close-circle
ZeroPhone - a Raspberry Pi smartphone
Pi Zero-based open-source mobile phone (that you can assemble for 50$ in parts)
This is a mobile phone that is:
1) As open-source as possible *while also being cheap*
2) Easy to get parts for if you want to assemble one
3) Easy to assemble and repair
4) Free from apps with privacy concerns
5) Easy to write apps for
It costs about 50$ in parts, and all the parts are available on eBay. Most of the phone can be assembled with just a soldering iron. User interface is written using Python, it has an UI framework for easier app development - and it gets better every day.
https://www.reddit.com/r/ZeroPhone/
A crowdfunded manufacturing run is expected in a month - subscribe to newsletter below!
Subscribe to the project newsletter - to get weekly news and be notified about crowdfunding!
Read previous newsletter editions
Project description and FAQ - January 2019
  • Modern phones are getting more and more complicated and hardware-packed. Unfortunately, that means they're becoming less modifiable and repairable.
  • Phones are getting more and more integrated. Unfortunately, that means more and more possibilities for manufacturers to lock them down without allowing us to modify them.
  • More and more software&hardware is kept closed-sourced. That means it's harder to learn, experiment and customize your phone.
The factors I've listed (integration, complexity and closed-source) are necessary in the world we're living in, with all the advances in engineering, competition between companies, as well as laws in different countries.
However, what if we could have a phone free from those constraints?
We can, and this is the reason ZeroPhone project was born. Nowadays, we can assemble a phone from easily available parts, using available SBCs that run Linux, and we'll be able to adjust it to our needs - unlike with modern phones, when we have to adjust ourselves to suit the workflow the phone offers. With ZeroPhone, hackers can finally have smartphones that are going to work for them, not against them, people with special needs will be able to have to have custom-tailored phones, and people that want to protect their privacy will have a phone that respects it.
Our technical challenges are: developing PCBs that'd be feature-packed, but with components that'd be easy to source and solder, as well as developing mobile phone software that'd be open, high-quality and highly modifiable to suit any needs people might have. However, much bigger challenges are - building a community of people experimenting with ZeroPhone platform, keeping ZeroPhone open-source and independent of any harmful influences, and experimenting with new ways of intergrating smartphones in our lives without selling our lives in the process.
Features:
  • Raspberry Pi Zero in a PCB sandwich
  • No proprietary connectors, hard-to-get parts or chips that are tricky to solder
  • All the specifications for making this phone yourself will be available
  • Python as the main language for developing apps (aiming to add other languages later)
  • UI toolkit making development quicker and easier
  • Numeric keypad, 1.3" 128x64 monochrome OLED screen (with screen header supporting other types of screens)
  • 2G modem for phone functions, can be replaced with a 3G modem
  • WiFi (using an ESP8266), HDMI and audio outputs, a free USB host port
  • GPIO expansion headers for customization
  • RGB LED and vibromotor - for notifications
  • Tons of Pi Zero-related hacks that were discovered along the way, that I'll share with you as the project goes =)
ZeroPhone Wiki
Interesting articles:
Licensing:
#pyLCI fork used for ZeroPhone is licensed under Apache License
ZeroPhone PCB files and keypad controller firmware are licensed under GPL v3
zerophone_alpha_v1_0.zip.torrent
ZeroPhone SD card image for alpha prototypes - torrent (665MB)
x-bittorrent - 26.52 kB - 03/06/2017 at 03:38
download-circle
Download
  • Hardware worklog: display problems understood
    Arsenijs3 days ago 3 comments
    When I was sourcing parts off Taobao, I ordered wrong display breakouts. They looked just like the ones I was supposed to buy, with two small differences - GND was swapped with VCC, and pin header had RST instead of CS. First problem caused me to burned a panel or two, second problem made me waste a week or two of my time. Here's how it goes:
    The ZeroPhone has expansion ports. In particular, there's a 13-pin expansion port on the side, with SPI-0 port on 4 of them. SPI is a really popular communication standard, you can use it to re-program BIOS chips, ATMega/ATTiny/other Atmel chips, show things on LCD/OLED/E-Ink displays, communicate with SD cards, RFID readers, thermocouple amplifiers, GPIO expanders... I have designed two mod boards for this exact headers, and I wanted to include them in the package sent to reviewers and contributors - because I believe it's important to show that ZeroPhone also has tools that make hardware experimentation easier.
