Minamil 3dp: another minimal CNC mill
A very compact, very inexpensive, very DIYable, very precise little CNC mill. This one uses 3d printed parts.
Public Chat
"MInamil" -- this time it's "Minamil 3dp" because 3d printed -- is a minimal CNC mill that actually works pretty well. It's small and it's not strong, but it's uncommonly precise for an amateur-accessible machine. Small is a feature, and light cuts with small cutters gets stuff done with available strength and stiffness. Work volume 75 mm x 75 mm x 50 mm.
(16 Sep '24 update: replace 0.2 mm trace example with 0.1 mm)
Hackaday Prize 2023 finalist! Thank you judges!
Minamil 3dp is another little CNC mill. This one uses 3d printed parts, which give (at least) two advantages:
  • probably more people can 3d print parts today than can laser cut parts
  • much easier assembly vs. building 3d structure from 2d parts
While not at all necessary to make the CNC parts work, a little more work put into the frame/enclosure can make a more practically usable result. The example shown below also shows:
  • a completely new configuration of the integrated enclosure concept relative to earlier work
  • more complete actual accomplished integration of accessory stuff that could be integrated but previously wasn't
And a little side show that makes this work, that I haven't seen elsewhere, and that might help anyone trying to do fine work with a cheap rotary tool: reducing runout.
Cut small stuff from useful materials:
Up to 75mm x 75mm x 50mm.
Figure cut from brass flat bar using 1 mm (0.039") and 0.015" (0.38 mm) flat endmills.
nevermind the paint -- that's a different learning curve.
...and yes, I will mix units horribly in this project. it will be ok, we're not trying to land on another planet.
Little airplane in a 4 mm disk cut from brass shim stock with a 0.1 mm V bit.
Sharp, accurate features in Aluminum with tiny cutters down to 0.010" (0.25 mm). This pic is a backlash test pattern for the "big" cutter that I repeated with the smaller cutters because new toys.
This short video is kinda neat but doesn't really add much so I'll link instead of embed so hopefully it won't slow down your first scroll through this stuff:
Mill circuit boards for fine-pitch components:
Breakout board for 0.5mm pitch QFN-16.
A more specific 0.5 mm pitch QFN-16 breakout for TLV7044 with supply bypass closer to the chip and pinning like the DIP & SO packaged parts. For a different project. Hopefully I'll be able to replace this pic with a populated board "soon"...
Isolated copper traces down to 0.1 mm center-center pitch with a massaged "0.1 mm" V bit.
But that's all flat stuff :-/
Yeah. I've been working on the tool instead of making stuff. But check this out:
First I'll show this little bevel gear,...
... because the "3dp" 3d printed mill that is the object of this project actually for real cut that gear at MRRF. So I hope you'll accept some parts cut by the earlier laser-cut version of this CNC as an illustration of capability:
Spider gears and structure parts for a little differential with a US "quarter" coin for scale.
The spider gear assembly in the complete differential is smaller than my fingernail. There's a <4 min. video about that over in the "2dc" project but it's old work and too much about the earlier laser-cut design to include in this project.
Packaging for UX
The CNC mechanics consist of an XY table and a separate Z axis. The two parts need some sort of frame to hold their positions relative to each other. The frame can be very basic. But I want to use my machine in a smallish urban condo with no "shop"-like space.  So I've put a little more effort into the frame and packaging..
The "telescoping" slide design allows very compact non-operating footprint.
More about packaging -- which is already obsolete because I haven't yet written up several improvements like cleaner DC supply and integrated logic-switched AC for the dremeloid.
Interested?
To build your own, start here.
To scan log entries, ToC here.
Spun off from #Minamil: a minimal CNC mill and companion to #"Desk Accessory" CNC Milling Machine.
This project encompasses 2 projects. And a half.
  • very small and low cost 3-axis CNC mill/router mechanics
  • #"Desk...
minamil3dp-XY-STLs-v0.9.1.zip
X+Y stage parts. For slicing info see https://hackaday.io/project/192074/log/223146/
Zip Archive - 6.71 MB - 09/24/2023 at 07:33
Download
minamil3dp-Z-STLs-v0.9.0.zip
Z axis parts.
