167895-super-micro-relay-computer
Relay projects on other sites
Harry Porter's Relay Computer
web.cecs.pdx.edu/~harry/Relay
(see the video )
i² (i Squared
isquared.weebly.com
Basic relay computer
electronixandmore.com/projects/relaycomputer
Relay Computer Two
electronixandmore.com/projects/relaycomputertwo
RC-3
computerculture.org/projects/rc3
Zusie
www.nablaman.com/relay
YouTube: https://www.youtube.com/channel/UCxTUNOQS56cvNHgRD5bKMsg
Mercia
relaiscomputer.nl
Relay calculator
simonwinder.com/projects/relay-calculating-engine (broken)
YouTube video of the square rooting machine : https://www.youtube.com/watch?v=gI8luQnyM9A (2014)
Paul Laws's Relay Computer
relaycomputer.blogspot.my
moved to https://relaycomputer.co.uk/
Clicks
clicksrelaycpu.blogspot.my
A fistful of relays
github.com/Dovgalyuk/Relay/wiki/Build-log
Radiolok
rln.nnov.ru/index.php
github.com/radiolok/RelayComputer2
tqfp.org/radiolok/releynaya-evm-versiya-2-releynaya-logika-alu
TIM series
northdownfarm.co.uk/rory/tim
Duo 14 Premium
ostracodfiles.com/ostracod/relay.html
R500/7T
strangecalc.ch
Youtube : https://www.youtube.com/watch?v=67jLony0mXg
Simon relay processor
cs.ubc.ca/~hilpert/e/simon
Relay Trainer
relaysbc.sourceforge.net
Relaiscomputer
relaiscomputer.de/pr.htm
Relaisrechner
schlaefendorf.de/relaisrechner/dokumentation
4-Bit Relay Adder
brainlubeonline.com/relaycomputer/RelayFramer.html
Neodem ALU/Computer
neodem.com/.../relay-computer
TD4 with relays
http://www.geocities.jp/team_zero_three/TD4/
Relay Computer
http://www.xpl0.org/rr6/
More:
Inspirational relay projects
Pongmechanik
cyberniklas.de/pongmechanik
Software for relay projects
TOFU Circuit Simulator
meatfighter.com/tofu
Relayser - Relay logic simulator
github.com/SmallRoomLabs/Relayser
Youtube:
Relay theory & general info
In the news
  • Falstad's Circuijs now has relays !
    Yann Guidon / YGDES06/27/2021 at 21:51 0 comments
    I was trying to simulate my incrementer's new carry logic and noticed a new feature in http://www.falstad.com/circuit/circuitjs.html : configurable relays !
    You can edit the coil's inductance and resistance, the contact's on and off resistances, the coil's on current and the number of contacts. Still missing is the off current so this is not yet ready to simulate hysteresis. I sent a bug/feature request ;-)
    This page already has some links to relay simulators but circuitjs stands on its own and does many things, moderately well but well enough for most cases. I used it a lot to simulate many types of circuits and now even more !
    What else do you think is still missing from circuitjs ?
    (And for those who might wonder, here is the new circuit for the carry logic, using coils in series instead of parallel as in a previous attempt, so now the current is constant for each slice of 4 bits)
    And the link to play at home.
    UPDATE
    Circuitjs now handles hysteresis ! Here's my first test with the experimental code :-) The new features will be soon integrated in the main dev branch.
  • Rory's computer
    Yann Guidon / YGDES09/08/2018 at 09:55 0 comments
    The TIM machine was featured at EMF !
    You too can build your own machine :-)
  • April 1st video
    Yann Guidon / YGDES03/28/2017 at 04:02 2 comments
    Sweet music composed by @Al Williamsl :-)
    Relays are so simple :-)
  • Relay calculators on youtube
    Yann Guidon / YGDES12/11/2016 at 16:51 0 comments
    Covers the early electromechanical calculators :-)
    The Harwell Dekatron / WITCH calculator, uses Dekatron tubes for storage and telephone relays for the rest. The oldest electronic computer that is still working !
    The computational speed is crazy and tested "live" !
    More links welcome !
View all 4 project logs
Yann Guidon / YGDES wrote 09/03/2023 at 14:57 point
How come I have forgotten @Dr. Cockroach ?
https://hackaday.io/project/21451-uglytech-the-cardboard-relay
https://hackaday.io/project/112078-cardboard-relay-uglytech-is-getting-better
Yann Guidon / YGDES wrote 06/09/2023 at 19:27 point
https://hackaday.io/project/174585-libre-gates/log/220106-the-taxonomy-of-setreset-latches
Yann Guidon / YGDES wrote 06/02/2023 at 03:47 point
https://hackaday.com/2023/06/01/hackaday-prize-2023-building-a-relay-alu/#comment-6648565 :
https://hackaday.io/project/180742-relay-alu
Yann Guidon / YGDES wrote 11/15/2021 at 07:11 point
More relay computing history :
https://de.wikipedia.org/wiki/OPREMA
https://arxiv.org/pdf/1908.09549.pdf
A dual-redundant computer with about 17K relays used at the soviet-controlled Karl Zeiss Jena plant.