    SPI uses the CS pin to signal, which peripheral it currently wants to communicate to. SPI-0 on the Pi has 2 CS lines - one goes to the display header, another goes to the expansion header. If, however, the display doesn't have the CS line exposed, then there's no way to signal to the display that it's not supposed to receive information at this point when, for example, there's an RFID reader on the expansion port. The result will be, at best, garbage shown on the display - at worst, the display might interpret commands sent to RFID reader as commands for the display, and it might even damage the display.
    So, just re-wiring the breakouts, swapping RST with CS, should be easy? After lots of broken panels and wasted time, I understood this wouldn't be the case.
  • Project state - boards to be tested, Hackaday Prize, project plans
    Arsenijs06/21/2017 at 06:31 2 comments
    A new version of ZeroPhone is being in-field tested right now, and the batch of 20 ZeroPhones is almost built - I'll be testing it now.
    Boards in stacks of 5. I ran out of some passives to finish the boards in the bottom left corner, but I'll have them tomorrow.
    The boards pictured are already checked visually, no visible soldering bridges or misplaced components (there were a lot of those). Now they just need some THT stuff attached - that will need lots of human intervention, but I've found some people that can help with it, tomorrow and the day after =) Also, hey, at least I seem to have all the THT parts I need and don't need to run around sourcing them.
  • Project state - assembling ZeroPhones!
    Arsenijs05/28/2017 at 17:20 2 comments
    So, I got the Gamma boards, panelized, 22 front&keypad board panels and 24 back&18650 board panels, all from DirtyPCBs:
    I also got lots of passives and actives, headphone jacks, all that, it seems I have all the parts necessary for ZeroPhone assembly. BTW, if you want to learn to panelize the boards like this, I got a tutorial for you =)
  • On volatility of Chinese breakouts; "production-ready" ZeroPhones
    Arsenijs05/28/2017 at 16:15 1 comment
      As I mentioned earlier, ZeroPhone is basically a PCB sandwich. Now, ZeroPhone consists of three custom boards, a Pi Zero and 5 Chinese breakouts:
      1. ESP-12 board
      2. SIM800-based modem board
      3. 1.3" OLED breakout
      4. Li-Ion charging circuit
      5. Step-up DC-DC board (generates 5V for USB port)
      All of these boards, except (very popular) ESP-12 breakouts, can change. Reasons are - Chinese optimize those breakouts all the time (decreasing BOM count and/or PCB size), want to add features to innovate (consequently, to raise price), and, I think, sometimes just copy the pinouts and board outlines from one another, re-tracing the board.
      For example, here are photos of different Arduino Pro Mini clone PCBs I have:
      Some of them don't look different, but the traces are all routed differently, and some differences are easy to spot from this photo - such as holes changing places. And that's only what I have currently, I've used and seen much more different boards.
      They went through these revisions in a couple of years, and it was mostly moving components around, but pinouts also changed - mostly A4-A7 pins. If you're designing a shield for Pro Minis (for easier assembly and user-friendliness) and it uses I2C, tough luck with sourcing boards.
  • Hardware switches and new discoveries ("paranoia worklog")
    Arsenijs05/24/2017 at 05:07 0 comments
    Let's talk about hardware switches, advertising profiles and side-channel leaks. ZeroPhone is different from many smartphones in that the GSM baseband is separate from the CPU, so there's no proprietary code running on the CPU that comes from the GSM modem manufacturer. The communications happen through UART and are controlled by and directed through open-source software.
    I sometimes got questions about hardware switches. It's a niche but nice feature - not only it's the ultimate power consumption decreasing mechanism, it's also a way to ensure the radio-enabled components can't work when you absolutely don't want them to work - for privacy and safety. ZeroPhone is using off-the-shelf GSM modules - and they have an inner CPU which runs some kind of firmware, and that firmware running on the modem can make it transmit, even though you might not be telling it to transmit. We can implement software kill switches, but maybe the software itself is going to have bugs? The simplest and most powerful "just make sure it's off" hack is cutting the VCC line to the modem, ensuring it doesn't work at all and thus doesn't have the ability to transmit when you want it turned off.
