Minamil 3dp: another minimal CNC mill
A very compact, very inexpensive, very DIYable, very precise little CNC mill. This one uses 3d printed parts.
"MInamil" -- this time it's "Minamil 3dp" because 3d printed -- is a minimal CNC mill that actually works pretty well. It's small and it's not strong, but it's uncommonly precise for an amateur-accessible machine. Small is a feature, and light cuts with small cutters gets stuff done with available strength and stiffness. Work volume 75 mm x 75 mm x 50 mm.
(26 Jul '26 update: link to gallery. duh. and a little reordering of what really needs more editing)
Hackaday Prize 2023 finalist! Thank you judges!
Cut small stuff from useful materials:
Up to 75mm x 75mm x 50mm.
Figure cut from brass flat bar using 1 mm (0.039") and 0.015" (0.38 mm) flat endmills.
nevermind the paint -- that's a different learning curve.
...and yes, I will mix units horribly in this project. it will be ok, we're not trying to land on another planet.
Minamil 3dp is another little CNC mill. This one uses 3d printed parts, which give (at least) two advantages over the laser cut version:
  • probably more people can 3d print parts today than can laser cut parts
  • much easier assembly vs. building 3d structure from 2d parts
While not at all necessary to make the CNC parts work, a little more work put into the frame/enclosure can make a more practically usable result. The example shown below also shows:
  • a completely new configuration of the integrated enclosure concept relative to earlier work
  • more complete actual accomplished integration of accessory stuff that could be integrated but previously wasn't
And a little side show that makes this work, that I haven't seen elsewhere, and that might help anyone trying to do fine work with a cheap rotary tool: reducing runout.
Little airplane in a 4 mm disk cut from brass shim stock with a 0.1 mm V bit.
Sharp, accurate features in Aluminum with tiny cutters down to 0.010" (0.25 mm). This pic is a backlash test pattern for the "big" cutter that I repeated with the smaller cutters because new toys.
This short video is kinda neat but doesn't really add much so I'll link instead of embed so hopefully it won't slow down your first scroll through this stuff:
Mill circuit boards for fine-pitch components:
Breakout board for 0.5mm pitch QFN-16.
A more specific 0.5 mm pitch QFN-16 breakout for TLV7044 with supply bypass closer to the chip and pinning like the DIP & SO packaged parts. For a different project. Hopefully I'll be able to replace this pic with a populated board "soon"...
Isolated copper traces down to 0.1 mm center-center pitch with a massaged "0.1 mm" V bit.
But that's all flat stuff :-/
Yeah. I've been working on the tool instead of making stuff. But check this out:
First I'll show this little bevel gear,...
... because the "3dp" 3d printed mill that is the object of this project actually for real cut that gear at MRRF. So I hope you'll accept some parts cut by the earlier laser-cut version of this CNC as an illustration of capability:
Spider gears and structure parts for a little differential with a US "quarter" coin for scale.
The spider gear assembly in the complete differential is smaller than my fingernail. There's a <4 min. video about that over in the "2dc" project but it's old work and too much about the earlier laser-cut design to include in this project.
More examples of work from this[*] little machine.
[*] some version of the same basic idea through its evolution so far.
Packaging for UX
The CNC mechanics consist of an XY table and a separate Z axis. The two parts need some sort of frame to hold their positions relative to each other. The frame can be very basic. But I want to use my machine in a smallish urban condo with no "shop"-like space.  So I've put a little more effort into the frame and packaging..
The "telescoping" slide design allows very compact non-operating footprint.
More about packaging -- which is already obsolete because I haven't yet written up several improvements like cleaner DC supply and integrated logic-switched AC for the dremeloid.
Interested?
To build your own, start here.
To scan log entries, ToC here.
Spun off from #Minamil: a minimal CNC mill and companion to #"Desk Accessory" CNC Milling Machine.
This project encompasses 2 projects. And a half.
  • very small...
minamil3dp-XY-STLs-v0.9.1.zip
X+Y stage parts. For slicing info see https://hackaday.io/project/192074/log/223146/
Zip Archive - 6.71 MB - 09/24/2023 at 07:33
Download
minamil3dp-Z-STLs-v0.9.0.zip
Z axis parts.