Konrad Zuse was the German pioneer of computing and the communists really wanted to catch up...  And they claimed that Oprema drew only 40 Watts ? vs 5KW for the Z5... see https://www.vde.com/de/geschichte/karte/thueringen/gedenktafel
Yann Guidon / YGDES wrote 08/09/2021 at 23:16 point
http://www.electronixandmore.com/projects/relaylogic/index.html
Yann Guidon / YGDES wrote 07/27/2021 at 03:00 point
https://www.youtube.com/watch?v=hReCPMIcLHg Excellent video from Dave, every relay user should know this already !
Stefano wrote 12/29/2020 at 11:29 point
Now with the completion of the main unit can go into the list! :)
Yann Guidon / YGDES wrote 12/29/2020 at 11:41 point
done :-)
Good luck !!!
Stefano wrote 12/29/2020 at 13:16 point
Thank you!
PS: looking at projects noted that "RELAY COMPUTING https://hackaday.io/project/163254-relay-computing" link is not working
Mr. Piay wrote 01/10/2019 at 03:13 point
Hi, I'm also getting into relay computing: https://hackaday.io/project/163254-relay-computing
Yann Guidon / YGDES wrote 01/10/2019 at 04:20 point
Welcome ! have fuuuuun !
Yann Guidon / YGDES wrote 12/29/2020 at 11:42 point
oh, your project has disappeared :-(
Yann Guidon / YGDES wrote 11/11/2018 at 01:52 point
https://www.youtube.com/watch?v=BE2F9dvAI-Q
just a flip-flop turned into a frequency divider :-D
roelh wrote 11/10/2018 at 20:30 point
For simulating your relay project, I recommend the Falstad simulator: http://www.falstad.com/circuit/
The relays can be selected in the "Draw" menu under "Passive components".
An example of using the Falstad simulator for relays can be found in my Simple Relay ALU project, https://hackaday.io/project/162246-simple-relay-alu (Scroll to the end of the Details section).
Advantages of the Falstad simulator:
1) It will also simulate 'backdriving', current that flows through a contact in the direction that was not intended,
2) It shows the actual position of the contacts.
3) You can edit the relay symbol to set the resistance and attract current.
Yann Guidon / YGDES wrote 11/11/2018 at 00:38 point
ah the memories... *pun*
https://hackaday.io/project/20864-ygrec-15-bis/log/58292-i-can-see-now
I used falstad to test my DRAM array and its excellence was challenged by my naughty circuit :-P But yeah it's a cool and useful tool :-)
roelh wrote 11/08/2018 at 18:40 point
The simplest Relay ALU ever ! Only 2 DPDT relays (or 3 SPDT relays) and a few diodes provide 10 functions, including shift-right. See https://hackaday.io/project/162246-simple-relay-alu !
Yann Guidon / YGDES wrote 08/21/2018 at 18:10 point
More old relays !
The ARC is a pioneering electromechanical automatic calculator designed by the Booth spouses in UK.
http://www.chilton-computing.org.uk/acl/literature/manuals/cambridge/p005.htm
First use of a drum high-speed magnetic memory, first electromechanical and fast computer with 20 bits of fixed points, addition in 1/50th of a second... Very interesting :-)
Yann Guidon / YGDES wrote 05/04/2018 at 17:45 point
Yet more relays, for beginners : https://en.wikipedia.org/wiki/Minivac_601
Yann Guidon / YGDES wrote 05/04/2018 at 17:48 point
With the associated HaD rebuild : #HOMEBREW MINIVAC 601 COMPUTER
Mark wrote 03/29/2017 at 00:17 point
I'd like to be on the list.  Relays are a big part of the games I've built with retired electromechanical pinball machine parts.  Thanks.    funwithpinball.com/games
Yann Guidon / YGDES wrote 03/29/2017 at 00:23 point
Welcome here !
will.stevens wrote 03/24/2017 at 22:36 point
Hi, thanks for this great resource, please could you add my project. It's about making the relays from scratch, and then using the relays to make control circuitry:
Yann Guidon / YGDES wrote 03/25/2017 at 01:53 point
Sure ! Thanks for the notice !
Dave Gönner wrote 05/21/2016 at 16:38 point
Can we include this one as well?
http://www.cyberniklas.de/pongmechanik/indexen.html
It's a mechanical implementation of  Pong, with relays for the game logic
matseng wrote 05/22/2016 at 02:47 point
Thanks. I added it in its own section "Inspirational projects" since there was no real technical info like diagrams/schematics and such about the projects, just a BOM.
Still it's a very cool project that I'd love to clone some day - just as I like to build this awesome (non-relay) based mechanical Lunar Lander game some day as well.  http://lushprojects.com/lunarlander/