Zip Archive - 8.39 MB - 08/09/2025 at 15:48
Download
minamil3dp-XY-workholding-STLs-v0.9.1.zip
You probably don't need this. see https://hackaday.io/project/192074/log/242907-workholding
Zip Archive - 769.01 kB - 10/10/2025 at 05:11
Download
minamil3dp-Z-STLs-v0.1.0.zip
*old* Z axis parts -- prolly going away soon
Zip Archive - 1.06 MB - 09/25/2023 at 20:41
Download
  • yet another little differential gearbox
    Paul McClay11/29/2025 at 20:30 3 comments
    Ok, I've been teasing pix of parts of this for half a year...
    ...while holding out for more of an eye-candy presentation idea. Not least because I don't have a "here, watch this..." video that shows the little machine in its 3d printed form.[a] But no such idea has landed. So, until that happens, here's an eye-spinach look at the latest little differential gearbox.
    What's this guy's deal with differentials anyhow?
    Well, it's like this...
    An early question for an earlier variation on this minimal CNC theme was 'why?'. What (in low budget hobby/"maker" context) could a little CNC do that a laser cutter or 3d printer couldn't? How about a small bevel gear? Laser cutters can make spur gears but not bevel gears. FDM printers can't make precise small features (with a sane nozzle). SLA printers can make small 3d objects -- out of fragile material (tho resins are getting better). So the first differentiating example was a small bevel gear cut from acrylic.
    But one bevel gear doesn't count. You can't even tell if it's right, let alone convince anyone it's interesting, without another bevel gear.
    (And lemme just say here that those gears mesh intoxicatingly well. The little wobble in the gif above is only an artifact of the hasty setup and running out of duster gas to keep trying to catch video of a really smooth spin. Smooth driving torque against resistance too. It's one thing to read about involute geometry, and quite another to feel a self-made pair of own-design gears defying their coarse appearance. An instance of encouragement to keep the project going.)
    So, then, on the road to Shelbyville, as an example of something that more common tools wouldn't have made better more easily in a fraction of the time, that was sufficient. But not satisfying. Giving a pair of gears something interesting to do escalated to giving them more friends and a little differential to live in:
    who needs adjectives when English has nouns like 'differential'?
    And that was a fairly satisfactory example. For a while. There was that little thing about it ending up not quite as compact as I'd first had in mind because I was having a hard time (i.e. not) keeping consistently small runout... But life could go on.
    Until, eventually, I started to get a better handle on runout.
    And then, eventually, which is what they called 'later' in those days, I got around to scratching the "not quite as compact as I'd first had in mind" itch...
    ... and made another, littler differential
    If you're wondering what "differential" is about: when Big Finger stops one of the swirly side parts, the middle part keeps spinning and the other side swirly part spins faster. So trucks can deliver food into cities.
    That's still a fine demo wodget. Which, among other widgets, is useful because all this is easier to show than tell. But t's awkward that the catchy video about that shows an obviously different variation on the "Minamil" theme. But I don't have the next eye-candy demo video yet. O the wearying weight of first world problems.
    So, that's the first chapter or three of "what's this guy's deal with differentials anyhow?"
    And then...
    ...a couple of things. Two independent events described here in arbitrary order because I don't remember which was first or second and it doesn't matter.
    Thing 1
    I thought of a use for a cheap little RC car. Online Retail offers heaps of cheap little RC cars and controls that look like what I was looking for, so that seemed like the easy part.
    Until, on the cusp of ordering one, I figured out that all the cheap ones use bang-bang control (go, not go, go backward, turn left, not turn, turn right), which would not do, and the jump up to cheapest with proportional control was too much less cheap for the idea in mind.
    Until, on the cusp of not ordering one, I stumbled on the D12 Mini -- inaugural product of CXD, a fresh (then) spinoff from an...
  • Workholding
    Paul McClay08/21/2025 at 17:29 0 comments
    CNC milling/routing involves holding the thing that's getting cut.
    (If you aim to build one of these for yourself, start here not here! This is extra complexity you almost certainly do not need! More exclamation marks: !!)
    I've been using double-sided tape to hold work since the second iteration of the laser-cut precursor to this project. It's hard to beat for simplicity, and it works well enough often enough to make some stuff. But sometimes it reminds me to think about mechanical workholding again. After a few years of no good ideas, I think this might work.
    spaces for nuts below and places to drill for screws above -- with an arbitrary 10 x 10 patch of nuts just to show what 100/207 looks like
    That's
    • a bunch of square nut pockets sunk into the formerly flat top of the "top" part, and
    • a new flat slab on top of that.