Zip Archive - 8.39 MB - 08/09/2025 at 15:48
Download
minamil3dp-XY-workholding-STLs-v0.9.1.zip
You probably don't need this. see https://hackaday.io/project/192074/log/242907-workholding
Zip Archive - 769.01 kB - 10/10/2025 at 05:11
Download
minamil3dp-Z-STLs-v0.1.0.zip
*old* Z axis parts -- prolly going away soon
Zip Archive - 1.06 MB - 09/25/2023 at 20:41
Download
  • Almost not sideways. But not not sideways.
    Paul McClay • 07/17/2026 at 04:07 • 0 comments
    If this note is still here, and you might consider making one of these things for youself, start here not here. Really. Click away while you can. We'll wait...
    You're still here? Ok.
    For context: the previous log serves as a checkpoint where anyone interested in making and using one of these things for real can stop reading because this and foreseeable updates are going off into deep weeds for a while before getting back to anything actually useful.
    My tension at this point is that I've been accumulating a backlog of project evolution to log, but the evolution is a bit sideways and not yet to a point of "here! build this!" or "hey! look at this!" and I rilly rilly really don't want anyone who's thinking "hmm, I might actually do that" to think "hmm, it looks like I should wait for this immanent update". Really. If you're thinking about making and using one of these things for real: there is nothing about to drop that's going to make you wish you'd waited.
    So what's this half-year (so far) of "sideways"?
    tl;dr: another failure to change one thing at a time.
    Dear Reader: I don't know that writing this out will benefit anyone other than me trying to keep my own story straight, and to shift a partial load of backstory out of anticipated Log entries that might possibly reflect more forward progress.
    From the previous log: one fine day I discovered solid sliding contact between layers of the XY stack. It appeared to have been so for some time and through a few revisions without hindering normal operation. I could have just said "so it is" and let it be so. But trying to pass that off as a working mechanical design seemed like a slouch too far.
    So here's a story that runs more-or-less linear through the part that could have been easy, then diverges.
    The printed parts of this X+Y stack are all PLA -- the printable plastic that's stiffer than most (all?) alternatives that aren't exotic. When it's not too hot. And too hot isn't very hot. The X & Y steppers run hot enough to make compatibility with PLA a question from the start. That's why the motor+screw units live at the outboard edges of each layer and with open-ish ventilation around the motors. Empirical results so far indicate that the thicker middle part carries the Y motor without trouble, but the thinner top part softens enough to let the X motor droop.
    The greater vulnerability of the top part/X motor is no surprise.
    Working clearances reduce direct support for the motor to a long thin cantilever:
    With the interior of the part body thinned out so much, support for the motor leans more on the stiffness of the perimeter. The motor+screw unit fits right along the front edge, which runs between the front corners which are supported by the left & right edges, which have greater section depth through their cantilever projections beyond the supporting rod ends:
    The front face supports the front edge of the otherwise floppy font third of the top surface -- from which the motor hangs. It also has a big hole in it for airflow to cool the motor. Continuity of edges above & below the big hole help the face resisted bending, but the resulting parallelogram is weak in shear, which pops the 'stiffness of the perimeter' baloon. Reducing the vent area seems like the wrong answer to a heat problem.
    So the X motor is held up by some long, thin, warm cantilevers. Clipping a couple of corners of the big hole might have helped. A little. Maybe.
    ...And that all turns into a sliding interface with the part below, as highlighted in the first image above. Which works. For inaesthetic reasons.
    Hmm...
    How about shifting the motor+screw to the other end of the front edge?
    aside:I was already considering that shift as part of a deferred cable routing aspiration which I had "...convinced myself to stop thinking about ... But d[id]n't not consider it anymore." But the current...
  • Warm PLA sag: accidentally not really a problem
    Paul McClay • 06/29/2026 at 00:19 • 0 comments
    tl;dr: dr won't hurt
    These three iterations of the evolving "top" part show the same sag around the X motor:
    So that's been happening for a while. I've let it go on without much thought because it hasn't caused much trouble.
