ZeroPhone - a Raspberry Pi smartphone
Pi Zero-based open-source mobile phone (that you can assemble for 50$ in parts)
This is a mobile phone that:
- First and foremost, will be a well-working reliable phone
- Is as open-source as possible *while also being cheap*
- Can be assembled and repaired independently
- Is easy to get parts for
- Doesn't have apps with privacy concerns
- Allows to write your own apps in Python
It costs about 50$ in parts, and all the parts are available on eBay/TaoBao/etc, most of the phone can be assembled with just a soldering iron. User interface is written using Python
and is being morphed into a lightweight phone-tailored UI framework.
A crowdfunded manufacturing run is expected in a month - kits will be available, as well as a small batch of fully-assembled phones. Subscribe to newsletter below!
Subscribe to the project newsletter - to get weekly news and be notified about crowdfunding!
Read previous newsletter editions
Latest newsletter editions:
  • Modern phones are getting more and more complicated and hardware-packed. Unfortunately, that means they're becoming less modifiable and repairable.
  • Phones are getting more and more integrated. Unfortunately, that means more and more possibilities for manufacturers to lock them down without allowing us to modify them.
  • More and more software&hardware is kept closed-sourced. That means it's harder to learn, experiment and customize your phone.
The factors I've listed (integration, complexity and closed-source) are necessary in the world we're living in, with all the advances in engineering, competition between companies, as well as laws in different countries.
However, what if we could have a phone free from those constraints?
So, ZeroPhone project was born. Nowadays, we should be able to assemble a phone from easily available parts, using cheap boards that run Linux, and we should be able to adjust it to our needs - unlike as it is with modern phones, when we have to adjust ourselves to suit the workflow that the phone offers. With ZeroPhone, hackers can finally have smartphones that are going to work for them and not against them, people with special needs will be able to have to have custom-tailored phones, and people that want to protect their privacy will have a phone that respects that.
Technical challenges are: developing PCBs that'd be reasonably feature-packed, but with easily sourceable components that could be soldered without special tools, as well as developing mobile phone software that'd be open, high-quality and highly modifiable to suit any needs people might have. However, much bigger challenges are - building a community of people experimenting with ZeroPhone platform, keeping ZeroPhone open-source and independent of any harmful influences, and experimenting with new ways of integrating smartphones in our lives without having to lose privacy in return.
Features:
  • Raspberry Pi Zero in a PCB sandwich
  • No proprietary connectors, hard-to-get parts or chips that are tricky to solder
  • All the specifications for making this phone yourself will be available
  • Python as the main language for developing apps (aiming to add other languages later)
  • UI toolkit that makes app development quicker and easier
  • Numeric keypad, 1.3" 128x64 monochrome OLED screen (also supports other screens)
  • 2G modem for phone functions, can be replaced with a 3G modem
  • WiFi (using an ESP8266), HDMI and audio outputs, a free full-sized USB host port and a MicroUSB port for charging
  • GPIO expansion headers for hardware addons and customization
  • RGB LED and vibromotor - for notifications
ZeroPhone Wiki
Interesting articles:
Licensing:
#pyLCI fork used for ZeroPhone is licensed under Apache License
ZeroPhone PCB files and keypad controller firmware are licensed under GPL v3
Original project...
ZeroPhone-PCBs-gamma.zip
Latest PCB revision
Zip Archive - 12.32 MB - 10/21/2017 at 14:00
Download
  • 1 × This list is provided for the reference, for sourcing see https://wiki.zerophone.org/index.php/Sourcing_ZeroPhone_parts
  • 5 × Transistors and FETs 2x BC847B, 3x IRLML6401
  • 2 × Diodes 1x 1N4148, 1x SS14
  • 1 × ATMega328P TQFP-32 package, harvestable from an Arduino Pro Mini
  • 1 × 16MHz crystal for ATMega HC-49 or CSTCE, harvestable from an Arduino Pro Mini
View all 27 components
  • New app - avrdude
    Arsenijs07/01/2018 at 22:20 0 comments
    This month, I've been working on an avrdude app - an app that uses avrdude to program AVR microcontrollers. It's now finished, with 500 LOC in the app itself and 800 more in the associated libraries. You might be surprised - why this and not something else, like a messenger app? Here are the reasons:
    • At the time, I had a small gig that involved programming 50 ATMega-based boards. So, after working with avrdude for quite a while, I was quite sick of it and wanted to automate it away - and also wanted to make sure there's a straightforward way to burn popular bootloaders to ATMega-based boards, which is a big part of this app. Now, I don't need to be summoned anywhere to program a new batch of boards - I can just give that person a ZPUI-enabled device with a user-friendly interface.