    Slab
    I don't know what to call the new slab on top of the top part (of "bottom", "middle", and "top" parts of the XY stack). If it were square-rigged, it would be the t'gallant part. Maybe it will be just "slab" for now.
    Outwardly, the slab is just a flat slab with ½-dozen screws through it. Between the solid top & bottom surfaces there are void holes aligned with the nut pockets in the top surface of the top part. More to the point, "holes" means vertical cylinder walls around the holes to bear compression.
    Because ... why?
    Wherever you want to screw/clamp/hold work on top of the slab, drill through the nearest "drill here" mark on the bottom of the slab to open the top and bottom (i.e. bottom and top) of one of the internal voids and drop a nut in the corresponding pocket.
    The selectively populated 8 mm square grid of "drill here" marks is easier to see in the CAD render below than in the photo above. (even tho the marks are bigger in the photo)
    "legal" points of 8 mm × 8 mm grid
    I don't know whether or not this idea is actually novel, but I don't recall seeing it anywhere else. I also don't know whether or not it is actually useful, because I haven't actually used it to make anything other than pretty pictures for this page.
    Here is a (i.e. the) a worked example:
    drill through "legal" grid points nearest where you want to place screws
    drop square nuts into corresponding square nut pockets
    secure the slab on top of the top; now there are robust metal threads under the drilled holes
    workholding widgets
    workholding widgets holding work -- in a repeatable(ish) position
    !!: different length screws shimmed to near-exact lengths to fully engage nut thread without bottoming in shallow pockets!
    Maybe
    Of course it works. Because what could go wrong? ¯\_ (ツ)_/¯
    vibration
    Screws working loose from vibration is the first risk that comes to mind. The bet here is that clamped PLA is springy enough to prevent that. If not: Thin square nylock nuts would be great but I haven't found such a thing yet. Common hex nylocks would require deeper pockets (thicker top or fewer pockets) and holding a hex nut shape against torque with PLA is less easy than holding square nuts. McMaster-Carr lists "thin profile" hex nylocks, which seem quite pointless in smaller sizes: 3.9 mm thick vs 4 mm for m3. It appears that barleycorn nuts run thinner per thread diameter: 4-40 thread at 2.85 mm diameter is 95% of m3 diameter (90% section area) and "thin profile" 4-40 nylock nuts are only 2.8 mm thick or 70% of m3 (4 mm), so "thin" 4-40 nylock nuts could be accommodated within current dimensions with some very thin pocket floors. There are also anti-vibration screws: e.g. with a patch of nylon on the thread, or "tri-lobe" shape (tho use with steel nuts would be off-label). Or maybe just 3 mm o-rings under the screw heads.
    widgetry
    Those totally credible-looking "workholding widgets" were totally just whipped up to make the few  ̶p̶r̶e̶t̶t̶y̶  helpfully illustrative pictures above....
  • A better Z axis that's actually better
    Paul McClay08/09/2025 at 09:58 3 comments
    The previously shared Z axis was very much a rough proof of concept. It worked well enough to not demand revision while I worked on other aspects of the project. Two prior attempts to fix its faults proved out some ideas but introduced other faults. This version seems like time to say "build this not that".
    Beware vocabulary: I haven’t found a reliable escape from using “tool” to mean both “Dremel®-like rotary tool” and “endmill”. Context or bust.
    What
    Vertical axis for the CNC mill described in this project.
    Why
    Because I don’t already see tragedy in this attempt to fix faults of earlier attempts to fix faults of the previously published version. That version worked well enough to warrant sharing so you can make your own copy of a capable tool. But it was a placeholder waiting for a better replacement. An earlier log entry describes problems with the first version, and solutions that worked in earlier attempts to come up with the better replacement. This try keeps the solutions without stepping in any new poo that I’ve smelled so far. Of course lots could be different and I’m not saying any of it is “best” or “right” or "done" but I'm pretty happy with it for now.
    How
    Briefly:
    • Build X+Y stage
    • Choose a rotary tool
    • Choose clamp configuration
    • Print parts
    • Collect other parts
    • Assemble
    Biuld X+Y
    You don’t really have to, but I think building the X+Y stage first will help because there are more words and pictures about how to put that together. Familiarity with detailed information there should help to make sense of less detailed info here.
    In keeping with the low cost/less stuff theme of this project, the Z axis is designed to hold a vanilla Dremel®-like rotary tool for a milling spindle. Clamping and releasing the tool is meant to be easy, so you can use the daily-driver you may already have and drop it into your little mill when you want to do a little milling.