    One more reason for that - what if the GSM modem firmware is malicious? We don't know, SimCom doesn't provide much of source code and SDKs, and one of the modem batches they send out could be programmed with a firmware that's slightly different from the widely-used firmware, with some *extra features*. Can we *trust* the modem? No, not really.
  • Project state - prototype batch will soon be built
    Arsenijs05/10/2017 at 21:46 6 comments
    Components arrived, PCBs ordered
    A week ago I received a box full of goodies:
    Most of the parts pictured are ZeroPhone-specific, and some parts are either extras or parts I ordered for myself =) The bag in the bottom center is full of 18650 holders, all three models pictured. Tape with white squares are the coolest BIOS chip holders ever, that I was trying to find for ages until I finally did find them for very reasonable price on TaoBao. Next to the laptop bag you can see a tape of 50 ESP-12 modules, and the bag next to it is full of Arduino Pro Minis. Ziplock bags in the center, to the left, are full of pushbuttons - the biggest of those bags has 750 buttons, and the plastic tube has 30 MCP23017 ICs. And, of course, there are 25 screens and 20 GSM modules - the latter I didn't have problems with, but screens just keep breaking on me.
  • 4) Publish at least one (1) image illustrating how the project might be used.
    Arsenijs04/30/2017 at 19:34 1 comment
    This may be a sketch, schematic, flow chart, rendering, or other type of image. - from Hackaday Prize rules.
    So, @Radomir Dopieralski drew a sketch:
    And I made a diagram:
    Over these three months, while explaining ZeroPhone to people, I understood one thing - it's a platform, and platforms can be hard to explain because there are so many possible usages. ZeroPhone is a platform for hackers, people not happy with their smartphones, people that want privacy, people that want the power of Linux in their pockets and many more. I hope we'll see a lot of usage examples from all those categories as the project grows =)
  • ZeroPhone software - pyLCI TODO and challenges
    Arsenijs04/30/2017 at 12:20 0 comments
    Introduction:
    When I started developing pyLCI, it was meant to be an interface for 2x16 character displays. Therefore, it was optimised for having only two lines of text on the screen and 5 buttons. I'm not aiming to maintain backwards compatibility between pyLCI for character displays and ZeroPhone pyLCI. In fact, the ZeroPhone version of pyLCI might as well be renamed to signify the fact that it's a similar, yet different version of software.
    Right now, ZeroPhone pyLCI is not too far from original pyLCI in terms of capabilites. I'm listing those problems so that there's a list of problems that currently interfere with pyLCI being a good ZeroPhone interface.
    The problems listed are either finished, WIP or still waiting to be solved - I encourage you to help me solve them by either helping me find a good solution, or contributing to the development (I've opened GitHub issues to keep track of problems, they're linked in the titles and sometimes in the text.)
    Naming
    pyLCI is Python-based Linux Control Interface. However, right now it's becoming ZeroPhone-specific and moving further from pyLCI concept. I'll be thinking of a better name - it obviously has a low priority, but if you have some ideas, please throw them here.
  • Project state: Gamma boards finished, beta boards released, components on the way
    Arsenijs04/30/2017 at 11:35 0 comments
    One more iteration of hardware - I wish I could say it's the v1.0, but I made enough changes to know there will certainly be bugs. Therefore, it's a Gamma revision - this is the revision that's going to go to project contributors and reviewers. I already know about some changes that I want to make for the next version, but I'm afraid I don't have time to re-trace what I want to re-trace (to be exact, I want to move the GSM modem to the back of the back board, along with GPIO expander, and move the charging breakout to the front). However, that might just be the change I make today/tomorrow if I have enough time =)
    I have ordered components for 20 ZeroPhones from Taobao - using Spreenow agent. They ordered everything for me, which was something I couldn't really risk, with about 30 different things I needed to buy. I spent 630 EUR on all the components, from which I think 400-450 EUR were spent directly on ZeroPhone parts (other were either extra parts or stuff for my personal projects). I'm surprised about how TaoBao is cheap, really. Before this, I didn't know about a good way to order stuff from China quickly. With Spreenow, I was able to submit a list of parts, they ordered them, checked all of them and sent them by EMS in a single box. When I tried to do the same with an eBay vendor, the price would have had been consolidated in a really expensive way, and last time I tried to negotiate a better price with a seller ('cause DHL from China shouldn't cost 150$ for 100$ shipment), the seller said "No, use the rate eBay gives you" and I was like "Fuck it" and re-planned the project I was working on at the time, which wasn't a pleasant thing to do.