    • ZPUI needed a helper class to run long-term processes and parse their output - which is something that avrdude app would need, so after I wrote it, it only made sense to write an app around it. Such a class will be necessary for anybody who would want to write a wrapper to run any command-line tool and see what it outputs in real-time - be it ffmpeg or mjpg-streamer (which I plan to add for single-click video streaming), an interactive CLI script that needs your password, another microcontroller flasher or just a long-winded script that you want to monitor, there's now a way to wrap it in a developer-friendly object you can use to get output, send output and terminate the process at a whim (surprisingly, something that I still haven't found a proper Python library for).
    • I wanted to understand whether there's something that ZPUI lacks - it's something you can only see while you're programming a large app like this, and given that I'm the only person working on ZPUI and controlling its direction, it's crucial for me to check every once in a while if there's something that could be added to ZPUI. As a result of this work, I've added a lot of new functions, and more different ways to use the existing ones.
    • Also, I wanted to test out the recent ZPUI additions - like context switching, canvas system and class-based apps, and write a large app that uses all these things in a way that others can then refer to. While I was writing this app, I uncovered plenty of bugs and inconsistencies, which were promptly fixed.
    • Last but not least, writing large apps gives me the experience I can use to advise others on writing large apps - for now, nobody but me has this kind of experience, which is necessary to help people writing large apps that actually work.
    The end result is an Atmel MCU programming app that can backup and restore firmware from/to the MCU, flash arbitrary .hex files and bootloaders. For now, I've only tested it with usbasp programmers, but linux SPI device and other programmer support will be coming soon. I've used it a lot already, and it's even more useful given that I'm now working on several AVR-powered ZeroPhone mod boards (so, a simple way for users to update the mod board firmware is needed). It also has pinout information and the most crucial settings available, as well as some user-friendliness related features. In addition to that, there's a lot of bugfixes, improvements, new ideas for improving ZPUI and insights into problems that ZPUI has.
    One large problem that I now understand ZPUI has - lack of some kind of markup system for UI design. Essentially, when you're trying to draw your own UI, you need to calculate position of each element on the screen, requiring plenty of math (and extra variables) if you don't want parts of your UI to overlap/disappear. When it comes to text, the situation is even worse - as of now, it's pretty much impossible to properly word-wrap arbitrary text on a screen, for example. What do we do about it? I have no idea yet, and that's something I'll need to address sooner or later, unless I want ZeroPhone to be infamous for ugly apps... or not scaling further than the small display...
  • Delta boards released!
    Arsenijs05/24/2018 at 00:40 2 comments
    The new revision, ZeroPhone Delta, is out. I've been using a Gamma ZeroPhone for quite some time now, and it needs some bugfixes. Specifically, I:
    • Fixed a mechanical weak spot where a row on the keypad would break due to lack of structural support
    • Fixed tantalum capacitor footprints - now they're more solderable
    • Fxed the problem where traces on the 18650 board would get exposed to the back board (and short things together) due to soldermask scraping off the back board when scratched by the back board through-hole pins
    • Flipped the 3G modem upside down, making the routing significantly easier
    • Reorganized the SPI (side) expansion header footprint, changing it to use 12-pin headers (easier to source)
    • Reorganized the I2C expansion header to be compatible with the Raspberry Pi I2C pinout, allowing to connect existing I2C RPi expansion boards to ZeroPhone
    • Reorganized the IR (top) expansion header - now it's safe to plug expansion boards in reverse
    • Audio buffer, vibromotor and keypad backlight circuits are now powered from VSYS
    • Flipped the DC-DC power FET so it's no longer necessary to solder it flipped
    • Flipped the charger board - now it's easier to solder it, as well as swap and test
    • Made the Pi Zero pads on the back board oval - making them stronger (for rework purposes)
    • Changed the 4-pin GSM audio header into a 6-pin one - for easier sourcing
    • Improved the microphone footprint on the front board
    • Made fiducials smaller - mostly I needed more space for routing
    • Improved the switchable display header - the jumper pads are now smaller, and through-hole part of it is covered by soldermask on the front of the board (to avoid displays shorting to it)
    • Made the surface-mount crystal resonator pads on the front board larger, in attempt to make the resonator hand-solderable
    • Added traces to the MCP23017 footprint in an attempt to make it more reworkable
    Here's what I added:
    • Inductors in series with GSM microphone traces - for noise filtering
    • Assembly instructions/guidelines on front, back and keypad boards
    • Usage instructions on the 18650 board
    • Expansion header pinouts on the back board
    • A comparator - detecting charger&USB undervoltage and charger board overheating
    • A circuit that'd allow sensing whether the "power switch override" button is pressed while still eping the phone switched on
    • An UART buffer - not connecting the GSM UART to the Pi UART until a GPIO is asserted
    • UART testpoints near the charger board outline - to allow for a charging+UART board to be made
    • Serial number fields on front, back and keypad boards
    • An audio amplifier for the GSM speaker (unfortunately, it's a TI part - I'll be looking for a substitute)
    • An I2C EEPROM to GPIO0 and GPIO1 to the back board - to make the back board work as a Pi HAT in software
    • Better power filtering for the GSM modem power
    • A "connect 5V DC-DC to the charger input when the DC-DC is powered off" circuit
    • 3.5mm jack audio filtering to remove GSM noise
    • ATMega UART header reverse polarity protection
    • A fuse to the 18650 board between two batteries, to avoid problems when people insert batteries in reverse, or batteries with different levels of charge
    • Finally designed the first solution to attach the GSM speaker
    I also removed a lot of things that didn't prove themselves useful:
    • The RTC footprint - proved to be unnecessary and incomplete, and was taking a lot of PCB real estate
    • The GND-BATT- jumper - wasn't useful
    • The capacitor footprint in parallel with BATT+ and BATT- - wasn't useful
    • The MPU9050-compatible footprint - wasn't useful enough compared to the PCB real estate
    • The second USB socket (facing the board center) - wasn't useful
    • The RST and TV-OUT pad connections - weren't useful (though having a way to bring them back later would be cool, maybe add a pad for a surface-mount pin header?)