    What will work?
    The tool clamp is designed around a tool body pattern set by Dremel (i.e. Emmerson) in a prior millenium. I don’t know of any simple name for the type except that they look like this:
    current Dremel product image
    Many Dremel tools that look like that are called “MultiPro”, but the form was up to “type 5” before they were called “MultiPro” and not all “MultiPro” tools look like that. Current Dremel products have mostly moved on to different shapes, but Dremel still (mid-2025) sells their low-end 100 & 200 models in this style, but you probably don’t want one of those because they lack speed control, but several generic labels are selling 5-speed clones that look like they come out of the same molds as used by whoever makes Dremel’s 100 and 200 units these days. The basic pattern includes a straight cylindrical body segment between a taper down to a threaded nose below and a fatter section above that includes brush bosses and a vent or switch at a fairly uniform height.
    The tool-carrying sled
    • clamps around the cylindrical part,
    • clamps a ring screwed on the tool’s nose, and
    • allows clearance for the extra stuff above including access to the switch or vent at the level of the brushes.
    Like this:
    For tools with the switch between the brushes, clip out the lattice for access.
    For a Dremel 300, clip out the thin bits around the spindle lock boss.
    The left four models fit as intended. I’ve used the first three and @janvorli on the Discord server has verified that his Dremel 300 (the fourth) fits. For tools with the switch between the brushes, clip out the lattice for access. For a Dremel 300, clip out the thin bits around the spindle lock boss.
    I haven't tried the questionable two on the right, but only looked at photos and marked features that differ from what the clamp was designed to hold.
    The long nose of the “type 3”...
  • MRRF 2025
    Paul McClay07/25/2025 at 07:50 0 comments
    Lots of project log backlog to catch up on. Again. Starting with:
    MRRF. Successfully after not getting there last year.
    Taking this project to the Midwest RepRap Festival (MRRF) a couple of times (2022, 2023) has encouraged and enriched continuing development of the idea.
    A great drone flythrough video gives a quick visual impression of the event.
    MRRF is mostly about 3d printing. A very few CNC machines of ye olde subtractive nature turn up too, so they haven't kicked me out yet.
    "But what is this 'RepRap'?" you might ask. Increasingly many people aware of "3d printing" won't know that personal/home/hobby/cheap/accessible 3d printing all happened under a banner called "RepRap" before it graduated to global industry. ERRF already isn't called that anymore.
    Anyhow...
    I didn't take any pictures (again), but Shenanigans3d stopped by while live streaming his tour of the show (1:05:32 if the link doesn't drop you in at that time).
    Hustle to make some new demo widget before the show contributed to letting logs lapse here. That turned into yet another yet smaller differential gearbox -- this time with a bona fide application(!) -- which will get its own log entry here *cough*soon*cough*. Apart from Mr. Shenanigan's autofocusonsomethingelse close-up, all I've got to show for now are a couple of in-progress pix:
    People, like Mr. Shenanigans, stopping to look and talk for more than a minute seems like feedback that this project is actually interesting. Just for fun, here's an interview with another guy, "Steve". His thing is interesting in its own right and he reps it well (at 26:38). Did you know about the "CLSP" scene? I for sure didn't until I went over to see what was that thing like-but-unlike a sewing machine that he had. Relevant for this paragraph: the guy in the blue T-shirt and beard beyond the interviewer's left shoulder is another more-than-a-minute visitor there looking and talking though most of the duration of Steve's interview. People even remember from prior shows. Maybe the highlight of the trip was a quiet parting handshake from an old machinist.
  • On making a "simple frame" simply
    Paul McClay04/07/2025 at 05:59 0 comments
    To repeat a theme: this project focuses on the CNC mechanics, and the shortest path to building your own and making it work includes not following me down the fancy box rabbit hole. Yet. This is enough to get started:
    Made from a few rough scraps, drywall screws, and eyeball "measurements"
    If you have access to a table saw, or some other way to make straight square cuts, you can make a slightly less haphazard version of the same thing:
    Same thing but looks better if you have means to make straight square saw cuts
    While square parts look good, that's still only "slightly less haphazard" because the four frame parts are sized by eye with no measured dimension. Keeping it simple!
    Placement of Z over X&Y
    The frame's job is to hold the vertical axis over the horizontal axes. That's the relationship that matters. Here are some dimensions to help set up that relative relationship. The numbers are millimeters, but "looks like this" is close enough.
