Reincarnation: https://hackaday.io/contest/160135-the-return-of-the-square-inch-project
Grand prize winner: #quadcopter in one inch
Winners: #Key Pass, #Small voltmeter, #Micro Word Clock, #RFID air pressure sensor, #Square Inch USB Sound Card, #Micro progmeter
See here for the hackaday.com article!
Your mission, should you choose to accept it, is to make a PCB that fits into a 1x1 inch square, has a purpose, and is cool.
Seven projects will be awarded a prize:
One first prize winner gets $100 in credit for the Hackaday store and $50 for OSHPark.
Six other projects will get $50 in credit for the Hackaday store and $25 for OSHPark.
Hackaday store prizes are courtesy of Hackaday, OSHPark credit is courtesy of both OSHPark and Hackaday. Huge thanks to them both for this!
You don't have to use OSHPark to get your boards fabbed, but it turns out they have the lowest minimum price for this size of PCBs—for $5, you get three copies of your 2-layer, 1 in² board delivered (almost) anywhere! Check them out!
Read the rules and the quick-start guide, then enter here!
Example project: #Laptop Emergency Charger, one square inch
Please leave a comment with your feedback or suggestions :)
Winners can be seen here!
alpha_ninja
Bruce Land
TRAN.VINH.QUANG
Joshua Elsdon
Ian Shannon Weber
sssssssssssssssso? I cannot wait to know who won! It'd also be very cool to at least have a "finalists list" in a project log (hint hint).
Oh, happy new year!
Cheers, Mick