    Now I have all the PCBs I need, except one - I have to make a 7x4 board which would house the 18650 battery holder I'm using. Other than that, I'm ready to order panels filled with misc boards. The soldermask is blue - to look like all the Chinese breakouts the phone is using =) After that, it's time for software work - all the things I didn't yet code, I'll be coding them now. For that, there's a separate worklog - go read it if you're interested in software problems that ZeroPhone is facing.
  • Why not a large display (with a touchscreen)?
    Arsenijs04/15/2017 at 22:00 2 comments
    This is a complicated question to answer. Part of that choice is a design decision, another part is a matter of convenient development for me at the time I was working on ZeroPhone base, and there are also hardware limitations, let's start with those!
    Hardware limitations
    Raspberry Pi has a couple of display interfaces - or interfaces we could use for a display. Let's count - there's DSI, DPI (parallel RGB), HDMI, composite video and SPI, let's get through those.
    DSI is supported by many cool displays, like iPhone screens. However, it's not available on Pi Zero, and is out of question for RPi in general - it's locked down, only peripheral that works with it is official Raspberry Pi touchscreen, which is large, expensive and consumes a lot of power. Next!
    HDMI is good, it's GPU-accelerated, powerful and compatible with lots of stuff. However, there aren't many small screens compatible with it, it's proprietary-ish and the available HDMI chips don't have the best power consumption. Moreover, Pi Zero has MiniHDMI and it's hard to integrate stuff with this kind of connector. Let's leave it for an external display, next!
    Composite video is ubiquitous, has been there for ages and is very cheap. It also has a fundamental video quality cap, and market is full of small shitty screens with no quality ones. The power issue is there, too - not only popular chips for analog video still use 5V, most Chinese product designers would use a linear regulator for in-screen 5V, and say that "it requires 12V" - bam, the power consumption is "horrible" on top of "bad"!
    DPI is GPU-accelerated, supported by many displays and actually has software support. However, it would take most of GPIOs we have on a Pi Zero, and most of those aren't re-mappable, meaning we'd lose I2C, SPI, UART and some more cool things.
    SPI is what ZeroPhone uses now. It's not GPU-accelerated, but we don't always need that - especially not in the case of a 128x64 monochrome display (though AFAIK it becomes relevant when screen is bigger and a color one). It doesn't use too much power, can reach high enough speeds for quick redraws (unlike I2C, for example) and is compatible with lots of existing displays.