    View from front; bottom edge of fixed base of Z axis about 10.5-11 cm above the deck; tool axis about 2 cm in from left edge of XY stack
    View from above; vertical face for mounting the Z axis about 7cm back from the front edge of the XY stack
    Left and right clearances
    View from front; leave room on the right side of the XY stack for your vacuum cleaner "crevice tool"; the X axis extends 75 mm to the left, so leave 8 or 9 cm on that side
    Just a little bit less simple
    Closing off the lower back of the frame will go a long way to making cleanup easier.
    A bit of cardboard and tape will do the job:
    For just a little more effort when cutting parts, a couple more pieces cut to the same width as the vertical transverse piece will both close off the back and also make the frame significantly more stiff. And if you're going that far, a third piece across the top will add another increment of stiffness to the Z axis.
    Chunky material like the 3/4" (18mm) slabs illustrated here will probably be plenty stiff enough on their own for a minimal four-piece frame. If your material is thin or otherwise uninspiring, the three extra pieces shown above can very significantly stiffen the frame. If using the narrow horizontal pieces behind the top and bottom edges of the vertical Z axis support, they should be attached along those spanwise edges as well as at their ends.
  • Discord: active and productive!
    Paul McClay01/27/2025 at 05:04 0 comments
    More log catch-up...
    The project subtitle includes "very DIYable". I can say so, but proving so remains for others to do.
    While I've been not updating logs here, a couple of builders on Discord have completed their own "Minamil"-like machines up to first cuts. They've hit some major milestones for the project and I'm well late at saying so.
    Discorder janvorli has built his machine with a proper spindle:
    He started with a Dremel 300 in mind (I.e. in hand) which almost but not quite fit in the Z tool clamp. Then he found a too-good-to-pass deal on the 52mm spindle bundled with power supply etc. So there are a couple more versions of the Z sled to be found in Discord chat history, or for asking:
    • slightly modified for compatibility with Dremel 300 in addition to whatever else already fit
    • more modified for 52mm spindle only (& clearance for 54mm fan if present)
    In the photo above, janvorli has two Z motors rigged. That didn't work. ...I think the 'why' will get its own log entry... What does work for this ~1kg spindle is a single motor and 2:1 purchase.  He bored the tie-off bit out the printed part and fitted part of a 3mm smooth metal rod from an old floppy drive. The hoist cord coming down from the motor now turns around that pin with very little friction and runs back up to a screw eye screwed into the fixed base just below the motor/pulley.
    At last report on Discord, janvorli had cut a couple of flat spaces:
    It may not look like much but the considerable victory shown there is that, after troubleshooting his heavier Z axis and my dual motor fallacy, the two flats are milled to exactly the same depth. Big win.
    I think it's important to note that janvorli is the first, that I knew of, to wade into building the 3d printed version of this "Minamil" concept. So he bore the brunt of (not) finding what I hadn't written yet, and challenging the Z axis with a load that I hadn't actually tested for real. I appreciate his help to advance the documentation, and understanding of how the Z axis really works -- and what to try next for that.
    Meanwhile, Raf on Discord was building his own "Minamil" when he found that his Dremel 3000 didn't fit into the Z sled. He found a 3D model of the tool that I could use in lieu of the real tool in hand, and we had some back-and-forth about adapting the tool clamp to fit. Almost:
    Then a friend of his with relevant CAD skill grafted a suitable clamp onto the base of the Z sled STL to put Raf in business. Raf also shared the new STL back to Discord.  A more responsive me would already have all these modified tool clamps uploaded to the HaD project files. So please ask if you have need and don't feel like combing through Discord history. (But hey, join the Discord party anyhow!)
    And here's Raf's built machine:
    Yeah, the tool body clamp broke. He says it's working ok with just the nose clamp.
    He too has both Z motors rigged. If we've understood janvorli's case correctly, that works for Raf, and my earlier trials, because it doesn't really need both motors to lift the spindle, so it's less vulnerable to differences between theory and reality of load sharing as currently implemented. ...more about that in the other log entry that I haven't written yet.
    Raf's uploaded filename "minamil_first_try" suggests this is his first result:
    Nice! I think that's a pretty big deal, in my view of the project, that someone who's not me has actually in fact worked thru the how-to write-up, such as it is, and put together a replica that, apparently, worked well enough to produce something near to intended results on the first try. Plus adapting the Z sled for a different "spindle" tool along the way.
    Bravo Raf!