    Part in context:
    left = left; right = front; X axis = down-left to up-right
    That was a predictable weak spot, analyzed by the method of build-it-and-see-how-it-breaks. The part gets thin over the motor frame and adjacent bearing clearance which weakens cantilever support for the motor. The left and right sides provide better cantilever support for the front corners which support the front edge which would better support the front side of the motor frame if no big chunk of ventilation were cut out from it. Tying across the top and bottom of the vent opening resists bending along the front edge, but the resulting parallelogram does little to resist shear. Diagonal bracing across the vent opening might help, but obstructing airflow doesn't feel like the right solution to a heat problem.
    So stuff sags after a while. This has two effects:
    1. The motor and motor end of the screw drop. I've assumed imprecise vertical separation between the layers of the XY stack from the very first try at the basic idea, so tolerance for a little droop of the motor+screw unit was already in there, and proves more tolerant than expected. This has been a non-problem.
    2. Deformation relaxes the zip tie around the motor end of the motor+screw unit. This has been mostly a non-problem because that mostly doesn't affect axial constraint. Once (maybe twice?) the tie got slack enough to let the corner radius of the motor frame drop to the level of the relatively shallow end of the pocket into which the motor fits (maybe that needs a picture...) which let backlash grow enough to matter when I wanted really small backlash. So when mostly-not-a-problem got to be enough of a problem to notice, the fix was to replace the tie holding up the motor.
    Flipping the motor down to the top side of the more substantial "middle" part would be easy, but that would expose the screw to falling debris, which I've been able to avoid so far.
    A while (um, half a year by now...) ago I noticed that the sagging front edge of the "top" part was in solid contact with the "middle" part. I guess that explains why all three examples above had sagged to the same extent.
    That apparently is also a non-problem because, even though the parts are firmly in contact through about half of the slide travel, the rounded part of the middle part has no edge and the bottom edge of the top part is burnished smooth. Where "firmly in contact" means firmly pinch and hold a sheet of paper forced in between the two parts. The fact that it all works fine shows that this makes a sliding interface with very little friction. Maybe I could sell that as clever mechanical design if it wasn't so obviously not.
    So... nothing. If you're thinking about building one of these for yourself, don't stop for this.
    What's not in this log update includes sequelae of discovering unintended sliding contact.
  • OT: MRRF is dead, long live (not)MRRF!​
    Paul McClay • 06/27/2026 at 21:54 • 0 comments
    (because I haven't noticed this elsewhere in Hackadaydom yet)
    Made it to another MRRF -- er -- a month ago by now. The last MRRF. with the good folk of MakerHive commissioned to fill its place with a new thing under a new name.
    From the organizers' 14 June (2026) fb post after closing the show:
    [...] Sonny and I are in awe every year at how many and how far come to attend this festival.
    As we say goodbye this afternoon, we ask that everyone support the new festival next year.  I know they will do their best to keep the spirit of MRRF alive, while building onto it with their own ideas and communities.  Please make sure to follow The MakerHive as they take on the torch and continue the festival with a new name and their amazing members organizing the evolution of MRRF.
    -Sonny (Os1r1s)
    -John (Johnoly99)
    MRRF/Sonny/John image
  • yet another little differential gearbox
    Paul McClay • 11/29/2025 at 20:30 • 3 comments
    Ok, I've been teasing pix of parts of this for half a year...
    ...while holding out for more of an eye-candy presentation idea. Not least because I don't have a "here, watch this..." video that shows the little machine in its 3d printed form.[a] But no such idea has landed. So, until that happens, here's an eye-spinach look at the latest little differential gearbox.
    What's this guy's deal with differentials anyhow?
    Well, it's like this...
    An early question for an earlier variation on this minimal CNC theme was 'why?'. What (in low budget hobby/"maker" context) could a little CNC do that a laser cutter or 3d printer couldn't? How about a small bevel gear? Laser cutters can make spur gears but not bevel gears. FDM printers can't make precise small features (with a sane nozzle). SLA printers can make small 3d objects -- out of fragile material (tho resins are getting better). So the first differentiating example was a small bevel gear cut from acrylic.