    OSHPark links: 18650 board, back board, front board, keypad board and speaker adapter
    Some of these points (like silkscreen additions) could be explained further, but I'll show them off once I receive the...
  • Some ZeroPhone problems I'll be fixing
    Arsenijs02/15/2018 at 09:26 7 comments
    Even though I've put a lot of work optimising ZeroPhone for everyday usage, self-assembly and manufacturing, there still are things we can do better in the next revision. Let's go through them, so that you can see the final changes I need to make to the boards, and things I need to figure out before the crowdfunding!
    This list is a result of me carrying a ZeroPhone with me through this year - and, therefore, fixing these problems will make sure your ZeroPhone lives as long as possible and is not merely some kind of gimmick that dies after a couple of months. Most of these problems are either fixable or have workarounds - if they didn't, I wouldn't have had been able to assemble the Gamma PCBs. However, they will be problematic for new people, so I have to make sure to eliminate as much of those problems as possible for the next version - to properly achieve the ZeroPhone "self-assembly" goal, making the assembly "as easy as possible" and not just "possible".
    Charging and protection boards
    We use popular modules from China for the ZeroPhone battery charging and protection. I had problems with the way those modules had to be soldered on the back board - it wasn't straightforward, and it wasn't easy to get done. So, I've flipped the footprint - now it's compatible with more module types, and it's much easier to solder the modules on - the board layout also became much more straightforward, since power traces used to be crossed and now they aren't! The component side of the modules is now exposed to the outside of the phone, though - I'll have to make sure this doesn't cause problems, such as short-circuits (possibly, release a 3D-printable cover).
    In addition, there were stability problems with a new version of these modules. Beta boards were using an earlier version:
    For Gamma boards, however, I used slightly different modules, a newer version  - I ordered them by mistake, so I quickly changed the footprint to fit the new modules in order to avoid ordering the older ones.
    That turned out to be a bad idea - the newer modules seem to not function as well as the previous, some of them randomly fail (luckily, they fail safe). It happened to some of my ZeroPhones, and it also happened to some of the ZeroPhones that I sent out (which resulted in the person having to send it back, for me to repair, and that's something I'd really like to avoid). That's not acceptable - if the module is broken, ZeroPhone cannot operate from the battery at all - or it switches off randomly, which is even more annoying. Fortunately, the new, flipped footprint allows for all kinds of modules, so it should be easier to find a suitable board now!
    During the manufacturing, we'll need to find a way to either find a reliable source for these modules, or to manufacture our own (I've already reverse-engineered the schematics and the PCB, thankfully, and I'm asking for manufacturing quotes) - as a backup plan in case the commercial modules are no longer suitable for us. I've also tried understanding the problem by comparing "old" and "new" modules - I've checked the schematic and it's the same (the boards are slightly different, but the changes are minimal), so my guess is that the "new" modules are using cheaper components, which causes the failures. But, just in case, I'm going to see if there's a way for us to source these boards reliably.
    Reworkability
    It turned out that current ZeroPhone PCBs might have some problems while doing repairs - traces breaking, pads being lifted etc. Generally, it will only happen to low-quality PCBs - but it's hard to make sure the PCBs you're ordering are of sufficiently high quality (and if you're ordering from a place like DirtyPCBs, it's likely your PCBs won't be good enough to survive overheating). This is bad, since it makes ZeroPhone less repairable - in the end, I have two back boards and one front board that are unusable because too many pads got lifted, and I also have some more that need...