    Both janvorli and Raf have built "corner" frames with the Z axis at 45° to the base. I feel a bit like a bad influence setting that example on my overwrought quest for compactness...
  • One minute video
    Paul McClay01/15/2025 at 22:23 0 comments
    A while back I made a few videos to show some of what's easier shown than said. Or believed. Since then I've: shed the Z counterweight, shifted from laser cut to 3d print construction, and changed the frame among other less visible changes. But I haven't made any new widget as photogenic as a little gearbox to prompt a new eye candy vid.
    So here's one minute of simple but sharp recent work with 3d printed mechanics in the current iteration of fancy package:
    I'll probably lift some tight shots from earlier videos eventually, when there's more of more recent content to mix it into. Just replacing wide shots of old stuff with wide shots of new stuff could be expedient, but then "... and here's a different machine that didn't do any of that but could have believemeIpromise" would be awkward.
  • FR-2 = "wood" for very fine detail
    Paul McClay01/13/2025 at 22:33 0 comments
    ...and tough too!
    In the previous entry about contacting local scale model builders to ask if they might appreciate an accessible little CNC machine, I mentioned a couple tries at making a "trail board" for a Midwest Model Shipwrights member.
    People have been making scaled-down models of inconveniently large things for a long time ... and I've abandoned hope of summarizing that in a sentence. Making detailed wooden models of wooden ships stands a little aside from the model-making mainstream as we approach the 21st mid-century AD, but the venerable practice persists and practitioners gather nearby.
    Wood has grain. Scaling down wooden parts has the effect of scaling up the wood's grain. Very fine grain woods mitigate that with good success well established[1]. But trying to capture finer detail at smaller scale eventually turns into trying to carve a tea set from a stack of sewer pipe.
    From last time:
    • I wrote about FR2 exceeding expectations as a machinable material not entirely completely unrelated to wood but with essentially no grain. "FR2" is an imprecise term for the brown resin-saturated paper board used for the cheapest, simplest circuit boards.[2] Similar material is available by other names. Contrast with FR4 which is glass fiber+epoxy and hostile stuff to work with. I'm thinking this paper+phenolic stuff looks promising for compatibility with wood model construction, but that remains untested by actual model builders -- that I know of. But maybe I'm just the last guy to get the clue. Some "phenolic paper" material is advertised for "enhanced" or "finest" machinability. "FR" = flame retardant.
    • I had started off in the wrong direction with the first couple of whacks at the "trail board" example. Further information clarifies that what look like scrollwork borders of a flat board appear straight only in profile. The ornamented part is parallel with the mid-plane so it can be taken directly from the drawing. And the builder already has the structure and only needs the decoration.
    So, back to the drawing board.
    Then milled a patch of FR2 down to 0.3 mm thick (or so I thought, but it came out more like 0.34mm -- dunno why) and from that cut out a mirrored pair of figures using a 20°, 0.1mm Vbit. I didn't feel like testing how deep it could cut without breaking the tip or deflecting when I really wanted the best narrow cut and sharp inside corners, so I ran six passes at very conservative ~0.05mm steps down ("~" because a little more to match four Z motor half-steps). I expected that to cut through or very nearly so. But it didn't. So I ran a few more half-steps down until the bottom of the cut looked different. I was complicating this for myself by trying to cut no deeper than necessary because deeper makes the V cut wider.
    When I peeled that up it turned out of that I still hadn't cut through. My current guess is that maybe the glossy surface layer has a different consistency so the top of the bottom skin looks different, but I don't know. In any case, that was initially disappointing. Then I tried sanding the remaining thickness off the uncut side, and that worked quite well.
    Some beauty shots:
    That's a half-millimeter scale. (labeled "MM" in CAPS and numbered by cm. :-/ )
    Check out how thin the thin parts are! Earlier I didn't have any great ideas for how to avoid bending that if made from something like brass or styrene, or breaking it if possibly something like that could be cut from boxwood (which I have yet to try). That's where the FR2 works great. Not only is it possible to make those, but also to handle them. They are, of course, fragile. But so far I've been able to handle them "carefully", in the ordinary sense of "careful".
    I gather that a chronic challenge / mark of skill among model builders is matching reflected pairs of parts or features like this. To demonstrate...
  • Thumbnails are the windows to ... scale modeling
    Paul McClay11/25/2024 at 01:06 0 comments
    Log backlog got big again...