    But one bevel gear doesn't count. You can't even tell if it's right, let alone convince anyone it's interesting, without another bevel gear.
    (And lemme just say here that those gears mesh intoxicatingly well. The little wobble in the gif above is only an artifact of the hasty setup and running out of duster gas to keep trying to catch video of a really smooth spin. Smooth driving torque against resistance too. It's one thing to read about involute geometry, and quite another to feel a self-made pair of own-design gears defying their coarse appearance. An instance of encouragement to keep the project going.)
    So, then, on the road to Shelbyville, as an example of something that more common tools wouldn't have made better more easily in a fraction of the time, that was sufficient. But not satisfying. Giving a pair of gears something interesting to do escalated to giving them more friends and a little differential to live in:
    who needs adjectives when English has nouns like 'differential'?
    And that was a fairly satisfactory example. For a while. There was that little thing about it ending up not quite as compact as I'd first had in mind because I was having a hard time (i.e. not) keeping consistently small runout... But life could go on.
    Until, eventually, I started to get a better handle on runout.
    And then, eventually, which is what they called 'later' in those days, I got around to scratching the "not quite as compact as I'd first had in mind" itch...
    ... and made another, littler differential.
    If you're wondering what "differential" is about: when Big Finger stops one of the swirly side parts, the middle part keeps spinning and the other side swirly part spins faster. So trucks can deliver food into cities.
    That's still a fine demo wodget. Which, among other widgets, is useful because all this is easier to show than tell. But t's awkward that the catchy video about that shows an obviously different variation on the "Minamil" theme. But I don't have the next eye-candy demo video yet. O the wearying weight of first world problems.
    So, that's the first chapter or three of "what's this guy's deal with differentials anyhow?"
    And then...
    ...a couple of things. Two independent events described here in arbitrary order because I don't remember which was first or second and it doesn't matter.
    Thing 1
    I thought of a use for a cheap little RC car. Online Retail offers heaps of cheap little RC cars and controls that look like what I was looking for, so that seemed like the easy part.
    Until, on the cusp of ordering one, I figured out that all the cheap ones use bang-bang control (go, not go, go backward, turn left, not turn, turn right), which would not do, and the jump up to cheapest with proportional control was too much less cheap for the idea in mind.
    Until, on the cusp of not ordering one, I stumbled on the D12 Mini -- inaugural product of CXD, a fresh (then) spinoff from an...
  • Workholding
    Paul McClay • 08/21/2025 at 17:29 • 0 comments
    CNC milling/routing involves holding the thing that's getting cut.
    (If you aim to build one of these for yourself, start here not here! This is extra complexity you almost certainly do not need! More exclamation marks: !!)
    I've been using double-sided tape to hold work since the second iteration of the laser-cut precursor to this project. It's hard to beat for simplicity, and it works well enough often enough to make some stuff. But sometimes it reminds me to think about mechanical workholding again. After a few years of no good ideas, I think this might work.
    spaces for nuts below and places to drill for screws above -- with an arbitrary 10 x 10 patch of nuts just to show what 100/207 looks like
    That's
    • a bunch of square nut pockets sunk into the formerly flat top of the "top" part, and
    • a new flat slab on top of that.
    Slab
    I don't know what to call the new slab on top of the top part (of "bottom", "middle", and "top" parts of the XY stack). If it were square-rigged, it would be the t'gallant part. Maybe it will be just "slab" for now.
    Outwardly, the slab is just a flat slab with ½-dozen screws through it. Between the solid top & bottom surfaces there are void holes aligned with the nut pockets in the top surface of the top part. More to the point, "holes" means vertical cylinder walls around the holes to bear compression.
    Because ... why?
    Wherever you want to screw/clamp/hold work on top of the slab, drill through the nearest "drill here" mark on the bottom of the slab to open the top and bottom (i.e. bottom and top) of one of the internal voids and drop a nut in the corresponding pocket.