  • ZeroPhone block diagram
    Arsenijs12/25/2017 at 11:17 1 comment
    Merry Christmas everybody! I'm going through the ZeroPhone project files, and here's something that I haven't yet posted - by @Morning.Star:
  • Writing a 2048 game for a ZeroPhone
    Arsenijs12/10/2017 at 04:21 0 comments
    Today, I was watching my wife play 2048, and I remembered about all the fun I had with this game myself, back when it was popular. While I don't recall ever getting past 512, I did spend a lot of time and I liked it. So, ZeroPhone can fit 8 lines of text on the screen, and 2048 needs a 4x4 playing field - seems like a perfect match!
    I found some Python code on GitHub that seems to be a great fit - it's cleanly split into logic and GUI parts, and logic does not depend on the GUI in any way, so can be re-used easily. Now that's a great design, if you ask me =) Reading further into it, it seems to be somebody's programming assignment, and I have to say that it was very helpful of that person to put it on GitHub!
    So, let's reuse the logic part, and build our own UI for the game!
  • ZeroPhone uses: streaming audio from desktop to headphones
    Arsenijs11/13/2017 at 06:43 0 comments
    Do you ever feel tethered to your computer because you're wearing headphones, and you can't go away from it because you can't use your speakers for whatever reason? This is for you.
    I often found myself in this situation. Sometimes I'm listening to podcasts, and I want to get up from my desk and grab something from other room, but the speakers aren't loud enough. Sometimes people around are sleeping and I don't want to wake them up, but I also can't carry my laptop with me just because I like the track I just found on YouTube.
    One of ZeroPhone plans is enabling hands-free applications, using audio for things like notifications (of course, only the most important ones, and the ones you want to hear.) Naturally, I'll be using it a lot  - I'm the "headphones" kind of person, and I know there are plenty of ZeroPhone notifications I'll want to hear about immediately when they happen. Now, what if I want to listen to a podcast, should I unplug headphones from my ZeroPhone and not hear the notifications? The most obvious idea is using the ZeroPhone as an audio receiver, and stream audio from my laptop to ZeroPhone, so that notifications could be overlayed, and I wouldn't find myself re-plugging the headphones all the time.
    So, the setup is like this: I want to stream all audio from my Windows laptop to my ZeroPhone, which sits in my pocket, receives the audio stream and plays it back to my headphones. If my laptop ran Linux, I could just use pulseaudio network streaming capabilities and be done with it. As it's Windows, though, I needed to find something that would work on Windows and would be more user-friendly than using a long command-line copy-pasted from Stackoverflow.
  • An in-depth explanation of a simple GPIO app
    Arsenijs11/08/2017 at 04:09 0 comments
    For Hackaday Prize video, I made some simple ZPUI apps (some of them were mockups, though). One of them was reading an external flame sensor and displaying pictures on the screen depending on whether the sensor detected flame or not. I had to do this in a rush, and I ended up adding some basic, but very useful, functions to ZPUI (though I did have to clean them up quite a bit before I could merge them into official ZPUI version =) ).
    What's the algorithm of this app?
    Set up the GPIO
    In a loop, read from the GPIO pin
    If pin has logic low on it:
        display picture of fire
    Else:
        display picture of fire crossed out
    The app is, therefore, very short. So, let's go through it thoroughly, explaining it in as much detail as possible!
  • A guide on powering Pi Zero directly from LiIon batteries
    Arsenijs10/23/2017 at 05:10 0 comments
    At the project's beginning, when I was writing the "Features" section in the project's description, last entry was "Tons of Pi Zero-related hacks that were discovered along the way, that I'll share with you as the project goes =)". I didn't actually get to sharing any of them in 9 months' time (also because there actually weren't many I found noteworthy), so last time I was editing the project's description, I just removed that line. Now, I've been reading through hackaday.com/blog, as usual (to be exact, through email notifications that I receive for each post that comes up there - highly recommend subscribing to those). Pi Zero-based projects get there every now and then, part of them are portable projects, most of those use LiIon batteries for power - for example, SegaPi Zero does - check it out!
    The small problem that I see with portable Pi Zero-based projects is - they all use a step-up, to get 5V for powering Pi Zero. When I started designing ZeroPhone hardware, one of the biggest problems was: how to avoid the stepup? Board space was not plentiful (still isn't), I don't know of many 5V-suitable step-ups that actually work well and are easy to source, and sourcing yet another part would be a PITA. Now I'm sure that, in many "Portable Pi Zero" cases, having a step-up is unnecessary, and ZeroPhone experience so far proves it.
    In ZeroPhone, Pi Zero is powered from a Lithium-Ion battery directly (so, instead of suggested 5V, it's getting 3.3V-4.2V). Does it work? Hell yeah it does! It works reliably, saving power, money and board space. What follows is a wall of text that describes why I went that way, and how's that supposed to work:
  • Low-key project state: Hackaday Prize video, cases!