    I've been plugging away at making little CNC machines and writing about it. And making little things, few of which have much use apart from tinkering with the thing-making machine. Earlier  ̶t̶h̶i̶s̶ last year I randomly discovered that there are several scale modeling clubs around here, including the Midwest Model Shipwrights. Might people who actually make little things have some interest in actually using a little CNC to make actual little things for the thing they do?
    Now, these Model Shipwrights are very good at making the things that they already make. And they already make all the things that they need to make model ships. And they know a lot about making model ships. Viz:
    orgforumjournal
    Nautical Research GuildModel Ship WorldNautical Research Journal
    ISSN 0738-7245
    Ships of ScaleShips of ScaleThe MSB Journal
    ISSN 1913-6943
    There are journals. With ISSNs. Not just one.
    So I'm not going to tell these people how to model ships.
    But I ventured to show up at a meeting with some example widgets and asked if making such things seemed like an interesting capability, and what sorts of ship model things might be interesting to make differently with a different tool.
    That went well enough to gain an invitation to return, some examples of things to try, and some material samples.
    Things to try that might prove interesting included a drawing of window frames, which "usually present a challenge for modelers":
    That's where the window in my thumb comes from. We'll get back to that...
    This post grew long before it got to the end that I had in mind at the start. It's mostly but not entirely about little windows. If I'm saying this is doable, I probably should show at least one example of process from idea to result. That said, this is more an illustration of how some ideas evolved when the tool at hand was a little CNC mill and not so much a tutorial for CAD or CAM or steps to replicate this result.
    Show > Tell: What useful work could a little CNC do for a modeler of ships?
    The first example I tackled was this "trail board" -- one of the pair of decorated boards that sometimes dress up the pointy (or blunt*) end of a ship.
    The trail board, which I understood to be flat, looks like it runs from the stem back to a point where the hull has some breadth. I guessed that it might be oriented something like the blue and gold trail board on this model:
    source: Roland's Ship Building Blog (that part is pewter, and so maybe a candidate for milling instead)
    Supposing so, then the profile drawing shows a projection of the board leaving two degrees of rotation to determine the correct shape. In between me asking for, and the builder of that model sending another view, he described the boards in a vertical plane. So that's down to one rotation. A first proof of concept demonstrator doesn't have to be actually correct, so I guessed and projected from the drawing to make a solid model. The yellow inch ties model scale to the drawing.
    (wrong first guess -- later this will get corrected)
    While the ornamental figure has a convoluted outline, it appears essentially flat in the drawing. Maybe the prototype was more viney/leafy and maybe a larger scale drawing would show that. For a first whack, it's convenient to believe that it really is supposed to be flat and extrude the traced figure into a "2.5"D solid.
    First articles: port & starboard figures cut from 0.001" brass glued to a chip of hardboard.
    Sharp inside corners were the main challenge. These parts were received as good enough to validate the idea; next try could be sharper. In part because the underlying surface could be more nearly level -- note left end of the upper part vs right end of the lower part.
    aside:                                         ...
  • circuit milling: 0.05 mm (2 mil) trace/space
    Paul McClay09/13/2024 at 05:10 0 comments
    Last year 0.2 mm trace pitch seemed pretty tight:
    "... just think of the precision required to take off the copper layer and only the copper layer, and leave traces down to 0.2 mm behind." -- HaD Prize 2023 finalist announcement
    Here's half that...
    isolated copper traces from 0.2 mm to 0.1 mm center-to-center in 0.025 mm steps
    Admittedly more tedious than $pendier option$ with a big friendly START button, but this little machine got the job done.
    detail view rotated 135°ccw before writing anything which makes writing hard: X bottom-right to top-left; Y top-right to bottom-left; horizontal/vertical <--> diagonal; I could de-rotate but describing features doesn't actually get much easier unless with a labeled diagram and that's a rabbit hole I'm trying to not go down today...
    • From counting pixels[1] and a little more math than expected[2], I figure the 0.1 mm center-to-center traces (the skinny ones) are 46% trace and 54% space. So 0.046 mm trace and 0.054 mm space. Not 0.050 but both round to 0.05 so I'll go ahead and plant that flag. In barleycorn units: 1.8 mil trace and 2.1 mil space out of 3.9 mil pitch, and again I'll conveniently round to 2 mil trace/space of 4 mil pitch.