    The selectively populated 8 mm square grid of "drill here" marks is easier to see in the CAD render below than in the photo above. (even tho the marks are bigger in the photo)
    "legal" points of 8 mm × 8 mm grid
    I don't know whether or not this idea is actually novel, but I don't recall seeing it anywhere else. I also don't know whether or not it is actually useful, because I haven't actually used it to make anything other than pretty pictures for this page.
    Here is a (i.e. the) a worked example:
    drill through "legal" grid points nearest where you want to place screws
    drop square nuts into corresponding square nut pockets
    secure the slab on top of the top; now there are robust metal threads under the drilled holes
    workholding widgets
    workholding widgets holding work -- in a repeatable(ish) position
    !!: different length screws shimmed to near-exact lengths to fully engage nut thread without bottoming in shallow pockets!
    Maybe
    Of course it works. Because what could go wrong? ¯\_ (ツ)_/¯
    vibration
    Screws working loose from vibration is the first risk that comes to mind. The bet here is that clamped PLA is springy enough to prevent that. If not: Thin square nylock nuts would be great but I haven't found such a thing yet. Common hex nylocks would require deeper pockets (thicker top or fewer pockets) and holding a hex nut shape against torque with PLA is less easy than holding square nuts. McMaster-Carr lists "thin profile" hex nylocks, which seem quite pointless in smaller sizes: 3.9 mm thick vs 4 mm for m3. It appears that barleycorn nuts run thinner per thread diameter: 4-40 thread at 2.85 mm diameter is 95% of m3 diameter (90% section area) and "thin profile" 4-40 nylock nuts are only 2.8 mm thick or 70% of m3 (4 mm), so "thin" 4-40 nylock nuts could be accommodated within current dimensions with some very thin pocket floors. There are also anti-vibration screws: e.g. with a patch of nylon on the thread, or "tri-lobe" shape (tho use with steel nuts would be off-label). Or maybe just 3 mm o-rings under the screw heads.
    widgetry
    Those totally credible-looking "workholding widgets" were totally just whipped up to make the few  ̶p̶r̶e̶t̶t̶y̶  helpfully illustrative pictures above....
  • A better Z axis that's actually better
    Paul McClay • 08/09/2025 at 09:58 • 3 comments
    The previously shared Z axis was very much a rough proof of concept. It worked well enough to not demand revision while I worked on other aspects of the project. Two prior attempts to fix its faults proved out some ideas but introduced other faults. This version seems like time to say "build this not that".
    Beware vocabulary: I haven’t found a reliable escape from using “tool” to mean both “Dremel®-like rotary tool” and “endmill”. Context or bust.
    What
    Vertical axis for the CNC mill described in this project.
    Why
    Because I don’t already see tragedy in this attempt to fix faults of earlier attempts to fix faults of the previously published version. That version worked well enough to warrant sharing so you can make your own copy of a capable tool. But it was a placeholder waiting for a better replacement. An earlier log entry describes problems with the first version, and solutions that worked in earlier attempts to come up with the better replacement. This try keeps the solutions without stepping in any new poo that I’ve smelled so far. Of course lots could be different and I’m not saying any of it is “best” or “right” or "done" but I'm pretty happy with it for now.
    How
    Briefly:
    • Build X+Y stage
    • Choose a rotary tool
    • Choose clamp configuration
    • Print parts
    • Collect other parts
    • Assemble
    Biuld X+Y
    You don’t really have to, but I think building the X+Y stage first will help because there are more words and pictures about how to put that together. Familiarity with detailed information there should help to make sense of less detailed info here.
    In keeping with the low cost/less stuff theme of this project, the Z axis is designed to hold a vanilla Dremel®-like rotary tool for a milling spindle. Clamping and releasing the tool is meant to be easy, so you can use the daily-driver you may already have and drop it into your little mill when you want to do a little milling.
    What will work?
    The tool clamp is designed around a tool body pattern set by Dremel (i.e. Emmerson) in a prior millenium. I don’t know of any simple name for the type except that they look like this:
    current Dremel product image
    Many Dremel tools that look like that are called “MultiPro”, but the form was up to “type 5” before they were called “MultiPro” and not all “MultiPro” tools look like that. Current Dremel products have mostly moved on to different shapes, but Dremel still (mid-2025) sells their low-end 100 & 200 models in this style, but you probably don’t want one of those because they lack speed control, but several generic labels are selling 5-speed clones that look like they come out of the same molds as used by whoever makes Dremel’s 100 and 200 units these days. The basic pattern includes a straight cylindrical body segment between a taper down to a threaded nose below and a fatter section above that includes brush bosses and a vent or switch at a fairly uniform height.