View all 27 project logs
Arsenijs wrote 3 days ago point
Hi! So, I've been testing a ZeroPhone with a Zero W for a month now. Well, it works - I was a little afraid about DC-DC not quite capable of delivering enough juice to everything, but it does seem to work as well as it does on the Zero. The two problems are: the WiFi antenna reception is not that great (could be normal for the Zero W, could be decreased from normal due to all the metal around the antenna - I'll have to put Zero W and Zero-based ZeroPhones next to each other and check), and Bluetooth is not accessible out-of-box - I figure it's because the DT overlay I'm using to remap stable UART back to GSM is not quite enough and there are some configuration files which need changes made (I just didn't have the time to dig further). Other than that, there don't seem to be any problems =)
elvestal wrote 07/06/2017 at 11:50 point
Can we get this ones with 3G and swedish keyboard? I want 3.. no 5. To start with. Better fire up that emulator and start building a lot of great apps
Arsenijs wrote 4 days ago point
Hi! Damn, no notifications again =( The 3G upgrade is in the works this week. As for the Swedish keyboard - I'll be looking into getting Unicode fonts on the display, then we'll be able to have all kinds of input (and localisation) languages on ZeroPhone =)
If you'll have any questions about app development (like, ways to do things, tips etc.), come to our IRC - #ZeroPhone on freenode, kiwiirc.com/client/irc.freenode.net/#ZeroPhone
elvestal wrote 3 days ago point
This is nice, I would love to get the required hardware for building 8-10 phones on our next maker-space meetup, a perfect way to spend a saturday in Sweden
This sounds great! It's likely going to run you about 500$ in hardware, and I can walk you through the "ordering parts" process if you'd like me to - I'd be happy to compile a "sourcing parts" page for the Wiki, at last =)
Thank you that would be terrific. I hope we will be able to take it from there, otherwise I guess we'll just have to buy you a ticket. ;)
Tindie wrote 06/30/2017 at 21:14 point
We'd love to see this on Tindie :)
Eventually, I'm going to sell it on Tindie - but this is likely going to be after the crowdfunding =)
oshpark wrote 06/24/2017 at 19:02 point
Great project!  Are there shared project pages for the boards that were made with us?  Thanks, Drew
Arsenijs wrote 06/24/2017 at 19:13 point
Hi! Of course, that's the least I could do for you, I'm very thankful for your help when I was working on the beta version! The current version OSHPark shared links can be found in this blog post: https://hackaday.io/project/19035/log/59341 , I'll be sharing new versions upon each board release. Once I'll make a ZeroPhone Wiki page on sourcing ZeroPhone components, I'll also add the OSHPark links there.
oshpark wrote 06/24/2017 at 19:22 point
Great, thanks!
dj butansky wrote 06/22/2017 at 16:36 point
Looks great.
Since you are in the game could you give an opinion on how hard a POCSAG pager module would be to add to this?  It has been done with RTL-SDR on the N900 but an integrated and low power receiver/decoder makes it an everyday user's option to be radio silent and untracked unless we want to power up the modem and connect to the mobile phone network.  I discussed this with RMS and he would consider finally acquiring a FOSS mobile phone like this if it respected the user's privacy rather than the power of the state and profitability of the mobile network company.
Arsenijs wrote 06/24/2017 at 10:10 point
Hi! Do you have some specific POGSAC module in mind? It seems some of them use RS232, and we could definitely communicate over that. BTW, I even have 3 or 4 Motorola pagers in my collection of old tech - though when pagers were all the rage, I was too young to have one =) Do you have some info on the RTL-SDR&N900 usage? (seems like it's receive-only)
I think that RMS would be not pleased by the fact that there's still proprietary firmware on the Pi Zero, basically, the whole GPU-that-launches-CPU thing. Once we have a BeagleBone CPU module, however, I think it'll be OK =)
dj butansky wrote 06/24/2017 at 17:48 point
I am a N900 user still, so obviously not as pure as our prophet.  The RTL-SDR used the regular Linux SDR tools and a customized UI gqrx, I dont recall the decoder for pagers, Morse, etc; but the RTL TV dongle literally ran hot in the fragile USB port, not feasible because of the wasted electricity.  I dont have any pagers anymore in my junk collection but yes when talking to Joerg from the opemnoko/GDC project about a radio-silent but listening pager mode; so he came up with the hacker buss during the design phase for the Neo900, a GTA-4mod for the N900 form factor.  The hacker-buss POCSAG module was never actually designed that I know of but he spoke of there still being RS232 interface easy to PCB hardware around.
Arsenijs wrote 06/24/2017 at 19:24 point
The RTL-SDR kind of decoding has to use lots of CPU power, too, so the RTL-SDR wouldn't be the only thing running hot.
Check this out: http://www.radiocom.co.uk/Radiocom - Products.htm This is literally the first result when searching for "POGSAC module", and I can't find the price but the hardware seems OK. Any info on this?
Also, how do you test the module? Are there still pager networks in some countries? Because I think Latvia has long abandoned the thing - but I can re-check if necessary.
Haven't received a notification about your comment, weird =(
gir wrote 06/20/2017 at 22:13 point
congrats! I'm _so_ looking forward for this project getting finalized! Arsenijs - you earned your 1k$!
