Hexastorm is an open-hardware laser scanning engine designed for high-speed, high-resolution direct laser imaging (LDI) in PCB lithography and photopolymer 3D printing. By utilizing a high-speed rotating refractive prism scanner, it achieves rapid raster exposure on photosensitive substrates (such as UV solar paper, dry-film photoresist, or cyanotype paper) without expensive galvanometer systems or slow Cartesian gantries.
Specifications and spot metrics were characterized via direct camera-sensor exposure (without a lens) and analyzed using OpenCV. For in-depth theoretical analysis and background, see the blog.
Specifications
- Wavelength: 405 nm
- Optical Power: 500 mW
- Rotation Speed: 3000 RPM (rated up to 21,000 RPM)
- Line Scan Speed: Up to 34 m/s (at 21,000 RPM)
- Spot Size (FWHM): Circular, ~25 µm diameter
- Cross-Scan Error: 40 µm (orthogonal to scan line)
- In-Scan Jitter: 35 µm (parallel to scan line)
- Stabilization Accuracy: 2.2 µm (scanning direction)
- Scan Line Length: 8 mm typical (24 mm maximum)
- Duty Cycle: 47%
- Laser Driver Frequency: 400 kHz (current FPGA core supports up to 12 MHz)
- Prism Scanner: 4-facet rotating prism, 30 × 30 × 2 mm
Electronics & Architecture
- FPGA: Lattice iCE40UP5K-SG48 (developed with the open-source Icestorm / Yosys toolchain)
- Gateware Framework: Amaranth HDL with components from the LUNA ecosystem
- Microcontroller: ESP32-S3
- Motion Control: 3× TMC2209 silent stepper motor drivers + high-speed laser diode driver
Status & Results
The toolchain accepts standard SVG layer exports directly from KiCad and compiles them into synchronized raster/motion commands for the scan head.
Single-facet exposures on UV photo paper easily resolve sub-60 µm features. Ongoing optimization is focused on mechanical backlash compensation (~100 µm stage play) and seam-width calibration to eliminate slight overlap between adjacent scan lanes.
Watch the scanner during a live raster exposure run below:
Repositories & Resources
- Gateware: Hexastorm Amaranth HDL Repository
- Optics: Optical Design & Simulation Files
- Electronics: Firestarter Driver PCB
- Mechanical CAD: CAD Files & 3D Models
- Documentation: RepRap Project Whitepaper
- Website: hexastorm.com
Acknowledgements
- Henner Zeller for his pioneering open-source work on LDGraphy (see demonstration video).
- Dr. Jacobus Jamar & TNO / Amsystems for a related prism laser scanning concept using multiple beams per prism.
- whitequark and Catherine 'ktemkin' for Amaranth HDL and the LUNA toolset.
Hexastorm
Owen Trueblood
helge
FabLab München
LesWright
I have been following this project for a few years now. Can't wait to see the end results. Thanks for sharing the journey !