    The tool-carrying sled
    • clamps around the cylindrical part,
    • clamps a ring screwed on the tool’s nose, and
    • allows clearance for the extra stuff above including access to the switch or vent at the level of the brushes.
    Like this:
    For tools with the switch between the brushes, clip out the lattice for access.
    For a Dremel 300, clip out the thin bits around the spindle lock boss.
    The left four models fit as intended. I’ve used the first three and @janvorli on the Discord server has verified that his Dremel 300 (the fourth) fits. For tools with the switch between the brushes, clip out the lattice for access. For a Dremel 300, clip out the thin bits around the spindle lock boss.
    I haven't tried the questionable two on the right, but only looked at photos and marked features that differ from what the clamp was designed to hold.
    The long nose of the “type 3”...
  • MRRF 2025
    Paul McClay • 07/25/2025 at 07:50 • 0 comments
    Lots of project log backlog to catch up on. Again. Starting with:
    MRRF. Successfully after not getting there last year.
    Taking this project to the Midwest RepRap Festival (MRRF) a couple of times (2022, 2023) has encouraged and enriched continuing development of the idea.
    A great drone flythrough video gives a quick visual impression of the event.
    MRRF is mostly about 3d printing. A very few CNC machines of ye olde subtractive nature turn up too, so they haven't kicked me out yet.
    "But what is this 'RepRap'?" you might ask. Increasingly many people aware of "3d printing" won't know that personal/home/hobby/cheap/accessible 3d printing all happened under a banner called "RepRap" before it graduated to global industry. ERRF already isn't called that anymore.
    Anyhow...
    I didn't take any pictures (again), but Shenanigans3d stopped by while live streaming his tour of the show (1:05:32 if the link doesn't drop you in at that time).
    Hustle to make some new demo widget before the show contributed to letting logs lapse here. That turned into yet another yet smaller differential gearbox -- this time with a bona fide application(!) -- which will get its own log entry here *cough*soon*cough*. Apart from Mr. Shenanigan's autofocusonsomethingelse close-up, all I've got to show for now are a couple of in-progress pix:
    People, like Mr. Shenanigans, stopping to look and talk for more than a minute seems like feedback that this project is actually interesting. Just for fun, here's an interview with another guy, "Steve". His thing is interesting in its own right and he reps it well (at 26:38). Did you know about the "CLSP" scene? I for sure didn't until I went over to see what was that thing like-but-unlike a sewing machine that he had. Relevant for this paragraph: the guy in the blue T-shirt and beard beyond the interviewer's left shoulder is another more-than-a-minute visitor there looking and talking though most of the duration of Steve's interview. People even remember from prior shows. Maybe the highlight of the trip was a quiet parting handshake from an old machinist.
  • On making a "simple frame" simply
    Paul McClay • 04/07/2025 at 05:59 • 0 comments
    To repeat a theme: this project focuses on the CNC mechanics, and the shortest path to building your own and making it work includes not following me down the fancy box rabbit hole. Yet. This is enough to get started:
    Made from a few rough scraps, drywall screws, and eyeball "measurements"
    If you have access to a table saw, or some other way to make straight square cuts, you can make a slightly less haphazard version of the same thing:
    Same thing but looks better if you have means to make straight square saw cuts
    While square parts look good, that's still only "slightly less haphazard" because the four frame parts are sized by eye with no measured dimension. Keeping it simple!
    Placement of Z over X&Y
    The frame's job is to hold the vertical axis over the horizontal axes. That's the relationship that matters. Here are some dimensions to help set up that relative relationship. The numbers are millimeters, but "looks like this" is close enough.