    Arsenijs10/21/2017 at 12:48 5 comments
    Just made a video for the Hackaday Prize. Right now I'm too sleepy to talk about it, especially given that I accidentally the whole script, so I had to rewrite it 10 hours before, and some photos came to me at the last moment possible =(
    Recently, I made a "How I use my ZeroPhone" worklog. It was really easy to write for me, I shared it on Reddit, got a lot of positive responses and some really good questions. Those questions prompted me to write two more worklogs - "Why ZeroPhone ships with 18650 batteries" and "Making ZeroPhone work as an actual phone". The first one was easy to write - the second one was noticeably harder =) Anyway, stay tuned for the next part of "How I use my ZeroPhone" - I hope it's going to be as easy to write as the first part!
    Now, about project's contributors. @Ninjalicious has the first design of a ZeroPhone case!
  • Making ZeroPhone work as an actual phone
    Arsenijs10/20/2017 at 21:15 2 comments
    One of the most important factors that can contribute to a project falling into obscurity is - does it work as well for calls/SMS/data connections as a real phone would? Right now, it doesn't, and it's immensely important it does. I want to make it a point to have the GSM part, both in hardware and software, stable, and make it one of ZeroPhone project's promises. It's pretty much a pre-crowdfunding priority - that is, until I know it's possible to solve it without changing the project in some major way, I don't feel safe launching the crowdfunding. What's the plan?
    [TODO: insert photo/gif of current phone UI]
    First of all, the 2G modem works with ZeroPhone. I can send AT commands through the serial port to initiate or accept calls, as well as receive or send SMS. Apart from some bugs in the modem's firmware and an issue with the microphone noise (only affects current revision of PCBs), the hardware is accessible and working - but, obviously, you can't use the terminal to call others on a daily basis, and PDU encoding of messages is not that easy to decode by just looking at it =D Now, it needs GSM backend software to be usable.
View all 47 project logs
  • 1
    Step 1
    Instructions are under construction
    Sorry for any inconvenience =) It takes time to make them as good as I want them to be.
  • 2
    Source the PCBs
    You can use OSHPark, DirtyPCBs, Elecrow or some other PCB manufacturing service to order PCBs. Grab the latest release from GitHub, order the PCBs and wait for them to arrive! More detailed instructions are available here
  • 3
    Source the components
    The full list of components (with links to places where to source them) is still being compiled here. Meanwhile, you can use this Google doc as a reference - I'm also making my calculations for larger-scale manufacturing runs of ZeroPhones there.
View all 10 instructions
Louis Parkerson wrote 09/19/2018 at 00:42 point
Sorry, me again! So much good documentation is bound to be a few errors. I noticed in the BOM and Description spreadsheet, the link for the crystal on row 6 is a link for a capacitor.
Arsenijs wrote 09/19/2018 at 02:37 point
...I should purge that spreadsheet from the existence =D Here are official up-to-date sourcing requirements: https://wiki.zerophone.org/index.php/Sourcing_ZeroPhone_parts Here's a list of links for self-assembly in general: https://hackaday.io/project/19035-zerophone-a-raspberry-pi-smartphone/discussion-113018
Louis Parkerson wrote 09/19/2018 at 06:20 point
Okay. I will use the Wiki instead.
Thanks,
Louis
Louis Parkerson wrote 09/10/2018 at 22:32 point
Hi Arsenijs, thanks for this great open source project.  Have you considered using a more powerful chip like a SAMD21 instead of the ATMega. The bootloader can be burned following this (https://learn.adafruit.com/programming-microcontrollers-using-openocd-on-raspberry-pi/wiring-and-test) tutorial whilst in the phone or with a QFN socket connected a bootloader can be burned before the chip being soldered on. I am guessing you have already considered this and eliminated the idea for a good reason.
Arsenijs wrote 09/17/2018 at 23:08 point
Hi, Louis, and thank you for your suggestion! I used the ATMega328P initially because it's much more popular (and easier to source). I didn't eliminate the "more powerful processor" (whether it's a SAMD21 or, say, STM32) idea, I've thought about it and I think we could use the resources for good - like, put a small self-sufficient phone "OS" in there for decreased power consumption, or make a I2S DAC/ADC so that we can mix Pi Zero and GSM audio easily, in short, add all kinds of cool features.
However, at this point in ZeroPhone development, I think it's OK to have something really simple, as we don't even have the manpower to work on improving the current (ATMega-based) setup. In the future, I think it'd be really cool if somebody were to modify the front board to swap the ATMega for something cooler, but that goal is too much for my current skillset and free time, and I'd rather concentrate on something else.. like, making sure there's an UI for calls =)
Louis Parkerson wrote 09/17/2018 at 23:21 point
Thanks for the reply Arsenijs! ATMega should be good for now as you said. When Zerophones are available to buy, I might try add a SAMD21 myself allowing some extra 'fun' sensors to be added (e.g. a thermal camera).