Arsenijs wrote 06/24/2017 at 10:02 point
Thank you! I hope that you'll continue to make great stuff and inspire others by your great projects, too! =)
Youlian Troyanov wrote 05/31/2017 at 14:40 point
how long until it's on crowd supply? also could you make it maximally modular? i would like to use parts of your design with a completely different arm board, for example, an allwinner one, like chip. using a different arm board could make the whole thing significantly cheaper.
Arsenijs wrote 06/24/2017 at 10:00 point
Sorry, for some reason I didn't get an email notification about your comment =( I'm still delayed by the prototype batch, but now I'm building a testing jig to test the parts - then, after fixing all issues found during testing and sending the phones out, the campaign can start =)
Currently, modularity is more of a side effect, but, due to the fact ZeroPhone consists of separate PCBs, it's indeed possible to re-use them and replace them - for example, you could swap in a different keypad board. However, the processor board is to be stacked with the front and back boards in the current configurations, so unless you want to re-design the front and back boards, you'll need to design a new CPU board with the same pinout and more or less the same form factor as the Pi Zero does. Oh, and you definitely could re-use the schematics =)
I'm curious - which boards do you want to use? I'll be planning for some compatibility with other boards in the next ZeroPhone versions, so knowing about what you want to use would be very helpful because I could plan it in in earlier stages and maybe figure out some problems I wouldn't figure out otherwise,
Radu Motisan wrote 05/23/2017 at 14:28 point
this was on my todo list as well
Arsenijs wrote 05/23/2017 at 15:01 point
Hey, join the project if you feel like helping =)
Andrew Pam wrote 05/04/2017 at 17:12 point
2G mobile has already been switched off in Australia, so this won't be useful without at least a 3G modem.
Arsenijs wrote 05/14/2017 at 01:24 point
Yes, that's sad. The new version is soon to be in the works, I'm currently consulting people about component choice because a part of the back board needs to be redesigned for a bigger modem.
Ramon Schepers wrote 04/15/2017 at 21:16 point
i see you are using the pi zero (w), though i wonder why though.
i mean:
1: the pi zero has high power consumption unlike a stm32l4 (for example), so you can use a smaller battery as well
2: if you want to shrink down to a thinner device, you'd need a custom pi zero pcb (including bga package soldering!)
3: the size of a pi zero ain't optimal for a phone-like device.
4: do you really need a pi zero (with it's half gb of ram) for a (dumb?)phone?
5: the pi zero does not have a ADC built in* by default, so if you want the call audio go trough the pi, you'd need to hack a adc in first
note: this is not meant offensively at all, just curious why you did these design choices :)
* = if i am right
Ramon Schepers wrote 04/15/2017 at 21:17 point
i forgot to mention though: i had a similar idea for quite a while by now :)
Ricardo Ferro wrote 04/15/2017 at 23:46 point
make one with stm3214 , that thing has ultra low power at 8 nA!
Arsenijs wrote 04/15/2017 at 22:28 point
Well, it's not "just a DIY phone", and it's not evena  dumbphone, there are enough of those =) It's a Linux-based smartphone, which re-uses all the wonderful software available for Linux, and it's also based on Raspberry Pi - a platform that many people are familiar with. When it comes to "just dumbphones", yes, you can make one with an AVR or an STM, and you'd learn a lot on the way, but it won't have as much potential than a Linux-based phone will - and you'd never out-compete Chinese dumbphones on price!
In general, it's more like a platform for developing whatever you want that could be based on a smartphone. Therefore, it needs to be as much high-level as possible - that's why user-exposed parts are mostly in Python, not a lower-level language =) It's so powerful in terms of capabilities, you can easily use this phone to develop software for itself - and if that means I'd need a bigger battery, I'll just attach a bigger battery. Yes, the size is not the best, the pinouts aren't the best - but then, hardly everything always fits perfectly. Shrinking down would be a problem, but see the #RPi Zero WiFi-Enabled Hardware Password Manager - it's pretty damn small, I have one and I don't see why you'd actually want to make a phone that's even smaller than that =D
*yeah, there's no ADC, but I'm using an ATMega328P on one of the boards, it takes care of all my ADC/PWM needs.
kunstenaar wrote 04/17/2017 at 18:22 point
Did you have the time to measure, how the Zero W behaves...?