    View from front; bottom edge of fixed base of Z axis about 10.5-11 cm above the deck; tool axis about 2 cm in from left edge of XY stack
    View from above; vertical face for mounting the Z axis about 7cm back from the front edge of the XY stack
    Left and right clearances
    View from front; leave room on the right side of the XY stack for your vacuum cleaner "crevice tool"; the X axis extends 75 mm to the left, so leave 8 or 9 cm on that side
    Just a little bit less simple
    Closing off the lower back of the frame will go a long way to making cleanup easier.
    A bit of cardboard and tape will do the job:
    For just a little more effort when cutting parts, a couple more pieces cut to the same width as the vertical transverse piece will both close off the back and also make the frame significantly more stiff. And if you're going that far, a third piece across the top will add another increment of stiffness to the Z axis.
    Chunky material like the 3/4" (18mm) slabs illustrated here will probably be plenty stiff enough on their own for a minimal four-piece frame. If your material is thin or otherwise uninspiring, the three extra pieces shown above can very significantly stiffen the frame. If using the narrow horizontal pieces behind the top and bottom edges of the vertical Z axis support, they should be attached along those spanwise edges as well as at their ends.
  • Discord: active and productive!
    Paul McClay • 01/27/2025 at 05:04 • 0 comments
    (May 2026 update: "first non-trivial milling" from janvorli, and added a couple more builds/builders)
    More log catch-up...
    The project subtitle includes "very DIYable". I can say so, but proving so remains for others to do.
    While I've been not updating logs here, a couple of builders on Discord have completed their own "Minamil"-like machines up to first cuts. They've hit some major milestones for the project and I'm well late at saying so.
    Discorder janvorli has built his machine with a proper spindle:
    He started with a Dremel 300 in mind (I.e. in hand) which almost but not quite fit in the Z tool clamp. Then he found a too-good-to-pass deal on the 52mm spindle bundled with power supply etc. So there are a couple more versions of the Z sled to be found in Discord chat history, or for asking:
    • slightly modified for compatibility with Dremel 300 in addition to whatever else already fit
    • more modified for 52mm spindle only (& clearance for 54mm fan if present)
    In the photo above, janvorli has two Z motors rigged. That didn't work. ...I think the 'why' will get its own log entry... What does work for this ~1kg spindle is a single motor and 2:1 purchase.  He bored the tie-off bit out the printed part and fitted part of a 3mm smooth metal rod from an old floppy drive. The hoist cord coming down from the motor now turns around that pin with very little friction and runs back up to a screw eye screwed into the fixed base just below the motor/pulley.
    At last report on Discord, janvorli had cut a couple of flat spaces:
    It may not look like much but the considerable victory shown there is that, after troubleshooting his heavier Z axis and my dual motor fallacy, the two flats are milled to exactly the same depth. Big win.
    I think it's important to note that janvorli is the first, that I knew of, to wade into building the 3d printed version of this "Minamil" concept. So he bore the brunt of (not) finding what I hadn't written yet, and challenging the Z axis with a load that I hadn't actually tested for real. I appreciate his help to advance the documentation, and understanding of how the Z axis really works -- and what to try next for that.
    Update from janvorli: "I think I can finally declare my Minamil as finished :-). I've done a first non-trivial milling today."
    missing image - try refreshing the page to poke the server again
    ... please pardon my slow update here in May (2026) to reflect janvorli's progress from last October. Also a couple more new builds below if you're here for the updates.
    Meanwhile, Raf on Discord was building his own "Minamil" when he found that his Dremel 3000 didn't fit into the Z sled. He found a 3D model of the tool that I could use in lieu of the real tool in hand, and we had some back-and-forth about adapting the tool clamp to fit. Almost:
    Then a friend of his with relevant CAD skill grafted a suitable clamp onto the base of the Z sled STL to put Raf in business. Raf also shared the new STL back to Discord.  A more responsive me would already have all these modified tool clamps uploaded to the HaD project files. So please ask if you have need and don't feel like combing through Discord history. (But hey, join the Discord party anyhow!)
    And here's Raf's built machine:
    Yeah, the tool body clamp broke. He says it's working ok with just the nose clamp.