Arsenijs wrote 09/17/2018 at 23:25 point
If you want to do some recon in the meantime, here are the front PCB files:
https://github.com/ZeroPhone/ZeroPhone-PCBs/tree/master/front_pcb/
And here's how currently the Pi GPIOs are mapped:
https://wiki.zerophone.org/index.php/Gamma_board_Pi_GPIO_mapping
Why not connect the thermal camera to the Pi, through SPI&I2C? (IIRC that's what Flir modules use)
Louis Parkerson wrote 09/18/2018 at 23:22 point
Thanks for those links! Although I thought of the Flir sensor, my budget would not stretch to one of them at the moment. I was thinking of the cheaper MLX90640 would do the job (although the Flir is a lot better), although it looks like I could still hook that up to the Pis GPIO.
Thanks,
Louis
Arsenijs wrote 09/18/2018 at 23:31 point
Yep, should be absolutely doable to hook up something like MLX90640! It uses I2C (available on ZP, as opposed to, say, UART, which is occupied by the GSM modem), and even though it seems the amount of I2C communications required is massive, if it works with a Pi Zero, it ought to work with a ZeroPhone. Not sure that, say, a pure Python module could handle all the math involved, but I think that for 1-10FPS even Python will do just fine!
Louis Parkerson wrote 09/19/2018 at 00:00 point
At the moment, all there is for the MLX90640 on the Pi is a C library. I was thinking about the amount of I2C communication as well. I can imagine the Pi will struggle, considering it uses 87% CPU to load some text onto a 128 x 64 I2C OLED (as I found out the other day)! The MLX90640 would surely use more than that. In the mod boards I just noticed a triple Qwiic adapter which means you should already be able to use the MLX90640 with this board (https://www.sparkfun.com/products/14769).
alebu3007 wrote 09/05/2018 at 17:47 point
Hi Arsenijs, I've just seen your project In my Google feed, in the site crowd supply. I was intrigued so I looked on the internet and found this site. I immediately liked the idea, but I did not understand if it has already come out, how much it costs, and how to build it, if it is to be built. I'm here to ask for some information about this project. All you can explain to me please
Arsenijs wrote 09/07/2018 at 19:53 point
Hi! ZeroPhone already exists, but hasn't yet "come out" - it's in beta, so there's hardware going around and some people are assembling their own phones from instructions I made. The parts should cost about $50 if you buy them one-by-one. As for building - I've linked all current links in the comment below yours, will add a new one right now. Apart from all the info on this page (in description and details), there's also a beautiful block diagram by @Morning.Star  - https://hackaday.io/project/19035/log/71960 , check this out to get a better understanding of this phone's hardware =) Any other questions?
PhantomWare wrote 09/03/2018 at 00:37 point
Where can I find a full instruction manual? I can't seem to find it on this page :\
Arsenijs wrote 09/03/2018 at 20:02 point
There's no *full* manual yet for building from scratch - we're compiling it slowly but surely. There are sourcing instructions on the Wiki (for Gamma version, Delta/Delta-B instructions are WIP) [1], assembly instructions partially available on the Wiki [2] [3] and here [4], and PCB ordering instructions on YouTube [5].
[1] https://wiki.zerophone.org/index.php/Sourcing_ZeroPhone_parts
[2] https://wiki.zerophone.org/index.php/ZeroPhone_assembly_guide
[3] https://wiki.zerophone.org/index.php/ZeroPhone_SMD_assembly
[4] https://hackaday.io/project/19035/instructions
[5] https://www.youtube.com/watch?v=iG2J-DwYaYc
Arsenijs wrote 09/07/2018 at 19:56 point
Update: our contributor, fnux, has helped us add the InteractiveHtmlBom tool for people assembling PCBs from scratch - here's an example http://assembly.zerophone.org/delta-b/back_pcb/ , and you can go to different boards and revisions starting from the  http://assembly.zerophone.org/ page.
PhantomWare wrote 08/28/2018 at 01:29 point
I may have missed it but I have a question: How is it able to send/receive calls/texts? Does it use a SIM card? Does it use Wi-Fi? How does this ZeroPhone work? I am very interested in it and want to make it badly. Thank you!
Arsenijs wrote 08/28/2018 at 09:42 point
It uses a GSM modem module for calls, SMS and data - currently, we're using a 2G modem, SIM800, but we're going to have a 3G modem upgrade as well. The modem, in turn, has a SIM card slot and connect to the SIM card by itself. ZeroPhone also has a WiFi capability, but that is not used for calls/SMS by default - it's definitely possible to have calls over WiFi, it's just that nobody wrote the software yet =)
About "how does ZeroPhone work", see the block diagram https://hackaday.io/project/19035-zerophone-a-raspberry-pi-smartphone/log/71960-zerophone-block-diagram by @Morning.Star . Basically, the Pi Zero interfaces with everything - the display, the GSM modem, an Arduino-driven keypad, the GPIO expander and some other things. The Pi Zero runs Raspbian Linux, and everything thus is controlled from Linux.