Other options to provide options for lower power consumption? Things like this?: https://www.jeffgeerling.com/blogs/jeff-geerling/raspberry-pi-zero-conserve-energy (see also comments there)
http://www.earth.org.uk/note-on-Raspberry-Pi-setup.html (you need to scroll down a bit to come to 'Initial Adventures in Power Reduction')
https://github.com/raspberrypi/linux/issues/1335 (the question what you can achieve with cpufreq, but I do not know its current status on RPi, and if such 'tricks' work)
Rishaldy Prisly wrote 04/30/2017 at 20:32 point
COOL!!!!!
Louis Pearson wrote 04/14/2017 at 05:27 point
I am really intrigued by the possibilities of this project! Definitely interested in getting one when the crowd supply campaign starts :)
In a possible future iteration, might you consider using a EOMA68 (https://www.crowdsupply.com/eoma68/micro-desktop)? It isn't quite there yet, but it would make this device even more repairable! Just thought I'd let you know about it.
Arsenijs wrote 04/15/2017 at 22:10 point
May I interest you in a survey? https://zerophone.github.io/newsletter/survey/ =D
I'm following their campaign, it seems they're close to having the computer cards manufactured (IIRC last time I got an email update, they were smuggling PCBs and components across the border =D ). Once I'll get through this whole manufacturing thing, and will have enough software (by the end of this year, at least), I'll be looking at making a touchscreen ZeroPhone, or perhaps a tablet, and this is where EOMA68 will be one of my likely picks =) Thank you for the tip!
Louis Pearson wrote 04/16/2017 at 05:47 point
You're welcome! =)
I posted this project on the mailing list and the possibility of using an EOMA68 for something like this and lkcl (the creator) seems to like the idea of making a phone using a computer card. He did point out that the EOMA68 might be a little to big to be practical, and actually wants to make a smaller version called EOMA54 for something like that. Here's a link to the concept he has for it: http://rhombus-tech.net/community_ideas/hybrid_phone/
Looking forward to the crowd supply campaign - I'll try my hardest to support you on there. Looking forward to trying my hand at developing software for the ZeroPhone.
Arsenijs wrote 05/24/2017 at 03:25 point
If you're interested in ZeroPhone software development and you have some ideas in mind, you can play with the UI emulator already: http://wiki.zerophone.org/index.php/PyLCI_emulator_setup
Louis Pearson wrote 05/25/2017 at 04:22 point
Sweet! I'll check that out. Actually, I have a raspberry pi 3 and a oled screen available, so I might try using that for testing. Keep up the good work! :)
kunstenaar wrote 04/05/2017 at 06:57 point
Update pls... :)
Arsenijs wrote 04/11/2017 at 21:39 point
Done - https://hackaday.io/project/19035/log/57132! Sorry, had to freelance a bit =)
Arsenijs wrote 04/30/2017 at 18:37 point
Hi! About your links on power saving - thank you! I've already read through all of them by now, and my power saving plans include assembling a ZeroPhone, cutting its power traces that lead to different components and inserting voltage&current measurement sensors in between, then experimenting with various clock rates, peripheral power saving modes and other software tweaks. I really want to discover new things about Raspberry Pi power saving, since, well, all those available solutions can get you up to some point, but no further, and I don't want to blindly turn features off without actually knowing what causes what level of power consumption and how exactly things could be tweaked for maximum power saving/usability ratio.
EDIT: and no, I didn't yet have the time to measure Zero W power consumption, but that's mainly because I don't expect many surprises, and for now I'm concentrating on other things - but I'll get to it sooner or later =)
Ember Leona wrote 03/31/2017 at 22:54 point
WOW.
alasdair wrote 03/21/2017 at 14:24 point
Really looking forward to your CrowdSupply campaign and the success of this.
Have you had a thought about a permissions system (if required), lets face it the permission system on *droid is bollocks?
Also are there (respected) hardware crypto modules (that are affordable) which could be incorporated - obviously not at the $50 mark you are aiming for?