    • I have to stop thinking about how to interpret the various irregularities -- maybe that will be another log entry later. For example, the horizontal segments at top-left (which are diagonal) are straight but the similar horizontal (diagonal) segments at top-right are wavy. Both were cut by moving in the same direction at the same rate. The segments on the right were the first in their loops where the bit plunged at their left (in that pic), moved not-so-straight to the right, then continued clockwise. The 2nd and 4th of those (down from top) were approached from about the same direction and have about the same kink. The same segments came out better when cut with ~30 μm (~1 mil) more backlash in Y (found and fixed before cutting the example shown). The "vertical" (diagonal) segments at the left look generally straight but a little more rough than the rest -- those came out worse when cut with a little more backlash in Y. It looks like the cut path deflects a few tenths (of a mil) to the left relative to travel. Etc.
    • But mostly: hey look at that! Not "just barely" but actually pretty decent. Another increment of exceeding already much exceeded expectations for this extremely low cost, extremely compact CNC design. !.
    did he say "tedious"?
    Yeah. It was a development exercise. Lessons learned may help make future work at this scale less tedious, but probably not not tedious.
    how
    You're already reading this project about how to build a little CNC mill. Elements of coaxing the built thing to carve tiny isolation lines through copper cladding include,
    • stable hands-free magnification
    • design to X/Y stepper full steps
    • repeat to refine
      • pointy v-bits
      • runout
      • density test cuts
    • repeat to refine
      • level
      • level test cuts
    • laps
    This time I went straight for the stereo microscope because not needing one wasn't an objective. I've also used my phone on a little tripod for nearly no (incremental) cost, and a USB camera for le$$ than the microscope, either of which might have adequately supported this exercise.
    design to X/Y steppers' full steps
    The small steps in the least-stepped segments adjacent to straight segments match the 0.025 mm practical limit of horizontal positioning for the motor+screw units used here. (The little jog segment length is step×√2 for diagonals (pic at 45°).) That step-over distance corresponds to one full motor step. I'm running x8 microstepping for best acceleration & speed (another log entry "soon"...) but single microsteps are so uneven that there's no fraction of a 0.025 mm step cycle that's useful for positioning. Designing to a 0.025mm "snap grid" puts each feature at the same phase in the microstep cycle for each motor....
View all 30 project logs
zakqwy wrote 04/14/2025 at 11:53 point
Ah I love this little machine. Impressive results, too! The fold-up enclosure and the "tucked" storage position is quite clever.
Paul McClay wrote 04/16/2025 at 09:29 point
Hi and thanks for the kind words. Anyone reading this should check out your "circuit graver" too!
The folding/expanding arrangement here is a happy accidental development of a project that has far exceeded anything I was imagining at the outset. The whole fancy box thing is a side quest (i.e. distraction) that's not at all necessary to get results from the CNC part.
Gravis wrote 03/08/2024 at 12:06 point
I like this project and have a recommendation: change the stage so that each axis travels from -50% to +50% (of it's width) from it's original position. Exceeding 50% increase the chances of tramming issues.
Paul McClay wrote 03/08/2024 at 21:07 point
Thanks Gravis for your interest, comment, and recommendation.
Maybe I don't understand what you mean. My first impression is that the mechanical change you suggest would lead to a more conventional layout and a larger footprint. For this project I'd rather keep the small footprint than chase better tram.  With tiny endmills the unadjusted tram hasn't caused enough trouble yet to prompt any effort to make it better, so I don't yet know what I'll end up with if I (anyone) ever get around to trying to tram this thing as it is.
Do you mean that defining "home" at mid-travel and tramming there can minimize variation between there and either end vs tramming at one end?
For best stiffness, this layout favors operation near the "home" ends of the X & Y axes. Happily, it suffers much less loss of stiffness at full extension than I expected. In case it's not already clear (in the description/pix as of writing this comment), the first part of this page shows how these X & Y axes work: https://hackaday.io/project/174370-minamil-2dc-a-minimal-cnc-mill/log/185281-some-of-the-basic-ideas-that-seem-to-be-working
Gravis wrote 03/11/2024 at 01:08 point
Yes, I do mean that "home" position would be at 50% of the stroke distance of the actuator.
Despite being stiff, it will invariably sag more and more the further it is from the home position. If you place the home position at exactly 50% of the actuator stroke distance then that will minimize the sagging on each axis.
Sagging compounds with each axis, so cutting something on the outermost limit of both axes will be the worst case scenario.
Paul McClay wrote 03/19/2024 at 04:06 point
I think you're describing a different mechanism that would have different trade-offs. In other words, a mechanism that isn't different from what's already common.