If you want to make it, you can source all the parts yourself and solder one together (there are people in the process of doing it already), and soon there'll be a crowdfunding campaign where we'll be offering kits =)
Eric Duncan wrote 08/06/2018 at 03:18 point
Dual-Sims please!  Maybe the ability to switch between them.  The ultimate idea would make it compatible with dual-providers in the US, such as CDMA and GSM.
Google's Project Fi does this (using MVNO networks Sprint(cdma) and TMobile(gsm)).  It switches between whichever has the strongest signal.  It has doubled my coverage with all the gaps I had on each network individually back when I was at Ting and kept switching GSM and CDMA SIMs out.
Hpag wrote 08/17/2018 at 00:44 point
I think dual sim card support is hard to implement in ofono
ws786873 wrote 08/01/2018 at 01:32 point
HI,i am in china . so, can i make it by myself?
Arsenijs wrote 08/02/2018 at 07:34 point
Hey! Definitely, you should be able to start - order the PCBs, find a Pi Zero and start sourcing other components. Here are (unfinished) sourcing instructions for Delta: https://wiki.zerophone.org/index.php/Sourcing_ZeroPhone_parts#PCBs
ws786873 wrote 08/02/2018 at 07:36 point
thank you!
Arsenijs wrote 08/02/2018 at 08:00 point
You're welcome! Feel free to come to our IRC channel for realtime help if you have questions: http://kiwiirc.com/client/irc.freenode.net/#zerophone
Vincent wrote 07/13/2018 at 08:44 point
Hi Arsenijs, following this great project for a while now.. (and burning) I'm wondering if an up to date kit will be released.. Thanks :)
Arsenijs wrote 07/13/2018 at 11:47 point
It is indeed going to be released - right now, I'm working with Delta revision batch sourcing and assembly - half of it kits, which are going to be made as soon as I get all of the components I need (still waiting for audio jacks, amplifier ICs and FETs. Basically, waiting for some critical stuff to arrive before I can continue =)
peter jansen wrote 07/05/2018 at 00:24 point
Great project -- I'm curious what kind of battery life you're getting on the Pi Zero? (and with what size of battery?).  And also how you're handling the corruptability of the SD card on bad powerdowns?  Keeping the filesystem read-only, or have you implemented a soft powerdown?  Thanks!
Arsenijs wrote 07/05/2018 at 04:26 point
Hi! The battery life with the ~4000mAh battery is 20 hours - most of that is attributed to the Pi Zero itself, there's also no WiFi or GSM powersaving implemented yet, and the CPU clock scaling hasn't been investigated either. I haven't yet had any SD card corruption on ZeroPhones yet, and I've been using them for more than year and a half (admittedly, I changed SD cards during this period, but only to increase storage space). To be fair, Raspberry Pi is much better with SD cards now, too. The filesystem is rw for now, there's a soft powerdown possible but it's not yet implemented in full (there's no hardware yet to control the power switch).
peter jansen wrote 07/05/2018 at 18:02 point
Wow!  It feels like half the time I yank the power, the card gets corrupted.  I'm sure it's much less often than that, but the inconvenience makes it seem more often than it is.
Also, 20 hours is quite good -- I wonder if/when power saving capabilities will become part of an official Raspbian release.
uwr01207 wrote 06/27/2018 at 19:25 point
Is their a website for ZeroPhone? In what ways are you looking to support the lasting survival of the project?
Arsenijs wrote 07/01/2018 at 22:30 point
There's ZeroPhone Wiki - wiki.zerophone.org , and I'm publishing as much information as possible there. I've also published a sourcing guide, I'm in the process of publishing assembly instructions (right now, I'm editing a video about ZeroPhone gamma assembly), all of the code used is open and motivations behind this project are described here. In short, if anybody wants to pick up this project, they can =)
uwr01207 wrote 06/27/2018 at 19:24 point
When the phone is complete will we be able to buy them online? If so then for how long? Will their be a max quantity?
Arsenijs wrote 07/01/2018 at 22:34 point
The phone will be available through crowdfunding soon (so that we can make one big batch instead of making them in small batches). Unless the project will not be sustainable financially (which I do my best in preventing), the phones will be available for as long as there will be demand. I don't see any reason for max quantity restrictions to happen - of course, I'll do it if it proves to be a good decision for survival of the project (which I don't yet see reasons for, but sometimes manufacturing is weird like that).
uwr01207 wrote 06/27/2018 at 19:19 point
Can the screen be made bigger and run Android or CopperHeadOS? If no then why not?