    He too has both Z motors rigged. If we've understood janvorli's case correctly, that works for Raf, and my earlier trials, because it doesn't really need both motors to lift the spindle, so it's less vulnerable to differences between theory and reality of load sharing as currently implemented. ...more about that in the other log entry that I haven't written yet.
    Raf's uploaded filename "minamil_first_try" suggests this is his first result:
    Nice! I think that's a pretty big deal, in my view of the project, that someone who's not me has actually in fact worked thru the how-to write-up, such...
  • One minute video
    Paul McClay • 01/15/2025 at 22:23 • 0 comments
    A while back I made a few videos to show some of what's easier shown than said. Or believed. Since then I've: shed the Z counterweight, shifted from laser cut to 3d print construction, and changed the frame among other less visible changes. But I haven't made any new widget as photogenic as a little gearbox to prompt a new eye candy vid.
    So here's one minute of simple but sharp recent work with 3d printed mechanics in the current iteration of fancy package:
    I'll probably lift some tight shots from earlier videos eventually, when there's more of more recent content to mix it into. Just replacing wide shots of old stuff with wide shots of new stuff could be expedient, but then "... and here's a different machine that didn't do any of that but could have believemeIpromise" would be awkward.
View all 33 project logs
Ahron Wayne wrote 01/03/2026 at 08:17 • point
Seeing the medallion necklace thing made me think it would be neat if you could use coins as stock.
Paul McClay wrote 01/04/2026 at 02:03 • point
I hope to try some more different metals this year, which will entail more development of how to deal with cutting lube in a context built with high confidence that I'd never have to deal with cutting lube. Just this morning Bezos dropped off a bottle of Anchorlube -- ordered after a comment exchange w/ @dekutree64. Water-based, dilutable, and said by some to be mostly harmless.
zakqwy wrote 04/14/2025 at 11:53 • point
Ah I love this little machine. Impressive results, too! The fold-up enclosure and the "tucked" storage position is quite clever.
Paul McClay wrote 04/16/2025 at 09:29 • point
Hi and thanks for the kind words. Anyone reading this should check out your "circuit graver" too!
The folding/expanding arrangement here is a happy accidental development of a project that has far exceeded anything I was imagining at the outset. The whole fancy box thing is a side quest (i.e. distraction) that's not at all necessary to get results from the CNC part.
Gravis wrote 03/08/2024 at 12:06 • point
I like this project and have a recommendation: change the stage so that each axis travels from -50% to +50% (of it's width) from it's original position. Exceeding 50% increase the chances of tramming issues.
Paul McClay wrote 03/08/2024 at 21:07 • point
Thanks Gravis for your interest, comment, and recommendation.
Maybe I don't understand what you mean. My first impression is that the mechanical change you suggest would lead to a more conventional layout and a larger footprint. For this project I'd rather keep the small footprint than chase better tram.  With tiny endmills the unadjusted tram hasn't caused enough trouble yet to prompt any effort to make it better, so I don't yet know what I'll end up with if I (anyone) ever get around to trying to tram this thing as it is.
Do you mean that defining "home" at mid-travel and tramming there can minimize variation between there and either end vs tramming at one end?
For best stiffness, this layout favors operation near the "home" ends of the X & Y axes. Happily, it suffers much less loss of stiffness at full extension than I expected. In case it's not already clear (in the description/pix as of writing this comment), the first part of this page shows how these X & Y axes work: https://hackaday.io/project/174370-minamil-2dc-a-minimal-cnc-mill/log/185281-some-of-the-basic-ideas-that-seem-to-be-working
Gravis wrote 03/11/2024 at 01:08 • point
Yes, I do mean that "home" position would be at 50% of the stroke distance of the actuator.
Despite being stiff, it will invariably sag more and more the further it is from the home position. If you place the home position at exactly 50% of the actuator stroke distance then that will minimize the sagging on each axis.
Sagging compounds with each axis, so cutting something on the outermost limit of both axes will be the worst case scenario.
Paul McClay wrote 03/19/2024 at 04:06 • point
I think you're describing a different mechanism that would have different trade-offs. In other words, a mechanism that isn't different from what's already common.