Arsenijs wrote 04/11/2017 at 21:50 point
What's wrong with the permission system on Android? I recall two problems - granularity (seems to be improved recently) and the fact that you couldn't just deny the app some of the permissions is asked for (IIRC got fixed in 5.0 and later). I'm not much of an Android guy, so would be interesting to hear your take on this =)
alasdair wrote 04/11/2017 at 23:21 point
You pretty much hit the nail on the head there however I still noticed issues on 5.0+ (not sure about latest) in that a) not all permissions asked for in the app were toggleable b) some were there that hadnt been asked for. There still seemed to be issues with granularity and inconsistencies with what ws requested upon installation and what you were able to selectively permission once installed (assuming the app had not already abused any of those permissions between installation and toggling). I hope that makes sense. Sorry to hear you needed to take on another project I am sure you will be swamped when you launch the crowdfunding for this.
adam.klotblixt wrote 03/08/2017 at 16:40 point
A very nice project, looking forward to see the future updates.
One feature I look forward to is WIFI-hotspot, so that this phone could be the ONLY data access point, and all my other commercial pads and smartphones talk through it, with the possibility to REALLY be sure what data comes through. A true portable router of sorts. 3G or better is of course nicer and surely in the path.
Please, make sure the phone audio can be recorded properly, ideally into separated stereo (left: caller, right:callee). Many smartphones are really bad at sound-mixing and audio-paths.
And I also see a great potential to be able to use ANY size battery for this phone! Imagine having a phone that has the potential to dock several size batteries. Mmm...
Arsenijs wrote 04/11/2017 at 21:48 point
Will keep the audio advice in mind. As of now, GSM audio and Pi Zero are not interconnected, but I'm already adding a way to connect an add-on board to output/input audio data to GSM modem. With the setup that I'm thinking about, recording audio into any combination of channels would be a matter of software.
We'll get to having WiFi hotspot app sooner or later =) Also, I've already experimented with batteries - as long as it's 1s and Li-Ion (the usual kind of chemistry), you should be able to just power it from that without any modifications or addons. I've used a 450mAh battery for a while, then got tired with low battery life (there are no significant optimizations for battery power in ZeroPhone software yet) and upgraded it to 2x18650 in parallel - I figure it now has about 4000mAh of battery, and it does get me through a day of listening to music non-stop =)
Arsenijs wrote 02/28/2017 at 17:30 point
I ordered two of those, expect my review in a week or two =)
Craig Hissett wrote 02/15/2017 at 13:17 point
Received my kit buddy - thank you so much!
As soon as my screen arrives I'll get this bad boy assembled and start having some fun!
Arsenijs wrote 02/15/2017 at 13:20 point
Nice! Thank you for notifying, I will get to preparing the SD card images tomorrow =)
You can actually assemble everything without the display - if you have some free time, the display can easily be soldered last.
Craig Hissett wrote 02/15/2017 at 13:33 point
Awesome sauce! Thanks mate!
kunstenaar wrote 02/15/2017 at 12:24 point
Just fyi:
https://blog.rosenzweig.io/blobless-linux-on-the-pi.html
Sounds we getting closer to 'bloblessness'... Have a good read. ;)
Arsenijs wrote 02/15/2017 at 15:45 point
It was a very educational read, indeed! Wondering if it'll ever get usable - maybe, with all the interest to both this and the ZeroPhone project, it will =)
Samurai wrote 02/13/2017 at 16:38 point
How long did it take for you to build this marvelous nerdy great thing?
I wonder if I wonna do the same...
Arsenijs wrote 02/14/2017 at 12:15 point
About two months of work since I've started it, and many more to come =) As for the "assembling it from the kit" - shouldn't take more than an evening of drinking beer&soldering.
kamathln wrote 02/13/2017 at 05:15 point
HI,
I feel a couple of jog dials would be an awesome usabiity enhancement. Adjusting volumes, scrolling though menus, file lists etc., will be a breeze.
Arsenijs wrote 02/13/2017 at 09:58 point
Hi! I had a very early Sony-Ericsson phone with a side jog dial, it was awesome =) I won't be including that in the mass-produced version (they're hard to source), but it can be a keypad PCB mod (I've added 5 pins to the keypad PCB that have I2C, so would be very easy to implement jog dial readouts with a small MCU). Thank you for the idea!