Arsenijs wrote 07/01/2018 at 22:28 point
Screen: not exactly. A bigger screen can be added (either through SPI or HDMI), but it can't run Android. The biggest problem is that Raspberry Pi Zero can't really run Android - and so, I've decided I'm not going to pursue it, instead focusing on Linux and making a small&sleek UI for dumbphone features (and quite some smartphone-related, too).
sworobukjamie wrote 11/20/2017 at 02:58 point
when will we get the instruction so we can make this beautiful piece of tech?
Arsenijs wrote 11/22/2017 at 17:32 point
The instructions are being slowly compiled here: https://hackaday.io/project/19035/instructions It's a massive task, so I'm working on it in the background, adding new parts once a week. But before this is finished, I'll finish sourcing instructions - those are going to be finished much sooner =)
Jonathan Cross wrote 11/06/2017 at 18:56 point
It is great to see someone working on an Open Hardware phone, but how do we keep this from falling into obscurity like so many other projects?  Have you considered teaming up with others to collaborate?
Arsenijs wrote 11/10/2017 at 12:29 point
Absolutely! I'm taking it slow in this regard, I have lots of people to send prototype units to, but I'd rather fix some glaring issues (such as microphone noise). Nevertheless, I've sent out about 10 ZeroPhones to collaborators already, and I'm going to send out more (I've got one on my desk that's going to be sent out on Monday, for example). I'll also seek opportunities to collaborate with other open-source phone makers - right now, I'm looking at reusing their software.
My general idea about "not letting the project fall into obscurity" (which is, indeed, a big problem) is making the project cheap and easy to replicate - one of the main goals of this project. Once that's achieved, we only need reliable software to go with it - and that's what I'll be putting work in, too =)
Jonathan wrote 11/02/2017 at 05:19 point
What are the possibilities of VoTor? Haha
Voice over Tor?
Arsenijs wrote 11/10/2017 at 12:51 point
As long as there's existing software that does it, that would be easy =) Once I'll get the microphone addon board made, I'll be looking into things like these. Any existing software for voice over Tor that you could suggest?
tngreene wrote 10/06/2017 at 14:19 point
Hey, been keeping an eye on this for a while. Did I miss the crowdfunding opportunity? I'm not sure how crowdfunding works in the sector of the tech world works, but I was expecting like a Kickstarter or Indiegogo link to appear sometime. I'm new, obviously.
Tor wrote 10/07/2017 at 22:48 point
https://www.crowdsupply.com/arsenijs/zerophone   <- This is what I found for a pre-launch crowd funding page. I'm not affeliated with the core team, but I have been watching every single day for updates. I'm so excited for launch.
Arsenijs wrote 10/11/2017 at 14:02 point
Hi! Sorry, would've answered myself this earlier but didn't get a comment notification - again =( So, I'm still preparing the hardware for the crowdfunding - there are lots of variables I need to take into account before I can even estimate the cost, and I also need to make a revision which is as optimized for independent assembly as possible - which is going to be the next revision. Also, I'm now working on complying to Hackaday Prize finalist requirements =) The pre-launch page @Tor linked is the right one, but it's taking time to get to the launch.
dinu wrote 09/09/2017 at 02:46 point
Great piece of work, thanks for sharing.
Magnus Westin wrote 09/02/2017 at 05:42 point
I tried to make a donation using your paypal link, but got this error from paypal:
This recipient accepts PayPal payments only through their website. To complete this payment, please go to their website and follow their instructions, or email the recipient for instructions.
Arsenijs wrote 09/06/2017 at 01:23 point
The new link is paypal.me/TheZeroPhone - I'll tell about the problem that happened in one of the next newsletters =)
Arnaldo Pirrone wrote 08/11/2017 at 10:50 point
Hi, does it makes sense redesigning the modem board to use a simcomm SIM7600C module or equivalent which supports LTE? Considering that GSM/2G is being dismissed more and more and the fact that the ZeroPhone might also be a great pocket modem device (like huawei pocket modems) i'd assume yes. I don't know if it would be cost effective, though.
Arsenijs wrote 08/13/2017 at 08:49 point
Right now, I'm trying to find time to finish the adapter board for SIM5320 that I've started =) It's 3G, and shouldn't require too much additional hardware, so that should be OK for now - 3G doesn't seem to be dismiss-able in the next couple of years.
Blecky wrote 08/09/2017 at 05:12 point
Have you considered a Nokia style case for this at all?
Arsenijs wrote 08/13/2017 at 08:47 point
I have, just that the PCBs will definitely need to be redesigned. There's #Nokia 3210 Retro Fit Board project - I'm watching it closely, check it out, too, it's great!
